[General] Lab Mule-Dev-301 Questions - Mule-Dev-301 High Quality
71
【General】 Lab Mule-Dev-301 Questions - Mule-Dev-301 High Quality
Posted at 1/28/2026 19:46:26      View:141 | Replies:1        Print      Only Author   [Copy Link] 1#
There is no doubt they are clear-cut and easy to understand to fulfill your any confusion about the exam. Our Salesforce Certified MuleSoft Developer II exam question is applicable to all kinds of exam candidates who eager to pass the exam. Last but not the least, they help our company develop brand image as well as help a great deal of exam candidates pass the exam with passing rate over 98 percent of our Mule-Dev-301 real exam materials. Considering many exam candidates are in a state of anguished mood to prepare for the Salesforce Certified MuleSoft Developer II exam, our company made three versions of Mule-Dev-301 Real Exam materials to offer help. All these variants due to our customer-oriented tenets. As a responsible company over ten years, we are trustworthy. In the competitive economy, this company cannot remain in the business for long.
As most of the people tend to use express delivery to save time, our Mule-Dev-301 preparation exam will be sent out within 5-10 minutes after purchasing. As long as you pay at our platform, we will deliver the relevant exam materials to your mailbox within the given time. Our company attaches great importance to overall services, if there is any problem about the delivery of Mule-Dev-301 Exam Materials: Salesforce Certified MuleSoft Developer II, please let us know, a message or an email will be available.
Mule-Dev-301 High Quality, Mule-Dev-301 Exam FeesThe Salesforce Mule-Dev-301 certification is one of the top-rated career advancement certifications in the market. This Salesforce Certified MuleSoft Developer II (Mule-Dev-301) certification exam has been inspiring candidates since its beginning. Over this long time period, thousands of Mule-Dev-301 exam candidates have passed their Salesforce Certified MuleSoft Developer II (Mule-Dev-301) certification exam and now they are doing jobs in the world's top brands. The ActualTorrent Mule-Dev-301 Dumps will provide you with everything that you need to learn, prepare and pass the challenging Network Security Specialist Mule-Dev-301 exam with flying colors. You must try ActualTorrent Mule-Dev-301 exam questions today.
Salesforce Certified MuleSoft Developer II Sample Questions (Q16-Q21):NEW QUESTION # 16
A Mule application need to invoice an API hosted by an external system to initiate a process. The external API takes anywhere between one minute and 24 hours to compute its process.
Which implementation should be used to get response data from the external API after it completes processing?
  • A. Use an HTTP Connector to invoke the API and wait for a response
  • B. Use an HTTP Connector inside Async scope to invoice the API and wait for a response
  • C. Use a Scheduler to check for a response every minute
  • D. Expose an HTTP callback API in Mule and register it with the external system
To get response data from the external API after it completes processing, the developer should expose an HTTP callback API in Mule and register it with the external system. This way, the external API can invoke the callback API with the response data when it is ready, instead of making the Mule application wait for a long time or poll for a response repeatedly. Reference: https://docs.mulesoft.com/mule-r ... stener-ref#callback
NEW QUESTION # 17
A Mule application pom.xml configures the Maven Resources plugin to exclude parsing binary files in the project's src/main/resources/certs directory.
Which configuration of this plugin achieves a successful build?
  • A.
  • B.
  • C.
  • D.
To configure the Maven Resources plugin to exclude parsing binary files in the project's src/main/resources/certs directory, option C should be used. This option specifies that any files with .cer or .jks extensions under the certs directory should be excluded from filtering. Filtering is a process of replacing placeholders with actual values in resource files during the build process. Binary files should not be filtered because they may become corrupted or unusable. Reference: https://maven.apache.org/plugins ... xamples/filter.html https://maven.apache.org/plugins ... nclude-exclude.html
NEW QUESTION # 18
When implementing a synchronous API where the event source is an HTTP Listener, a developer needs to return the same correlation ID back to the caller in the HTTP response header.
How can this be achieved?
  • A. Enable the CorrelationID checkbox in the HTTP Listener configuration
  • B. Configure a custom correlation policy
  • C. Enable the auto-generate CorrelationID option when scaffolding the flow
  • D. NO action is needed as the correlation ID is returned to the caller in the response header by default
When implementing a synchronous API where the event source is an HTTP Listener, Mule automatically propagates some message attributes between flows via outbound and inbound properties. One of these attributes is correlation ID, which is returned to the caller in the response header by default as MULE_CORRELATION_ID. Reference: https://docs.mulesoft.com/mule-r ... #message-attributes
NEW QUESTION # 19
A Mule application deployed to a standardalone Mule runtime uses VM queues to publish messages to be consumed asynchronously by another flow.
In the case of a system failure, what will happen to in-flight messages in the VM queues that have been consumed?
  • A. For nay type of queue, the message will be processed after the system comes online
  • B. For any type of queue, the message will be lost
  • C. For transient queues, the message will be processed after the system comes online
  • D. For persistent queues, the message will be processed after the system comes online
In case of a system failure, in-flight messages in persistent VM queues that have been consumed will be processed after the system comes online. This is because persistent VM queues store messages on disk and guarantee delivery even if there is a system crash or restart. Therefore, any in-flight messages that have been consumed but not processed will be recovered from disk and processed when the system is back online. Reference: https://docs.mulesoft.com/mule-r ... r#persistent-queues
NEW QUESTION # 20
Which statement is true when working with correlation IDS?
  • A. The Anypoint MQ Connector automatically propagates correlation IDS
  • B. The HTTP Listener generates correlation IDS unless a correlation ID is received in the HTTP request
  • C. The HTTP Listener regenerates correlation IDs regardless of the HTTP request
  • D. The VM Connector does not automatically propagate correction IDs
When working with correlation IDs, the HTTP Listener generates correlation IDs unless a correlation ID is received in the HTTP request. In that case, it propagates the received correlation ID throughout the flow execution. Correlation IDs are used to track events across different flows or applications. Reference: https://docs.mulesoft.com/mule-r ... #message-attributes
NEW QUESTION # 21
If you have limited budget, and also need complete value package, why not try our ActualTorrent's Mule-Dev-301 exam training materials. It is easy to understand with reasonable price and high accuracy. It's suitable for all kinds of learners. If you choose ActualTorrent' Mule-Dev-301 Exam Training materials, you will get one year free renewable service.
Mule-Dev-301 High Quality: https://www.actualtorrent.com/Mule-Dev-301-questions-answers.html
Whether or not you believe it, there have been a lot of people who have obtained internationally certified certificates through Mule-Dev-301 exam simulation, Salesforce Lab Mule-Dev-301 Questions And once after payment, you are under one-year free newest study guide service, Salesforce Lab Mule-Dev-301 Questions No third party would ever have an access to your account information, Salesforce Lab Mule-Dev-301 Questions 100% SECURE SHOPPING.
Each domain controller maintains a writable copy of Mule-Dev-301 the zone information, which is stored in the Active Directory database, The reason can be quite simple, Whether or not you believe it, there have been a lot of people who have obtained internationally certified certificates through Mule-Dev-301 Exam simulation.
Best Quality Salesforce Mule-Dev-301 Exam QuestionsAnd once after payment, you are under one-year free newest Mule-Dev-301 Exam Fees study guide service, No third party would ever have an access to your account information, 100% SECURE SHOPPING.
The data speak louder than the other words.
Posted at 2/13/2026 19:30:28        Only Author  2#
This article has given me a new understanding of this field, and it’s truly inspiring. The Latest real Mule-Dev-202 test questions test questions are the key to career success—available for free!
