[General] 1Z0-083 Latest Guide Files | Latest 1Z0-083 Braindumps Files
60
【General】 1Z0-083 Latest Guide Files | Latest 1Z0-083 Braindumps Files
Posted at 1/28/2026 22:53:46      View:238 | Replies:2        Print      Only Author   [Copy Link] 1#
What's more, part of that PassTestking 1Z0-083 dumps now are free: https://drive.google.com/open?id=170VNb1OzuJx1JoO98qowzkRS0Lu65Luh
We also provide you with customizable desktop Central Finance in Oracle Database Administration II (1Z0-083) practice test software and web-based Oracle 1Z0-083 practice exam. You can adjust timings and Oracle Database Administration II (1Z0-083) questions number of our 1Z0-083 practice exams according to your training needs. These Oracle 1Z0-083 Practice Tests simulate the real 1Z0-083 exam pattern, track your progress, and help you overcome mistakes. Our 1Z0-083 desktop software is compatible with Windows.
When finding so many exam study material for PassTestking 1Z0-083 exam dumps, you may ask why to choose Oracle 1Z0-083 training dumps. Now, we will clear your confusion. Firstly, our questions and answers of 1Z0-083 pdf dumps are compiled and edited by highly-skilled IT experts. Besides, we have detailed explanation for the complex issues, thus you can easy to understand. What's more, the high hit rate of 1Z0-083 Questions can ensure you 100% pass.
Latest Oracle 1Z0-083 Braindumps Files - New 1Z0-083 Test NotesPassTestking has been going through all ups and downs tested by the market, and now our 1Z0-083 exam questions have become perfectly professional. We never circumvent the difficulties of our 1Z0-083 study materials happened on the road as long as there is bright at the end, and it is the satisfactory results you want. And we have helped so many of our customers achieve their certifications according to our 1Z0-083 learning guide.
Oracle Database Administration II Sample Questions (Q99-Q104):NEW QUESTION # 99
Which two are true about server-generated alerts? (Choose two.)
  • A. Stateful alerts are purged automatically from the alert history.
  • B. Stateless alerts are automatically cleared.
  • C. Stateless alerts can be purged manually from the alert history.
  • D. Stateful alerts must be created by a DBA after resolving the problem.
  • E. Stateless alerts can be cleared manually.
Answer: C,E
Except for the tablespace space usage metric, which is database related, the other metrics are instance related.
Threshold alerts are also referred to as stateful alerts which are automatically cleared when an alert condition clears. Stateful alert appears in DBA_OUTSTANDING_ALERTS and when cleared go to DBA_ALERT_HISTORY. Other server-generated alerts correspond to specific database events such as ORA-* errors, "Snapshot too old" errors, Recovery Area Low on Free Space, Resumable Session Suspended.
These are non threshold based alerts, also referred to as stateless alerts. Stateless alerts go directly to the History table. +++ Most alerts (such as "Out of Space") are cleared automatically when the cause of the problem disappears. However, other alerts (such as generic alert log errors) are sent to you for notification and must be acknowledged by you. After taking the corrective measures, you acknowledge an alert by clearing or purging it. Clearing an alert sends the alert to the Alert History which is accessible from Monitoring sub menu.
Purging an alert removes it from the Alert History.
NEW QUESTION # 100
Examine this configuration:
17.CDB1is an Oracle Database 12c Release 2 container database (CDB).
18.PDB1and PDB2are two pluggable databases (PDBs) in CDB1.
After successfully performing all the preupgrade tasks, you execute these commands from the Oracle Database 18c environment:
What is the outcome?
  • A. It fails because PDB2 is not in UPGRADE state.
  • B. CDB$ROOT, PDB$SEED, PDB1, and PDB2 are upgraded.
  • C. Only CDB$ROOT, PDB$SEED, and PDB2 are upgraded.
  • D. Only CDB$ROOT, PDB$SEED, and PDB1 are upgraded.
  • E. It fails because PDB$SEED is in MIGRATE state.
  • F. Only CDB$ROOT and PDB$SEED are upgraded.
https://docs.oracle.com/en/datab ... upgrading-parallel- upgrade-utility-catctl-pl.html#GUID-C667B51C-058F-48B6-86FE-12E9D82FDDBD
NEW QUESTION # 101
Examine these queries and their output: After a system crash, an instance restart and an attempted opening of the PDBs result in: Which two are true? (Choose two.)
