[General] Exam SOA-C02 Testking - Official SOA-C02 Practice Test
87
【General】 Exam SOA-C02 Testking - Official SOA-C02 Practice Test
Posted at 1/28/2026 22:31:35      View:124 | Replies:3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of itPass4sure SOA-C02 dumps from Cloud Storage: https://drive.google.com/open?id=1nykkHxaZANYlhyr5JtiI7SyCyh_QhBp0
The whole world of SOA-C02 preparation materials has changed so fast in the recent years because of the development of internet technology. We have benefited a lot from those changes. In order to keep pace with the development of the society, we also need to widen our knowledge. If you are a diligent person, we strongly advise you to try our SOA-C02 real test. You will be attracted greatly by our SOA-C02 practice engine. .
The Amazon SOA-C02 Exam consists of 65 multiple-choice and multiple-response questions that need to be completed within 130 minutes. The questions are designed to test the candidate's knowledge of AWS services such as EC2, RDS, S3, and CloudFormation, as well as their ability to use AWS management tools such as CloudWatch, CloudTrail, and AWS Config.
Official SOA-C02 Practice Test, Examcollection SOA-C02 Dumps TorrentNowadays there is a growing tendency in getting a certificate. SOA-C02 study materials offer you an opportunity to get the certificate easily. SOA-C02 exam dumps are edited by the experienced experts who are familiar with the dynamics of the exam center, therefore SOA-C02 Study Materials of us are the essence for the exam. Besides we are pass guarantee and money back guarantee. Any other questions can contact us anytime.
Amazon AWS Certified SysOps Administrator - Associate (SOA-C02) Sample Questions (Q118-Q123):NEW QUESTION # 118
A company's VPC has an existing IPv4 configuration. The IPv4 configuration includes public subnets, private subnets, NAT gateways, default route tables, and ACLs.
The company associates an IPv6 CIDR block with the VPC. The company adds IPv6 allocations to each existing subnet and adds routes to the route tables. The company updates the ACLs to allow all IPv6 traffic.
Public subnets are working as expected, but private subnets are not allowing internet IPv6 connections.
What should a SysOps administrator do to allow outbound-only connectivity for the new IPv6 subnets?
  • A. Turn on IPv6 NAT on the NAT gateways. Create a default route in the route tables that are associated with the private subnets. Configure the default route to point to the NAT gateways.
  • B. Configure a new IPv6-only NAT gateway. Create a default route in the route tables that are associated with the private subnets. Configure the default route to point to the IPv6-only NAT gateway.
  • C. Configure an egress-only internet gateway and associate it with the VPC. Create a default route in the route tables that are associated with the private subnets. Configure the default route to point to the egress-only internet gateway.
  • D. Create a default route in the route tables that are associated with the private subnets. Configure the default route to point to the existing internet gateway.
https://docs.aws.amazon.com/vpc/ ... ternet-gateway.html
NEW QUESTION # 119
A company has an application that runs on a fleet of Amazon EC2 instances behind an Elastic Load Balancer. The instances run in an Auto Scaling group. The application's performance remains consistent throughout most of each day. However, an increase in user traffic slows the performance during the same 4-hour period of time each day.
What is the MOST operationally efficient solution that will resolve this issue?
  • A. Configure a second Elastic Load Balancer in front of the Auto Scaling group with a weighted routing policy.
  • B. Configure the fleet of EC2 instances to run on larger instance types to support the increase in user traffic.
  • C. Manually add a few more EC2 instances to the Auto Scaling group to support the increase in user traffic.
  • D. Create a scheduled scaling action to scale out the number of EC2 instances shortly before the increase in user traffic occurs.
They see the same slow performance at the same time each day. Scheduled scaling makes sense.
Scheduled scaling helps you to set up your own scaling schedule according to predictable load changes. For example, let's say that every week the traffic to your web application starts to increase on Wednesday, remains high on Thursday, and starts to decrease on Friday. You can configure a schedule for Amazon EC2 Auto Scaling to increase capacity on Wednesday and decrease capacity on Friday.
To use scheduled scaling, you create scheduled actions. Scheduled actions are performed automatically as a function of date and time. When you create a scheduled action, you specify when the scaling activity should occur and the new desired, minimum, and maximum sizes for the scaling action. You can create scheduled actions that scale one time only or that scale on a recurring schedule.
https://docs.aws.amazon.com/auto ... eduled-scaling.html
NEW QUESTION # 120
A SysOps administrator is designing a solution for an Amazon RDS for PostgreSQL DB instance. Database credentials must be stored and rotated monthly. The applications that connect to the DB instance send write- intensive traffic with variable client connections that sometimes increase significantly in a short period of time.
Which solution should a SysOps administrator choose to meet these requirements?
  • A. Configure AWS Secrets Manager to automatically rotate the credentials for the DB instance. Use RDS Proxy to handle the increases in database connections.
  • B. Configure AWS Key Management Service (AWS KMS) to automatically rotate the keys for the DB instance. Use RDS read replicas to handle the increases in database connections.
