Splunk SPLK-3002 Pass4sure Dumps Pdf | Latest SPLK-3002 Braindumps Sheet
Posted at 1/28/2026 03:29:08
2026 Latest Free4Dump SPLK-3002 PDF Dumps and SPLK-3002 Exam Engine Free Share: https://drive.google.com/open?id=1IKO0fIeDK94ZY8YKasV9cRnmmwJq4AiE
In this website, you can find three different versions of our SPLK-3002 guide torrent which are prepared in order to cater to the different tastes of different people from different countries in the world since we are selling our SPLK-3002 test torrent in the international market. Most notably, the simulation test is available in our software version. With the simulation test, all of our customers will have an access to get accustomed to the SPLK-3002 Exam atmosphere and get over all of bad habits which may influence your performance in the real SPLK-3002 exam. Therefore, you can carry out the targeted training to improve yourself in order to make the best performance in the real exam, most importantly, you can repeat to do the situation test as you like.
Splunk SPLK-3002 certification exam is a valuable credential for IT professionals who want to demonstrate their expertise in using Splunk ITSI to monitor, analyze, and troubleshoot complex IT environments. By passing SPLK-3002 exam, candidates can enhance their career opportunities and increase their earning potential.
Splunk IT Service Intelligence Certified Admin exam consists of 60 multiple-choice questions and must be completed within 90 minutes. SPLK-3002 exam can be taken online or at a Pearson VUE testing center. To prepare for the exam, Splunk recommends that candidates take the Splunk IT Service Intelligence Fundamentals course and have hands-on experience with ITSI.
Splunk SPLK-3002 Exam is designed for IT professionals who want to validate their skills and knowledge in using Splunk IT Service Intelligence (ITSI) to manage IT services. Splunk IT Service Intelligence Certified Admin certification exam is a comprehensive assessment of an individual's ability to install, configure, and manage ITSI in a Splunk environment. SPLK-3002 exam is an online proctored test that consists of 60 multiple-choice and multiple-select questions. It has a time limit of 90 minutes, and the passing score is 70%.
Latest SPLK-3002 Braindumps Sheet & Hot SPLK-3002 QuestionsIt is generally acknowledged that candidates who earn the Splunk IT Service Intelligence Certified Admin (SPLK-3002) certification ultimately get high-paying jobs in the tech market. Success in the Splunk IT Service Intelligence Certified Admin (SPLK-3002) exam not only validates your skills but also helps you get promotions. To pass the Splunk IT Service Intelligence Certified Admin test in a short time, you must prepare with SPLK-3002 Exam Questions that are real and updated. Without studying with SPLK-3002 actual questions, candidates fail and waste their time and money.
Splunk IT Service Intelligence Certified Admin Sample Questions (Q30-Q35):NEW QUESTION # 30
What is an episode?
- A. A notable event group.
- B. A deep dive.
- C. A notable event.
- D. A workflow task.
It's a deduplicated group of notable events occurring as part of a larger sequence, or an incident or period considered in isolation.
An episode is a deduplicated group of notable events occurring as part of a larger sequence, or an incident or period considered in isolation. An episode helps you reduce alert noise and focus on the most important issues affecting your IT services. An episode is created by an aggregation policy, which is a set of rules that determines how to group notable events based on certain criteria, such as severity, source, title, and so on. You can use episode review to view, manage, and resolve episodes in ITSI. The statement that defines an episode is:
C) A notable event group. This is true because an episode is composed of one or more notable events that are related by some common factor.
The other options are not definitions of an episode because:
A) A workflow task. This is not true because a workflow task is an action that you can perform on an episode, such as assigning an owner, changing the status, adding comments, and so on.
B) A deep dive. This is not true because a deep dive is a dashboard that allows you to analyze the historical trends and anomalies of your KPIs and metrics in ITSI.
D) A notable event. This is not true because a notable event is an alert generated by ITSI based on certain conditions or correlations, not a group of alerts.
NEW QUESTION # 31
What is the default importance value for dependent services' health scores?
- A. 0
- B. 1
- C. Unassigned
- D. 2
By default, impacting service health scores have an importance value of 11.
