DP-420 Book Free & DP-420 Latest Test Preparation
Posted at 1/29/2026 04:05:39
View131
Replies1
What's more, part of that PassTestking DP-420 dumps now are free: https://drive.google.com/open?id=1kv_fOqSidYy1HFgD34Sz4MOCdBE6V_1n
Most customers reflected that our Microsoft exam questions cover most of questions of actual test. So if you decided to choose DP-420 as your study materials, you just need to spend your spare time to practice DP-420 Dumps PDF and remember the points of pass exam guide. Our latest vce dumps are the guarantee of clear exam.
Microsoft DP-420 (Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB) certification exam is designed for professionals who want to demonstrate their expertise in designing and implementing cloud-native applications using Microsoft Azure Cosmos DB. Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB certification validates the candidate's ability to design and implement scalable and highly available cloud-native applications using Azure Cosmos DB.
Microsoft DP-420 Exam is an industry-recognized certification designed for professionals who want to prove their expertise in designing and implementing cloud-native applications using Microsoft Azure Cosmos DB. This is an advanced-level exam that tests the candidate's knowledge and skills in cloud-native application development, Azure Cosmos DB, and other related technologies.
DP-420 Latest Test Preparation | Free DP-420 Exam DumpsYou will get a lot of personal and professional benefits after passing the Microsoft DP-420 test. The Microsoft DP-420 exam is a valuable credential that will assist you to advance your career. The Microsoft DP-420 is a way to increase your knowledge and skills. You can also trust on PassTestking and start Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB DP-420 test preparation with Microsoft DP-420 practice test material.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q129-Q134):NEW QUESTION # 129
You plan to implement con-iot1 and con-iot2.
You need to configure the default Time to Live setting for each container. The solution must meet the loT telemetry requirements.
What should you configure? To answer, select the appropriate options in the answer NOTE: Each correct selection is worth one point.
Box 1 = On (no default)For con-iot1, you need to configure the default TTL setting to On (no default), which means that items in this container do not expire by default, but you can override the TTL value on a per-item basis. This meets the requirement of retaining all telemetry data unless overridden1.
Box 2 = On (3600 seconds)For con-iot2, you need to configure the default TTL setting to On (3600 seconds), which means that items in this container will expire 3600 seconds (one hour) after their last modified time. This meets the requirement of deleting all telemetry data older than one hour1.
NEW QUESTION # 130
You have an Apache Spark pool in Azure Synapse Analytics that runs the following Python code in a notebook.
New and updated orders will be added to contoso-erp.orders: Yes
The code performs bulk data ingestion from contoso-app: No
Both contoso-app and contoso-erp have Analytics store enabled: Yes
The code uses the spark.readStream method to read data from a container named orders in a database named contoso-app. The data is then filtered by a condition and written to another container named orders in a database named contoso-erp using the spark.writeStream method. The write mode is set to "append", which means that new and updated orders will be added to the destination container1.
The code does not perform bulk data ingestion from contoso-app, but rather stream processing. Bulk data ingestion is a process of loading large amounts of data into a data store in batches. Stream processing is a process of continuously processing data as it arrives in real-time2.
Both contoso-app and contoso-erp have Analytics store enabled, because they are both accessed by Spark pools using the spark.cosmos.oltp method. This method requires that the containers have Analytics store enabled, which is a feature that allows Spark pools to query data stored in Azure Cosmos DB containers using SQL APIs3.
NEW QUESTION # 131
The following is a sample of a document in orders.
The orders container uses customer as the partition key.
You need to provide a report of the total items ordered per month by item type. The solution must meet the following requirements:
Ensure that the report can run as quickly as possible.
Minimize the consumption of request units (RUs).
What should you do?
- A. Configure the report to query a new aggregate container. Populate the aggregates by using SQL queries that run daily.
- B. Configure the report to query a new aggregate container. Populate the aggregates by using the change feed.
- C. Configure the report to query orders by using a SQL query through a dedicated gateway.
- D. Configure the report to query orders by using a SQL query.
You can facilitate aggregate data by using Change Feed and Azure Functions, and then use it for reporting.
Reference: https://docs.microsoft.com/en-us/azure/cosmos-db/change-feed
NEW QUESTION # 132
You are designing a data model for an Azure Cosmos DB for NoSQL account.
What are the partition limits for request units per second (RU/s) and storage? To answer, select the appropriate options in the answer area.
NEW QUESTION # 133
You have an Azure Cosmos DB for NoSQL account named account1 that supports an application named App1. App1 uses the consistent prefix consistency level.
You configure account1 to use a dedicated gateway and integrated cache.
You need to ensure that App1 can use the integrated cache.
Which two actions should you perform for APP1? Each correct answer presents part of the solution.
