Salesforce-Media-Cloud指南 &新版Salesforce-Media-Cloud考古題
Posted at 1/28/2026 22:15:35
2026 NewDumps最新的Salesforce-Media-Cloud PDF版考試題庫和Salesforce-Media-Cloud考試問題和答案免費分享:https://drive.google.com/open?id=1jOSB-tS-4nR5-_Wcra7Y7HQIu1eLI7rg
每個早晨都是全新一天的開始,給自己一個好心情,給自己一個新起點。擁有熱門的IT證照是你開啟IT之路的新起點。Salesforce Salesforce-Media-Cloud 考題認證考試是個檢驗IT專業知識的認證考試。如果你想取得 Salesforce-Media-Cloud 的認證資格,NewDumps 的 Salesforce-Media-Cloud 考古題可以實現你的願望。在你考試之前使用我們提供的針對性培訓和測試練習題以及答案,短時間內你會有很大的收穫。
Salesforce Salesforce-Media-Cloud 考試大綱:| 主題 | 簡介 | | 主題 1 | - Design: This section of the exam measures the skills of a Salesforce Media Cloud Consultant and covers the process of designing scalable and efficient Media Cloud solutions. It focuses on creating solution flows using ASM capabilities, applying best practices in solution architecture, recommending product model and pricing strategies, and aligning designs with the Media Cloud data model. It also evaluates the candidate's ability to set up sharing and permission sets, identify integration points, assess reporting needs, and determine deployment strategies that fit within a CI
- CD environment.
| | 主題 2 | - Implement: This section of the exam measures skills of a Salesforce Solution Architect and focuses on implementing the Media Cloud solution based on business and technical requirements. It includes supporting CI
- CD deployment processes, planning data migration with an understanding of the data model, selecting appropriate integration approaches for media-specific contexts, applying security settings to control data access, and ensuring performance outcomes align with defined KPIs and non-functional expectations.
| | 主題 3 | - Discovery: This section of the exam measures the skills of a Salesforce Solution Architect and covers the ability to assess business and technical requirements for implementing Media Cloud applications. It includes determining the technical scope for a statement of work (SOW), mapping use cases to Salesforce Media Cloud components, understanding how third-party systems integrate with the Media Cloud ecosystem, outlining system flows based on the existing business environment, and identifying relevant non-functional requirements based on customer needs.
有用的Salesforce-Media-Cloud指南和資格考試中的領先提供者和一流的新版Salesforce-Media-Cloud考古題用最放鬆的心態面對一切艱難。Salesforce的Salesforce-Media-Cloud考試雖然很艱難,但我們考生要用最放鬆的心態來面對一切艱難,因為NewDumps Salesforce的Salesforce-Media-Cloud考試培訓資料會幫助我們順利通過考試,有了它我們就不會害怕,不會迷茫。NewDumps Salesforce的Salesforce-Media-Cloud考試培訓資料是我們考生的最佳良藥。
最新的 Accredited Professional Certification Salesforce-Media-Cloud 免費考試真題 (Q42-Q47):問題 #42
A Media Cloud customer is already running Advertising Sales Management (ASM) on an org and wants to upgrade from an older release to a newer release.
What should a Consultant do before migration?
- A. Take a backup of any customized or modified older ASM components
- B. Activate Custom Lightning Web Components and FlexCards
- C. Customize or modify the newer ASM components
- D. Take a backup of any newer ASM components
答案:A
解題說明:
Before migrating ASM to a newer release, it is crucial to take a backup of any customized or modified components in the existing (older) release to avoid losing customizations. Newer components should not be customized before migration. Activating new LWC and FlexCards is a post-migration step.
ASM Upgrade and Migration Best Practices
https://help.salesforce.com/s/ar ... rade.htm&type=5
問題 #43
A home store wants to advertise their products on a particular TV channel owned by a publishing company.
Which channel should this media plan include?
- A. Linear
- B. Out Of Home (OOH)
- C. Print
- D. Digital
答案:A
解題說明:
Linear refers to traditional TV broadcasting channels where advertisements run in a scheduled, linear fashion. Since the home store wants to advertise on a TV channel, the media plan should include the Linear channel type. Digital refers to online channels, Print to newspapers/magazines, and OOH to outdoor advertising formats.
