[General] Plat-Dev-210 Latest Test Questions, Plat-Dev-210 Reliable Test Pdf
98
General Plat-Dev-210 Latest Test Questions, Plat-Dev-210 Reliable Test Pdf
Posted at 1/29/2026 08:44:01      View155 | Replies2        Print      Only Author   [Copy Link] 1#
We will be happy to assist you with any questions regarding our products. Our Plat-Dev-210 practice exam Easy4Engine helps to prepare applicants to practice time management, problem-solving, and all other tasks on the standardized Plat-Dev-210 Exam and lets them check their scores. The Plat-Dev-210 results help students to evaluate their performance and determine their readiness without difficulty.
Salesforce Plat-Dev-210 Exam Syllabus Topics:
  • Integrated Troubleshooting and Deployment: This final section measures the skills of a Support Engineer and focuses on identifying and resolving issues within Omnistudio tools. It involves diagnosing errors based on given scenarios and determining where breakdowns occur in the data flow for specific customer issues. This ensures the candidate can effectively troubleshoot, debug, and maintain solutions to ensure optimal performance and reliability.
  • Omnistudio Data Mappers: This part of the exam measures the skills of a Data Engineer and focuses on the use of Omnistudio Data Mappers for extracting, transforming, and loading data. It includes identifying the appropriate Data Mapper for a given requirement, as well as determining the necessary Extract, Load, Transform, and Turbo Extract functionalities based on specific use cases. This section ensures the candidate can effectively map and manipulate data to support business processes.
  • Flexcards: This section of the exam measures the skills of a Solution Architect and covers the ability to design and configure FlexCards based on specific business requirements. It evaluates the candidate's knowledge in selecting appropriate card styles, defining data sources and fields, and implementing user actions across different card states. Additionally, this domain tests the understanding of constructing the underlying JSON data structure that powers the FlexCards framework, ensuring that the configured cards meet both functional and technical specifications.
Accurate Salesforce Plat-Dev-210 Exam Dumps With 100% Success RateOur Plat-Dev-210 guide questions boost many advantages and varied functions. You can have a free download and tryout of our product before the purchase and our purchase procedures are safe. Our software carries no viruses and we provide 3 versions for you to choose. You need little time to learn the Plat-Dev-210 Exam Torrent and prepare the exam. Our passing rate and the hit rate is very high. After you pass the exam you will gain a lot of benefits such as enter in the big company and double your wage.
Salesforce Certified Omnistudio Developer Sample Questions (Q43-Q48):NEW QUESTION # 43
A healthcare company wants to enable its subscribers to add, edit, or delete dependents related to their policy Community portal. The developer on the project decides to use an MniScript.
How should the developer configure the OmniScript to providethis functionality?
  • A. Use a Text Block element and a Remote Action element.
  • B. Use an Input Block element and a DataRaptor Post Action element.
  • C. Use an Edit Block element configured with Remote Actions.
  • D. Use an Edit Block element configured with SOQL statements.
An Edit Block element configured with Remote Actions allows the developer to create a dynamic table that can display, add, edit, or delete records from a Salesforce object. The Remote Actions can be configured to perform CRUD operations on the object using SOQL or Apex.
NEW QUESTION # 44
Which two fields in an Integration Procedure can use a function like CONCAT or DATEDIFF?
Choose 2 answers
  • A. In Procedure Configuration, in a Tracking Custom Data value field.
  • B. In a Remote Action, in a Remote Options value field.
  • C. In a Remote Action, in an Additional Output value field.
  • D. In a Response Action, in an Additional input value field.
According to the Integration Procedure Actions page, a Remote Action can use a function in an Additional Output value field or in a Remote Options value field. According to the Response Actions page, a Response Action can use a function in an Additional Input value field.
NEW QUESTION # 45
An OmniScript displays data from an API using Integration Procedure, but some of the data is missing.
Which two configuration errors could cause this? Choose 2 answers
  • A. The Integration Procedure Preview Input Parameters do not match the JSON sent from the OmniScript.
  • B. The missing data is trimmed in the Integration Procedure Action Response JSON Path.
  • C. The element name for the missing data does not match the JSON node key in the Integration Procedure Response.
  • D. The JSOW sent from the Integration Procedure Action does not match any of the Original Input for the Integration Procedure
The element name for the missing data must match the JSON node key in the Integration Procedure Response, otherwise the data will not be mapped correctly. The JSON sent from the Integration Procedure Action must match one of the Original Input for the Integration Procedure, otherwise the Integration Procedure will not execute properly. The Integration Procedure Preview Input Parameters and the Response JSON Path have no effect on displaying data in OmniScript.
NEW QUESTION # 46
A healthcare company wants to enable its subscribers to add, edit, or delete dependents related to their policy via their Community portal. The developer on the project decides to use an OmniScript.
How should the developer configure the OmniScript to provide this functionality?
  • B. Use an Edit Block element configured with Remote Actions.
  • C. Use an Input Block element and a Data Mapper Post Action element.
In OmniStudio, the Edit Block element is purpose-built for allowing users to dynamically add, edit, or delete rows of related data, such as dependents under a policy. To save these changes, Remote Actions (typically backed by Apex or API) are used to process each record operation (Create/Update/Delete).
* A. Use an Edit Block element configured with Remote Actions - Correct. This is the recommended and most scalable way to support CRUD operations in OmniScripts for collections (e.g., dependents).
The Edit Block provides UI-level support, while Remote Actions handle back-end interaction with Salesforce or external systems.
Incorrect Options:
* B. Text Block is for display purposes and cannot manage data input or backend actions.
* C. Input Block elements do not support row-level add/edit/delete functionality as Edit Blocks do.
* D. SOQL is a read-only query language and cannot be used to update or delete records directly within an OmniScript.
Salesforce OmniStudio Guide # OmniScript Edit Block Element
OmniStudio Best Practices # CRUD Operations in OmniScripts
NEW QUESTION # 47
All inputs to the Calculation Matric are set correctly.
The Calculation Matrix has the following input:
What is the output?
  • A. Null
  • B. 13.99
  • C. 12.99,13.99
  • D. 12.99
According to the Calculation Matrix Overview page, a Calculation Matrix is "a lookup table that takes an input and returns an output". In this case, the input is the ProductCode and the output is the Price. The exhibit shows a Calculation Matrix with four rows, each with a different ProductCode and Price. The input given is ProductCode: HRA3320, which matches the second row of the matrix. Therefore, the output is Price: 13.99, which is the value in the same row.
NEW QUESTION # 48
Our Plat-Dev-210 study materials are compiled and tested by our expert. Plat-Dev-210 try hard to makes Plat-Dev-210 exam preparation easy with its several quality features. We send learning information in the form of questions and answers, and our Plat-Dev-210 study materials are highly relevant to what you need to pass Plat-Dev-210 certification exam. Our free demo will show you the actual Plat-Dev-210 Certification Exam. You can learn about real exams in advance by studying our Plat-Dev-210 study materials and improve your confidence in the exam so that you can pass Plat-Dev-210 exams with ease. This is also the reason that has been popular by the majority of candidates.
Plat-Dev-210 Reliable Test Pdf: https://www.easy4engine.com/Plat-Dev-210-test-engine.html
Posted at 2/7/2026 19:01:50        Only Author  2#
That article opened up a whole new world of ideas for me. New BAPv5 exam camp pdf provides excellent material, and it's entirely free of charge.
Posted at 2/12/2026 03:12:34        Only Author  3#
Your article really shocked me; thank you for sharing! Please wish me all the best for the upcoming Latest exam camp 1z0-1046-25 file exam!