Answer: B,E
the Azure Cosmos DB integrated cache is an in-memory cache that is built-in to the Azure Cosmos DB dedicated gateway. The dedicated gateway is a front-end compute that stores cached data and routes requests to the backend database. You can choose from a variety of dedicated gateway sizes based on the number of cores and memory needed for your workload1. The integrated cache can reduce the RU consumption and latency of read operations by serving them from the cache instead of the backend containers2.
For your scenario, to ensure that App1 can use the integrated cache, you should perform these two actions:
* Change the account endpoint to https://account1.sqlx.cosmos.azure.com. This is the dedicated gateway endpoint that you need to use to connect to your Azure Cosmos DB account and leverage the integrated cache. The standard gateway endpoint (https://account1.documents.azure.com) will not use the integrated cache2.
* Change the consistency level of requests to session. This is the highest consistency level that is supported by the integrated cache. If you use a higher consistency level (such as strong or bounded staleness), your requests will bypass the integrated cache and go directly to the backend containers
NEW QUESTION # 134
To cater to the different needs of different customers, our product for DP-420 exam have provide three different versions of practice materials. I f you are more like the paper version, then PDF version will be your choice, since this version can be printed. If you are more likely to use the computer, the Desktop version is your choice, this version can provide you the feeling of the Real DP-420 Exam.If you prefer to practice the materials on online, then online version is your choice, this version support all web browers, and you can practice it in your free time if you want. Just try it, there is always a version for you.
DP-420 Latest Test Preparation: https://www.passtestking.com/Microsoft/DP-420-practice-exam-dumps.html
- DP-420 Test Question 🔑 Latest DP-420 Test Voucher 🔰 Reliable DP-420 Exam Syllabus 👄 Open ⮆ [url]www.validtorrent.com ⮄ and search for ⮆ DP-420 ⮄ to download exam materials for free 💎DP-420 Exam Sample Online[/url]
- DP-420 training materials - DP-420 exam torrent - DP-420 dumps torrent 🎿 Search for ✔ DP-420 ️✔️ and download it for free on [url]www.pdfvce.com website 🔝DP-420 Reliable Test Book[/url]
- www.vce4dumps.com Microsoft DP-420 Dumps PDF Preparation Material is Available 📉 Open [url]www.vce4dumps.com enter ⏩ DP-420 ⏪ and obtain a free download 🪁Certification DP-420 Exam[/url]
- DP-420 Lead2pass Review 🔡 DP-420 Valid Study Materials 🏞 DP-420 Exam Sample Online 🥒 Download ▶ DP-420 ◀ for free by simply searching on [url]www.pdfvce.com 🦀DP-420 Latest Torrent[/url]
- DP-420 Lead2pass Review 💛 DP-420 Lead2pass Review ↪ Reliable DP-420 Dumps Ebook 🔝 Open website ▶ [url]www.vce4dumps.com ◀ and search for DP-420 for free download 🐠
ractice DP-420 Engine[/url] - DP-420 Exam Book Free - Valid DP-420 Latest Test Preparation Pass Success 🕷 Search for ⮆ DP-420 ⮄ and easily obtain a free download on [url]www.pdfvce.com 🍶Reliable DP-420 Dumps Ebook[/url]
- Pass Guaranteed Quiz Microsoft - DP-420 Updated Book Free 🥿 Go to website ▶ [url]www.prep4sures.top ◀ open and search for ⇛ DP-420 ⇚ to download for free 😭Certification DP-420 Exam[/url]
- Latest DP-420 Test Voucher 🎃 DP-420 Reliable Test Book 💬 Reliable DP-420 Exam Syllabus ❤ Open website ⇛ [url]www.pdfvce.com ⇚ and search for DP-420 for free download ✡Interactive DP-420 Questions[/url]
- DP-420 training materials - DP-420 exam torrent - DP-420 dumps torrent ✳ Simply search for ➡ DP-420 ️⬅️ for free download on ➽ [url]www.prep4sures.top 🢪 🙊Interactive DP-420 Questions[/url]
- Pass Guaranteed Quiz Microsoft - DP-420 Updated Book Free 🧉 Enter [url]www.pdfvce.com and search for ➠ DP-420 🠰 to download for free 🏹100% DP-420 Accuracy[/url]
- Microsoft DP-420 Dumps For Quick Exam Preparation 2026 🤘 Search for ➠ DP-420 🠰 and download it for free on { [url]www.practicevce.com } website 🍎Valid DP-420 Exam Guide[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
P.S. Free 2026 Microsoft DP-420 dumps are available on Google Drive shared by PassTestking: https://drive.google.com/open?id=1kv_fOqSidYy1HFgD34Sz4MOCdBE6V_1n
