[General] Analytics-Admn-201考試 -最新Analytics-Admn-201題庫資訊
103
【General】 Analytics-Admn-201考試 -最新Analytics-Admn-201題庫資訊
Posted at 1/28/2026 08:54:40      View:126 | Replies:2        Print      Only Author   [Copy Link] 1#
目前是經濟衰退的時期,找一份工作不容易,考取 Analytics-Admn-201 認證的證書肯定是有用的,能夠幫助你穩定你的位置,增加求職的成功率。Fast2test Analytics-Admn-201 認證考題已經幫助很多考生通過 Analytics-Admn-201 考試。并被很多考生視為首選的 Analytics-Admn-201 證照參考資料,是考生一直稱贊和信得過的考題。想獲取 Salesforce 的證照考生需要參加Analytics-Admn-201 考試。
Salesforce Analytics-Admn-201 考試大綱:
主題簡介
主題 1
  • Administration: This section of the exam measures the skills of Tableau Administrators and covers the day-to-day tasks of maintaining Tableau Server. Candidates should understand how to create and manage schedules, subscriptions, backups, and restores, as well as how to use tools such as TSM, Tabcmd, and REST API. It emphasizes monitoring, server analysis, log file usage, and embedding practices. It also includes managing projects, sites, and nested structures, while contrasting end-user and administrator abilities. Knowledge of publishing, web authoring, sharing views, caching, and data source certification is also tested.
主題 2
  • Migration & Upgrade: This section of the exam measures the skills of System Engineers and covers the process of upgrading and migrating Tableau Server environments. Candidates should understand how to carry out clean reinstalls, migrate servers to new hardware, and maintain backward compatibility during the process.
主題 3
  • Troubleshooting: This section of the exam measures the skills of Support Specialists and covers resolving common Tableau Server issues. Candidates must know how to reset accounts, package logs, validate site resources, rebuild search indexes, and use analysis reports. It also includes understanding the role of browser cookies and creating support requests when needed.
主題 4
  • Connecting to and Preparing Data: This section of the exam measures the skills of Tableau Administrators and covers the basic understanding of Tableau Server’s interface, navigation, and overall topology. Candidates are expected to recognize both client and server components, understand how these interact, and know where to find information about versions, releases, and updates. It also focuses on system requirements, including hardware, operating systems, browsers, email configurations, cloud considerations, and licensing models. Additionally, it examines knowledge of server processes, data source types, network infrastructure, and ports needed for a stable deployment.
主題 5
  • Installation and Configuration: This section of the exam measures the skills of Server Engineers and covers the process of installing Tableau Server, understanding installation paths, identity store options, SSO integrations, SSL setup, and silent installs. Candidates also need to demonstrate the ability to configure Tableau Server by setting cache, distributing processes, customizing sites, and configuring user quotas. It further includes adding users, managing their roles and permissions, and applying Tableau’s security model at different levels from sites to workbooks.
高質量的Analytics-Admn-201考試,覆蓋大量的Salesforce認證Analytics-Admn-201考試知識點我受不了現在的生活和工作了,想做別的工作。你現在有這樣的想法嗎?但是,怎樣才能做更好的工作呢?你喜歡IT嗎?想通過IT來證明自己的實力嗎?如果你想從事IT方面的工作,那麼參加IT認定考試,取得認證資格是非常有必要的。你現在要做的就是參加被普遍認可的、有價值的IT資格考試。從而打開你職業生涯的新的大門。關於Salesforce的Analytics-Admn-201考試,你一定不陌生吧。取得這個資格可以讓你在找工作的時候得到一份助力。什麼?沒有信心參加這個考試嗎?沒關係,你可以使用Fast2test的Analytics-Admn-201考試資料。
最新的 Salesforce Administrator Analytics-Admn-201 免費考試真題 (Q54-Q59):問題 #54
You need to verify the status of the Coordination Service ensemble in a high-availability (HA) Tableau Server cluster. What should you do?
  • A. Run the command tsm maintenance ziplogs
  • B. Run the command tsm status -v
  • C. Examine the Tableau Server Status page
  • D. Examine the Tableau Services Manager (TSM) web client Status page
答案:B
解題說明:
In an HA Tableau Server cluster, the Coordination Service (ZooKeeper ensemble) maintains cluster state- let's find the best way to check it:
* Coordination Service:
* Runs on multiple nodes (3 or 5 in HA) to ensure quorum and failover.
* Status indicates if it's running and synced-critical for cluster health.
* Option C (Run tsm status -v): Correct.
* Details: tsm status --verbose lists all processes across nodes, including Coordination Service (e.
g., "Coordination Service: RUNNING").