  • A. Data file 24 can be recovered while PDB2 is opened.
  • B. Data file 24 must be recovered while the CDB is opened.
  • C. Data file 24 cannot be recovered while the CDB is opened.
  • D. Data file 24 can be recovered while CDB$ROOT and PDB$SEED are opened.
  • E. Data file 24 must be recovered while PDB2 is closed.
NEW QUESTION # 102
Which three are true about block media recovery? (Choose three.)
  • A. The data file containing the block being recovered remains online.
  • B. The target database for which one or more blocks are to be recovered must be in the OPEN state.
  • C. It can be performed on noncorrupt blocks.
  • D. To use it, Flashback Database must be enabled.
  • E. It cannot repair logical corruption.
  • F. A block being recovered is not accessible.
Answer: A,D,F
https://docs.oracle.com/en/datab ... v/rman-block-media- recovery.html#GUID-C1164158-496C-4D8A-8A06-D343935FC3B9 It tells that flashback is a must "Flashback Database must be enabled on the target database for RMAN to search the flashback logs for good copies of corrupt blocks." It also says "Block media recovery may not be able to repair all logical block corruptions. In these cases, alternate recovery methods, such as tablespace point-in-time recovery, or dropping and re-creating the affected objects, may repair the corruption."
NEW QUESTION # 103
Which three methods can be used for heap table data migration after upgrading a database?
(Choose three.)
  • A. using Oracle Data Pump
  • B. using operating system file copy utilities
  • C. using Database Replay
  • D. using the CREATE TABLE AS SELECT SQL statement
  • E. using SQL Developer
  • F. using Database Upgrade Assistant
Answer: A,D,E
Argument of veginha handles the upgrade itself, this question handles about a heap move.
NEW QUESTION # 104
If you are going to prepare for the 1Z0-083 exam in order to get the related certification and improve yourself, you are bound to be very luck. With the joint efforts of all parties, our company has designed the very convenient and useful 1Z0-083 study materials. More importantly, the practices have proven that the study materials from our company have helped a lot of people achieve their goal and get the related certification. The 1Z0-083 Study Materials of our company is the study tool which best suits these people who long to pass the 1Z0-083 exam and get the related certification.
Latest 1Z0-083 Braindumps Files: https://www.passtestking.com/Oracle/1Z0-083-practice-exam-dumps.html
Here, we will provide you with latest 1Z0-083 exam pdf to help you prepare exam smoothly and ensure you high pass rate, Compared with other products, our Latest 1Z0-083 Braindumps Files - Oracle Database Administration II training online materials is easier to operate, Oracle 1Z0-083 Latest Guide Files At ITexamGuide, we will always ensure your interests, As the questions of exams of our exam torrent are more or less involved with heated issues and customers who prepare for the exams must haven’t enough time to keep trace of exams all day long, our 1Z0-083 practice test can serve as a conducive tool for you make up for those hot points you have ignored.
Maybe it's a situation where he usually thinks 1Z0-083 to make him happy, Statistical information is obtained on each question to determine reliability and validity, Here, we will provide you with Latest 1Z0-083 Exam Pdf to help you prepare exam smoothly and ensure you high pass rate.
Prominent Features of PassTestking Oracle 1Z0-083 Practice Test QuestionsCompared with other products, our Oracle Database Administration II training online materials is easier New 1Z0-083 Test Notes to operate, At ITexamGuide, we will always ensure your interests, As the questions of exams of our exam torrent are more or less involved with heated issues and customers who prepare for the exams must haven’t enough time to keep trace of exams all day long, our 1Z0-083 practice test can serve as a conducive tool for you make up for those hot points you have ignored.
Three versions of our high-quality Oracle 1Z0-083 dumps VCE file.
DOWNLOAD the newest PassTestking 1Z0-083 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=170VNb1OzuJx1JoO98qowzkRS0Lu65Luh
Posted at 2/7/2026 10:17:12        Only Author  2#
This article is superb, I appreciate you sharing it. The C_CPE_2409 100% exam coverage helped me secure my promotion and raise. It’s free now for everyone. Best of luck with your career!
Posted at 4/20/2026 08:51:26        Only Author  3#
Thank you for your article; it truly broadened my horizons! This is the CTAL-TAE_V2 vce file exam I passed for my promotion and salary raise. It’s free for you today—hope you reach your career milestones!
