[General] Pass Guaranteed Quiz 2026 Microsoft AZ-104: Valid Microsoft Azure Administrator
104
【General】 Pass Guaranteed Quiz 2026 Microsoft AZ-104: Valid Microsoft Azure Administrator
Posted at 1/29/2026 03:30:23      View:200 | Replies:2        Print      Only Author   [Copy Link] 1#
2026 Latest Lead2Passed AZ-104 PDF Dumps and AZ-104 Exam Engine Free Share: https://drive.google.com/open?id=1U2GpRM-f2K7RSt12jpiml_wm0bYEbsae
To creat the most popular AZ-104 exam questions in the market, we have been working hard on the compiling the content and design the displays. And our professional experts have been studying and doing reseach on the AZ-104 study materials for a long time. These experts spent a lot of time before the AZ-104 Study Materials officially met with everyone. They spent a lot of time to collate data and carefully studied the characteristics of the stocks to make sure every detail is perfect.
The Microsoft AZ-104 certification brings multiple career benefits. Reputed firms happily hire you for well-paid jobs when you earn the Microsoft Azure Administrator. If you are already an employee of a tech company, you get promotions and salary hikes upon getting the AZ-104 credential. All these career benefits come when you crack the Microsoft AZ-104 certification examination. To pass the AZ-104 test, you need to prepare well from updated practice material such as real Microsoft AZ-104 Exam Questions.
Free PDF Quiz Microsoft - AZ-104 - Microsoft Azure Administrator –Reliable Reliable Exam BootcampWith rigorous analysis and summary of AZ-104 exam, we have made the learning content easy to grasp and simplified some parts that beyond candidates' understanding. In addition, we add diagrams and examples to display an explanation in order to make the interface more intuitive. Our AZ-104 exam questions will ease your pressure of learning, using less Q&A to convey more important information, thus giving you the top-notch using experience if you study with our AZ-104 Training Materials. And with the high pass rate of 99% to 100%, the AZ-104 exam will be a piece of cake for you.
Microsoft Azure Administrator Sample Questions (Q239-Q244):NEW QUESTION # 239
You have an Azure subscription that contains the vaults shown in the following table.
You deploy the virtual machines shown in the following table.
Each of the following statements, select Yes if the statement is true. Otherwise, select No NOTE: Each cored selection it worth one point.
NEW QUESTION # 240
You have an Azure subscription named Subcription1 that contains a resource group named RG1.
In RG1. you create an internal load balancer named LB1 and a public load balancer named 162.
You need to ensure that an administrator named Admin 1 can manage LB1 and LB2. The solution must follow the principle of least privilege.
Which role should you assign to Admin1 for each task? To answer, select the appropriate options in the answer area.
NOTE: Caen correct selection is worth one point.
Box 1: Network Contributor on RG1
To add to the backend pool, write permission is required on the Resource Group because it writes deployment information. To add a backend pool, you need network contributor role on the LB and on the VMs that will be part of the backend pool.
For this reason the network contributor role must be assigned to the RG where the LB and the VM resides. So the correct answer is Network Contributor on RG1 .
Box 2: Network Contributor on RG1
For Health Probe also, without having access to RG1, no health probe can be added. If only Network Contributor role is assigned to LB then the user would not be able to access the IP addresses of the member pools.
Owner/Contributor can give the user access for everything. So it will not fit into the the principle of least privilege. Hence Owner and contributor role is incorrect choices for the question.
https://docs.microsoft.com/en-us ... trol/built-in-roles
NEW QUESTION # 241
You are developing an Azure web app named WebApp1. WebApp1 uses an Azure App Service plan named Plan1 that uses the B1 pricing tier.
You need to configure WebApp1 to add additional instances of the app when CPU usage exceeds 70 percent for 10 minutes.
https://azure.microsoft.com/en-u ... pp-service/windows/
https://blogs.msdn.microsoft.com ... ing-azure-web-apps/
NEW QUESTION # 242
You have an Azure Subscription named Subcription1.has
Subcription1 contains the virtual machines in the following table.
VM3 has multiple network, including a network adapter named NIC3, IP forwarding is enabled on NIC3. Routing is enabled on VM3.
You create a route table named RT1 that contains the routes in the following table.
You apply RT1 to subnet1 and Sybnet2.
For each of the following statements, select Yes if the statements is true. Otherwise, select No.
