[General] Adobe AD0-E137 Boot Camp | AD0-E137 High Passing Score
83
【General】 Adobe AD0-E137 Boot Camp | AD0-E137 High Passing Score
Posted at 1/28/2026 04:18:36      View:88 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest TestPassKing AD0-E137 PDF Dumps and AD0-E137 Exam Engine Free Share: https://drive.google.com/open?id=19mRk9f6YETHzg-hrzFflWqBp2QvX62mk
With rigorous analysis and summary of AD0-E137 exam, we have made the learning content easy to grasp and simplified some parts that beyond candidates’ understanding. In addition, we add diagrams and examples to display an explanation in order to make the interface more intuitive. Our AD0-E137 Exam Questions will ease your pressure of learning, using less Q&A to convey more important information, thus giving you the top-notch using experience. With our AD0-E137 practice engine, you will have the most relaxed learning period with the best pass percentage.
Adobe AD0-E137 Exam Syllabus Topics:
  • Configurations: This section of the exam measures skills of AEM Developers and covers how to select and configure dispatcher rules based on scenario, set up multi-tenant environments, integrate SAML and LDAP for authentication, configure replication agents, and manage editable templates or content fragment models.
  • AEM Development: This section of the exam measures the skills of Technical Consultants and covers implementing a single-page application (SPA) structure, building components using HTL, sling models, and services, writing unit tests and mapping mock data, integrating third-party APIs, developing OSGi services or servlets, and choosing appropriate JCR queries in context.
  • Build and Deployment: This section of the exam measures the skills of AEM Developers and covers front-end and back-end dependency management, creating a project via Maven archetype, crafting custom run modes, configuring workflows, and creating and managing custom Oak indexes.
  • Environment Maintenance: This section of the exam measures the skills of Implementation Specialists and covers managing AEM environment configurations, release management, synchronizing content and configurations across environments via package manager, and applying maintenance tools to support environments.
AD0-E137 High Passing Score | AD0-E137 Prep GuideWhereas the AD0-E137 PDF file is concerned this file is the collection of real, valid, and updated Adobe AD0-E137 exam questions. You can use the Adobe AD0-E137 PDF format on your desktop computer, laptop, tabs, or even on your smartphone and start Adobe Experience Manager Sites Developer Expert (AD0-E137) exam questions preparation anytime and anywhere.
Adobe Experience Manager Sites Developer Expert Sample Questions (Q25-Q30):NEW QUESTION # 25
A developer is asked to create an Adobe Experience Manager servlet MyServlet that listens for HTTP requests capable of handling the GET method. The servlet must be registered using Declarative Services (OSGi) and be bound to a specific resource type /my/resourcetype allowing it to serve requests for a particular component.
What is the correct way to register a servlet?
A)
@SlingServletResourceTypes(resourceTypes ="/my/resourcetype", methods = {"get"}) public class MyServlet extends SlingSafeMethodServlet {
@Override
protected void doGET(SlingHttpServletRequest request, SlingHttpServletResponse response) throws ServletException, IOException {
// Handle get request
B)
@SlingServletResourceTypes(resourceTypes="/my/resourcetype", methods = { "GET" }) public class MyServlet extends SlingAllMethodsServlet {
@Override
protected void doGet(SlingHttpServletRequest request, SlingHttpServletResponse response) throws ServletException, IOException {
C)
@SlingServletResourceTypes(resourceTypes ="/my/resourcetype", methods = { "get" }) public class MyServlet extends SlingSafeMethodServlet {
@Override
protected void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
  • A. Option C
  • B. Option A
  • C. Option B
NEW QUESTION # 26
An Adobe Experience Manager architect is asked to configure run mode for their UAT environment.
Which configuration will work for the environment?
  • A. /apps/<Project Name>/osgiconfig/config.publish.uat/<Persistent Identity>.cfg.json in ui.config project
  • B. /apps/<Project Name>/osgiconfig/config.author.author/<Persistent Identity>.json in ui.apps project
  • C. /apps/<Project Name>/osgiconfig/config.uat.author/<Persistent Identity>.cfg.json in ui.apps project
NEW QUESTION # 27
While configuring SSO with SAML 2.0 compatible IDP on AEM, a developer notices an infinite loop between the IDP and AEM when trying to log in to AEM using SSO.
Which dispatcher-specific configuration is required to prevent this scenario?
  • A. Config File: filters.any
    Config: /0100 {/type "allow" /method "POST" /url "*/saml_login"}
  • B. Config File: vhosts.any
    Config: /0100 {/type "allow" /method "POST" /url "*/samllogin"}
  • C. Config File: allowed_clients.any
    Config: /0100 {/type "allow" /method "PUT" /url "*/samllogin"}
NEW QUESTION # 28
A client has a requirement to get the location of stores based on the zip code authored in the component dialog. Location needs to be pulled from an external API using OSGi services.
Which OSGi Service code snippet should be used to represent the requirement?
A)
@OSGIService(component = Service.class)
public class ServiceImpl implements Service {
@Override
public List<String> getStoresByZipCode(String zipCode) {
List<String> storeLocations = new ArrayList<>();
// Create an HTTP client
try (CloseableHttpClient httpClient = HttpClients.createDefault()) {
// Processing logic to get all the locations from external api
} catch (IOException e) {
return storeLocations;
B)
@Component(service = Service.class)
@Override
C)
@Service(service = Component.class)
@Override
  • A. Option B
  • B. Option C
  • C. Option D
  • D. Option A
NEW QUESTION # 29
A developer is required to create a package with these requirements:
Package Name: aem-package
Content Path: /content/aem-site
Group: aem_group
What is the correct zip package file created in Adobe Experience Manager package manager?
  • A. aem-package-aem_group-1.0.zip
  • B. aem_group-aem-site-aem-package.zip
  • C. aem-package-1.0.zip
NEW QUESTION # 30
Sometimes a small step is possible to be a big step in life. AD0-E137 exam seems just a small exam, but to get the AD0-E137 certification exam is to be reckoned in your career. Such an international certification is recognition of your IT skills. In addition, except AD0-E137, many other certification exams are also useful. The latest information of these tests can be found in our TestPassKing.
AD0-E137 High Passing Score: https://www.testpassking.com/AD0-E137-exam-testking-pass.html
BTW, DOWNLOAD part of TestPassKing AD0-E137 dumps from Cloud Storage: https://drive.google.com/open?id=19mRk9f6YETHzg-hrzFflWqBp2QvX62mk
Posted at 1/29/2026 14:04:49        Only Author  2#
擁有PECB ISO-IEC-27001-Lead-Auditor認證考試證書可以幫助在IT領域找工作的人獲得更好的就業機會,也將會為成功的IT事業做好鋪墊。
