[General] 156-836 Exam Duration - Test 156-836 Centres
112
【General】 156-836 Exam Duration - Test 156-836 Centres
Posted at 1/28/2026 19:47:47      View:127 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New 156-836 dumps are available on Google Drive shared by BraindumpStudy: https://drive.google.com/open?id=1_1PklNUWPY46FQqpzLFQWi0pkHsEv60-
Are you still feeling distressed for expensive learning materials? Are you still struggling with complicated and difficult explanations in textbooks? Do you still hesitate in numerous tutorial materials? 156-836 study guide can help you to solve all these questions. 156-836 certification training is compiled by many experts over many years according to the examination outline of the calendar year and industry trends. With 156-836 Study Guide, you only need to spend 20 to 30 hours practicing to take the exam. In addition, 156-836 certification training has a dedicated expert who updates all data content on a daily basis and sends the updated content to the customer at the first time. Therefore, using 156-836 guide torrent, you don't need to worry about missing any exam focus.
Check Point Certified Maestro Expert - R81 (CCME) is a certification exam that aims to test the skills and expertise of professionals in managing and administering Check Point's Maestro solution. 156-836 Exam is designed for professionals who have already acquired the Check Point Certified Maestro Associate certification and are looking to further enhance their knowledge and skills in this field.
Test 156-836 Centres | 156-836 Exam Cram QuestionsIt will provide you with the CheckPoint 156-836 dumps latest updates until 365 days after purchasing the 156-836 exam questions. Above all, you will obtain these updates entirely free if the CheckPoint 156-836 certification authorities issue fresh updates. BraindumpStudy ensures that you will hold the prestigious CheckPoint 156-836 certificate on the first endeavor if you work consistently, taking help from our remarkable, up-to-date, and competitive CheckPoint 156-836 dumps.
CheckPoint Check Point Certified Maestro Expert - R81 (CCME) Sample Questions (Q61-Q66):NEW QUESTION # 61
The core four manual diagnostic tools include:
asg diag verify, asg perf -v, orch_stat -all, and
  • A. hcp -r all
  • B. cpinfo
  • C. asg stat -v
  • D. asg diag verify
"Asg stat -v" could be a part of the core diagnostic tools, providing valuable statistics and information for manual diagnostics.
References =
*Maestro Expert (CCME) Course - Check Point Software 3
*Check Point Maestro R81.X Administration Guide 1
*Check Point Maestro R81.X Getting Started Guide 2
3: https://www.checkpoint.com/downl ... t-r81.10-course.pdf 1:
https://www.manualslib.com/manua ... estro-R80-20sp.html 2:
https://sc1.checkpoint.com/docum ... gStarted/html_frame
NEW QUESTION # 62
What command can be run to show which SGM is selected to receive traffic?
  • A. dxl calc
  • B. asg calc
  • C. g_tcpdump
  • D. asg monitor
The asg calc command is a tool to show which SGM is selected to receive traffic based on the distribution mode and the packet parameters. It takes the port number, the source IP, the destination IP, and optionally the source port and the destination port as arguments and returns the SGM ID and the hash value. For example, asg calc 1 10.0.0.1 20.0.0.2 1234 80 will show which SGM will receive the traffic from 10.0.0.1:1234 to
20.0.0.2:80 on port 1.
References
*Check Point Certified Maestro Expert (CCME) R81.X Courseware, Module 4: Using theCommand Line Interface and WebUI, Lesson 4.1: asg calc, page 4-5
*Check Point R81 Maestro Administration Guide, Chapter 4: Using the Command Line Interface and WebUI, Section: asg calc, page 4-5
*asg calc - Check Point Software
NEW QUESTION # 63
What is the difference between Dual-Site and Dual-Room?
  • A. They are the same
  • B. Dual-Room is Active / Standby and Dual-Site is Active / Active
  • C. Dual-Room is a kind of Dual-Site deployment within the same building
  • D. Dual-Room is a Single-Site deployment where all Appliances are connected to both orchestrators
References =
*[Maestro Frequently Asked Questions (FAQ)]
*Maestro Dual Site configuration with a direct connection through L2 switches
*Dual Site Single Maestro Hyperscale Orchestrator Cluster (Dual Site Single MHO Redundancy)
*CHECK POINT MAESTRO EXPERT
NEW QUESTION # 64
Layer 4 distribution is enabled by default in Maestro. Which is not a scenario when you would want to leave this enabled?