  • C. Configure AWS Key Management Service (AWS KMS) to automatically rotate the keys for the DB instance. Use RDS Proxy to handle the increases in database connections.
  • D. Configure AWS Secrets Manager to automatically rotate the credentials for the DB instance. Use RDS read replicas to handle the increases in database connections.
To meet the requirements of storing and rotating database credentials monthly and handling write-intensive traffic with variable client connections, you can use AWS Secrets Manager and Amazon RDS Proxy.
* AWS Secrets Manager for Credential Rotation:
* Open the AWS Secrets Manager console at AWS Secrets Manager Console.
* Store the database credentials as a new secret and configure automatic rotation for every 30 days.
* AWS Secrets Manager will handle the rotation process and update the secret with new credentials.
* Amazon RDS Proxy for Connection Management:
* Open the Amazon RDS console at Amazon RDS Console.
* Create an RDS Proxy for the PostgreSQL DB instance.
* Configure the proxy to handle the connection pooling and manage the connections efficiently.
* The proxy will help manage the database connections, reduce the overhead on the database, and improve performance during peak loads.
This solution ensures that database credentials are securely stored and rotated automatically while handling increased database connections effectively.
AWS Secrets Manager
Using AWS Secrets Manager to Rotate Amazon RDS Database Credentials
Amazon RDS Proxy
NEW QUESTION # 121
A company is running an application on premises and wants to use AWS for data backup All of the data must be available locally The backup application can write only to block-based storage that is compatible with the Portable Operating System Interface (POSIX) Which backup solution will meet these requirements?
  • A. Configure the backup software to use Amazon S3 as the target for the data backups
  • B. Configure the backup software to use Amazon S3 Glacier as the target for the data backups
  • C. Use AWS Storage Gateway, and configure it to use gateway-stored volumes
  • D. Use AWS Storage Gateway, and configure it to use gateway-cached volumes
NEW QUESTION # 122
A SysOps administrator created an Amazon VPC with an IPv6 CIDR block, which requires access to the internet. However, access from the internet towards the VPC is prohibited. After adding and configuring the required components to the VPC. the administrator is unable to connect to any of the domains that reside on the internet.
What additional route destination rule should the administrator add to the route tables?
  • A. Route 0.0.0.0/0 traffic to an egress-only internet gateway
  • B. Route ::/0 traffic to an egress-only internet gateway
  • C. Route ::/0 traffic to an internet gateway
  • D. Route ;:/0 traffic to a NAT gateway
https://docs.aws.amazon.com/vpc/ ... ternet-gateway.html To allow outbound IPv6 traffic from instances in your VPC to the internet, but prevent inbound traffic from the internet, you should use an egress-only internet gateway.
* Egress-Only Internet Gateway:
* An egress-only internet gateway is a horizontally scaled, redundant, and highly available VPC component that allows outbound communication over IPv6 from instances in your VPC to the internet and prevents the internet from initiating an IPv6 connection with your instances.
* Routing Configuration:
* Open the Amazon VPC console.
* Select the route table associated with your VPC.
* Add a route for IPv6 traffic (destination ::/0) to the egress-only internet gateway.
Egress-Only Internet Gateways
Routing for IPv6 Traffic
NEW QUESTION # 123
The price of Amazon SOA-C02 updated exam dumps is affordable. You can try the free demo version of any Amazon SOA-C02 exam dumps format before buying. For your satisfaction, itPass4sure gives you a free demo download facility. You can test the features and then place an order. So, these real and updated AWS Certified SysOps Administrator - Associate (SOA-C02) SOA-C02 Dumps are essential to pass the SOA-C02 exam.
Official SOA-C02 Practice Test: https://www.itpass4sure.com/SOA-C02-practice-exam.html
BONUS!!! Download part of itPass4sure SOA-C02 dumps for free: https://drive.google.com/open?id=1nykkHxaZANYlhyr5JtiI7SyCyh_QhBp0
Posted at 2/5/2026 03:03:44        Only Author  2#
Such a powerful article, thank you for sharing! Explore FCP_FGT_AD-7.6 reliable dumps, which is packed with valuable content, freely available to help you.
Posted at 2/13/2026 14:14:27        Only Author  3#
Your article was so enlightening, thank you for this wonderful insight. Ready for the New Workday-Pro-HCM-Reporting test cram review exam? Let’s hope I pass it with ease!
Posted at 2/17/2026 21:35:25        Only Author  4#
我們都知道在現在這個競爭激烈的IT行業,擁有一些IT相關認證證書是很有必要的。IT認證證書是對你的IT專業知識和經驗的最好證明。在IT行業中Oracle 1z0-1033-25 認證考試是一個很重要的認證考試,但是通過Oracle 1z0-1033-25 認證考試是有一定難度的。但是為了能讓工作職位有所提升花點金錢選擇一個好的培訓機構來幫助你通過考試是值得的。KaoGuTi擁有最新的針對Oracle 1z0-1033-25認證考試的培訓資料,與真實的考試很95%相似性。如果你使用KaoGuTi提供的培訓,你可以100%通過考試。如果你考試失敗,我們會全額退款。
