[General] CTS Reliable Test Dumps | CTS Reliable Braindumps Files
90
General CTS Reliable Test Dumps | CTS Reliable Braindumps Files
Posted at 1/28/2026 15:09:56      View142 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CTS dumps are available on Google Drive shared by TestBraindump: https://drive.google.com/open?id=1MAeFZvM1RPZP3_55TnS5D26VIGkhLR0X
As a professional dumps vendors, we provide the comprehensive CTS pass review that is the best helper for clearing CTS actual test, and getting the professional certification quickly. It is a best choice to improve your professional skills and ability to face the challenge of CTS Practice Exam with our online training. We have helped thousands of candidates to get succeed in their career by using our CTS study guide.
AVIXA CTS - General Exam Syllabus Topics:
TopicWeight
Duty A:Creating AV Solutions47%
Task 1:Gather Customer Information10%
Task 2:Conduct Initial Site Survey9%
Task 3: Evaluate Site Environment (acoustics, lighting, seating, finishing, etc.)9%
Task 4evelop an AV Project Scope9%
Task 5: Design AV Solutions10%
Domain 2:Implementing AV Solutions27%
Task 1:Integrate AV Solutions10%
Task 2:Operate AV Solutions9%
Task 3:Manage AV Projects8%
Domain 3:Servicing AV Solutions26%
Task 1:Maintain AV Operations8%
AVIXA - Reliable CTS - Certified Technology Specialist Reliable Test DumpsThe only use of the internet is to validate the product license for the CTS practice exam software. If you are not online, you can still practice for the AVIXA CTS exam questions thanks to this feature of TestBraindump's CTS Exam simulation software. As a result, the CTS desktop-based practice test software is a particularly useful option for customers who do not constantly have access to the internet.
AVIXA Certified Technology Specialist Sample Questions (Q175-Q180):NEW QUESTION # 175
What is the BEST way to manage a campus-wide AV system deployment?
  • A. remote monitoring solution
  • B. on-site monitoring checks
  • C. service level agreement
  • D. stand-by stock of equipment
A remote monitoring solution is the best way to manage a campus-wide AV system deployment because it allows for continuous, real-time monitoring and management of the AV systems from a central location. This approach enables quick detection and resolution of issues, minimizes downtime, and reduces the need for on-site visits. Remote monitoring can provide insights into system performance, usage patterns, and potential problems, making it easier to maintain and optimize the AV infrastructure across a large campus.
NEW QUESTION # 176
Exhibit:
These images provide examples of _____ distortion.
  • A. Chromatic
  • B. Keystone
  • C. Contrast
  • D. Trapezoid
The images shown represent keystone distortion, which occurs when a projector is not aligned perpendicularly to the screen. This misalignment results in a trapezoidal image rather than a rectangular one.
According to the AVIXA CTS Exam Guide, keystone distortion is covered under the Display Systems section, which states:
"Keystone distortion happens when the projector lens is not perpendicular to the screen plane, often due to improper vertical or horizontal positioning. The image appears wider at one end and narrower at the opposite, forming a shape like a keystone - hence the name." This distortion is not related to contrast (A), which refers to the difference between light and dark elements in an image, nor chromatic (B), which pertains to color distortion or aberration. While the shapes resemble trapezoids, trapezoid (D) is a description of the resulting shape, not the distortion type. The technical term for this specific distortion is keystone.
AVIXA CTS Exam Guide, 5th Edition - Chapter 7: Display Systems, page 145-147.
CTS-D Body of Knowledge: Image Display and Projection Techniques, Keystone Correction section.
NEW QUESTION # 177
Which section of the Ohm's Law chart would you use to calculate watts? Select the coned quadrant.
To calculate watts (P) using the Ohm's Law chart, you would use the sections that involve power formulas.
These sections are:
* P = V * I
* P = I² * R
* P = V² / R
These formulas show the relationship between power (watts) and the other electrical quantities: voltage (V), current (I), and resistance (R).
NEW QUESTION # 178
By code, projection screens should be positioned in a manner that avoids blocking
  • A. alarm indicators, clocks, and light switches.
  • B. paintings, cabinets, and sliding doors.
  • C. windows, aquariums, and other glass surfaces.
  • D. lines of sight and lectern access.
Projection screens should be positioned to avoid obstructing alarm indicators, clocks, and light switches, as these are critical elements within a room that need to remain accessible and visible. Ensuring they are not blocked helps maintain safety and usability within the space.
CTS Technology Specialist ReferenceAs per CTS guidelines, projection screen placement should consider accessibility and visibility of room elements critical to operation and safety, like alarms and controls.
NEW QUESTION # 179
An integrator has to upgrade a camera system in an existing board room. What is the MOST IMPORTANT information to gather on the site visit?
  • A. resolution of camera system
  • B. ambient lighting placement
  • C. cable length
  • D. distance from the lens to first participant
The most important information to gather on a site visit when upgrading a camera system in an existing boardroom is the distance from the lens to the first participant. This measurement is crucial for determining the appropriate camera lens and its focal length to ensure all participants are clearly visible within the camera's field of view. It also affects the placement and angle of the camera to achieve the best possible coverage. Axis Technology Specialist documentation emphasizes the importance of precise measurements and placement to optimize camera performance and video quality in boardroom settings.
Top of Form
Bottom of Form
NEW QUESTION # 180
TestBraindump is the best choice for those in preparation for exams. Many people have gained good grades after using our CTS exam materials, so you will also enjoy the good results. Our free demo provides you with the free renewal in one year so that you can keep track of the latest points happening in the world. As the questions of our CTS Exam Prep are more or less involved with heated issues and for customers who prepare for the CTS exam.
CTS Reliable Braindumps Files: https://www.testbraindump.com/CTS-exam-prep.html
2026 Latest TestBraindump CTS PDF Dumps and CTS Exam Engine Free Share: https://drive.google.com/open?id=1MAeFZvM1RPZP3_55TnS5D26VIGkhLR0X
