Trustworthy PSP Source - PSP Real Exam Answers
101
Posted at 1/28/2026 02:30:17      View:109 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Pass4sureCert PSP PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1ENWqHb3r1h5VplXPg7CnxpD8136Uq_ky
The ASIS Physical Security Professional Exam (PSP) web-based practice test works on all major browsers such as Safari, Chrome, MS Edge, Opera, IE, and Firefox. Users do not have to install any excessive software because this PSP practice test is web-based. It can be accessed through any operating system like Windows, Linux, iOS, Android, or Mac. Another format of the practice test is the desktop software. It works offline only on Windows. Our ASIS Physical Security Professional Exam (PSP) desktop-based practice exam software comes with all specifications of the web-based version.
ASIS PSP (ASIS Physical Security Professional) Exam is a highly respected certification for security professionals. It is designed to validate the knowledge and expertise of individuals who are involved in physical security systems and practices. PSP Exam covers a wide range of topics including risk assessment, security management principles and practices, physical security design and implementation, and emergency management.
PSP Real Exam Answers & Valid PSP Test PdfThere are a lot of users of PSP learning prep, and our staff has come in contact with various kinds of help. Therefore, you can rest assured that we can solve any problem you have with our PSP exam questions. If you are concerned that online services are relatively indifferent, the staff at PSP practice quiz will definitely change your mind. Our staff really regards every user as a family member and sincerely provides you with excellent service.
ASIS Physical Security Professional Exam Sample Questions (Q175-Q180):NEW QUESTION # 175
Using the "normal" schedule, what is the early finish date of activity 10002 and its total float?
  • A. 12-27-03 and 24 days of float
  • B. 12-18-03 and 4 days of float
  • C. 12-17-03 and 4 days of float
  • D. 12-18-03 and 25 days of float
Early Finish Date Calculation:
* Duration of Activity 10002: 7 days.
* Assuming the start date aligns with project calendars, calculate the early finish by adding the duration to the early start, considering working days.
* Early finish date: 12-17-03.
Float Calculation:
* Total float is the difference between the late finish and early finish dates or derived by backward pass calculations.
* Total float: 4 days.
Verification with PSP Guidelines:Float and early finish calculations are foundational in the PSP framework and involve analyzing forward and backward pass data (Ref: PSP Study Guide, Chapter 2A: Calculations and Float Analysis).
NEW QUESTION # 176
Determine the correct formula and date for the late finish for Activity 2002.
  • A. LS of 2003 less 1 day equaling to 06 Nov 2021
  • B. LS of 2003 less 1 day equaling to 05 Oct 2021
  • C. LS of 2003 plus 1 day equaling to 07 Oct 2021
  • D. LS of 2003 less 1 day equaling to 06 Oct 2021
Late Finish (LF) is calculated by adjusting the Late Start (LS) of the subsequent activity (2003) by the lag value.
The formula, LS of 2003 - 1 day, aligns with CPM principles where the predecessor's LF must occur before the successor starts.
The date calculation, considering lags and dependencies, results in 06 Oct 2021.
References: PSP Study Guide, Section 2.2.4 - Relationships and Calculations, Appendix A - Sample Calculations for LF and LS relationships.
NEW QUESTION # 177
For activity 11001. why would the crashed direct cost be greater than the direct cost of the normal schedule?
  • A. Generally, more equipment is used for a crashed project; therefore, it costs more to demobilize
  • B. Management bonuses for early completion were included in this activity
  • C. Additional extended overhead is also being shown in this activity
  • D. Some costs resulting from the crashed efforts were forgotten in previous activities
Crashing increases direct costs as additional resources, equipment, or expedited delivery methods are employed to shorten the project duration. The PSP Study Guide (Section 2.3.5, "Acceleration") highlights that crashing involves trade-offs between time and cost, often resulting in higher demobilization costs due to the increased deployment of equipment and resources.
NEW QUESTION # 178
What method would be the best way to determine the most likely as-built critical path of a project that is underway, and the schedule of which has been partially progressed?
  • A. Interview the project personnel for their perceptions and opinions because the schedule is usually inadequate.
  • B. Use the progressed portion of the critical path of the baseline schedule.
  • C. Use the progressed portion of the critical path of all the updates previous to the current update.
  • D. Use the forward-looking critical path of the most current updates.
Understanding As-Built Critical Path Analysis:
* Determining the as-built critical path of a project involves identifying the sequence of activities that actually dictated the completion of the project. This is especially important in projects that are underway, as schedules often deviate from the original baseline due to progress updates and unplanned changes.
* Explanation of Each Option:
* A. Use the progressed portion of the critical path of all the updates previous to the current update:
This is correct. To determine the most likely as-built critical path, analyzing the progressed portion of the critical path from all previous updates provides the most accurate representation of the project's actual execution. By reviewing the progression over time, you can piece together the actual sequence of critical activities.
* B. Use the progressed portion of the critical path of the baseline schedule:This is incorrect. The baseline schedule reflects the original plan, which may no longer be accurate due to progress deviations, delays, or changes in logic. Using the baseline alone does not account for the dynamic nature of the project.
* C. Interview the project personnel for their perceptions and opinions because the schedule is usually inadequate:This is incorrect. While project personnel may provide insights, relying solely on subjective opinions introduces biases and inconsistencies. A properly maintained and updated schedule is far more reliable for determining the critical path.
* D. Use the forward-looking critical path of the most current updates:This is incorrect. The forward- looking critical path only reflects what is expected to happen from the current point onward. It does not provide an accurate representation of the as-built critical path up to the current point.
Study Guide References:
* The PSP Study Guide emphasizes the importance of analyzing progress updates to trace the actual sequence of critical activities. Section 2.3.2 (Tracking Schedule Progress) discusses the role of historical updates in understanding project performance.
* The guide also highlights that a proper as-built analysis requires a review of all updates to identify shifts in the critical path over time.
NEW QUESTION # 179
_______________ defines the problem, set the requirements, discuss solutions and set out punishment for infractions.
  • A. Network Security Policy
  • B. Spam filtering
  • C. Physical security
  • D. Forensic investigations
NEW QUESTION # 180
The most important part of ASIS PSP exam preparation is practice, and the right practice is often the difference between success and failure. Pass4sureCert also makes your preparation easier with practice test software to help you get hands-on exam experience before the actual ASIS Physical Security Professional Exam (PSP) exam. After consistent practice, the final exam will not be too difficult for a student who has already practiced from real ASIS PSP exam questions.
PSP Real Exam Answers: https://www.pass4surecert.com/ASIS/PSP-practice-exam-dumps.html
Posted at 3/8/2026 10:38:23        Only Author  2#
The content is too good not to like. Time to take the Test PRINCE2-Practitioner valid exam. Hope I pass with flying colors!