* Why Best: Provides detailed, node-specific status in the CLI-e.g., "Node 1: RUNNING, Node
2: RUNNING."
* Use: Run on the initial node; -v ensures full output.
* Option A (TSM web client Status page): Incorrect.
* Why: The TSM UI (Server > Status) shows process counts (e.g., "Coordination Service: 3 instances"), but not detailed per-node status-less granular than CLI.
* Option B (tsm maintenance ziplogs): Incorrect.
* Why: Generates log archives for troubleshooting, not a real-time status check.
* Option D (Tableau Server Status page): Incorrect.
* Why: The Server Status page (Server > Status in the web UI) monitors application processes (e.
g., VizQL), not TSM's Coordination Service.
Why This Matters: Coordination Service health ensures HA stability-tsm status -v is the admin's go-to for precision.
Reference: Tableau Server Documentation - "Check Server Status" (https://help.tableau.com/current/server/en- us/tsm_status.htm).
問題 #55
What statement correctly describes locking permissions to a project?
  • A. Content permissions are locked to a project by default
  • B. Locking permissions to projects must be enabled on the Tableau Server Settings page
  • C. You can lock permissions to a project by setting the appropriate Project permission role
  • D. You can lock permissions to a project by changing Customizable to Locked
答案:D
解題說明:
In Tableau Server, projects organize content (workbooks, data sources) and use permissions to control access. "Locking permissions" restricts how permissions are managed within a project-let's explore this exhaustively:
* Permission Management Modes:
* Managed by Owner: Default mode. Content owners (e.g., workbook publishers) can set permissions on their items, inheriting project defaults as a starting point.
* Locked to the Project: Project-level permissions are enforced, and content owners cannot modify them. This ensures consistency across all items in the project.
* How to Lock:
* In the Tableau Server web UI:
* Go to Content > Projects.
* Select a project, click Actions > Permissions.
* In the Permissions dialog, change Permissions Management from "Customizable" (Managed by Owner) to "Locked."
* Set the desired permissions (e.g., Viewer, Editor) for users/groups, which then apply uniformly to all content.
* Via REST API: Use the updateProject endpoint with "permissionsLocked": true.
* Option B (You can lock permissions to a project by changing Customizable to Locked): Correct.
* Details: This is the precise action in the UI-switching from "Customizable" to "Locked" locks permissions at the project level.
* Impact: Owners lose the ability to override permissions on individual workbooks/data sources, enforcing governance.
* Example: Set "All Users" to Viewer (Locked)-all content in the project is view-only, regardless of owner intent.
* Option A (Locking permissions must be enabled on the Server Settings page): Incorrect.
* Why: Locking is a per-project setting, not a server-wide toggle. The Server Settings page (via TSM) controls global configs (e.g., authentication), not project permissions.
* Option C (Content permissions are locked by default): Incorrect.
* Default: New projects are "Managed by Owner" (Customizable), allowing flexibility unless explicitly locked by an admin.
* Option D (By setting the appropriate Project permission role): Incorrect.
* Confusion: "Project permission role" isn't a term-permissions are set via rules (e.g., Viewer, Editor), but locking is a separate action (Customizable # Locked).
Why This Matters: Locking permissions ensures uniform access control, critical for regulated environments or large teams where consistency trumps flexibility.
Reference: Tableau Server Documentation - "Lock Project Permissions" (https://help.tableau.com/current
/server/en-us/permissions_lock.htm).
問題 #56
What Tableau Server authentication method should you configure to use OpenID Connect?
  • A. SAML
  • B. Local Authentication
  • C. Active Directory
  • D. Kerberos
答案:A
解題說明:
Tableau Server supports multiple authentication methods, including Local Authentication, Active Directory, Kerberos, SAML, and OpenID Connect. OpenID Connect (OIDC) is an identity layer built on OAuth 2.0, commonly used for single sign-on (SSO). In Tableau Server, OIDC is implemented as a variant of SAML (Security Assertion Markup Language) authentication because both are SSO protocols managed through the same configuration workflow.
To use OpenID Connect:
* Configure Tableau Server for SAML/SSO.
* Provide an OIDC-compatible identity provider (IdP) configuration (e.g., Google, Okta).
* Set up the IdP metadata and certificates in TSM.
* Option D (SAML): Correct. Tableau Server treats OIDC as a subset of its SAML authentication framework, so you configure it under the SAML settings in TSM.
* Option A (Local Authentication): Incorrect. Local Authentication uses Tableau's internal user database, not an external SSO protocol like OIDC.
* Option B (Kerberos): Incorrect. Kerberos is a network authentication protocol for Windows environments, unrelated to OIDC.