Media Cloud Channel Definitions
Advertising Sales Management Media Types
https://help.salesforce.com/s/ar ... nels.htm&type=5
問題 #44
A publishing company has been using media cloud decides that thhey want to use marketing cloud intelligence for analytics. However, there is an outh 2.0 authentication issue when attempting to set up data stream setup in marketing cloud intelligence. Where should a consultant go within Salesforce to ensure that the settings in marketing cloud intelligence are set up correctly?
- A. named credential
- B. aut.Provider
- C. custom metadata
- D. connected app
答案:A
解題說明:
When facing OAuth 2.0 authentication issues during the setup of a data stream in Marketing Cloud Intelligence, checking the Named Credential settings within Salesforce is a critical step. Named Credentials provide a secure way to manage authentication details for external services, ensuring that Salesforce can securely connect to Marketing Cloud Intelligence. By verifying and, if necessary, adjusting the Named Credential settings, the consultant can resolve authentication issues, enabling successful data stream setup and integration between Salesforce and Marketing Cloud Intelligence.Reference:https://help.salesforce.com/
問題 #45
Which three types of permission sets are required for a persona to be present in an environment?
Choose 3 answers
- A. OmniStudioUser
- B. OmniStudioAdmin
- C. Rule Engine Runtime
- D. Media Cloud Base User
- E. DocGenInd CME Designer User
答案:A,C,D
解題說明:
Personas in Media Cloud require OmniStudioUser for OmniStudio access, Rule Engine Runtime for business rules, and Media Cloud Base User for base feature access. OmniStudioAdmin is an administrative-level permission, and DocGenInd CME Designer User is specific to document template design, not core persona presence.
Media Cloud Persona Setup
Permission Sets Overview
https://help.salesforce.com/s/ar ... sets.htm&type=5
問題 #46
A customer needs to implement an automated Continuous Integration and Continuous Development (CI/CD) workflow where developers will work on their own Developer orgs to configure different OmniScripts. The developers then need to migrate the changes they have done to a sandbox that will be used for testing before promoting changes to Production.
Which tool should developers use to automate the migration of OmniStudio DataPacks and Salesforce metadata within the Media Cloud orgs?
- A. IDX Build Tool
- B. Backup and Restore Automation
- C. Data Loader
- D. IDX Workbench
答案:A
解題說明:
IDX Build Tool is the recommended tool for automating migration and deployment of OmniStudio DataPacks and metadata between Salesforce orgs, supporting CI/CD workflows. IDX Workbench is more manual, and Backup and Restore Automation and Data Loader do not support OmniStudio DataPacks.
Salesforce IDX Build Tool Documentation
Media Cloud Deployment Automation
https://help.salesforce.com/s/ar ... tool.htm&type=5
問題 #47
最近,身邊考 Salesforce 認證的人也是相當多的,那麼,怎麼去準備 Salesforce-Media-Cloud 考試呢?建議大家,可以先到考試中心去打聽這科考試的有關的情況。了解考試的流程,考試的注意事項。預約一個合適的時間去報名參加考試即可。為了更有把握的通過考試,可以看看NewDumps 考題網的 Salesforce-Media-Cloud 題庫,上面的題目都是真題,很准,我做了很多遍的練習。練習題有些部分超出了 Salesforce 的要求,但是對於扎實的掌握知識是很有幫助的,建議做完,搞懂。這是你輕鬆通過考試的最好的方法。
