1z0-076 Dumps Discount & 1z0-076 Vce Free
Posted at 1/28/2026 16:23:41
2026 Latest Actual4Cert 1z0-076 PDF Dumps and 1z0-076 Exam Engine Free Share: https://drive.google.com/open?id=16dbu1mHzOVK7_YdjPDz39qXufRUtVaOm
You will stand at a higher starting point than others if you buy our 1z0-076 exam braindumps. Why are 1z0-076 practice questions worth your choice? I hope you can spend a little time reading the following content on the website, I will tell you some of the advantages of our 1z0-076 Study Materials. Firstly, our pass rate for 1z0-076 training guide is unmatched high as 98% to 100%. Secondly, we have been in this career for years and became a famous brand.
Oracle 1z0-076 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
| | Topic 2 | - Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
| | Topic 3 | - Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
| | Topic 4 | - Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
| | Topic 6 | - Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
| | Topic 7 | - Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
| | Topic 9 | - Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
| | Topic 10 | - Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
Actual4Cert Offers Valid and Real 1z0-076 Oracle Database 19c: Data Guard Administration Exam QuestionsOf course, 1z0-076 simulating exam are guaranteed to be comprehensive while also ensuring the focus. We believe you have used a lot of 1z0-076 learning materials, so we are sure that you can feel the special features of 1z0-076 training questions. The most efficient our 1z0-076 Study Materials just want to help you pass the exam more smoothly. For our technicals are checking the changes of the questions and answers everyday to keep them the latest and valid ones.
Oracle Database 19c: Data Guard Administration Sample Questions (Q104-Q109):NEW QUESTION # 104
Which three are true about using RMAN in a Data Guard environment?
- A. Backups of archived redo logs taken on a physical standby are interchangeable with a primary.
- B. Backups of data files taken on a physical standby are interchangeable with a primary.
- C. A recovery catalog is required when RMAN is used to take backups from a physical standby database if you plan to recover the primary using those backups.
- D. A recovery catalog is required when RMAN is used to take backups from a logical standby database in a Data Guard configuration if you plan to recover the primary using those backups.
- E. Backups of control files taken on a physical standby are not interchangeable with a primary.
Answer: A,B,E
NEW QUESTION # 105
Which three Data Guard monitoring activities may be performed using Enterprise Manager Cloud Control?
- A. You can check if redo apply needs to be tuned.
- B. You can monitor the redo apply rate on a snapshot standby database.
- C. You can set a critical threshold on the redo generation rate metric for a primary database.
- D. You can monitor the redo apply rate on a logical standby database.
- E. You can set a warning threshold on the redo generation rate metric for a physical standby database.
- F. You can check the potential data loss in the event of a disaster.
Answer: C,D,F
Enterprise Manager Cloud Control offers comprehensive monitoring capabilities for Oracle Data Guard environments. It enables monitoring the rate at which redo is being applied on a logical standby database (A), which is crucial for ensuring that the standby database is keeping up with the changes from the primary. It also allows setting thresholds on performance metrics, such as the redo generation rate on the primary database (B), to alert administrators when values exceed critical or warning thresholds. Additionally, it provides the capability to estimate the potential data loss in the event of a disaster (E), helping in disaster recovery planning and ensuring business continuity.
References:Oracle Enterprise Manager Cloud Control documentation provides extensive information on its monitoring features for Oracle Data Guard, including setting thresholds, estimating potential data loss, and tracking redo apply rates.
NEW QUESTION # 106
Examine this validate command:
DGMGRL> VALIDATE DATABASE VERBOSE "<database name>";
Which THREE statements are TRUE?
- A. The command performs a comprehensive set of database checks prior to a role change.
- B. The command can be used for a logical standby database.
- C. The command performs a comparison of SPFILE entries between the primary database and a specified standby database.
- D. The command performs network connectivity checks between members of a broker configuration.
- E. The command uses information available in various Oracle Data Guard views as well as the Automatic Diagnostic Repository.
Answer: A,B,D
The command performs a comprehensive set of database checks prior to a role change (A): The VALIDATE DATABASE command in Data Guard Manager (DGMGRL) is designed to perform an exhaustive check of a specified database's readiness for a role change, such as a switchover or failover.
The command performs network connectivity checks between members of a broker configuration (C): One of the checks includes verifying that the necessary network connectivity exists between the databases in a Data Guard Broker configuration.
The command can be used for a logical standby database (D): The VALIDATE DATABASE command is versatile and can be used for both physical and logical standby databases to ensure their readiness for role changes.
Oracle Data Guard Broker documentation
Oracle Data Guard Concepts and Administration Guide
NEW QUESTION # 107
Which two are prerequisites for configuring flashback database for Oracle 19c databases, in a Data Guard environment?
- A. The data guard broker must be used.
- B. A far sync instance must be configured to flash back a standby when the primary has been flashed back.
- C. A fast recovery area must be configured.
- D. The database must be in ARCHTVELOG mode.
- E. The Data Guard real-time apply feature must be enabled.
* A fast recovery area must be configured (B): Flashback Database requires a fast recovery area to be set up because flashback logs are stored there. The fast recovery area is a unified storage location for all recovery-related files and activities.
* The database must be in ARCHIVELOG mode (C): Flashback Database operation relies on the ability to archive redo logs. Therefore, the database must be running in ARCHIVELOG mode for Flashback Database to be enabled.
