[General] AZ-120 Free Sample, AZ-120 Valid Test Labs
80
General AZ-120 Free Sample, AZ-120 Valid Test Labs
Posted at 1/29/2026 05:33:01      View125 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamcollectionPass AZ-120 dumps for free: https://drive.google.com/open?id=1HzPy8YnZhjML0kKoWz4xsBYi2wYcPGck
Overall obtaining AZ-120 certificate can be a valuable investment in your professional career. As it can help you to stand out in a competitive market, more career opportunities, and advancement of your career. To gain all these advantages you just need to enroll in the Microsoft AZ-120 Certification Exam and put all your efforts to pass this challenging AZ-120 exam with flying colors.
Microsoft AZ-120 exam is designed to assess the skills of IT professionals in planning and administering Microsoft Azure for SAP workloads. Planning and Administering Microsoft Azure for SAP Workloads certification is ideal for those who want to demonstrate their expertise in deploying and managing SAP workloads on Azure. Candidates who pass the AZ-120 Exam earn the Microsoft Certified: Azure for SAP Workloads Specialty certification, which demonstrates their ability to design, implement, and manage SAP solutions on Azure.
AZ-120 Valid Test Labs & New AZ-120 Exam ObjectivesExamcollectionPass offers a full refund guarantee according to terms and conditions if you are not satisfied with our AZ-120 product. You can also get free Microsoft Dumps updates from ExamcollectionPass within up to 365 days of purchase. This is a great offer because it helps you prepare with the Latest AZ-120 Dumps even in case of real Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) exam changes.
Microsoft AZ-120 is a certification exam that focuses on planning and administering Microsoft Azure for SAP Workloads. Planning and Administering Microsoft Azure for SAP Workloads certification is designed for professionals who are responsible for managing and deploying SAP workloads on Azure. AZ-120 Exam evaluates the candidate's abilities to configure, manage, and monitor Azure resources that are used in the context of SAP workloads.
Microsoft Planning and Administering Microsoft Azure for SAP Workloads Sample Questions (Q135-Q140):NEW QUESTION # 135
You have an on-premises SAP environment.
Backups are performed by using tape backups. There are SO TB of backups.
A Windows file server has BMP images of checks used by SAP Finance. There are 9 IB of images.
You need to recommend a method to migrate the images and the tape backups to Azure. The solution must maintain continuous replication of the images.
What should you include in the recommendation? To answer, select the appropriate options in the answer area.
Tape Backups - Azure Databox
File Server - Azure Storage Explorer
NEW QUESTION # 136
You are deploying an SAP production landscape to Azure.
Your company's chief information security officer (CISO) requires that the SAP deployment complies with ISO 27001.
You need to generate a compliance report for ISO 27001.
What should you use?
  • A. Azure Monitor
  • B. Azure Log Analytics
  • C. Azure Security Center
  • D. Azure Active Directory (Azure AD)
In the Azure Security Center regulatory compliance blade, you can get an overview of key portions of your compliance posture with respect to a set of supported standards. Currently supported standards are Azure CIS, PCI DSS 3.2, ISO 27001, and SOC TSP.
https://azure.microsoft.com/en-u ... nter-now-available/
NEW QUESTION # 137
You have an SAP environment on Azure.
You use Azure Recovery Services to back up an SAP application server.
You need to test the restoration process of a file on the server.
Step 1: From Azure Recover Vault, select File Recovery
To restore files or folders from the recovery point, go to the virtual machine and choose the desired recovery point.
Step 2: Download and run the mount disk executable
Step 3: recover the file and unmount the disk
NEW QUESTION # 138
You have an on-premises deployment of SAP HANA.
You plan to migrate the deployment to Azure.
You need to identify the following from the last six months:
The number of active users
The database performance
https://assets.cdn.sap.com/sapco ... a3-c30de2ffd8ff.pdf
NEW QUESTION # 139
You plan to deploy SAP HANA to an Azure virtual machine that has a constrained vCPU size.
You need to validate that the virtual machine complies with SAP-defined resource requirements by using the SAP HANA Hardware and Cloud Measurement Tools (HCMT).
In which order should you perform the actions? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
Table Description automatically generated with low confidence
NEW QUESTION # 140
AZ-120 Valid Test Labs: https://www.examcollectionpass.com/Microsoft/AZ-120-practice-exam-dumps.html
P.S. Free & New AZ-120 dumps are available on Google Drive shared by ExamcollectionPass: https://drive.google.com/open?id=1HzPy8YnZhjML0kKoWz4xsBYi2wYcPGck
