[General] Web-Based Practice Exams to Evaluate Salesforce Identity-and-Access-Management-A
94
General Web-Based Practice Exams to Evaluate Salesforce Identity-and-Access-Management-A
Posted at 1/28/2026 20:13:12      View145 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that PassReview Identity-and-Access-Management-Architect dumps now are free: https://drive.google.com/open?id=1j5rOpLI72ND7tJEoaGXRMItl392BE-bh
Choosing right study materials is key point to pass the Salesforce certification exam. PassReview is equipped with the latest questions and valid answers to ensure the preparation of Identity-and-Access-Management-Architect exam easier. The feedback from our candidates showed that our Identity-and-Access-Management-Architect Dumps PDF covers almost 90% questions in the actual test. So put our dumps to your shopping cart quickly.
Salesforce Identity-and-Access-Management-Architect (Salesforce Certified Identity and Access Management Architect) Certification Exam is designed for professionals who want to demonstrate their expertise in the field of identity and access management within the Salesforce platform. Salesforce Certified Identity and Access Management Architect certification exam is aimed at individuals who have experience in designing and implementing complex identity and access management solutions in Salesforce.
Identity-and-Access-Management-Architect Valid Test Review, Valuable Identity-and-Access-Management-Architect FeedbackOur Identity-and-Access-Management-Architect learning questions have its own advantage. In order to make sure you have answered all questions, we have answer list to help you check. Then you can choose the end button to finish your exercises of the Identity-and-Access-Management-Architect study guide. The calculation system of our Identity-and-Access-Management-Architect Real Exam will start to work and finish grading your practices. Quickly, the scores will display on the screen. The results are accurate. You need to concentrate on memorizing the wrong questions.
Salesforce Identity-and-Access-Management-Architect certification exam covers a wide range of topics related to identity and access management. Some of the key areas that are tested include identity and access management architecture, identity governance, authentication and authorization, single sign-on (SSO), and federation. Identity-and-Access-Management-Architect Exam also covers topics such as user provisioning, password management, and identity lifecycle management.
Salesforce Certified Identity and Access Management Architect Sample Questions (Q99-Q104):NEW QUESTION # 99
Universal containers (UC) wants users to authenticate into their salesforceorg using credentials stored in a custom identity store. UC does not want to purchase or use a third-party Identity provider. Additionally, UC is extremely wary of social media and does not consider it to be trust worthy. Which two options should an architect recommend to UC? Choose 2 answers
  • A. Implement the Openid protocol and configure an authentication provider
  • B. Use a professional social media such as LinkedIn as an Authentication provider
  • C. Build a custom Web service that is supported byDelegated Authentication.
  • D. Build a custom web page that uses the identity store and calls frontdoor.jsp
The two options that an architect should recommend to UC are to build a custom web service that is supported by delegated authentication and to implement the OpenID protocol and configure an authentication provider. Delegated authentication is a feature that allows Salesforce to delegate user authentication to an external service instead of using Salesforce credentials3. A custom web service can be built to use the credentials stored in the custom identity store and validate them against Salesforce using SOAP or REST API3. OpenID is an open standard protocol that allows users to authenticate with various web services using an existing account4. An authentication provider can be configured in Salesforce to use OpenID and connect with the custom identity store5.
References: Delegated Authentication, OpenID, Authentication Providers
NEW QUESTION # 100
Universal containers (UC) is setting up Delegated Authentication to allow employees to log in using their corporate credentials. UC's security team is concerned about the risk of exposing the corporate login service on the Internet and has asked that a reliable trust mechanism be put in place between the login service and salesforce. What mechanism should an architect put in place to enable a trusted connection between the login services and salesforce?
  • A. Require the use of Salesforce security Tokens on password.
  • B. Include client ID and client secret in the login header callout.
  • C. Enforce mutual Authentication between systems using SSL.
  • D. Set up a proxy server for the login service in the DMZ.
To enable a trusted connection between the login services and Salesforce, UC should enforce mutual authentication between systems using SSL. Mutual authentication is a process in which both parties in a communication verify each other's identity using certificates7. SSL (Secure Sockets Layer) is a protocol that provides secure communication over the Internet using encryption and certificates8. By using mutual authentication with SSL, UC can ensure that only authorized login services can access Salesforce and vice versa. This can prevent unauthorized access, impersonation, or phishing attacks.
