[Hardware] Reliable AZ-204 Exam Simulations - Microsoft Developing Solutions for Microsoft
126
【Hardware】 Reliable AZ-204 Exam Simulations - Microsoft Developing Solutions for Microsoft
Posted at 1/29/2026 05:49:04      View:119 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New AZ-204 dumps are available on Google Drive shared by DumpStillValid: https://drive.google.com/open?id=1PX8qhHCSE-HXJL_Aul2ZPoPrMbmqreiF
Our AZ-204 exam dumps are possessed with high quality which is second to none. Just as what have been reflected in the statistics, the pass rate for those who have chosen our AZ-204 exam guide is as high as 99%. In addition, our AZ-204 test prep is renowned for free renewal in the whole year. With our AZ-204 Training Materials, you will find that not only you can pass and get your certification easily, but also your future is obvious bright. Our AZ-204 training guide is worthy to buy.
Although it is not an easy thing for most people to pass the exam, therefore, they can provide you with efficient and convenience learning platform, so that you can obtain as many certificates as possible in the shortest time. We provide all candidates with AZ-204 test torrent that is compiled by experts who have good knowledge of exam, and they are very experience in compile study materials. Not only that, our team checks the update every day, in order to keep the latest information of AZ-204 latest question. Once we have latest version, we will send it to your mailbox as soon as possible.
New AZ-204 Dumps & AZ-204 Online ExamTo learn more about our AZ-204 exam braindumps, feel free to check our AZ-204 Exams and Certifications pages. You can browse through our AZ-204 certification test preparation materials that introduce real exam scenarios to build your confidence further. Choose from an extensive collection of products that suits every AZ-204 Certification aspirant. You can also see for yourself how effective our methods are, by trying our free demo. So why choose other products that can’t assure your success? With DumpStillValid, you are guaranteed to pass AZ-204 certification on your very first try.
Microsoft Developing Solutions for Microsoft Azure Sample Questions (Q11-Q16):NEW QUESTION # 11
A web service provides customer summary information for e-commerce partners. The web service is implemented as an Azure Function app with an HTTP trigger. Access to the API is provided by an Azure API Management instance. The API Management instance is configured in consumption plan mode. All API calls are authenticated by using OAuth.
API calls must be cached. Customers must not be able to view cached data for other customers.
You need to configure API Management policies for caching.
How should you complete the policy statement?
https://docs.microsoft.com/en-us ... nt-caching-policies
NEW QUESTION # 12
You need to add code at line PC32 in Processing.cs to implement the GetCredentials method in the Processing class.
How should you complete the code? To answer, drag the appropriate code segments to the correct locations.
Each code segment may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Box 1: AzureServiceTokenProvider()
Box 2: tp.GetAccessTokenAsync("..")
Acquiring an access token is then quite easy. Example code:
private async Task<string> GetAccessTokenAsync()
var tokenProvider = new AzureServiceTokenProvider();
return await tokenProvider.GetAccessTokenAsync("https://storage.azure.com/");
https://joonasw.net/view/azure-a ... ed-service-identity
NEW QUESTION # 13
You are developing an ASP.NET Core website that can be used to manage photographs which are stored in Azure Blob Storage containers.
Users of the website authenticate by using their Azure Active Directory (Azure AD) credentials.
You implement role-based access control (RBAC) role permissions on the containers that store photographs.
You assign users to RBAC roles.
You need to configure the website's Azure AD Application so that user's permissions can be used with the Azure Blob containers.
How should you configure the application? To answer, drag the appropriate setting to the correct location.
Each setting can be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Box 1: user_impersonation
Box 2: delegated
Example:
1. Select the API permissions section
2. Click the Add a permission button and then:
Ensure that the My APIs tab is selected
3. In the list of APIs, select the API TodoListService-aspnetcore.
4. In the Delegated permissions section, ensure that the right permissions are checked: user_impersonation.
5. Select the Add permissions button.
Box 3: delegated
Example
2. Click the Add a permission button and then,
Ensure that the Microsoft APIs tab is selected
3. In the Commonly used Microsoft APIs section, click on Microsoft Graph
4. In the Delegated permissions section, ensure that the right permissions are checked: User.Read. Use the search box if necessary.
https://docs.microsoft.com/en-us ... bapi-openidconnect-
NEW QUESTION # 14
You are developing an application that use an Azure blob named data to store application data. The application creates blob snapshots to allow application state to be reverted to an earlier state. The Azure storage account has soft deleted enabled.
The system performs the following operations in order:
*The blob is updated
*Snapshot 1 is created.
*Snapshot 2 is created.
*Snapshot 1 is deleted.
A system error then deletes the data blob and all snapshots.
You need to determine which application states can be restored.
What is the restorability of the application data? To answer, select the appropriate options in the answer area.
Box 1: Can be restored
When enabled, soft delete enables you to save and recover your data when blobs or blob snapshots are deleted.
This protection extends to blob data that is erased as the result of an overwrite.
Box 2: Cannot be restored
It has been deleted.
Box 3: Can be restored
It has not been deleted.
https://docs.microsoft.com/en-us ... ge-blob-soft-delete
NEW QUESTION # 15
You implement role-based access control (RBAC) role permission on the containers that store photographs. You assign users to RBAC role.
How should you configure the application? To answer, drag the appropriate setting to the correct location. Each setting may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
https://docs.microsoft.com/en-us ... ion-using-azure-ad/
NEW QUESTION # 16
We provide the update freely of AZ-204 exam questions within one year and 50% discount benefits if buyers want to extend service warranty after one year. The old client enjoys some certain discount when buying other exam materials. We update the AZ-204 guide torrent frequently and provide you the latest study materials which reflect the latest trend in the theory and the practice. So you can master the Developing Solutions for Microsoft Azure test guide well and pass the exam successfully. While you enjoy the benefits we bring you can pass the exam. Don’t be hesitated and buy our AZ-204 Guide Torrent immediately!
New AZ-204 Dumps: https://www.dumpstillvalid.com/AZ-204-prep4sure-review.html
Microsoft Reliable AZ-204 Exam Simulations We will help you in the first time, Microsoft Reliable AZ-204 Exam Simulations Study training materials anywhere you want, Microsoft Reliable AZ-204 Exam Simulations We provide live chat support 24 hours per day, 7 days a week to our customers, Just rush to buy our AZ-204 practice guide, Microsoft Reliable AZ-204 Exam Simulations ITCertKey is a good website that involves many IT exam materials.
This will make the entire process of setting up and implementing AZ-204 success events much easier, Charging Expenses to a Customer, We will help you in the first time.
Study training materials anywhere you want, We provide live chat support 24 hours per day, 7 days a week to our customers, Just rush to buy our AZ-204 practice guide!
Microsoft Reliable AZ-204 Exam Simulations & DumpStillValid - Leading Provider in Certification Exams MaterialsITCertKey is a good website that involves many IT exam materials.
BONUS!!! Download part of DumpStillValid AZ-204 dumps for free: https://drive.google.com/open?id=1PX8qhHCSE-HXJL_Aul2ZPoPrMbmqreiF
Posted at 2/11/2026 08:58:38        Only Author  2#
This article is incredible, thank you for sharing it! The Latest exam C_P2WFI_2023 simulator online content is of high value, and it’s free to access.
Posted at 2/20/2026 06:13:16        Only Author  3#
Your article has truly left me speechless, thank you for sharing! Wishing you success! Here are the free 820-605 valid test cram sheet test materials.
