[General] PEGACPLSA23V1Y - PEGACPLSA23V1 PDF
83
General PEGACPLSA23V1Y - PEGACPLSA23V1 PDF
Posted at 1/28/2026 03:58:01      View125 | Replies2        Print      Only Author   [Copy Link] 1#
ȻŬ@PegasystemsPEGACPLSA23V1ԇJC҂Fast2test㌍Fĉ룬Fast2test PegasystemsPEGACPLSA23V1ԇӖYƷ|õӖYϣṩһõČWƽ_}Μʂ@ԇԴ_ٷְٳɹǷdzεģmĕrgWǾx҂Fast2test PegasystemsPEGACPLSA23V1ԇӖYϣ㌢옷pĜʂ俼ԇ
Pegasystems PEGACPLSA23V1 JCCǺܶITʿġPegasystems PEGACPLSA23V1 JCԇǂzITI֪RͽJCԇͨ^ԇҪSIT֪Rͽ򞡣@N֪RһҪMĕrg;Fast2testǂ܎㹝srg;ľWվܿЧ؎aPegasystems PEGACPLSA23V1 JCԇP֪R㌦Fast2testdȤھWMdFast2testṩIJPPegasystems PEGACPLSA23V1 JCԇľ}ʹLԇ
挍PEGACPLSA23V1YϓģM挍ԇhcܛVCE汾100ͨ^ʵPEGACPLSA23V1 PDF@PEGACPLSA23V1JCITšIlչ֤Fast2test˾ṩʴ_PEGACPLSA23V1}Yϣ׺挍ԇ֪Rc҂ČWYϣMrgȥx^ąֻҪMһĕrgȥW҂Pegasystems PEGACPLSA23V1}YվṩPDF汾ܛPEGACPLSA23V1}죬PDF汾ķӡܛ汾Pegasystems PEGACPLSA23V1}ģM挍Ŀԇh㿼x
µ CLSA PEGACPLSA23V1 Mԇ} (Q34-Q39):} #34
A Customer Service application requires customer data assembled from multiple external systems.
The customer data is captured by a parent case. Subcases of that parent case need to reference the same customer data. The customer data must be as current as possible.
Which two options are used as part of the solution? (Choose Two)
  • A. Use the System of Record (SOR) data access pattern when capturing the customer data.
  • B. Have each subcase load a portion of the customer data prior to updating the parent case.
  • C. Use the Snapshot data access pattern to capture the customer data prior to subcase spin off.
  • D. Load the customer data in parallel using the Load -Data Page and Connect-Wair methods.
𰸣A,D
} #35
In which situation do you consider calling external services asynchronously?
  • A. When the response is not immediately required.
  • B. When the response is required exactly after one hour.
  • C. When the response is immediately required.
  • D. When the response may return an error condition.
𰸣A
} #36
You are implementing a paga customer service application and are integrating the system of record data for account information? (Choose three)
  • A. Integrate with the system of record to populate an Account data class.
  • B. Integrate with the system of record in the pega customer service account class
  • C. Rename the pega customer service data pages to match the system of record.
  • D. Specialize the pega customer service data pages that use account data.
  • E. Create a data transform to map the Account data class to the pega customer service Account class
𰸣A,B,E
} #37
When implementing a Next-Best-Action, the customer Lifetime value Threshold is used to
__________ for an offer
  • A. prioritize customer
  • B. determine customer eligibility
  • C. prioritze high value propositions
  • D. apply the customer's lifetime value
𰸣B
} #38
In a SQL query, which of the following is an example of a complex SQL function?
  • A. UPPER()
  • B. LEN()
  • C. CONCAT()
  • D. DATEPART()
𰸣D
} #39
ѽPEGACPLSA23V1JCԇ᣿Dz挦һѵďYϺ}е^ʹأFast2testԎQ@һ}^هľWվֻҪxʹFast2testWվṩYϣ^pͨ^ԇc仨Mrgڲ֪ǷõďYϣsowFast2testoķգ߀ڵʲNsoЄӰɡ
PEGACPLSA23V1 PDF: https://tw.fast2test.com/PEGACPLSA23V1-premium-file.html
Pegasystems Certified Pega Lead System Architecture (LSA) Exam 23 - PEGACPLSA23V1 }aƷnj PEGACPLSA23V1 ԇṩᘌӖYϣ׌̕rgaITČI֪R׌ PEGACPLSA23V1 JCԇóֵĜʂ䣬ԣ҂HҪxxxPEGACPLSA23V1}гֵľ߀Ҫȥ|@݆}֮ģMĿ}Fast2test_eͬWPEGACPLSA23V1}ȥ ǣܴҶPEGACPLSA23V1}ϣKPEGACPLSA23V1ԇУfF˺ܴIJ࣬ȫ濼}JCWYϣ܉һͨ^ Pegasystems Certified Pega Lead System Architecture (LSA) Exam 23 - PEGACPLSA23V1 JCԇ۽ڼջҹ賿㣬ֻҪɸϵͳԶPEGACPLSA23V1ԇӖYϵĵ䣬ء
˓ָYЦLҼF䓵ģӣ˕r޲ó֌ͺŮӽoҼPegasystems Certified Pega Lead System Architecture (LSA) Exam 23 - PEGACPLSA23V1 }aƷnj PEGACPLSA23V1 ԇṩᘌӖYϣ׌̕rgaITČI֪R׌ PEGACPLSA23V1 JCԇóֵĜʂ䡣
PEGACPLSA23V1YϺYԇPEGACPLSA23V1еIṩߣCertified Pega Lead System Architecture (LSA) Exam 23ԣ҂HҪxxxPEGACPLSA23V1}гֵľ߀Ҫȥ|@݆}֮ģMĿ}Fast2test_eͬWPEGACPLSA23V1}ȥ ǣܴҶPEGACPLSA23V1}ϣKPEGACPLSA23V1ԇУfF˺ܴIJࡣ
Posted at 2/11/2026 17:10:04        Only Author  2#
This is such an uplifting article, thanks for sharing! The Exam NETA_2 experience test was the key to unlocking my promotion and raise. Grab it for free today!
Posted at 2/19/2026 03:24:40        Only Author  3#
Im deeply impressed by your article, thank you for sharing it! AD0-E725 valid study guide free provides a variety of useful content, freely offered to support your learning.
