[General] Quiz SPLK-3002 - Splunk IT Service Intelligence Certified Admin Newest Latest Le
81
【General】 Quiz SPLK-3002 - Splunk IT Service Intelligence Certified Admin Newest Latest Le
Posted at 1/29/2026 13:15:13      View:117 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of CramPDF SPLK-3002 dumps from Cloud Storage: https://drive.google.com/open?id=1bhkUQMYahRP8q6_T7NyqtdYCvDzAcHI3
Research indicates that the success of our highly-praised SPLK-3002 test questions owes to our endless efforts for the easily operated practice system. Most feedback received from our candidates tell the truth that our SPLK-3002 guide torrent implement good practices, systems.We educate our candidates with less complicated Q&A but more essential information. And our SPLK-3002 Exam Dumps also add vivid examples and accurate charts to stimulate those exceptional cases you may be confronted with. You can rely on our SPLK-3002 test questions, and we'll do the utmost to help you succeed.
Where there is life, there is hope. Never abandon yourself. You still have many opportunities to counterattack. If you are lack of knowledge and skills, our SPLK-3002 study materials are willing to offer you some help. Actually, we are glad that our study materials are able to become you top choice. In the past ten years, we always hold the belief that it is dangerous if we feel satisfied with our SPLK-3002 Study Materials and stop renovating. Luckily, we still memorize our initial determination.
SPLK-3002 Reliable Test Tutorial | Reliable SPLK-3002 Exam RegistrationAs the labor market becomes more competitive, a lot of people, of course including students, company employees, etc., and all want to get SPLK-3002 authentication in a very short time, this has developed into an inevitable trend. Each of them is eager to have a strong proof to highlight their abilities, so they have the opportunity to change their current status, including getting a better job, have higher pay, and get a higher quality of SPLK-3002 material, etc.
Splunk IT Service Intelligence Certified Admin Sample Questions (Q69-Q74):NEW QUESTION # 69
Which of the following is a good use case regarding defining entities for a service?
  • A. Automatically associate entities to services using multiple entity aliases.
  • B. Being able to split a CPU usage KPI by host name.
  • C. KPI total values are aggregated from multiple different category values in the source events.
  • D. All of the entities have the same identifying field name.
Define entities before creating services. When you configure a service, you can specify entity matching rules based on entity aliases that automatically add the entities to your service.
A is the correct answer because defining entities for a service allows you to automatically associate entities to services using multiple entity aliases. Entity aliases are alternative names or identifiers for an entity, such as host name, IP address, MAC address, or DNS name. ITSI matches entity aliases to fields in your data sources and assigns entities to services accordingly. This way, you can avoid manually adding entities to each service and ensure that your services reflect the latest changes in your environment. Reference: Define entities for a service in ITSI
NEW QUESTION # 70
Which of the following statements describe default glass tables in ITSI?
  • A. There are no default glass tables.
  • B. There is one service template default glass table.
  • C. The Service Health Score default glass table.
  • D. There is one default glass table per service.
In Splunk IT Service Intelligence (ITSI), glass tables are fully customizable dashboards that provide a visual representation of an organization's IT environment, along with the health and status of services and KPIs. Unlike some pre-configured views or dashboards that might come with default setups in various platforms, ITSI does not provide default glass tables out of the box. Instead, users are encouraged to create their own glass tables tailored to their specific monitoring needs and operational views. This approach ensures that each organization can design glass tables that best represent their unique infrastructure, applications, and service landscapes, providing a more personalized and relevant operational overview.
NEW QUESTION # 71
Which index is used to store KPI values?
  • A. itsi_summary
  • B. itsi_service_health
  • C. itsi_metrics
  • D. itsi_summary_metrics
The IT Service Intelligence (ITSI) metrics summary index, itsi_summary_metrics, is a metrics-based summary index that stores KPI data.
NEW QUESTION # 72
Which of the following is a problem requiring correction in ITSI?
  • A. Two        or        more entities        with        the same entity key value in        any        info field.
  • B. Two        or        more entities        with        the same service ID.
  • C. Two        or        more entities        with        the same entity ID.
  • D. Two        or        more entities        with        the same value in a single alias field.
In Splunk IT Service Intelligence (ITSI), entities represent infrastructure components, applications, or other elements that are monitored. Each entity is uniquely identified by its entity ID, and entities can be associated with one or more services through the concept of aliases. A problem arises when two or more entities have the same value in a single alias field because aliases are used to match events to entities in ITSI. If multiple entities share the same alias value, ITSI might incorrectly associate data with the wrong entity, leading to inaccurate monitoring and analytics. This scenario requires correction to ensure that each alias uniquely identifies a single entity, thereby maintaining the integrity of the monitoring and analysis process within ITSI. The uniqueness of service IDs, entity IDs, and entity key values in info fields is also important but does not typically present the same level of issue as duplicate values in an alias field.
NEW QUESTION # 73
Besides creating notable events, what are the default alert actions a correlation search can execute? (Choose all that apply.)
  • A. Send email.
  • B. Ping a host.
  • C. Run a script.
  • D. Include in RSS feed.
Answer: A,C,D
Throttling applies to any correlation search alert type, including notable events and actions (RSS feed, email, run script, and ticketing).
B, C, and D are correct answers because they are the default alert actions that a correlation search can execute besides creating notable events. You can configure a correlation search to send an email, include the results in an RSS feed, or run a custom script when the search matches a defined pattern. Ping a host is not a default alert action for correlation searches. Reference: Configure correlation search settings in ITSI
NEW QUESTION # 74
You can easily download these formats of Splunk SPLK-3002 actual dumps and use them to prepare for the Splunk SPLK-3002 certification test. You do not need to enroll yourself in expensive SPLK-3002 Exam Training classes. With the Splunk SPLK-3002 valid dumps, you can easily prepare well for the actual Splunk IT Service Intelligence Certified Admin exam at home.
SPLK-3002 Reliable Test Tutorial: https://www.crampdf.com/SPLK-3002-exam-prep-dumps.html
Convenience, SPLK-3002 exam braindumps offer you free update for one year, and in the following year, you can know the latest information for the exam, While, the SPLK-3002 free demo also let you know the different format of these three versions, thus you can easy to decide what version is suitable for you, Splunk Latest SPLK-3002 Learning Materials And electronic equipments do provide convenience as well as efficiency to all human beings.
Associate Professor of Computer Science, directs the Interactive SPLK-3002 Reliable Test Tutorial Systems and User Experience Research Cluster of Excellence at the University of Central Florida.
What are the five processes transparent bridges use for determining what to do with a frame, Convenience, SPLK-3002 Exam Braindumps offer you free update for one year, SPLK-3002 and in the following year, you can know the latest information for the exam.
Latest SPLK-3002 Learning Materials Authoritative Questions Pool Only at CramPDFWhile, the SPLK-3002 free demo also let you know the different format of these three versions, thus you can easy to decide what version is suitable for you, And electronic Cert SPLK-3002 Guide equipments do provide convenience as well as efficiency to all human beings.
You needn't worry about how to get it, your SPLK-3002 Reliable Test Tutorial email will receive the newer Splunk IT Service Intelligence Certified Admin updated training in the short time.
What's more, part of that CramPDF SPLK-3002 dumps now are free: https://drive.google.com/open?id=1bhkUQMYahRP8q6_T7NyqtdYCvDzAcHI3