A service template is a predefined set of KPIs and entity rules that you can apply to a service or a group of services. A service template helps you standardize the configuration and monitoring of similar services across your IT environment. A service template can also include dependent services, which are services that are required for another service to function properly. For example, a web server service might depend on a database service and a network service. The default importance value for dependent services' health scores is:
D) 10. This is true because the importance value indicates how much a dependent service contributes to the health score of the parent service. The default value is 10, which means that the dependent service has the highest impact on the parent service's health score. You can change the importance value of a dependent service in the service template settings.
The other options are not correct because:
A) 11. This is not true because 11 is an invalid value for importance. The valid range is from 1 (lowest) to 10 (highest).
B) 1. This is not true because 1 is the lowest value for importance, not the default value. A value of 1 means that the dependent service has the lowest impact on the parent service's health score.
C) Unassigned. This is not true because every dependent service has an assigned importance value, which defaults to 10.
NEW QUESTION # 32
Which of the following are the default ports that must be configured on Splunk to use ITSI?
- A. SplunkWeb (8089), SplunkD (8088), and HTTP Collector (8000)
- B. SplunkWeb (8088), SplunkD (8089), and HTTP Collector (8000)
- C. SplunkWeb (8405), SplunkD (8519), and HTTP Collector (8628)
- D. SplunkWeb (8000), SplunkD (8089), and HTTP Collector (8088)
Reference: https://splunk.github.io/docker-splunk/ARCHITECTURE.html
C is the correct answer because ITSI uses the default ports of Splunk Enterprise for its communication and data collection. SplunkWeb uses port 8000, SplunkD uses port 8089, and HTTP Event Collector uses port
8088. These ports can be changed if needed, but they must match the configuration of Splunk Enterprise.
References: Ports used by ITSI
NEW QUESTION # 33
There are two departments using ITSI. Finance and Sales. Analysts in each department should not be allowed to see each other's services. What are the role configuration steps required to accomplish this?
- A. itoa_finance_admin, inherited from itoa_team_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_analyst; itoa_sales_analyst, inherited from itoa_analyst.
- B. itoa_finance_admin, inherited from itoa_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_analyst; itoa_sales_analyst, inherited from itoa_team_analyst.
- C. itoa_finance_admin, inherited from itoa_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_team_analyst; itoa_sales_analyst, inherited from itoa_team_analyst.
- D. itoa_finance_admin, inherited from itoa_admin; itoa_sales_admin, inherited from itoa_team_admin; itoa_finance_analyst, inherited from itoa_analyst; itoa_sales_analyst, inherited from itoa_analyst.
C is the correct answer because teams are a feature of ITSI that allow you to restrict access to service content in UI views based on user roles. To create separate teams for finance and sales analysts, you need to create custom roles that inherit from the itoa_analyst role, which has read-only access to ITSI content. For example, you can create itoa_finance_analyst and itoa_sales_analyst roles that inherit from itoa_analyst. Then, you need to create custom teams that include these roles and assign them to the relevant services. For example, you can create a finance team that includes the itoa_finance_analyst role and assign it to the finance services.
Similarly, you can create a sales team that includes the itoa_sales_analyst role and assign it to the sales services. This way, analysts in each department can only see their own services and not each other's.
References: Create teams in ITSI, Assign teams to services in ITSI
NEW QUESTION # 34
Within a correlation search, dynamic field values can be specified with what syntax?
- A. eval(fieldname)
- B. %fieldname%
- C. fieldname
- D. <fieldname /fieldname>
B is the correct answer because dynamic field values can be specified with <fieldname /fieldname> syntax within a correlation search. This syntax allows you to insert values from fields returned by the correlation search into alert actions such as email subject or body. For example, <host /host> inserts the value of the host field into the email. Reference: [Use dynamic field values in correlation searches in ITSI]
NEW QUESTION # 35
Our company keeps pace with contemporary talent development and makes every learners fit in the needs of the society. Based on advanced technological capabilities, our SPLK-3002 study materials are beneficial for the masses of customers. Our experts have plenty of experience in meeting the requirement of our customers and try to deliver satisfied SPLK-3002 Exam guides to them. Our SPLK-3002 exam prepare is definitely better choice to help you go through the test.