IP forwarding enables the virtual machine a network interface is attached to:
Receive network traffic not destined for one of the IP addresses assigned to any of the IP configurations assigned to the network interface.
Send network traffic with a different source IP address than the one assigned to one of a network interface's IP configurations.
The setting must be enabled for every network interface that is attached to the virtual machine that receives traffic that the virtual machine needs to forward. A virtual machine can forward traffic whether it has multiple network interfaces or a single network interface attached to it.
Box 1: Yes
The routing table allows connections from VM3 to VM1 and VM2. And as IP forwarding is enabled on VM3, VM3 can connect to VM1.
Box 2: No
VM3, which has IP forwarding, must be turned on, in order for VM2 to connect to VM1.
Box 3: Yes
The routing table allows connections from VM1 and VM2 to VM3. IP forwarding on VM3 allows VM1 to connect to VM2 via VM3.
https://docs.microsoft.com/en-us ... tworks-udr-overview
https://www.quora.com/What-is-IP-forwarding
NEW QUESTION # 243
You have an Azure subscription that contains a user account named User1.
You need to ensure that User1 can assign a policy to the tenant root management group.
What should you do?
  • A. Assign the Global administrator role to User1, and then instruct User1 to configure access management for Azure resources.
  • B. Create a new management group and delegate User1 as the owner of the new management group.
  • C. Assign the Owner role for the Azure subscription to User1, and then modify the default conditional access policies.
  • D. Assign the Owner role for the Azure subscription to User1, and then instruct User1 to configure access management for Azure resources.
The following chart shows the list of roles and the supported actions on management groups.
Note:
Each directory is given a single top-level management group called the "Root" management group. This root management group is built into the hierarchy to have all management groups and subscriptions fold up to it.
This root management group allows for global policies and Azure role assignments to be applied at the directory level. The Azure AD Global Administrator needs to elevate themselves to the User Access Administrator role of this root group initially. After elevating access, the administrator can assign any Azure role to other directory users or groups to manage the hierarchy. As administrator, you can assign your own account as owner of the root management group.
https://docs.microsoft.com/en-us ... ent-groups/overview
NEW QUESTION # 244
At present, our company has launched all kinds of AZ-104 study materials, which almost covers all official tests. Every AZ-104 exam questions are going through rigid quality check before appearing on our online stores. So you do not need to worry about trivial things and concentrate on going over our AZ-104 Exam Preparation. After careful preparation, you are bound to pass the AZ-104 exam. Just remember that all your efforts will finally pay off.
Certification AZ-104 Dump: https://www.lead2passed.com/Microsoft/AZ-104-practice-exam-dumps.html
So if you persist in your effort with the help of our AZ-104 study guide, you can totally make it, Download of AZ-104 dumps pdf actual exam materials and tutorials for Microsoft certification for customers, Real Success Guaranteed with Updated AZ-104 exam questions and answers pdf pdf dumps Materials, First, you can download the trial of AZ-104 dumps free before you buy so that you can know our dumps well.
See my article How Blogging Can Help Your Career" for more on how to start blogging, AZ-104 For example, most commercial databases provide a set of system tables that contain metadata in the form of descriptions of the application tables.
Microsoft - AZ-104 - Microsoft Azure Administrator Reliable Exam BootcampSo if you persist in your effort with the help of our AZ-104 Study Guide, you can totally make it, Download of AZ-104 dumps pdf actual exam materials and tutorials for Microsoft certification for customers, Real Success Guaranteed with Updated AZ-104 exam questions and answers pdf pdf dumps Materials.
First, you can download the trial of AZ-104 dumps free before you buy so that you can know our dumps well, They are software, PDF and APP version of the AZ-104 guide torrent: Microsoft Azure Administrator.
If you still feel upset about your exams and wonder how to pass exam, our AZ-104 exam resources can help you pass exam for sure.
What's more, part of that Lead2Passed AZ-104 dumps now are free: https://drive.google.com/open?id=1U2GpRM-f2K7RSt12jpiml_wm0bYEbsae
Posted at 2/17/2026 17:50:38        Only Author  2#
Your article is outstanding, thank you for sharing! The Valid test Health-Fitness-and-Wellness questions vce exam that helped me achieve a promotion and pay raise is free today for you to use. Best of luck on your professional journey!
Posted at 2/21/2026 10:20:04        Only Author  3#
Your article really stuck with me, I’m sincerely grateful. Strengthen your IT abilities with free Exam HPE0-S59 registration. Good luck with your exams!
