Training Order-Management-Administrator Tools - Order-Management-Administrator R
12
Posted at 1/28/2026 20:54:55      View162 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free & New Order-Management-Administrator dumps are available on Google Drive shared by PracticeMaterial: https://drive.google.com/open?id=1cUMotcdPF5Tpb0jk3xPdtwhTBZ8o9r_p
Order-Management-Administrator test materials are famous for instant access to download. And you can obtain the download link and password within ten minutes, so that you can start your learning as quickly as possible. Order-Management-Administrator exam dumps are verified by professional experts, and they possess the professional knowledge for the exam, therefore you can use them at ease. In order to let you know the latest information for the exam, we offer you free update for one year, and our system will send the latest version for Order-Management-Administrator Exam Dumps to your email automatically.
Based on the research results of the examination questions over the years, the experts give more detailed explanations of the contents of the frequently examined contents and difficult-to-understand contents, and made appropriate simplifications for infrequently examined contents. Order-Management-Administrator test questions make it possible for students to focus on the important content which greatly shortens the students learning time. With Order-Management-Administrator Exam Torrent, you will no longer learn blindly but in a targeted way. With Order-Management-Administrator exam guide, you only need to spend 20-30 hours to study and you can successfully pass the exam. You will no longer worry about your exam because of bad study materials. If you decide to choose and practice our Order-Management-Administrator test questions, our life will be even more exciting.
Salesforce Order-Management-Administrator Reliable Test Answers, Order-Management-Administrator Reasonable Exam PriceAs long as you insist on using our Order-Management-Administrator learning prep, you can get the most gold certificate in the shortest possible time! Want to see how great your life will change after that! You can make more good friends and you can really live your fantasy life. Don't hesitate, the future is really beautiful! If you are still not sure if our product is useful, you can free download the free demos of ourOrder-Management-Administrator practice quiz. It is easy and fast.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q20-Q25):NEW QUESTION # 20
What does a summary object represent?
  • A. An individual change lo financial data
  • B. A change lo an underlying record.
  • C. A discount to underlying data
  • D. A dynamic view of underlying data
A summary object represents a dynamic view ofunderlying data. A summary object is a type of object that aggregates data from related records and displays it in a single record. For example, an Order Summary object represents the financial summary of an order that is received from an external system,such as B2C Commerce or B2B Commerce. An Order Summary object aggregates data from related Order Item Summary records and displays it in fields such as total amount, tax amount, discount amount, etc. Verified References:https://help.
salesforce.com/s/articleView?id=sf.order_management_order_summary.htm&type=5
NEW QUESTION # 21
What is the required amount of test code coverage when deploying an Apex class?
  • A. 0.55
  • B. 0.65
  • C. 0.85
  • D. 0.75
The required amount of test code coverage when deploying an Apex class is 75%. This means that at least
75% of the Apex code must be covered by unit tests, and all of those tests must complete successfully.
Verified
References:https://developer.salesforce.com ... _deploying_ant_depl
NEW QUESTION # 22
A customer orders two shirts and one jacket in B2C Commerce. The Order is ingested into Order Management. However, the customer decides to cancel the order prior to fulfillment. What object is created and linked to the Order Summary?
  • A. Cancel Order
  • B. Change Order
  • C. Return Order
  • D. Suspend Order
The object that is created and linked to the Order Summary when a customer cancels an order prior to fulfillment is Cancel Order. A Cancel Order is a record that represents a cancellation request for an order or part of an order. A Cancel Order has a lookup relationship to both Order Summary and Change Order objects, and it contains information such as the cancellation reason, status, date, etc. Verified References:https://help.salesforce.com/s/ar ... rder.htm&type=5
NEW QUESTION # 23
Which three statements are true about change sets?