Latest SPLK-3002 Braindumps Sheet: https://www.free4dump.com/SPLK-3002-braindumps-torrent.html
- Pass Guaranteed Quiz Updated Splunk - SPLK-3002 - Splunk IT Service Intelligence Certified Admin Pass4sure Dumps Pdf 🐱 Search on ➽ [url]www.practicevce.com 🢪 for ▛ SPLK-3002 ▟ to obtain exam materials for free download 🏏Relevant SPLK-3002 Exam Dumps[/url]
- Reliable SPLK-3002 Test Price 🐒 Exam SPLK-3002 Answers 🐘 Exam SPLK-3002 Questions Pdf 🎊 ☀ [url]www.pdfvce.com ️☀️ is best website to obtain ▶ SPLK-3002 ◀ for free download ⚽Exam SPLK-3002 Exercise[/url]
- SPLK-3002 test vce practice - SPLK-3002 exam training files - SPLK-3002 updated prep exam 🥥 Search for ▛ SPLK-3002 ▟ and download it for free on [ [url]www.troytecdumps.com ] website 🥉New SPLK-3002 Exam Review[/url]
- Quiz 2026 Splunk Marvelous SPLK-3002: Splunk IT Service Intelligence Certified Admin Pass4sure Dumps Pdf 🔝 Download ➡ SPLK-3002 ️⬅️ for free by simply entering ➥ [url]www.pdfvce.com 🡄 website 🍒SPLK-3002 Hot Questions[/url]
- SPLK-3002 test vce practice - SPLK-3002 exam training files - SPLK-3002 updated prep exam 🕐 Search for { SPLK-3002 } on ➠ [url]www.prepawaypdf.com 🠰 immediately to obtain a free download 🕘Valid SPLK-3002 Mock Test[/url]
- 100% Pass Quiz Splunk - SPLK-3002 - Splunk IT Service Intelligence Certified Admin –Valid Pass4sure Dumps Pdf 👝 Open “ [url]www.pdfvce.com ” and search for ➥ SPLK-3002 🡄 to download exam materials for free 🕵Exam SPLK-3002 Questions Pdf[/url]
- 100% Pass Quiz Splunk - SPLK-3002 - Splunk IT Service Intelligence Certified Admin –Valid Pass4sure Dumps Pdf 📲 Download ➤ SPLK-3002 ⮘ for free by simply searching on 《 [url]www.prep4sures.top 》 📈Exam SPLK-3002 Exercise[/url]
- Latest SPLK-3002 Test Questions 👶 Exam SPLK-3002 Answers 💷 SPLK-3002 Exam Exercise 🕜 Copy URL 《 [url]www.pdfvce.com 》 open and search for ⮆ SPLK-3002 ⮄ to download for free 🍲Reliable SPLK-3002 Test Price[/url]
- HOT SPLK-3002 Pass4sure Dumps Pdf - Valid Splunk Latest SPLK-3002 Braindumps Sheet: Splunk IT Service Intelligence Certified Admin 📧 Easily obtain ⏩ SPLK-3002 ⏪ for free download through ➠ [url]www.vce4dumps.com 🠰 🌅Relevant SPLK-3002 Exam Dumps[/url]
- Latest SPLK-3002 Exam Braindumps Materials - SPLK-3002 Test Prep - Pdfvce 👣 Search for ▷ SPLK-3002 ◁ and download it for free immediately on 「 [url]www.pdfvce.com 」 🪔Exam SPLK-3002 Torrent[/url]
- Exam SPLK-3002 Answers 👎 Latest SPLK-3002 Exam Camp 🐨 New Study SPLK-3002 Questions 🐈 Open ➠ [url]www.verifieddumps.com 🠰 and search for ☀ SPLK-3002 ️☀️ to download exam materials for free 🥯New Study SPLK-3002 Questions[/url]
- www.notebook.ai, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, xiyana2343.obsidianportal.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
BTW, DOWNLOAD part of Free4Dump SPLK-3002 dumps from Cloud Storage: https://drive.google.com/open?id=1IKO0fIeDK94ZY8YKasV9cRnmmwJq4AiE
