DVA-C02 Exam Guide - DVA-C02 Test Questions & DVA-C02 Exam Torrent
Posted at 1/29/2026 11:10:33
2026 Latest Actualtests4sure DVA-C02 PDF Dumps and DVA-C02 Exam Engine Free Share: https://drive.google.com/open?id=1laZ4vNvAKyxpPfTkGMEduLBRjiG4OUGX
Professional guidance is indispensable for a candidate. As a leader in the field, our DVA-C02 learning prep has owned more than ten years’ development experience. Thousands of candidates have become excellent talents after obtaining the DVA-C02 certificate. If you want to survive in the exam, our DVA-C02 actual test guide is the best selection. Firstly, our study materials can aid you study, review and improvement of all the knowledge. In addition, you do not need to purchase other reference books. Our DVA-C02 Exam Questions are able to solve all your problems of preparing the exam. Of course, our study materials are able to shorten your learning time. You will have more spare time to do other things. And we can ensure you to pass the DVA-C02 exam.
Amazon DVA-C02 (AWS Certified Developer - Associate) Certification Exam is a highly sought-after certification in the IT industry. It is designed for developers who want to validate their skills in developing and deploying applications on the AWS platform. AWS Certified Developer - Associate certification exam is a great way to demonstrate your knowledge and expertise in AWS and its associated services.
Reliable DVA-C02 Dumps Book, Free DVA-C02 Study MaterialEveryone has different learning habits, DVA-C02 exam simulation provide you with different system versions: PDF version, Software version and APP version. Based on your specific situation, you can choose the version that is most suitable for you, or use multiple versions at the same time. After all, each version of DVA-C02 Preparation questions have its own advantages. If you are very busy, you can only use some of the very fragmented time to use our DVA-C02 study materials. And each of our DVA-C02 exam questions can help you pass the exam for sure.
Amazon AWS Certified Developer - Associate Sample Questions (Q62-Q67):NEW QUESTION # 62
A developer is troubleshooting an Amazon API Gateway API Clients are receiving HTTP 400 response errors when the clients try to access an endpoint of the API.
How can the developer determine the cause of these errors?
- A. Create an Amazon Kinesis Data Firehose delivery stream to receive API call logs from API Gateway. Configure Amazon CloudWatch Logs as the delivery stream's destination.
- B. Turn on execution logging and access logging in Amazon CloudWatch Logs for the API stage. Create a CloudWatch Logs log group. Specify the Amazon Resource Name (ARN) of the log group for the API stage.
- C. Turn on AWS CloudTrail Insights and create a trail Specify the Amazon Resource Name (ARN) of the trail for the stage of the API.
- D. Turn on AWS X-Ray for the API stage Create an Amazon CtoudWalch Logs log group Specify the Amazon Resource Name (ARN) of the log group for the API stage.
This solution will meet the requirements by using Amazon CloudWatch Logs to capture and analyze the logs from API Gateway. Amazon CloudWatch Logs is a service that monitors, stores, and accesses log files from AWS resources. The developer can turn on execution logging and access logging in Amazon CloudWatch Logs for the API stage, which enables logging information about API execution and client access to the API. The developer can create a CloudWatch Logs log group, which is a collection of log streams that share the same retention, monitoring, and access control settings. The developer can specify the Amazon Resource Name (ARN) of the log group for the API stage, which instructs API Gateway to send the logs to the specified log group. The developer can then examine the logs to determine the cause of the HTTP 400 response errors. Option A is not optimal because it will create an Amazon Kinesis Data Firehose delivery stream to receive API call logs from API Gateway, which may introduce additional costs and complexity for delivering and processing streaming data. Option B is not optimal because it will turn on AWS CloudTrail Insights and create a trail, which is a feature that helps identify and troubleshoot unusual API activity or operational issues, not HTTP response errors. Option C is not optimal because it will turn on AWS X-Ray for the API stage, which is a service that helps analyze and debug distributed applications, not HTTP response errors.
NEW QUESTION # 63
A developer has an application that uses an Amazon DynamoDB table with a configured local secondary index (LSI). During application testing, the DynamoDB table metrics report a ProvisionedThroughputExceededException error message. The number of requests made by the test suite did not exceed the table's provisioned capacity limits.
What is the cause of this issue?