References: Mutual Authentication, SSL (Secure Sockets Layer)
NEW QUESTION # 101
Universal Containers (UC) uses middleware to integrate multiple systems with Salesforce. UC has a strict, new requirement that usernames and passwords cannot be stored in any UC system. How can UC's middleware authenticate to Salesforce while adhering to this requirement?
  • A. Create a Connected App that supports the Refresh Token OAuth Flow
  • B. Create a Connected App that supports the User-Agent OAuth Flow.
  • C. Create a Connected App that supports the JWT Bearer Token OAuth Flow.
  • D. Create a Connected App that supports the Web Server OAuth Flow.
NEW QUESTION # 102
Outfitters (NTO) is using Experience Cloud as an Identity for its application on Heroku. The application on Heroku should be able to handle two brands, Northern Trail Shoes and Northern Trail Shirts.
A user should select either of the two brands in Heroku before logging into the community. The app then performs Authorization using OAuth2.0 with the Salesforce Experience Cloud site.
NTO wants to make sure it renders login page images dynamically based on the user's brand preference selected in Heroku before Authorization.
what should an identity architect do to fulfill the above requirements?
  • A. Authorize third-party service by sending authorization requests to the community-url/services/oauth2
    /authonze/expid_value.
  • B. Create multiple login screens using Experience Builder and use Login Flows at runtime to route to different login screens.
  • C. For each brand create different communities and redirect users to the appropriate community using a custom Login controller written in Apex.
  • D. Authorize third-party service by sending authorization requests to the community-url/services/oauth2
    /authorize/cookie_value.
OAuth 2.0 is an open standard for authorization that allows a third-party application to obtain limited access to a protected resource on behalf of auser. To authorize a third-party service using OAuth 2.0 with the Salesforce Experience Cloud site, the identity architect should do the following steps:
* Create a connected app for the third-party service in Salesforce. A connected app is an applicationthat integrates with Salesforce using APIs and standard protocols, such as SAML, OAuth, and OpenID Connect. To create a connected app, you need to provide the basic information, such as the app name, logo URL, contact email, and API name. You also need toenable OAuth and configure the OAuth settings, such as the callback URL, the scopes, and the policies.
* Authorize the third-party service by sending authorization requests to the community-url/services
/oauth2/authorize/expid_value. This is a special endpoint that allows you to specify an experience ID (expid) as a query parameter in the authorization request. The experience ID is a unique identifier for each experience (community or site) in Salesforce. By using this endpoint, you can dynamically render thelogin page images based on the user's brand preference selected in the third-party service before authorization.
OAuth 2.0
OAuth 2.0 Web Server Authentication Flow
Connected Apps
Experience ID
Authorize Apps with OAuth
NEW QUESTION # 103
The executive sponsor for an organization has asked if Salesforce supports the ability to embed a login widget into its service providers in order to create a more seamless user experience.
What should be used and considered before recommending it as a solution on the Salesforce Platform?
  • A. Salesforce REST apis. Ensure that Secure Sockets Layer (SSL) connection for the integration is used.
  • B. Embedded Login. Consider whether or not it relies on third party cookies which can cause browser compatibility issues.
  • C. Embedded Login. Identify what level of UI customization will be required to make it match the service providers look and feel.
  • D. OpenID Connect Web Server Flow. Determine if the service provider is secure enough to store the client secret on.
Embedded Login is a feature that allows Salesforce to embed a login widget into any web page, such as a service provider's site, to enable users to log in with their Salesforce credentials. However, Embedded Login relies on third-party cookies, which can cause browser compatibility issues and require users to adjust their browser settings. Therefore, this should be considered before recommending it as a solution on the Salesforce Platform. References: Embedded Login, Embedded Login Implementation Guide
NEW QUESTION # 104
Identity-and-Access-Management-Architect Valid Test Review: https://www.passreview.com/Identity-and-Access-Management-Architect_exam-braindumps.html
2026 Latest PassReview Identity-and-Access-Management-Architect PDF Dumps and Identity-and-Access-Management-Architect Exam Engine Free Share: https://drive.google.com/open?id=1j5rOpLI72ND7tJEoaGXRMItl392BE-bh
Posted at 2/9/2026 03:48:41        Only Author  2#
Xhs1991ITJԇYOGEA-101}ṩƽԤ륦֥ȤǤXhs1991݅νUYƕԇYβϤ򾎼뤳ȤͨơߤOGEA-101}ɤޤ}˺ޤƤΤόgHԇYΆ}ȫЩ`뤳ȤǤޤ顢ʤһؤdzɹ뤳Ȥ^Ǥޤ