  • A. When there is a heavy imbalance of traffic between the SGMs that are members of the same SG.
  • B. When the SG is NATing a very high percentage of traffic passing through it.
  • C. When there is a large number of source ports in use by protocols such as HTTP, HTTPS, and DNS.
  • D. When dynamic routing protocols, such as BGP or OSPF are used.
This is the correct answer because Layer 4 distribution is not recommended when dynamic routing protocols are used in Maestro. Layer 4 distribution is a feature that adds the source and/or destination ports to the distribution equation, which can improve the load balancing among the SGMs. However, it can also cause issues with the correction layer, which is a mechanism that ensures the packets are processed by the correct SGM. Dynamic routing protocols, such as BGP or OSPF, use specific ports to exchange routing information and establish neighbor relationships. If Layer 4 distribution is enabled, it can interfere with the routing protocol packets and cause routing instability or failures.
References
*Check Point Certified Maestro Expert (CCME) R81.X Courseware, Module 2: Maestro Security Groups, Lesson 2.4: Traffic Flow, page 2-20
*Check Point R81 Maestro Administration Guide, Chapter 2: Maestro Security Groups, Section: Traffic Distribution, page 2-8
*Layer 4 Distribution - Yes or No? - Check Point CheckMates
*Support, Support Requests, Training ... - Check Point Software
NEW QUESTION # 65
When security policy is installed
  • A. All SGMs receive the security policy and simultaneous policy installation occurs.
  • B. The SMO Master receives the policy and performs a policy verification the policy is installed on the SMO Master, the SMO Master broadcasts the available package, other membersretrieve the new policy from the SMO Master, then the non-SMO Master SGMs install the policy.
  • C. All SGMs receive the security policy and one by one performs an independent policy verification. Then, all SGMs simultaneously install the policy.
  • D. The policy is installed on the SMO, the SMO Master broadcasts the available package, other members retrieve the new policy from the SMO Master and perform an independent policy verification, then the non-SMO Master SGMs install the policy.
This is the correct answer because it describes the security policy installation flow for a Maestro Security Group. The SMO Master is the Security Group Member that acts as the leader and the single point of contact for the Management Server. The SMO Master verifies the policy and installs it first, then notifies the other SGMs that a new policy is available. The other SGMs fetch the policy from the SMO Master and install it in parallel.
References
*Check Point Certified Maestro Expert (CCME) R81.X Courseware, Module 2: Maestro Security Groups, Lesson 2.3: Security Policy Installation, page 2-15
*Check Point R81 Maestro Administration Guide, Chapter 2: Maestro Security Groups, Section: Security Policy Installation, page 2-13
*Policy installation flow - Check Point Software
NEW QUESTION # 66
Many exam candidates feel hampered by the shortage of effective 156-836 preparation quiz, and the thick books and similar materials causing burden for you. Serving as indispensable choices on your way of achieving success especially during this 156-836 Exam, more than 98 percent of candidates pass the exam with our 156-836 training guide and all of former candidates made measurable advance and improvement.
Test 156-836 Centres: https://www.braindumpstudy.com/156-836_braindumps.html
BONUS!!! Download part of BraindumpStudy 156-836 dumps for free: https://drive.google.com/open?id=1_1PklNUWPY46FQqpzLFQWi0pkHsEv60-
Posted at 2/3/2026 04:03:40        Only Author  2#
I deeply appreciate your article, it was truly unforgettable. Thanks to the Valid test Comm-Dev-101 objectives pdf, I achieved a promotion and salary raise. Now, I’m sharing it for free with everyone. Best of luck with your career advancements!
Posted at 2/12/2026 05:44:31        Only Author  3#
This article has made me reflect on many things, and I’ve learned quite a bit. With the New EX200 dumps, I was able to secure a promotion and salary hike. It’s now available for free to all. Good luck on your career growth!
