Hardware
800-150 exam practice material & 800-150 study training pdf & 800-150 on
Posted at 1/29/2026 17:14:23
View143
Replies1
BTW, DOWNLOAD part of Pass4Leader 800-150 dumps from Cloud Storage: https://drive.google.com/open?id=1xvIVEPHtsXJrFyF5T8f72NUaomjMBl03
Have tough-minded boy only, ability appeases billows, hoist the sails Yuan Hang. Our Cisco 800-150 exam dumps are the first step to bring you achievement. It provides you with pdf real questions and answers. By choosing it, you must put through Cisco 800-150 Certification that other people think it is very difficult. After you get the certification, you can lighten your heart and start a new journey.
Cisco 800-150 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Cisco Hardware Replacement: This section of the exam measures the skills of a Technical Support Engineer and teaches how to safely and correctly replace Cisco hardware. It explains safety procedures such as creating safe work zones and handling electrostatic discharge. Students learn the step-by-step processes to replace a wide range of Cisco devices, from switches and routers to firewalls, UCS servers, and collaboration endpoints. It also covers configuring Cisco NX-OS software, including understanding operating modes, boot procedures, and password recovery, and introduces Cisco collaboration endpoint solutions like IP phones and video systems.
| | Topic 2 | - Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Ciscos cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
| | Topic 3 | - Common Service Tasks and Tools: This section of the exam measures the skills of a Technical Support Engineer and focuses on tasks commonly needed to manage Cisco devices. It explains how devices boot up, introduces common Cisco IOS commands, and identifies tools for file management. It shows how to confirm physical connections, remotely access devices, and connect to the console port. It also covers how to capture the status of a device, recover passwords, and replace devices by using proper tools. Students are also taught how to find serial numbers on Cisco equipment to assist with support and maintenance activities.
800-150 Latest Test Dumps & 800-150 PassedThere are a lot of students that bought Pass4Leader's Cisco 800-150 dumps and are satisfied with our services because they passed their 800-150 on the very first try. We assure you that if you study with our provided Supporting Cisco Devices for Field Technicians (800-150) practice questions, you can pass Cisco certifications Exam test in a single attempt, and if you fail to do it, you can claim your money back from us according to terms and conditions.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q16-Q21):NEW QUESTION # 16
Which command prompt commands provide the most thorough network diagnostic information when troubleshooting connectivity issues between a Windows PC and a Cisco device?
- A. netstat -a
netsh wlan show interfaces
ipconfig /release
ipconfig /renew - B. nslookup
arp -a
route print - C. ping
tracert
netstat - D. ipconfig /all
ping
When diagnosing network connectivity issues between a Windows PC and a Cisco device, the combination of ipconfig /all and ping commands provides comprehensive information:
ipconfig /all: Displays detailed IP configuration information, including IP addresses, subnet masks, default gateways, DNS servers, and MAC addresses for all network adapters. This information is crucial for verifying correct network settings.
ping: Tests the reachability of a host on an IP network and measures the round-trip time for messages sent from the originating host to a destination computer. It's a fundamental tool for checking connectivity between devices.
While other commands like netstat, tracert, nslookup, arp -a, and route print provide valuable information, ipconfig /all and ping are typically the first and most informative commands used in initial troubleshooting steps.
NEW QUESTION # 17
How must the power to a system with dual power supplies on aCisco Nexus switch be connected?
- A. Connect both power supplies to a single power source.
- B. Connect each power supply to a separate power source.
- C. Connect the primary power supply to the main source and the secondary to a backup generator.
- D. Connect both power supplies to a power distribution unit with built-in redundancy.
In a Cisco Nexus switch withdual power supplies, the recommended method is toconnect each power supply to a separate power source(Option C). This ensures power redundancy and fault tolerance.
If one power source fails (e.g., due to a power outage or circuit failure), the switch can continue operating uninterrupted using the second power source. Connecting both to a single source (Option D) defeats the purpose of redundancy.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Equipment and Related Hardware
NEW QUESTION # 18
What is the primary purpose of changing the configuration register when performing password recovery?
- A. To erase the entire configuration
- B. To enable advanced debugging features
- C. To unlock all user accounts
- D. To ignore the startup configuration
During password recovery on Cisco devices, the configuration register is modified to instruct the device to bypass the startup configuration stored in NVRAM. This allows administrators to access the device without being prompted for existing passwords. The standard procedure involves changing the configuration register value to 0x2142, which tells the device to ignore the startup configuration during the next boot. Once access is gained, the administrator can reset passwords and then restore the original configuration by resetting the configuration register to its default value, typically 0x2102.
NEW QUESTION # 19
Which protocol should be analyzed when troubleshooting call quality between IP phones?
- A. RTP
- B. SCCP
- C. SIP
- D. H.323
When addressing call quality issues between IP phones, theReal-time Transport Protocol (RTP)is the primary protocol to analyze. RTP is responsible for the actual transmission of voice data during a call, and its performance directly impacts call quality.
Key factors affecting RTP and, consequently, call quality include:
* Packet Loss:Missing packets can lead to audio gaps.
* Jitter:Variations in packet arrival times can cause choppy audio.
* Latency elays in packet delivery can result in noticeable lag.
Analyzing RTP streams allows technicians to identify these issues and implement appropriate Quality of Service (QoS) measures to mitigate them.
Incontrast:
* SIP (Session Initiation Protocol):Handles call setup, modification, and teardown but not the media stream.
