[Hardware] Latest training guide for Microsoft DP-420
62
Hardware Latest training guide for Microsoft DP-420
Posted at 1/28/2026 15:24:41      View162 | Replies2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of VCETorrent DP-420 dumps for free: https://drive.google.com/open?id=1-LkYbLrWRYOqzg7RAyMO0icWogaGsFLl
VCETorrent is a website that can provide all information about different IT certification exam. VCETorrent can provide you with the best and latest exam resources. To choose VCETorrent you can feel at ease to prepare your Microsoft DP-420 exam. Our training materials can guarantee you 100% to pass Microsoft certification DP-420 exam, if not, we will give you a full refund and exam practice questions and answers will be updated quickly, but this is almost impossible to happen. VCETorrent can help you pass Microsoft Certification DP-420 Exam and can also help you in the future about your work. Although there are many ways to help you achieve your purpose, selecting VCETorrent is your wisest choice. Having VCETorrent can make you spend shorter time less money and with greater confidence to pass the exam, and we also provide you with a free one-year after-sales service.
VCETorrent also offers up to 1 year of free updates. It means if you download our actual DP-420 exam questions today, you can get instant and free updates of these DP-420 questions. With this amazing offer, you don't have to worry about updates in the Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) examination content for up to 1 year. In case of any update within three months, you can get free DP-420 exam questions updates from VCETorrent.
Latest Upload Microsoft DP-420 Study Center - Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Study GroupWe provide the Microsoft DP-420 exam questions in a variety of formats, including a web-based practice test, desktop practice exam software, and downloadable PDF files. VCETorrent provides proprietary preparation guides for the certification exam offered by the DP-420 Exam Dumps. In addition to containing numerous questions similar to the DP-420 exam, the Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) exam questions are a great way to prepare for the Microsoft DP-420 exam dumps.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q98-Q103):NEW QUESTION # 98
You have an Azure Cosmos DB database that contains a container named container 1. The container1 container is configured with a maximum of 20,000 RU/s and currently contains 240 GB of data.
You need to estimate the costs of container1 based on the current usage.
How many RU/s will be charged?
  • A. 4.000
  • B. 0
  • C. 20,000
  • D. 1
NEW QUESTION # 99
You have an Azure Cosmos DB Core (SQL) account that has a single write region in West Europe.
database named db
Box 1: Yes
The Automatic failover option allows Azure Cosmos DB to failover to the region with the highest failover priority with no user action should a region become unavailable.
Box 2: No
West Europe is used for failover. Only North Europe is writable.
To Configure multi-region set UseMultipleWriteLocations to true.
Box 3: Yes
Provisioned throughput with single write region costs $0.008/hour per 100 RU/s and provisioned throughput with multiple writable regions costs $0.016/per hour per 100 RU/s.
https://docs.microsoft.com/en-us ... how-to-multi-master
https://docs.microsoft.com/en-us ... timize-cost-regions
NEW QUESTION # 100
You have a container named container1 in an Azure Cosmos DB Core (SQL) API account.
You need to make the contents of container1 available as reference data for an Azure Stream Analytics job.
Solution: You create an Azure function that uses Azure Cosmos DB Core (SQL) API change feed as a trigger and Azure event hub as the output.
Does this meet the goal?
  • A. Yes
  • B. No
The Azure Cosmos DB change feed is a mechanism to get a continuous and incremental feed of records from an Azure Cosmos container as those records are being created or modified. Change feed support works by listening to container for any changes. It then outputs the sorted list of documents that were changed in the order in which they were modified.
The following diagram represents the data flow and components involved in the solution:
Reference: https://docs.microsoft.com/en-us ... -ecommerce-solution
NEW QUESTION # 101
You have an Azure Cosmos DB container named container1.
You need to insert an item into contained. The solution must ensure that the item is deleted automatically after two hours.
How should you complete the item definition? To answer, select the appropriate options in the answer area.
