[General] Analytics-Arch-201 Certification Exam Infor | Reliable Analytics-Arch-201 Exam O
90
General Analytics-Arch-201 Certification Exam Infor | Reliable Analytics-Arch-201 Exam O
Posted at 1/28/2026 09:23:07      View145 | Replies0        Print      Only Author   [Copy Link] 1#
Salesforce Analytics-Arch-201 dumps PDF version is printable and embedded with valid Salesforce Analytics-Arch-201 questions to help you get ready for the Analytics-Arch-201 exam quickly. Salesforce Certified Tableau Architect (Analytics-Arch-201) exam dumps pdf are also usable on several smart devices. You can use it anywhere at any time on your smartphones and tablets. We update our Salesforce Analytics-Arch-201 Exam Questions bank regularly to match the changes and improve the quality of Analytics-Arch-201 questions so you can get a better experience.
Salesforce Analytics-Arch-201 Exam Syllabus Topics:
  • Design a Tableau Infrastructure: This section of the exam measures skills of Tableau Consultants and focuses on planning and designing a complex Tableau deployment. It covers gathering user requirements, licensing strategies including Authorization-to-Run, high availability and disaster recovery planning, and mapping server add-ons to the organizations needs. It includes planning and implementing Tableau Cloud with Bridge, authentication, user provisioning, and multi-site configuration. Additionally, it addresses migration planning across Tableau products, operating systems, identity stores, and consolidations, as well as designing process topologies, sizing, node roles, and recommending server configurations including security, hardware, and disaster recovery.
  • Deploy Tableau Server: This domain assesses the ability of Tableau Administrators to perform production-ready deployments of Tableau Server. It encompasses installing and configuring Tableau Server with external components, supporting air-gapped environments, disaster recovery validations, and blue-green deployments. It includes configuring and troubleshooting various authentication methods such as SAML, Kerberos, and LDAP. The section also covers implementing encryption strategies, installing and verifying Tableau Server on Linux and Windows platforms, resolving installation and configuration issues, and managing service accounts and logging.
  • Monitor and Maintain a Tableau Deployment: This section evaluates skills of Tableau Administrators in monitoring, maintaining, and optimizing Tableau environments. It involves creating custom administrative dashboards, conducting load testing using tools like TabJolt, and analyzing test results. Troubleshooting complex performance bottlenecks in workbooks and server resources is key, as is tuning caching and scaling strategies. It covers leveraging observability tools such as the Resource Monitoring Tool, analyzing logs and metrics, and adjusting architecture accordingly. Automation of maintenance functions using APIs, scripting, and scheduling is included, along with managing server extensions, content automation, dashboard extensions, web data connectors, and secure embedded solutions.
Free PDF Quiz Salesforce - Useful Analytics-Arch-201 - Salesforce Certified Tableau Architect Certification Exam InforIn fact, on one side, our Analytics-Arch-201 training braidumps can help you pass the exam and win the certification. On the othe side, i think it is even more important, that you can apply what you have learned on our Analytics-Arch-201 Practice Guide into practices. Your speed of finishing the task will be greatly elevated. Everting will take positive changes because of our Analytics-Arch-201 exam materials. Please cheer up for yourself.
Salesforce Certified Tableau Architect Sample Questions (Q88-Q93):NEW QUESTION # 88
When troubleshooting Connected App authentication issues in Tableau Server, what factor should be primarily investigated?
  • A. The speed and stability of the internet connection between the connected app and Tableau Server
  • B. The correctness and validity of the client credentials used by the connected app
  • C. The frequency of data synchronization between the connected app and Tableau Server
  • D. The version compatibility of Tableau Server with the connected app
The correctness and validity of the client credentials used by the connected app A common area to focus on when troubleshooting Connected App authentication issues is the correctness and validity of the client credentials (client ID and secret). Incorrect or expired credentials can prevent the connected app from authenticating with Tableau Server, leading to access issues. Ensuring that these credentials are correct and up-to-date is crucial for resolving authentication problems. Option A is incorrect because while internet connectivity is important, it is not typically the primary cause of authentication issues. Option C is incorrect as version compatibility, although important, is less likely to be the direct cause of authentication problems. Option D is incorrect be-cause the frequency of data synchronization is generally not related to authentication issues with connected apps.
NEW QUESTION # 89
You're setting up Tableau Server on a Windows system and encounter errors indicating DNS resolution problems. What is the most appropriate initial action to resolve this issue?