* SCCP (Skinny Client Control Protocol):A Cisco proprietary protocol for signaling, not media transport.
* H.323:An older protocolsuite for multimedia communication, encompassing both signaling and media, but less commonly used in modern IP telephony.Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Troubleshooting Methodologie
NEW QUESTION # 20
Which command is used to download a copied configuration file from a TFTP server to merge it with the running configuration of a replacement Cisco device?
- A. copy tftp: running-config
- B. merge tftp: running-config
- C. load tftp: running-config
- D. copy tftp: startup-config
The command copy tftp: running-config is used to retrieve a configuration file from a TFTP server and merge it with the current running configuration of a Cisco device. This operation is additive, meaning it integrates the new configuration commands into the existing running configuration without removing any pre-existing commands unless explicitly overridden.
This method is particularly useful when restoring configurations to a replacement device, as it allows for the seamless integration of necessary settings without disrupting the current operational state.
In contrast, using copy tftp: startup-config would overwrite the startup configuration file, which could lead to unintended consequences upon the next device reload. The options load tftp: running-config and merge tftp: running-config are not valid Cisco IOS commands.
NEW QUESTION # 21
According to a recent report, those who own more than one skill certificate are easier to be promoted by their boss. To be out of the ordinary and seek an ideal life, we must master an extra skill to get high scores and win the match in the workplace. Our 800-150 exam question can help make your dream come true. What's more, you can have a visit of our website that provides you more detailed information about the 800-150 Guide Torrent. Just have a try our 800-150 exam questions, then you will know that you will be able to pass the 800-150 exam.
800-150 Latest Test Dumps: https://www.pass4leader.com/Cisco/800-150-exam.html
- Latest 800-150 Braindumps Free 🧯 800-150 Exam Brain Dumps 😪 Valid 800-150 Practice Questions 🧒 Download ▶ 800-150 ◀ for free by simply entering [url]www.prepawaypdf.com website ⛰800-150 Reliable Braindumps Questions[/url]
- 800-150 Latest Exam Questions ⏭ New 800-150 Dumps Book 🆓 Exam Dumps 800-150 Free 💧 Go to website ➽ [url]www.pdfvce.com 🢪 open and search for ➽ 800-150 🢪 to download for free 🏍New 800-150 Dumps Book[/url]
- Highly Authoritative 800-150 Exam Prep Easy for You to Pass 800-150 Exam 🐢 Easily obtain ▷ 800-150 ◁ for free download through [url]www.testkingpass.com 😕800-150 Exam Brain Dumps[/url]
- Highly Authoritative 800-150 Exam Prep Easy for You to Pass 800-150 Exam ⚠ Enter ✔ [url]www.pdfvce.com ️✔️ and search for ▛ 800-150 ▟ to download for free 💻800-150 Book Pdf[/url]
- 800-150 New Dumps Free 🙀 800-150 Online Version 🥄 800-150 Clearer Explanation ⚽ Download ➡ 800-150 ️⬅️ for free by simply searching on [url]www.prepawayete.com 🤖800-150 Reliable Exam Braindumps[/url]
- Cisco - Efficient 800-150 - Supporting Cisco Devices for Field Technicians Latest Dumps 📆 Search for ▶ 800-150 ◀ and obtain a free download on { [url]www.pdfvce.com } 🐌800-150 Latest Exam Questions[/url]
- 800-150 Trustworthy Exam Torrent 💰 800-150 Books PDF 🥌 Exam Dumps 800-150 Free 🏢 Search for 800-150 on ⇛ [url]www.troytecdumps.com ⇚ immediately to obtain a free download 🥔800-150 Reliable Exam Braindumps[/url]
- [url=https://brunonoble.com/?s=New%20800-150%20Exam%20Simulator%20%f0%9f%9a%a1%20800-150%20Reliable%20Braindumps%20Questions%20%f0%9f%8e%b9%20800-150%20Exam%20Brain%20Dumps%20%f0%9f%a5%8e%20Easily%20obtain%20free%20download%20of%20%e2%9e%a1%20800-150%20%ef%b8%8f%e2%ac%85%ef%b8%8f%20by%20searching%20on%20[%20www.pdfvce.com%20]%20%f0%9f%92%ac800-150%20Reliable%20Exam%20Braindumps]New 800-150 Exam Simulator 🚡 800-150 Reliable Braindumps Questions 🎹 800-150 Exam Brain Dumps 🥎 Easily obtain free download of ➡ 800-150 ️⬅️ by searching on [ www.pdfvce.com ] 💬800-150 Reliable Exam Braindumps[/url]
- Latest Updated Cisco 800-150 Latest Dumps - Supporting Cisco Devices for Field Technicians Latest Test Dumps ‼ Easily obtain ➡ 800-150 ️⬅️ for free download through ⮆ [url]www.pdfdumps.com ⮄ ⚡800-150 New Dumps Free[/url]
- Cisco - Efficient 800-150 - Supporting Cisco Devices for Field Technicians Latest Dumps 🏙 Open ▛ [url]www.pdfvce.com ▟ and search for { 800-150 } to download exam materials for free 🧓
rep 800-150 Guide[/url] - Latest Updated Cisco 800-150 Latest Dumps - Supporting Cisco Devices for Field Technicians Latest Test Dumps 🍛 Open website ⮆ [url]www.pdfdumps.com ⮄ and search for { 800-150 } for free download ☝Reliable 800-150 Practice Questions[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bd.enrollbusiness.com, Disposable vapes