NEW QUESTION # 102
You have a database named db1 in an Azure Cosmos DB f You have a third-party application that is exposed thro You need to migrate data from the application to a What should you use?
  • A. Azure Data Factory
  • B. Azure Migrate
  • C. Database Migration Assistant
you can migrate data from various data sources to Azure Cosmos DB using different tools and methods. The choice of the migration tool depends on factors such as the data source, the Azure Cosmos DB API, the size of data, and the expected migration duration1. Some of the common migration tools are:
Azure Cosmos DB Data Migration tool: This is an open source tool that can import data to Azure Cosmos DB from sources such as JSON files, MongoDB, SQL Server, CSV files, and Azure Cosmos DB collections. This tool supports the SQL API and the Table API of Azure Cosmos DB2.
Azure Data Factory: This is a cloud-based data integration service that can copy data from various sources to Azure Cosmos DB using connectors. This tool supports the SQL API, MongoDB API, Cassandra API, Gremlin API, and Table API of Azure Cosmos DB3.
Azure Cosmos DB live data migrator: This is a command-line tool that can migrate data from one Azure Cosmos DB container to another container within the same or different account. This tool supports live migration with minimal downtime and works with any Azure Cosmos DB API4.
For your scenario, if you want to migrate data from a third-party application that is exposed through an OData endpoint to a container in Azure Cosmos DB for NoSQL, you should use Azure Data Factory. Azure Data Factory has an OData connector that can read data from an OData source and write it to an Azure Cosmos DB sink using the SQL API5. You can create a copy activity in Azure Data Factory that specifies the OData source and the Azure Cosmos DB sink, and run it on demand or on a schedule.
NEW QUESTION # 103
A good learning platform should not only have abundant learning resources, but the most intrinsic things are very important, and the most intuitive things to users are also indispensable. The DP-420 test material is professional editorial team, each test product layout and content of proofreading are conducted by experienced professionals who have many years of rich teaching experiences, so by the editor of fine typesetting and strict check, the latest DP-420 exam torrent is presented to each user's page is refreshing, but also ensures the accuracy of all kinds of learning materials is extremely high. Imagine, if you're using a DP-420 practice materials, always appear this or that grammar, spelling errors, such as this will not only greatly affect your mood, but also restricted your learning efficiency. Therefore, good typesetting is essential for a product, especially education products, and the DP-420 test material can avoid these risks very well.
DP-420 Study Group: https://www.vcetorrent.com/DP-420-valid-vce-torrent.html
Our DP-420 practice materials are like guns in your battle, You have no need to put off your party & travel because of preparing of your Microsoft DP-420 exams, Our comprehensive and cost-effective solution includes regularly updated Microsoft DP-420 Exam Questions, available in a convenient PDF format that can be downloaded on any device, including PC, laptop, mac, tablet, and smartphone, Microsoft DP-420 Study Center The most popular one is Paying instantly through PayPal and Western Union.
He manages the documentation teams supporting Microsoft System Center DP-420 Configuration Manager and Microsoft Intune, Career Changes There is one certainty in life we can all depend on: Change.
DP-420 Study Center 100% Pass-Rate Questions Pool Only at VCETorrentOur DP-420 practice materials are like guns in your battle, You have no need to put off your party & travel because of preparing of your Microsoft DP-420 exams.
Our comprehensive and cost-effective solution includes regularly updated Microsoft DP-420 Exam Questions, available in a convenient PDF format that can be downloaded on any device, including PC, laptop, mac, tablet, and smartphone.
The most popular one is Paying instantly through PayPal and Western Union, So you can safely use our Microsoft DP-420 exam review.
Posted at 2/4/2026 22:09:28        Only Author  2#
After reading this article, I feel I have grown a lot. The Latest MC-101 practice questions content is of great value, and it's completely free.
Posted at 2/14/2026 07:54:37        Only Author  3#
This article is absolutely enlightening, thank you for sharing! Wishing you the best of luck! Free Pass 300-610 test materials for everyone!