* Oracle Database Backup and Recovery User's Guide
* Oracle Data Guard Concepts and Administration Guide
NEW QUESTION # 108
Examine the Data Guard configuration:
DGMGRL> show configuration;
Configuration - Animals
Protection Mode: Max Availability
Databases:
dogs - Primary database sheep
- Physical standby database cats
Fast-Start Failover: DISABLED
Configuration Status: SUCCESS
An attempt to enable fast-start failover raises an error:
DGMGRL> enable fast_start failover;
Error: ORA-16693: requirements not met for enabling fast-start failover Failed.
Identify three possible reasons for this error.
- A. The fastStartFailoverTarget property is not set on Dogs.
- B. The LogxptModr property is set to async on Sheep while Sheep is the target standby database.
- C. The LogXptMode property is set to fastsync on Dogs.
- D. The LogXptMode property is set to FASTSYNC on Cats while Sheep is the target standby database.
- E. The LogXptMode property is set to async on Dogs.
Answer: A,B,E
When enabling fast-start failover, certain conditions must be met:
The fastStartFailoverTarget property is not set on Dogs (A): The primary database (Dogs) needs to have a fast-start failover target configured for the operation to succeed.
The LogXptMode property is set to ASYNC on Sheep while Sheep is the target standby database (B): Fast-start failover requires synchronous redo transport (SYNC or FASTSYNC) to ensure zero data loss, which is a prerequisite for enabling the feature.
The LogXptMode property is set to ASYNC on Dogs (D): Similar to the previous point, the primary database must be configured to use synchronous redo transport for the fast-start failover to be possible.
Oracle Database Error Messages Guide
NEW QUESTION # 109
If you want to be familiar with the real test and grasp the rhythm in the real test, you can choose our 1z0-076 exam test engine to practice. Both our soft test engine and app test engine provide the exam scene simulation functions. You set timed 1z0-076 test and practice again and again. Besides, 1z0-076 exam test engine cover most valid test questions so that it can guide you and help you have a proficient & valid preparation process.
1z0-076 Vce Free: https://www.actual4cert.com/1z0-076-real-questions.html
- Fantastic 1z0-076 Dumps Discount | Easy To Study and Pass Exam at first attempt - The Best Oracle Oracle Database 19c: Data Guard Administration 🕛 Easily obtain free download of 《 1z0-076 》 by searching on ➤ [url]www.examdiscuss.com ⮘ 💮Valid 1z0-076 Test Discount[/url]
- 1z0-076 Dumps Discount - Free PDF 2026 Realistic Oracle Oracle Database 19c: Data Guard Administration Vce Free 🌿 Search for ▛ 1z0-076 ▟ and easily obtain a free download on { [url]www.pdfvce.com } 🧟Book 1z0-076 Free[/url]
- Exam 1z0-076 Pass Guide 🧾 Reliable 1z0-076 Test Objectives 🏫 Valid Test 1z0-076 Bootcamp 🎈 《 [url]www.practicevce.com 》 is best website to obtain ➠ 1z0-076 🠰 for free download 🥧Reliable 1z0-076 Exam Blueprint[/url]
- 1z0-076 Actual Dump 🖌 1z0-076 Exam Learning 🍣 1z0-076 Exam Learning 🎃 Open 《 [url]www.pdfvce.com 》 and search for ▷ 1z0-076 ◁ to download exam materials for free 💭Test 1z0-076 Prep[/url]
- Trusted Oracle 1z0-076: Oracle Database 19c: Data Guard Administration Dumps Discount - Newest [url]www.examcollectionpass.com 1z0-076 Vce Free 🗽 Search on ⏩ www.examcollectionpass.com ⏪ for ▷ 1z0-076 ◁ to obtain exam materials for free download 🎮Reliable 1z0-076 Exam Blueprint[/url]
- Free PDF Reliable Oracle - 1z0-076 Dumps Discount 🌉 Download 「 1z0-076 」 for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🕟1z0-076 Dumps Vce[/url]
- Valid Test 1z0-076 Bootcamp 🐥 1z0-076 Dumps Vce 🍴 Valid 1z0-076 Test Discount 🚠 Immediately open ➥ [url]www.prepawaypdf.com 🡄 and search for [ 1z0-076 ] to obtain a free download 🏯Exam 1z0-076 Pass Guide[/url]
- Book 1z0-076 Free ☑ 1z0-076 Actual Dump 🅾 Test 1z0-076 Prep 🔖 Search for { 1z0-076 } and download it for free immediately on ▛ [url]www.pdfvce.com ▟ 🔨Valid Test 1z0-076 Bootcamp[/url]
- Get Authoritative 1z0-076 Dumps Discount and Useful 1z0-076 Vce Free 🖍 ➤ [url]www.validtorrent.com ⮘ is best website to obtain 【 1z0-076 】 for free download 🕎1z0-076 Actual Dump[/url]
- Free Download 1z0-076 Dumps Discount - Leader in Qualification Exams - Efficient 1z0-076: Oracle Database 19c: Data Guard Administration 💆 Search for “ 1z0-076 ” and download it for free immediately on 【 [url]www.pdfvce.com 】 🍱1z0-076 Online Bootcamps[/url]
- 1z0-076 Dumps Vce 〰 1z0-076 PDF Guide 🌎 Valid 1z0-076 Test Discount 👵 Open ▷ [url]www.verifieddumps.com ◁ enter ➡ 1z0-076 ️⬅️ and obtain a free download 🎨New 1z0-076 Exam Experience[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, hhi.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that Actual4Cert 1z0-076 dumps now are free: https://drive.google.com/open?id=16dbu1mHzOVK7_YdjPDz39qXufRUtVaOm
