[General] 100% Pass Quiz Accurate Oracle - 1Z1-947 - New Oracle GoldenGate 19c Implementat
【General】 100% Pass Quiz Accurate Oracle - 1Z1-947 - New Oracle GoldenGate 19c Implementat
Posted at 1/29/2026 01:14:01      View:77 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest ValidVCE 1Z1-947 PDF Dumps and 1Z1-947 Exam Engine Free Share: https://drive.google.com/open?id=1sled2FBSJQFcR5KnhwB5jA8K2ZBI67vy
The pass rate for 1Z1-947 training materials is 98.65%, and you can pass the exam just one time if you choose us. We have a professional team to collect and research the first-hand information for the exam, and therefore you can get the latest information if you choose us. In addition, 1Z1-947 exam materials cover most of knowledge points for the exam, and you can pass the exam as well as improve your professional ability in the process of learning. We have online and offline service. If you have any questions for 1Z1-947 Exam Braindumps, and you can contact with us, and we will give you reply as soon as possible.
We should formulate a set of high efficient study plan to make the 1Z1-947 exam dumps easier to operate. Here our products strive for providing you a comfortable study platform and continuously upgrade 1Z1-947 test prep to meet every customer’s requirements. Under the guidance of our 1Z1-947 Test Braindumps, 20-30 hours’ preparation is enough to help you obtain the Oracle certification, which means you can have more time to do your own business as well as keep a balance between a rest and taking exams.
1Z1-947 Trusted Exam Resource - Simulations 1Z1-947 PdfTherefore, you have the option to use Oracle 1Z1-947 PDF questions anywhere and anytime. ValidVCE Oracle GoldenGate 19c Implementation Professional (1Z1-947) dumps are designed according to the Oracle GoldenGate 19c Implementation Professional (1Z1-947) certification exam standard and have hundreds of questions similar to the actual 1Z1-947 Exam. ValidVCE Oracle web-based practice exam software also works without installation.
Oracle GoldenGate 19c Implementation Professional Sample Questions (Q85-Q90):NEW QUESTION # 85
Where can you view Oracle GoldenGate command syntax?
  • A. SQL*Plus Guide
  • B. Data Dictionary Views
  • C. Command Line Interface Reference
  • D. AWR Report
Help or Command Line Interface Reference for Oracle GoldenGate
NEW QUESTION # 86
Replicat makes checkpoints in the trail file to mark its last read position. How can you create a checkpoint table?
  • A. Use the ADD Extract Trail command.
  • B. Run the chkpt_db_extracttrail.sql script.
  • C. Use the ADD CHECKPOINTTABLE command.
  • D. Use the INFO REPLICAT command with the SHOWCH option.
A checkpoint table is used by Replicat (especially in coordinated or integrated mode) to store its checkpoint information inside the target database - rather than just in the local trail files. This improves visibility and manageability, especially in HA/DR setups.
NEW QUESTION # 87
The Integrated Replicat reads the trail, constructs logical change records that represent source DML or DDL transactions, and transmits these records to an inbound server in the Oracle target database. What statement is true about Integrated Replicat?
  • A. Source must be configured as Integrated Extract.
  • B. Both source and target can be Oracle and non-Oracle databases.
  • C. Integrated Replicat does not need a checkpoint or a trace table for its operations.
  • D. Trail files contain data that must be in logical change records format.
Integrated Replicat processes Logical Change Records (LCRs). These LCRs are read from trail files and passed to the Inbound Server. It supports parallel apply and uses Oracle Streams APIs internally.
NEW QUESTION # 88
You were assigned to install the Oracle GoldenGate 19c Microservices architecture software. There are three things that need to be done for the installation process: Install the software using the Oracle Universal Installer. Set the necessary environment variables. Deploy an Oracle GoldenGate instance using the configuration assistant, oggc a. What will running the oggca.sh utility do?
  • A. Create a database user for the GoldenGate instance.
  • B. Create the administration user for the GoldenGate instance.
  • C. Configure the Service Manager and the other Microservices architecture servers.
  • D. Launch GoldenGate instance wizard to guide you through creating an Extract and a Replicat.
Using oggca.sh to configure the service manager and source and target deployments. In the overview-- in this practice, you use the oggca.sh utility to configure the service manager and the two MA deployments.
NEW QUESTION # 89
Which transactions are captured if you ADD EXTRACT with BEGIN NOW at 1:00 PM, but START EXTRACT at 2:00 PM?
  • A. Transactions that started at or after 1:00 PM
  • B. Only transactions that started before 1:00 PM and committed after 1:00 PM
  • C. Only transactions that started at or after 2:00 PM
  • D. Transactions that started before 1:00 PM and committed after 2:00 PM
When you run ADD EXTRACT ... BEGIN NOW at 1:00 PM, GoldenGate records the current CSN/SCN as the starting point. So even if you start the Extract later (e.g., at 2:00 PM), it will capture transactions that started at or after 1:00 PM, ensuring no changes are missed from the defined start point.
NEW QUESTION # 90
Up to now we classify our 1Z1-947 exam questions as three different versions. They are pdf, software and the most convenient one APP online. Though the content of these three versions is the same, but their displays are different. Each of them has their respective feature and advantage including new information that you need to know to pass the 1Z1-947 test. So you can choose the version of 1Z1-947 training quiz according to your personal preference.
1Z1-947 Trusted Exam Resource: https://www.validvce.com/1Z1-947-exam-collection.html
The dumps contain all the relevant information of Oracle GoldenGate 1Z1-947 exam that is necessary for your success, Oracle New 1Z1-947 Test Sample We are UK based company, selling practice test questions answers, Now, our 1Z1-947 exam questions just need you to spend some time on accepting our guidance, then you will become popular talents in the job market, Our website ValidVCE provide the 1Z1-947 test guide to clients and help they pass the test 1Z1-947 certification which is highly authorized and valuable.
Study Tips like the advice and instruction that a 1Z1-947 New Exam Braindumps personal tutor might provide, I used the D in Diego as my center point, but there are three letters in front of it and four letters after it, so the 1Z1-947 solution required me to figure out how to match up the number of vertical strokes in each letter.
Fantastic Oracle - New 1Z1-947 Test SampleThe dumps contain all the relevant information of Oracle GoldenGate 1Z1-947 Exam that is necessary for your success, We are UK based company, selling practice test questions answers.
After purchasing our Oracle 1Z1-947 practice materials, the free updates will be sent to your mailbox for one year long if our experts make any of our Oracle 1Z1-947 guide materials.
What's more, part of that ValidVCE 1Z1-947 dumps now are free: https://drive.google.com/open?id=1sled2FBSJQFcR5KnhwB5jA8K2ZBI67vy
Posted at 2/3/2026 12:49:48        Only Author  2#
Your article is absolutely brilliant, thank you for sharing! Free Valid C_HRHPC_2505 test collection file questions—unlock your career advancement and salary boost!