  • A. Change sets can only be sent between orgs that are affiliatedwith a production org
  • B. A change request should be created when the admin wants to send customizations from the current org to another org
  • C. Changes can be deployed to any instance of Salesforce as long as the destination has approved it
  • D. Sending a change set between two orgs requires a deployment connection
  • E. Change sets can contain only modifications made through the Setup menu
Answer: A,D,E
Three statements that are true about change sets are:
Sending a change set between two orgs requires a deployment connection. A deployment connection is a link between two orgs thatallows one org to send change sets to another org.
Change sets can only be sent between orgs that are affiliated with a production org. A production org is an org that is used for live operations and data, and it can have one or more sandbox orgs that areused for development and testing. Change sets can only be sent from a sandbox org to its associated production org, or from one sandbox org to another sandbox org that shares the same production org.
Change sets can contain only modifications made throughthe Setup menu. A change set is a collection of metadata components that can be deployed from one org to another. Metadata components are customizations that are made through the Setup menu, such as custom objects, fields, workflows, etc.
Verified References: https://help.salesforce.com/s/ar ... bout.htm&type=5
https://help.salesforce.com/s/ar ... ents.htm&type=5
NEW QUESTION # 24
An administrator is creating a flow to manage order fulfillment The administrator creates a fault path to handle a possible error. What object record should the administrator create in the fault path to notify users of an error?
  • A. Order Error
  • B. Order Summary Exception
  • C. Process Exception
  • D. Fulfillment Error
The object record that the administrator should create in the fault path to notify users of an error is Process Exception. A Process Exception is a record that represents an error or exception that occurred during the order lifecycle, such as payment authorization failure, inventory allocation failure, fulfillment location assignment failure, etc. A Process Exception has a lookup relationship to the Order object, and it contains information such as the exception type, status, message, etc. Verified Reference: https://help.salesforce.com/s/ar ... tion.htm&type=5
NEW QUESTION # 25
The versions of our product include the PDF version, PC version, APP online version. Each versions using method and functions are different and the client can choose the most convenient version to learn our Order-Management-Administrator exam materials. For example, the PDF version is convenient for you to download and print our Order-Management-Administrator test questions and is suitable for browsing learning. If you use the PDF version you can print our Order-Management-Administrator test torrent on the papers and it is convenient for you to take notes. You can learn our Order-Management-Administrator Test Questions at any time and place. The APP online version is used and designed based on the web browser. Any equipment can be used if only they boost the browser. It boosts the functions to stimulate the exam, provide the time-limited exam and correct the mistakes online. There are no limits for the equipment and the amount of the using persons to learn our Order-Management-Administrator exam materials. You can decide which version to choose according to your practical situation.
Order-Management-Administrator Reliable Test Answers: https://www.practicematerial.com/Order-Management-Administrator-exam-materials.html
Go Through Order-Management-Administrator Practice Test Software, If you buy the goods of PracticeMaterial Order-Management-Administrator Reliable Test Answers, then you always be able to get newer and more accurate test information, PracticeMaterial Order-Management-Administrator Reliable Test Answers's claim is the 100% success of its clients, Salesforce Training Order-Management-Administrator Tools You will get the newest information about your exam in the shortest time, And you will certainly be satisfied with our online version of our Order-Management-Administrator training quiz.
It keeps communications clear in both directions and protects your client as well, As one of influential IT companies, Order-Management-Administrator attracts to plenty of young people to struggle for Order-Management-Administrator certification.
Fantastic Training Order-Management-Administrator Tools Help You to Get Acquainted with Real Order-Management-Administrator Exam SimulationGo Through Order-Management-Administrator Practice Test Software, If you buy the goods of PracticeMaterial, then you always be able to get newer and more accurate test information, PracticeMaterial's claim is the 100% success of its clients.
What's more, part of that PracticeMaterial Order-Management-Administrator dumps now are free: https://drive.google.com/open?id=1cUMotcdPF5Tpb0jk3xPdtwhTBZ8o9r_p
Posted at 2/21/2026 07:30:40        Only Author  2#
Thank you for sharing such an inspiring and impactful article! Get the ITIL4-DPI reliable exam questions pdf test questions for freeyour promotion and salary boost are within reach!
