[General] Easy to Use Salesforce PDII PDF Questions File
108
【General】 Easy to Use Salesforce PDII PDF Questions File
Posted at 1/28/2026 03:21:12      View:113 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Prep4SureReview PDII dumps from Cloud Storage: https://drive.google.com/open?id=1NSi7AEsbjoL9PaEiTQ8wKeFQPwOaS8m3
Up to now, we have business connection with tens of thousands of exam candidates who adore the quality of them. Besides, we try to keep our services brief, specific and courteous with reasonable prices of PDII practice materials. All your questions will be treated and answered fully and promptly. We guarantee that you can pass the exam at one time even within one week based on practicing our PDII studying materials regularly. 98 to 100 percent of former exam candidates have achieved their success by them.
The PDII certification exam consists of 60 multiple-choice questions and is timed for two and a half hours. It is a proctored exam that can be taken online or in-person at a testing center. The passing score for the exam is 63%, and the exam fee is $400. Platform Developer II certification is valid for three years and can be renewed by passing the latest version of the PDII Exam or by completing relevant Trailhead modules.
Free PDF Reliable PDII Real Exam | Easy To Study and Pass Exam at first attempt & Reliable Salesforce Platform Developer IIThe software version of the PDII study materials is very practical. This version has helped a lot of customers pass their exam successfully in a short time. The most important function of the software version is to help all customers simulate the real examination environment. If you choose the software version of the PDII Study Materials from our company as your study tool, you can have the right to feel the real examination environment. In addition, the software version is not limited to the number of the computer.
Salesforce Platform Developer II Sample Questions (Q118-Q123):NEW QUESTION # 118
Which two scenarios require an Apex method to be called imperatively from a Lightning web component?
Choose 2 answers
  • A. Calling a method that is not annotated with cacheable=true
  • B. Calling a method with the click of a button
  • C. Calling a method that makes a web service callout
  • D. Calling a method that is external to the main controller for the Lightning web component
NEW QUESTION # 119
A company processes Orders within their Salesforce instance. When an Order's status changes to 'Paid' it must notify the company's order management system (OMS). The OMS exposes SOAP web service endpoints to listen for when to retrieve the data from Salesforce.
What is the optimal method to implement this?
  • A. Generate the Partner WSDL and use it to make a callout to the OMS.
  • B. Generate the Enterprise WSDL and use it to make a callout to the OMS.
  • C. Create an Outbound Message that contains the session ID and send it to the OMS.
  • D. Create an Apex trigger and make a callout to the OMS from the trigger.
NEW QUESTION # 120
Which technique can run custom logic when a Lightning web component is loaded?
  • A. Use the randersd loack { } method.
  • B. Use the connectedCallback { } method.
  • C. Use an <aura:handler> init event to call a function.
  • D. Call 52. engqueusiction and pass in the method to call.
The connectedCallback { } method is a technique that can run custom logic when a Lightning web component is loaded. The connectedCallback { } method is a lifecycle hook that is invoked when a component is inserted into the DOM. The connectedCallback { } method can be used to perform any initialization tasks, such as fetching data, setting attributes, or registering event listeners. By using the connectedCallback { } method, the developer can run the custom logic when the component is loaded, and ensure that the component is ready to render and interact with the user. Reference: [connectedCallback Hook], [Lightning Web Components Lifecycle Hooks]
NEW QUESTION # 121
A developer is trying to decide between creating a Visualforce component or a Lightning component for a custom screen.
Which functionality consideration impacts the final decision?
  • A. Does the screen need to be accessible from the Lightning Experience UI?
  • B. Will the screen make use of a JavaScript framework?
  • C. Will the screen be accessed via a mobile app?
  • D. Does the screen need to be rendered as a PDF without using a thirdparty application?
Visualforce can render pages as PDFs, which Lightning Components cannot do. This functionality is crucial if PDF rendering is required.References: Visualforce Developer Guide - Rendering a Page as a PDF
NEW QUESTION # 122
A company has a custom component that allows users to search for records of a certain object type by invoking an Apex Controller that returns a list of results based on the user's input. When the search is completed, a searchComplete event is fired, with the results put in a results attribute of the event. The component is designed to be used within other components and may appear on a single page more than once.
What is the optimal code that should be added to fire the event when the search has completed?
  • A.
  • B.
  • C.
  • D.
The correct code to fire the event when the search has completed in a Lightning component is option B. $A.
get("e.c.searchComplete") is the syntax used to get the event, setParams is used to set the parameters, and fire is used to dispatch the event.
References: Lightning Components Developer Guide - Firing Events
NEW QUESTION # 123
We believe that if you trust our PDII exam simulator and we will help you obtain PDII certification easily. After purchasing, you can receive our PDII training material and download within 10 minutes. Besides, we provide one year free updates of our PDII learning guide for you and money back guaranteed policy so that we are sure that it will give you free-shopping experience. Now choose our PDII practic braindump, you will not regret.
Test PDII Objectives Pdf: https://www.prep4surereview.com/PDII-latest-braindumps.html
BONUS!!! Download part of Prep4SureReview PDII dumps for free: https://drive.google.com/open?id=1NSi7AEsbjoL9PaEiTQ8wKeFQPwOaS8m3
