[General] Reliable CCFH-202b Exam Bootcamp|Easily Pass CrowdStrike Certified Falcon Hunter
97
【General】 Reliable CCFH-202b Exam Bootcamp|Easily Pass CrowdStrike Certified Falcon Hunter
Posted at 1/28/2026 19:10:22      View:123 | Replies:0        Print      Only Author   [Copy Link] 1#
About the dynamic change of our CCFH-202b guide quiz, they will send the updates to your mailbox according to the trend of the exam. Besides, we understand you may encounter many problems such as payment or downloading CCFH-202b practice materials and so on, contact with us, we will be there. Our employees are diligent to deal with your need and willing to do their part 24/7. They always treat customers with courtesy and respect to satisfy your need on our CCFH-202b Exam Dumps.
Actually, most people do not like learning the boring knowledge. It is hard to understand if our brain rejects taking the initiative. Now, our company has researched the CCFH-202b study materials, a kind of high efficient learning tool. Firstly, we have deleted all irrelevant knowledge, which decreases your learning pressure. Then, the difficult questions of the CCFH-202b Study Materials will have vivid explanations. So you will have a better understanding after you carefully see the explanations.
Why Do You Need to Trust on DumpsTests CrowdStrike CCFH-202b Exam Questions?To stay updated and competitive in the market you have to upgrade your skills and knowledge level. Fortunately, with the CrowdStrike Certified Falcon Hunter (CCFH-202b) certification exam you can do this job easily and quickly. To do this you just need to pass the CCFH-202b certification exam. The CrowdStrike Certified Falcon Hunter (CCFH-202b) certification exam is the top-rated and career advancement CrowdStrike CCFH-202b Certification in the market. This CrowdStrike certification is a valuable credential that is designed to validate your expertise all over the world. After successfully competition of CCFH-202b exam you can gain several personal and professional benefits.
CrowdStrike Certified Falcon Hunter Sample Questions (Q49-Q54):NEW QUESTION # 49
When exporting the results of the following event search, what data is saved in the exported file (assuming Verbose Mode)? event_simpleName=*Written | stats count by ComputerName
  • A. All events in the Events tab
  • B. No data Results can only be exported when the "table" command is used
  • C. The text of the query
  • D. The results of the Statistics tab
When exporting the results of an event search, the data that is saved in the exported file depends on the mode and the tab that is selected. In this case, the mode is Verbose and the tab is Statistics, as indicated by the stats command. Therefore, the data that is saved in the exported file is the results of the Statistics tab, which shows the count of events by ComputerName. The text of the query, all events in the Events tab, and no data are not correct answers.
NEW QUESTION # 50
Which of the following is an example of a Falcon threat hunting lead?
  • A. An external report describing a unique 5 character file extension for ransomware encrypted files
  • B. Security appliance logs showing potentially bad traffic to an unknown external IP address
  • C. A routine threat hunt query showing process executions of single letter filename (e.g., a.exe) from temporary directories
  • D. A help desk ticket for a user clicking on a link in an email causing their machine to become unresponsive and have high CPU usage
A Falcon threat hunting lead is a piece of information that can be used to initiate or guide a threat hunting activity within the Falcon platform. A routine threat hunt query showing process executions of single letter filename (e.g., a.exe) from temporary directories is an example of a Falcon threat hunting lead, as it can indicate potential malicious activity that can be further investigated using Falcon data and features. Security appliance logs, help desk tickets, and external reports are not examples of Falcon threat hunting leads, as they are not directly related to the Falcon platform or data.
NEW QUESTION # 51
What kind of activity does a User Search help you investigate?
  • A. A list of process activity executed by the specified user account
  • B. A count of failed user logon activity
  • C. A history of Falcon Ul logon activity
  • D. A list of DNS queries by the specified user account
User Search is an Investigate tool that helps you investigate a list of process activity executed by the specified user account. It shows information such as process name, command line, parent process name, parent command line, etc. for each process that was executed by the user account on any host in your environment. It does not show a history of Falcon UI logon activity, a count of failed user logon activity, or a list of DNS queries by the specified user account.
NEW QUESTION # 52
Which of the following is a suspicious process behavior?
  • A. Non-network processes (eg, notepad exe) making an outbound network connection
  • B. PowerShell running an execution policy of RemoteSigned
  • C. PowerShell launching a PowerShell script
  • D. An Internet browser (eg, Internet Explorer) performing multiple DNS requests
Non-network processes are processes that are not expected to communicate over the network, such as notepad.exe. If they make an outbound network connection, it could indicate that they are compromised or maliciously used by an adversary. PowerShell running an execution policy of RemoteSigned is a default setting that allows local scripts to run without digital signatures. An Internet browser performing multiple DNS requests is a normal behavior for web browsing. PowerShell launching a PowerShell script is also a common behavior for legitimate tasks.
NEW QUESTION # 53
In the MITRE ATT&CK Framework (version 11 - the newest version released in April 2022), which of the following pair of tactics is not in the Enterprise: Windows matrix?
  • A. Persistence and Execution
  • B. Privilege Escalation and Initial Access
  • C. Reconnaissance and Resource Development
  • D. Impact and Collection
Reconnaissance and Resource Development are two tactics that are not in the Enterprise: Windows matrix of the MITRE ATT&CK Framework (version 11). These two tactics are part of the PRE-ATT&CK matrix, which covers the actions that adversaries take before compromising a target. The Enterprise: Windows matrix covers the actions that adversaries take after gaining initial access to a Windows system. Persistence, Execution, Impact, Collection, Privilege Escalation, and Initial Access are all tactics that are in the Enterprise: Windows matrix.
NEW QUESTION # 54
We are going to promise that we will have a lasting and sustainable cooperation with customers who want to buy the CCFH-202b study materials from our company. We can make sure that our experts and professors will try their best to update the study materials in order to help our customers to gain the newest and most important information about the CCFH-202b Exam. If you decide to buy our study materials, you will never miss any important information. In addition, we can promise the updating system is free for you.
Valid CCFH-202b Test Blueprint: https://www.dumpstests.com/CCFH-202b-latest-test-dumps.html
Our experts also collect with the newest contents of CCFH-202b study guide and have been researching where the exam trend is heading and what it really want to examine you, So we try our best to extend our dumps, and our DumpsTests Valid CCFH-202b Test Blueprint elite comprehensively analyze the dumps so that you are easy to use it, CrowdStrike Reliable CCFH-202b Exam Bootcamp The relevant products are neatly arranged and have through explanations.
Show before and after, But the actual exam test CCFH-202b is an effective way to help us memorize, Our experts also collect with the newest contents of CCFH-202b study guide and have been researching where the exam trend is heading and what it really want to examine you.
Real CCFH-202b Exam Questions in Three Easy FormatsSo we try our best to extend our dumps, and our DumpsTests elite comprehensively Valid CCFH-202b Test Blueprint analyze the dumps so that you are easy to use it, The relevant products are neatly arranged and have through explanations.
As we all know, CCFH-202b certificates are an essential part of one's resume, which can make your resume more prominent than others, making it easier for you to get the job you want.
If you can't wait getting the certificate, you are supposed to choose our CCFH-202b study guide.