* Option C (Active Directory): Incorrect. AD uses LDAP or Kerberos, not OIDC, for authentication.
Reference: Tableau Server Documentation - "Configure SAML and OpenID Connect" (https://help.tableau.
com/current/server/en-us/saml_config.htm).
問題 #57
If a user already exists as part of a group in Tableau Server, and Active Directory synchronization then applies a minimum site role to the group, what will happen to the existing user's site role?
  • A. It will change to the minimum site role only if the minimum site role provides more access
  • B. It will change to the minimum site role only if the minimum site role reduces access
  • C. It will always change to the minimum site role
  • D. It will never change as a result of synchronization
答案:B
解題說明:
When Tableau Server uses Active Directory (AD) for authentication, group synchronization imports AD groups and assigns a minimum site role (e.g., Viewer, Explorer) to users in that group. This ensures users meet a baseline access level. The behavior for existing users during sync is:
* If the user's current site role provides more access than the minimum (e.g., Explorer vs. Viewer), their role remains unchanged.
* If the user's current role provides less access than the minimum (e.g., Unlicensed vs. Viewer), their role is upgraded to the minimum.
This preserves higher privileges while enforcing a floor. "Reduces access" means the minimum role is lower than the current role (e.g., Viewer vs. Explorer), in which case the existing role stays.
* Option A (It will change to the minimum site role only if the minimum site role reduces access):
Correct. The user's role changes only if the minimum increases access (e.g., Unlicensed to Viewer); otherwise, it stays higher.
* Option B (It will change only if the minimum provides more access): Incorrect wording. This is the inverse of the actual behavior-change occurs when needed to meet the minimum, not to exceed it.
* Option C (It will always change): Incorrect. Existing higher roles are preserved.
* Option D (It will never change): Incorrect. It changes if the current role is below the minimum.
Reference: Tableau Server Documentation - "Synchronize Active Directory Groups" (https://help.tableau.com
/current/server/en-us/groups_sync.htm).
問題 #58
Which two commands are valid and complete commands? (Choose two.)
  • A. tsm maintenance cleanup
  • B. tsm maintenance backup
  • C. tsm maintenance ziplogs
  • D. tsm maintenance restore
答案:A,C
解題說明:
TSM commands manage Tableau Server maintenance-let's validate their syntax:
* Command Requirements:
* Some need arguments (e.g., file paths); others are standalone.
* Valid and Complete: Must work as-is without errors.
* Option C (tsm maintenance cleanup): Correct.
* Details: Removes temporary files and old logs-no arguments required (optional flags like -l exist).
* Use: tsm maintenance cleanup-runs fully.
* Option D (tsm maintenance ziplogs): Correct.
* Details: Creates a zip of logs (e.g., tsm-logs.zip)-no arguments needed (optional -d for date range).
* Use: tsm maintenance ziplogs-complete and valid.
* Option A (tsm maintenance backup): Incorrect.
* Why: Requires -f <filename>.tsbak (e.g., tsm maintenance backup -f backup.tsbak)-incomplete without it.
* Option B (tsm maintenance restore): Incorrect.
* Why: Needs -f <filename>.tsbak (e.g., tsm maintenance restore -f backup.tsbak)-not standalone.
Why This Matters: Correct syntax ensures maintenance tasks execute without errors-critical for server health.
Reference: Tableau Server Documentation - "TSM Maintenance Commands" (https://help.tableau.com/current
/server/en-us/cli_maintenance_tsm.htm).
問題 #59
除了確保為考生提供最新和最好的Salesforce Analytics-Admn-201題庫資料之外,我們更希望為您提供優質的服務,我們提供所有的考古題都是最新版的題庫資料。我們還使用國際最大最值得信賴的Paypal付款,安全支付有保障,考生可以放心購買最新的Analytics-Admn-201考古題。在現在競爭激烈的IT行業,擁有Salesforce Analytics-Admn-201認證是證明自己能力的標志。而Fast2test網站的最新版的考古題就確保您通過此認證,Analytics-Admn-201題庫是由多位專業的資深講師研究而來,成就您的夢想!
最新Analytics-Admn-201題庫資訊: https://tw.fast2test.com/Analytics-Admn-201-premium-file.html
Posted at 2/13/2026 13:57:38        Only Author  2#
This article is absolutely brilliant, thank you for sharing. Thanks to the 250-584 reliable exam dumps.zip, I got promoted and received a raise. Now, it’s available for free. Wishing you all success in your career!
Posted at 2/17/2026 00:11:13        Only Author  3#
Thank you for your article; it is truly outstanding! Reliable test SOA-C02 cram pdf is the reason I got promoted and earned a raise—now I’m giving it away for free!
