[General] EAEP2201 Reliable Exam Test - EAEP2201 Test Testking
98
General EAEP2201 Reliable Exam Test - EAEP2201 Test Testking
Posted at 1/28/2026 16:55:18      View153 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamsTorrent EAEP2201 dumps for free: https://drive.google.com/open?id=1O4MdUfSD9decYvih-ExD6TUqAszYRfZH
If you want a relevant and precise content that imparts you the most updated, relevant and practical knowledge on all the key topics of the EAEP2201 Certification Exam, no other EAEP2201study material meets these demands so perfectly as does ExamsTorrents study guides. The EAEP2201 questions and answers in these guides have been prepared by the best professionals who have deep exposure of the certification exams and the exam takers needs. The result is that ExamsTorrent's study guides are liked by so many ambitious professionals who give them first priority for their exams. The astonishing success rate of ExamsTorrent's clients is enough to prove the quality and benefit of the study questions of ExamsTorrent.
Esri EAEP2201 Certification is best suited for professionals who work as GIS administrators, consultants, and other enterprise managers who administer, operate, and implement enterprise-level Esri software solutions. The benefits of being an Esri Certified Enterprise Administration Professional are numerous. Firstly, Esri Certification validates that individuals have the required knowledge, skill set, and competency necessary to administer, manage, and implement Esri software solutions. Secondly, the certification enhances career advancement opportunities and professional credibility, showcasing technical proficiency and expertise in the industry.
EAEP2201 Test Testking | Test EAEP2201 Passing ScoreAlthough it is not an easy thing for most people to pass the exam, therefore, they can provide you with efficient and convenience learning platform, so that you can obtain as many certificates as possible in the shortest time. We provide all candidates with EAEP2201 test torrent that is compiled by experts who have good knowledge of exam, and they are very experience in compile study materials. Not only that, our team checks the update every day, in order to keep the latest information of EAEP2201 latest question. Once we have latest version, we will send it to your mailbox as soon as possible.
Esri Enterprise Administration Professional 2201 Sample Questions (Q13-Q18):NEW QUESTION # 13
A GIS administrator is publishing a feature service. All 2,400 features in the dataset must be able to be returned from a single request to the service.
Which action should the administrator perform?
  • A. Use service defaults for publishing
  • B. Adjust pooling to handle the request
  • C. Enable cached drawing mode
  • D. Increase the max record count
By default, feature services limit the number of records returned in a single request (usually set to
1,000). To allow all 2,400 features to be returned in one call, the administrator needs to increase the
"Maximum number of records returned by the server" (maxRecordCount) setting during or after publishing.
From the ArcGIS Server documentation:
"The maxRecordCount property defines the number of records returned by the server in a single request. To return all features, this value must be increased accordingly."
* Option A (adjust pooling) relates to concurrency and scalability, not data retrieval limits.
* Option C would keep the default setting of 1,000, which would not meet the requirement.
* Option D relates to visual performance, not record retrieval.
Reference:ArcGIS Server - Feature Service Settings and Tuning for Performance
NEW QUESTION # 14
ArcGIS Server is installed with its Web Adaptor on the same server. The configuration is as follows:
* ArcGIS Server is federated with Portal for ArcGIS
* Portal is set up to use Integrated Windows Authentication
* The environment was set up using a domain certificate
* The attempted login account is a Windows account with admin privileges A GIS administrator tries to connect to ArcGIS Server Manager through ArcGIS Web Adaptor but the connection fails. Why did the connection fail?
  • A. The certificate must come from a valid Certificate Authority and not a Domain Certificate Authority
  • B. The Web Adaptor was not set to allow administrative access to the server
  • C. The connection must be made with an internal admin account and not a Windows account
NEW QUESTION # 15
An ArcGIS Pro user receives the following error when trying to publish to ArcGIS Enterprise:
"Unable to publish to ArcGIS Server, error 001369: failed to create service" The ArcGIS Server logs reveal:
* Failed to create service
* Internal server error
* Unable to instantiate class for XML schema type
* Invalid XML registry file
* 390 ArcSOC processes running
* Server uses only half of available RAM
  • A. Use more dedicated instances instead of shared
  • B. Scale up the ArcGIS Server machine resources
  • C. Increase the non-interactive desktop heap size
This issue is consistent withdesktop heap exhaustion, especially when a high number ofArcSOC processes (e.g., 390)are running on Windows. Desktop heap is a limited memory resource used for GUI and system object management. When it runs out, services can fail to start and produce XML-related errors.
Increasing thenon-interactive desktop heap sizein the Windows registry resolves this.
From Esri documentation:
"If the Windows desktop heap size is too low, ArcGIS Server may be unable to create new processes (ArcSOC), causing service failures and related internal server errors."
* OptionBis a generic fix and won't address the specific heap exhaustion issue.
* OptionCdoesn't help if the root issue is OS-level heap size limits.
Reference:ArcGIS Enterprise -ArcSOC process limits and Windows desktop heap size
NEW QUESTION # 16
Users are reportingservice timeouts and performance issues. The administrator notices thatonly the minimum number of instances are runningduring performance spikes. They want tomonitor usage trends before adjusting instance settings.
  • A. Monitor Task Manager on each ArcGIS Server machine
  • B. Create a report of server statistics in ArcGIS Server Manager
  • C. Change the log level to Debug in ArcGIS Server Manager
  • D. Enable Windows Performance Monitor
To monitorusage patterns, including the number of requests and instances in use, ArcGIS Server provides statistics reportsin Server Manager. These reports showpeak and average service usage, helping administrators decide how toscale service instance counts.
From ArcGIS Server documentation:
"Use the ArcGIS Server Manager statistics reporting tool to monitor service usage trends over time. This data helps inform adjustments to instance counts."
* OptionAgives only raw system metrics, not service-specific insights.
* OptionB(Debug logs) causes overhead and isn't appropriate for monitoring trends.
Reference:ArcGIS Server -Monitoring and Reporting Service Usage Statistics
NEW QUESTION # 17
A GIS administrator has a group of users who share maintenance responsibilities for a critical application.
The administrator needs to allowall users to editthe application without transferring ownership.
Which option should the administrator use?
  • A. A public group
  • B. A shared update group
  • C. An administrative group
  • D. A collaboration group
Ashared update groupallows group members toediteach other's items without needing to transfer ownership. This is ideal for collaborative editing and shared responsibility for applications, maps, or dashboards.
"Shared update groups allow multiple members to update items shared with the group, even if they do not own the items."
* OptionBdoesn't exist as a group type in ArcGIS Enterprise.
* OptionCallows viewing, butnot editingothers' content.
* OptionDapplies to distributed collaboration, not shared editing.
Reference:ArcGIS Enterprise -Group Settings for Collaborative Management
NEW QUESTION # 18
The aim of ExamsTorrent is to support you in passing the Esri EAEP2201 certification exam. ExamsTorrent present actual Esri EAEP2201 practice test questions for you. The world's skilled professionals share their best knowledge with ExamsTorrent and create this set of actual Enterprise Administration Professional 2201 EAEP2201
EAEP2201 Test Testking: https://www.examstorrent.com/EAEP2201-exam-dumps-torrent.html
BTW, DOWNLOAD part of ExamsTorrent EAEP2201 dumps from Cloud Storage: https://drive.google.com/open?id=1O4MdUfSD9decYvih-ExD6TUqAszYRfZH
Posted at 2/6/2026 22:56:02        Only Author  2#
The article provided me with immense value. Wishing you success! Here are the free AP-219 reliable exam duration test materials.
