[General] CPRE-FL_Syll_3.0ģM}CPRE-FL_Syll_3.0ꥢѥ
83
General CPRE-FL_Syll_3.0ģM}CPRE-FL_Syll_3.0ꥢѥ
Posted at 1/28/2026 17:38:23      View178 | Replies1        Print      Only Author   [Copy Link] 1#
ȡФǤʤISQI``CPRE-FL_Syll_3.0^ȡäޤǤ̕rgԇY˺ϸǤ褦ˤȿƤޤ CPRE-FL_Syll_3.0ԇYΥץ饯ƥxkȡShikenPASSԇYΜʂ20〜30rgޤ CPRE-FL_Syll_3.0ѧ̲ĤԇYθҪCPRE-FL_Syll_3.0ɤ||ܽӤvBƤ뤿ᡢΤ褦ʶ̤rgǤ٤ƤΥƥĤKˤǤ뤫ɤ򌤤ͤϤޤ ¤λĤIREB Certified Professional for Requirements Engineering. Foundation Level֪RvBƤޤ CPRE-FL_Syll_3.0ԇY}˺ϸ񤷤ϤΤߡCPRE-FL_Syll_3.0ԇY˺ϸ񤷤ޤ
ISQI CPRE-FL_SILL_3.0ԇYϡҪ󥸥˥󥰤ηҰΌTҤˤȤäƲǷJ^ǤJϹHĤJR졢Ҫ󥸥˥󥰤vBڤȥԥå򥫥Щ`ƤޤϡTҤηҰ֪Rȥg^ꥢΙC򏊻냞줿Ǥ
ISQI CPRE-FL_SILL_3.0JԇYϡҪ󥸥˥󥰤ηҰǺaߤ֪Rȥy褦OӋƤޤJϡInternational Software Quality InstituteISQIˤä뤵졢ĤJRƤޤԇYϡIREBHҪ󥸥˥ίTᣩХ˻ŤƤޤϡҪ󥸥˥󥰤ΘI˜ʤҊʤƤޤ
ISQI CPRE-FL_SILL_3.0Ҫ󥸥˥󥰤ΤIREBJTҡA٥룩JԇYϡҪ󥸥˥󥰤Υ򏊻T򤱤OӋ줿ĤJ줿JǤJϡФΥեȥƷ|J^δ֥ץХ`ǤInternational Software Quality InstituteISQIˤäṩƤޤ CPRE-FL_SILL_3.0ԇYϡҪ󥸥˥󥰤λĤ֪RƥȤ褦OӋƤꡢηҰ¤TҤmƤޤ
ISQI CPRE-FL_Syll_3.0ꥢѥCPRE-FL_Syll_3.0ƥ21o󻯕rμεˤĤơˡϤΕrmǤ褦ˤĤԷ֤֪R򉈼ӤƤƤޤޤäʤǤITINˤĤԤСISQICPRE-FL_Syll_3.0JԇYITINǷȤǤʤJ^Ǥ顢ԇY˺ϸ񤹤ΤϤȤƤҪǤԇYyǤ顢ԇY˺ϸ񤹤йHĤJ^졢ܤ뤳ȤǤޤȡδȸ߽o餦¤֤Ƥ褦ˤʤޤShikenPASSȤȤmǤITJ^ȥ`˥YϤ֤äƤޤ顢ShikenPASSä餢ʤäڴƤgF뤳ȤǤ褦ˤʤޤѩ`Ȥκϸʤ^ޤ顢ISQICPRE-FL_Syll_3.0JԇYܤYΤʤϤޤΤäƤΤǤ٤ShikenPASSȤȤ򥯥åƤ
ISQI IREB Certified Professional for Requirements Engineering. Foundation Level J CPRE-FL_Syll_3.0 ԇY} (Q82-Q87):| # 82
Which of the following requirements are NOT in accordance with the template "[] []"? (Select 2 answers.)
  • A. Within 2 seconds, the system shall notify the administrator upon receiving a critical alert.
  • B. If the user selects 'Print' the printer shall generate a PDF file in less than 10 seconds.
  • C. If the payment fails, the system shall display within 1 second.
  • D. When the temperature exceeds 80C, the control unit shall shut down the heater for 10 minutes.
  • E. If the user logs in, the system shall display the user's profile within 2 seconds.
⣺AC
h
The phrase template specifies that an optional condition comes first, then subject, action, objects and finally an optional restriction. Options A-C respect this order and provide all elements: condition ("If/When ..."), subject ("system", "control unit", "printer"), action, object and a final restriction. In D the time restriction is placed at the beginning and the condition ("upon receiving a critical alert") is embedded incorrectly, violating the template's structure. In E, the object of the action ("what" the system shall display) is missing, so the sentence is incomplete. Thus, D and E do not comply.
| # 83
You are project manager for a system that your company is creating for the military in the field of logistics. A requirements engineer has been assigned to your project but does not have all the desirable skills for this role.
In respect to the attributes of the requirements engineer, which of the following statements implies the greatest risk for the requirements engineering? (1 Point)
  • A. The requirements engineer does not have detailed knowledge of the military norms and standards that should be applied to the system.
  • B. The requirements engineer is not familiar with the military ranks and so cannot deal adequately with the hierarchical sensitivities.
  • C. The requirements engineer has no solid project management training.
  • D. The requirements engineer is introverted and has no knowledge of requirements elicitation and documentation.
⣺D
| # 84
According to the Kano model, a feature that customers specifically request is called a:
  • A. Critical
  • B. Must-have
  • C. Satisfier
  • D. Delighter
⣺C
h
| # 85
The level of detail of requirements can be lower when:
  • A. The availability of feedback from stakeholders is high.
  • B. The developing team is less familiar with the context.
  • C. Shared understanding of the problem is low.
  • D. Freedom given to developers is low.
⣺A
h
CPRE notes that required detail depends on several factors. When teams know little about the domain, when shared understanding is weak, or when developers must be tightly constrained, more detailed and formal requirements are needed to avoid misinterpretation. Conversely, if stakeholders are highly available and can provide frequent feedback-e.g., in agile projects with close collaboration-requirements can initially be less detailed because uncertainties will be clarified iteratively. Thus, higher stakeholder feedback allows a lower initial detail level, making option D correct.
| # 86
Choose the correct option regarding elicitation techniques.
  • A. In system archaeology, requirements are extracted from existing systems by analyzing their documentation or implementation.
  • B. Reuse of requirements is not an elicitation technique.
  • C. All the other options are wrong.
  • D. During a brainstorm, quality prevails over quantity.
⣺A
| # 87
˽ISQIṩCPRE-FL_Syll_3.0ȥȤϡՓȌg¤_k˻ŤUY֤ČTҤˤäƥѥ뤵Ƥ뤿ᡢdzˁޤ uƷُ뤹ǰˡޤuƷԇƤ ShikenPASSCPRE-FL_Syll_3.0ԇYκϸĤǤʤrgȥͥ륮`򹝼sǤ뤿ᡢCPRE-FL_Syll_3.0ԇYʂُ뤹ޤ ͘Μ㤬˽Υ`ӥĿĤǤCPRE-FL_Syll_3.0ȥȤ򺆅gIREB Certified Professional for Requirements Engineering. Foundation Levelُ뤷Ƥ
CPRE-FL_Syll_3.0ꥢѥ: https://www.shikenpass.com/CPRE-FL_Syll_3.0-shiken.html
Posted at 3/4/2026 16:48:25        Only Author  2#
Your article has truly left me speechless, thank you for sharing! I used the ZDTA reliable study questions free to earn a promotion and salary boost. Now, its free for everyone. Best of luck on your career journey!