新版Salesforce-Media-Cloud考古題: https://www.newdumpspdf.com/Salesforce-Media-Cloud-exam-new-dumps.html
- Salesforce-Media-Cloud考題資訊 💄 Salesforce-Media-Cloud測試 🕜 Salesforce-Media-Cloud真題材料 😽 到➡ [url]www.pdfexamdumps.com ️⬅️搜索【 Salesforce-Media-Cloud 】輕鬆取得免費下載最新Salesforce-Media-Cloud題庫資源[/url]
- Salesforce-Media-Cloud考試內容 💻 Salesforce-Media-Cloud題庫最新資訊 🐷 Salesforce-Media-Cloud考古題分享 🤘 “ [url]www.newdumpspdf.com ”網站搜索⏩ Salesforce-Media-Cloud ⏪並免費下載Salesforce-Media-Cloud真題材料[/url]
- 最新的Salesforce-Media-Cloud指南 - 安全的新版Salesforce-Media-Cloud考古題:Salesforce Media Cloud Accredited Professional (AP) Exam 🦇 立即到▷ tw.fast2test.com ◁上搜索➡ Salesforce-Media-Cloud ️⬅️以獲取免費下載Salesforce-Media-Cloud熱門認證
- 完美的Salesforce-Media-Cloud指南和認證考試的領導者材料和完整的新版Salesforce-Media-Cloud考古題 ✉ 在▶ [url]www.newdumpspdf.com ◀上搜索▶ Salesforce-Media-Cloud ◀並獲取免費下載Salesforce-Media-Cloud考古题推薦[/url]
- Salesforce-Media-Cloud題庫資料 🦯 Salesforce-Media-Cloud題庫資料 🚐 Salesforce-Media-Cloud題庫最新資訊 🌴 【 [url]www.newdumpspdf.com 】是獲取➥ Salesforce-Media-Cloud 🡄免費下載的最佳網站Salesforce-Media-Cloud考題資源[/url]
- 最好的Salesforce-Media-Cloud指南 |高通過率的考試材料|值得信賴的新版Salesforce-Media-Cloud考古題 🎠 打開➤ [url]www.newdumpspdf.com ⮘搜尋⮆ Salesforce-Media-Cloud ⮄以免費下載考試資料Salesforce-Media-Cloud考題資訊[/url]
- Salesforce-Media-Cloud熱門認證 ❣ Salesforce-Media-Cloud題庫最新資訊 👜 Salesforce-Media-Cloud新版題庫上線 🌷 在⇛ [url]www.pdfexamdumps.com ⇚上搜索☀ Salesforce-Media-Cloud ️☀️並獲取免費下載Salesforce-Media-Cloud考古题推薦[/url]
- 使用Salesforce-Media-Cloud指南,傳遞Salesforce Media Cloud Accredited Professional (AP) Exam相關信息 📃 立即在“ [url]www.newdumpspdf.com ”上搜尋➡ Salesforce-Media-Cloud ️⬅️並免費下載Salesforce-Media-Cloud新版題庫上線[/url]
- 熱門的Salesforce-Media-Cloud指南,免費下載Salesforce-Media-Cloud學習資料幫助妳通過Salesforce-Media-Cloud考試 😝 免費下載✔ Salesforce-Media-Cloud ️✔️只需在《 [url]www.pdfexamdumps.com 》上搜索Salesforce-Media-Cloud考古題分享[/url]
- [url=https://www.panierdenoscampagnes.fr/?s=Salesforce-Media-Cloud%e8%80%83%e8%a9%a6%e5%85%a7%e5%ae%b9%20%f0%9f%a4%98%20Salesforce-Media-Cloud%e8%80%83%e9%a1%8c%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89%20%f0%9f%8d%8d%20Salesforce-Media-Cloud%e7%9c%9f%e9%a1%8c%e6%9d%90%e6%96%99%20%f0%9f%94%a5%20%e5%88%b0[%20www.newdumpspdf.com%20]%e6%90%9c%e5%b0%8b%e2%87%9b%20Salesforce-Media-Cloud%20%e2%87%9a%e4%bb%a5%e7%8d%b2%e5%8f%96%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89%e8%80%83%e8%a9%a6%e8%b3%87%e6%96%99Salesforce-Media-Cloud%e7%86%b1%e9%96%80%e8%aa%8d%e8%ad%89]Salesforce-Media-Cloud考試內容 🤘 Salesforce-Media-Cloud考題免費下載 🍍 Salesforce-Media-Cloud真題材料 🔥 到[ www.newdumpspdf.com ]搜尋⇛ Salesforce-Media-Cloud ⇚以獲取免費下載考試資料Salesforce-Media-Cloud熱門認證[/url]
- Salesforce-Media-Cloud認證考試 👩 Salesforce-Media-Cloud考古题推薦 💏 Salesforce-Media-Cloud通過考試 🚑 「 tw.fast2test.com 」最新▷ Salesforce-Media-Cloud ◁問題集合Salesforce-Media-Cloud考題資訊
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, writeablog.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, building.lv, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
P.S. NewDumps在Google Drive上分享了免費的2026 Salesforce Salesforce-Media-Cloud考試題庫:https://drive.google.com/open?id=1jOSB-tS-4nR5-_Wcra7Y7HQIu1eLI7rg