- A. The LSI's capacity is different from the table's capacity.
- B. The application is not implementing exponential backoff retry logic while interacting with the DynamoDB API.
- C. The data in the table's partition key column is not evenly distributed.
- D. The application has the IAM permission to query the DynamoDB table but not to query the LSI.
NEW QUESTION # 64
A company has an application that receives batches of orders from partners every day. The application uses an AWS Lambda function to process the batches.
If a batch contains no orders, the Lambda function must publish to an Amazon Simple Notification Service (Amazon SNS) topic as soon as possible.
Which combination of steps will meet this requirement with the LEAST implementation effort?
(Choose two.)
- A. Modify the existing Lambda function to log orders to an Amazon Kinesis data stream.
- B. Schedule a new Lambda function to analyze Amazon CloudWatch metrics every 24 hours to identify batches that contain no orders. Configure the Lambda function to publish to the SNS topic.
- C. Create a new Lambda function as an Amazon Kinesis data stream consumer. Configure the new Lambda function to track orders and to publish to the SNS topic when a batch contains no orders.
- D. Set up an Amazon CloudWatch alarm that will send a notification to the SNS topic when the value of the custom metric is 0.
- E. Update the existing Lambda function's code to send an Amazon CloudWatch custom metric for the number of orders in a batch for each partner.
Answer: D,E
NEW QUESTION # 65
A real-time messaging application uses Amazon API Gateway WebSocket APIs with backend HTTP service.
A developer needs to build a feature in the application to identify a client that keeps connecting to and disconnecting from the WebSocket connection. The developer also needs the ability to remove the client Which combination of changes should the developer make to the application to meet these requirements?
(Select TWO.)
- A. Use the callback URL to disconnect the client from the backend service.
- B. Switch to HTTP APIs in the backend service.
- C. Implement $connect and $disconnect routes in the backend service.
- D. Switch to REST APIs in the backend service.
- E. Add code to track the client status in Amazon ElastiCache in the backend service.
Answer: C,E
Requirement Summary:
* WebSocket-based messaging app using API Gateway WebSocket APIs
* Need to:
* Identify clients repeatedly connecting/disconnecting
* Be able to remove problematic clients
Evaluate Options:
A). Switch to HTTP APIs
* HTTP APIs don't support WebSocket connections
B). Switch to REST APIs
* REST APIs are not compatible with WebSockets
C). Use the callback URL to disconnect clients
* ## Possible, but not a direct option
* Callback URLs are used for sending messages to connected clients, not for disconnecting D). Track client status in ElastiCache
* Good solution: Store and update connection state (connected, disconnected, timestamps)
* Helps track abuse or reconnections
E). Implement $connect and $disconnect routes
* Required to capture connection lifecycle events
* These can be used to log/store client behavior and decide on removal
* WebSocket routes in API Gateway: https://docs.aws.amazon.com/apigateway/latest/developerguide
/apigateway-websocket-api-route-selection.html
* Managing WebSocket connections: https://docs.aws.amazon.com/apigateway/latest/developerguide
/apigateway-websocket-api-mapping-template-reference.html
NEW QUESTION # 66
A company runs an AWS CodeBuild project on medium-sized Amazon EC2 instances. The company wants to cost optimize the project and reduce the provisioning time.
- A. Select AWS Lambda as the compute mode for the CodeBuild project.
- B. Set up Amazon S3 caching for the CodeBuild project.
- C. Configure the project to run on a CodeBuild on-demand fleet.
- D. Configure the project to run on a CodeBuild reserved capacity fleet.
Comprehensive and Detailed Step-by-Step Explanation:
* Option D: Set up Amazon S3 Caching for CodeBuild:
* CodeBuild supports S3 caching to store intermediate build artifacts and dependencies. This reduces the time required to download dependencies during subsequent builds, effectively lowering costs and improving build performance.
* By using S3 caching, developers can optimize costs without changing the compute type or adding complexity.
* Why Other Options Are Incorrect:
* Option A: CodeBuild does not have a "reserved capacity fleet" option.
* Option B: AWS Lambda cannot be used as the compute mode for CodeBuild projects.
CodeBuild uses its own managed build environments.
* Option C: CodeBuild already operates on an on-demand basis, so this does not address the need for optimization or reduced provisioning time.