  • A. Changing the domain name of the Windows server to align with the DNS settings
  • B. Verifying and correcting the DNS settings on the Windows server
  • C. Installing a secondary DNS server to provide redundancy in the network configuration
  • D. Increasing the bandwidth allocation to the Windows server to improve network communication
Verifying and correcting the DNS settings on the Windows server When encountering DNS resolution problems during Tableau Server setup on Windows, the initial and most appropriate action is to verify and correct the DNS settings on the server. Incorrect DNS settings can prevent the server from resolving domain names properly, leading to network communication errors. Option A is incorrect because changing the domain name of the server is an excessive step before checking the existing DNS settings. Option C is incorrect as increasing bandwidth allocation does not address DNS resolution problems. Option D is incorrect because installing a secondary DNS server, while beneficial for redundancy, does not directly resolve existing DNS configuration issues on the primary server.
NEW QUESTION # 90
During the migration of Tableau Server from Windows to Linux, what key aspect should be ad-dressed to maintain performance and stability?
  • A. Conducting comprehensive testing of the Tableau Server on Linux, including data source connections and performance benchmarks
  • B. Neglecting the testing of data connections post-migration, assuming they will remain stable
  • C. Only transferring the most frequently used dashboards to reduce the load on the Linux server
  • D. Changing the underlying database platform to better suit the Linux environment
Conducting comprehensive testing of the Tableau Server on Linux, including data source connections and performance benchmarks Comprehensive testing is essential to ensure that the Tableau Server maintains its performance and stability in the new Linux environment, including verifying data connections and performance standards. Option A is incorrect because neglecting the testing of data connections can lead to critical issues post-migration. Option C is incorrect as only transferring frequently used dashboards does not address the overall stability and performance of the server. Option D is incorrect because changing the database platform is not necessarily required for a migration from Windows to Linux and could introduce unnecessary complexities.
NEW QUESTION # 91
In the context of interpreting Tableau Server installation logs, what is a key aspect to look for when diagnosing an installation failure?
  • A. Network bandwidth and latency during the installation process
  • B. User access levels and permissions at the time of installation
  • C. Error codes or messages that indicate the specific nature of the installation failure
  • D. The number of users accessing the server during the installation
Error codes or messages that indicate the specific nature of the installation failure When diagnosing an installation failure in Tableau Server, it is crucial to look for error codes or messages within the installation logs. These codes or messages can provide specific insights into what went wrong during the installation process, enabling targeted troubleshooting and resolution of the issue. Option A is incorrect because user access levels and permissions, while important, are not typically the primary focus when diagnosing an installation failure from the logs. Option B is incorrect as network bandwidth and latency are less likely to be detailed in installation logs and are not usually the primary causes of installation failures. Option D is incorrect because the number of users accessing the server during installation is unlikely to be a factor in installation failures and is not typically recorded in installation logs.
NEW QUESTION # 92
After analyzing a performance recording of a Tableau dashboard, you identify that complex calculated fields are causing significant delays. What action should be taken to resolve this issue?
  • A. Increasing the server's hardware specifications to handle complex calculations more efficiently
  • B. Optimizing the calculated fields by simplifying their formulas or pre-calculating values where possible
  • C. Limiting user access to the dashboard to reduce the load on the server
  • D. Rebuilding the entire dashboard from scratch to ensure optimal performance
Optimizing the calculated fields by simplifying their formulas or pre-calculating values where possible The most effective action to resolve delays caused by complex calculated fields in a Tableau dashboard is to optimize these fields. This can be achieved by simplifying the formulas used in the calculations or pre-calculating values in the data source, if possible. This approach directly addresses the root cause of the delays without the need for extensive changes to the server or dashboard. Option A is incorrect because while increasing hardware specifications might improve performance, it does not address the inherent inefficiency of the complex calculations. Op-tion C is incorrect as limiting user access does not solve the underlying issue with the calculated fields. Option D is incorrect because rebuilding the entire dashboard is an excessive measure and may not be necessary if the calculated fields can be optimized.
NEW QUESTION # 93
Now there are many IT professionals in the world and the competition of IT industry is very fierce. So many IT professionals will choose to participate in the IT certification exam to improve their position in the IT industry. Analytics-Arch-201 Exam is a very important Salesforce's certification exam. But if you want to get a Salesforce certification, you must pass the exam.
Reliable Analytics-Arch-201 Exam Online: https://www.examcollectionpass.com/Salesforce/Analytics-Arch-201-practice-exam-dumps.html