* AWS CodeBuild Caching Documentation
NEW QUESTION # 67
If you prefer to prepare for your DVA-C02 exam on paper, we will be your best choice. DVA-C02 PDF version is printable, and you can print them into hard one and take some notes on them if you like, and you can study them anytime and anyplace. In addition, DVA-C02 Pdf Version have free demo for you to have a try, so that you can have deeper understanding of what you are going to buy. DVA-C02 exam dumps are edited by skilled experts, and therefore the quality can be guaranteed. And you can use them at ease.
Reliable DVA-C02 Dumps Book: https://www.actualtests4sure.com/DVA-C02-test-questions.html
- Test DVA-C02 Dumps 🆑 Reliable DVA-C02 Exam Registration 🍙 DVA-C02 Exam Bible 📬 Search for { DVA-C02 } on ⮆ [url]www.troytecdumps.com ⮄ immediately to obtain a free download 🍳DVA-C02 Exam Pattern[/url]
- New DVA-C02 Exam Test 🥺 Latest Real DVA-C02 Exam 📜 New DVA-C02 Exam Test ♻ Open ⇛ [url]www.pdfvce.com ⇚ enter ▷ DVA-C02 ◁ and obtain a free download 🍺Exam DVA-C02 Forum[/url]
- Latest Real DVA-C02 Exam 🛴 DVA-C02 Valid Test Question 💟 Test DVA-C02 Dumps 🚝 Easily obtain ⏩ DVA-C02 ⏪ for free download through ➤ [url]www.troytecdumps.com ⮘ 🏂Latest Real DVA-C02 Exam[/url]
- Exam DVA-C02 Forum 🐏 DVA-C02 Exam Pattern 🍏 New DVA-C02 Exam Test 💚 Search for ☀ DVA-C02 ️☀️ and download it for free on ( [url]www.pdfvce.com ) website ⚽Examcollection DVA-C02 Dumps Torrent[/url]
- Pass Guaranteed 2026 Amazon DVA-C02 –Trustable New Learning Materials 🍗 Search for ➡ DVA-C02 ️⬅️ and download it for free on ➤ [url]www.pdfdumps.com ⮘ website 🦧DVA-C02 Exam Bible[/url]
- DVA-C02 Valid Test Syllabus 🏋 Real DVA-C02 Exams 🌸 New DVA-C02 Test Pattern 🤾 Easily obtain ➽ DVA-C02 🢪 for free download through ➠ [url]www.pdfvce.com 🠰 🧺DVA-C02 Exam Bible[/url]
- Quiz 2026 Reliable Amazon New DVA-C02 Learning Materials 🕜 Copy URL 《 [url]www.vce4dumps.com 》 open and search for 「 DVA-C02 」 to download for free ⚪Real DVA-C02 Exams[/url]
- Quiz 2026 Reliable Amazon New DVA-C02 Learning Materials 📂 Search for ▛ DVA-C02 ▟ on ⏩ [url]www.pdfvce.com ⏪ immediately to obtain a free download 🍬DVA-C02 Exam Pattern[/url]
- DVA-C02 Reliable Test Voucher 📬 Useful DVA-C02 Dumps ❤ DVA-C02 Test Cram Review 🆔 Open website ( [url]www.pass4test.com ) and search for ▶ DVA-C02 ◀ for free download 😆
ractice DVA-C02 Exam[/url] - DVA-C02 Reliable Test Voucher 👍 Examcollection DVA-C02 Dumps Torrent 🥭 Latest DVA-C02 Dumps Pdf 📲 Download ▶ DVA-C02 ◀ for free by simply searching on ▛ [url]www.pdfvce.com ▟ 🦠Examcollection DVA-C02 Dumps Torrent[/url]
- DVA-C02 Exam Pattern 🏕 DVA-C02 Exam Bible 😋 New DVA-C02 Test Pattern 🤘 Search for [ DVA-C02 ] and easily obtain a free download on ➡ [url]www.torrentvce.com ️⬅️ 🧎Examcollection DVA-C02 Dumps Torrent[/url]
- www.stes.tyc.edu.tw, www.kickstarter.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of Actualtests4sure DVA-C02 dumps from Cloud Storage: https://drive.google.com/open?id=1laZ4vNvAKyxpPfTkGMEduLBRjiG4OUGX
