[General] 1Z0-106WPӛ - 1Z0-106ԇ}
85
General 1Z0-106WPӛ - 1Z0-106ԇ}
Posted at 1/29/2026 17:34:49      View217 | Replies1        Print      Only Author   [Copy Link] 1#
⣬@ЩVCESoft 1Z0-106ԇ}IJփݬFMģhttps://drive.google.com/open?id=14WppshozvmroWWeqNTC1pc4qCU1Mzc5l
@ҵITИIУһЩJCCǿԎ㲽ġܶ๫˾šнеJCCĺOracle 1Z0-106JCԇǂܸߵĿԇOracle 1Z0-106 JCCܝMܶITИIƴ˵VCESoftԞṩOracle 1Z0-106JCԇᘌӖھWMdVCESoftṩPOracle 1Z0-106 JCԇӖߵԇðͲ־}Lԇ
Oracle 1Z0-106 JCԇҪĜʂ Oracle Linux 8 ϵyϵČ`򞡣ӋӴ˿ԇ IT Iʿԓ Linux ϵyͼ̵˽⣬Լahй Oracle Linux 8 ϵyĽ򞡣
ֻܚgӭ1Z0-106WPӛ׌ܶͨ^Oracle Linux 8 Advanced System Administration1Z0-106 JC Oracle JCwϵLIҲһHԵďSб^yJCԇ^ÓģVCESoft һʹ 1Z0-106 JCԇͨ^ߵһWվ҂ Oracle 1Z0-106 }ָ҂ČIFƽ1Z0-106 ԇϵy^YITJCvͼgҾľ݋ˮǰ 1Z0-106 ԇІx}}x}}}}͡Ԏͨ^ԇ
µ Professional Oracle Linux 8 System Administrator 1Z0-106 Mԇ} (Q12-Q17):} #12
Which two statements are true about fdisk?
  • A. fdisk -l displays disk size information for all disks.
  • B. It can divide logical devices into one or more block disks called partitions.
  • C. It can partition disks larger than 2 TB by using a GPT partition table.
  • D. It cannot partition disks larger than 2 TB by using a GPT partition table.
  • E. It understands GPT, MBR, and HFS partition tables.
𰸣A,D
}f
* Option B (Correct):Thefdisk -lcommand lists information about all available disks, including their sizes, partition tables, and partition details.
* Option E (Correct):fdiskcannot handle disks larger than 2 TB because it is limited to the Master Boot Record (MBR) partitioning scheme. To manage larger disks (over 2 TB), the GUID Partition Table (GPT) is required, andfdiskdoes not fully support GPT.
* Option A (Incorrect):fdiskdoes not support HFS (Hierarchical File System, used by macOS). It primarily supports MBR and has limited support for GPT.
* Option C (Incorrect):fdiskdoes not support partitioning disks larger than 2 TB with GPT; gdiskorpartedshould be used instead.
* Option D (Incorrect):fdiskdoes not divide logical devices into block disks called partitions; it operates on physical storage devices to create partitions.
Oracle Linux Reference:Refer to:
* OracleLinux 8: Managing Disks and Partitions
* man fdiskfor more details on the usage and limitations of thefdiskutility.
} #13
Which two statements are true about the Linux Auditing System?
  • A. Auditing modes include permissive, enforcing, and disabled.
  • B. Auditing can scan for Common Vulnerabilities and Exposures (CVE) and automatically apply needed patches to a system.
  • C. Auditing system call rules can affect system performance depending on the amount of information that is logged.
  • D. Auditing rules can log administrator attempts to access user home directories.
  • E. Auditing includes security policies, each of which includes security rules, or checks, which are checked when you run a security scan.
𰸣C,D
} #14
Which two components are used for creating a new rsyslog rule?
  • A. action
  • B. parser
  • C. module
  • D. filter
  • E. security policy
𰸣A,D
} #15
Which two default user account settings are contained in /etc/login.defs?
  • A. Decryption method used to decrypt passwords.
  • B. User hashed passwords.
  • C. Group hashed passwords.
  • D. Password aging controls.
  • E. Encryption method used to encrypt passwords.
𰸣D,E
}f
Explanation of Answer D:The/etc/login.defsfile in Oracle Linux contains configuration settings related to user account policies, including password aging controls. This includes settings such asPASS_MAX_DAYS, PASS_MIN_DAYS, andPASS_WARN_AGE, which define the maximum number of days a password is valid, the minimum number of days between password changes, and the number of days before password expiration to warn users, respectively.
Explanation of Answer E:The/etc/login.defsfile also contains settings for the encryption method used to encrypt user passwords. TheENCRYPT_METHODparameter specifies the hashing algorithm, such as SHA512, that is used to encrypt user passwords stored in/etc/shadow.
} #16
Which statement is true about slice units?
  • A. A slice unit is a concept for hierarchically managing resources in a group of processes.
  • B. Processes in a slice unit are named at the same level as scopes and services.
  • C. The system.slice contains all system services and user sessions.
  • D. A slice unit accepts multiple names by the creation of additional symlinks to the unit file.
𰸣A
}f
* Option A (Correct):A slice unit in systemd is a grouping mechanism used for hierarchical management of resources (such as CPU, memory, and I/O) among a group of processes.
* Options B, C, D (Incorrect):These options do not correctly describe the role or characteristics of slice units in Oracle Linux 8.
* OracleLinux 8: Managing Services with systemd
} #17
Oracle1Z0-106ԇITИI֮мҲdzҪһԇ҂ʂ|ČWָϺѵľϷգITIʿṩݏVCESoft Oracle1Z0-106}wҪ֪Ŀԇݺʹ𰸣ͨ^҂VCESoftĿ}ģM֪@ǧӋõĖ|KJ@ӲǞ鿼ԇʂ
1Z0-106ԇ}: https://www.vcesoft.com/1Z0-106-pdf.html
MVCESoft 1Z0-106ԇ}Wվ㿴ÿMVCESoft 1Z0-106ԇ}WվN࣬е⣬ͨ^мgOracle 1Z0-106JCYʹԼһ¹˾@òeĹCITܣһõšIlչ·Oracle 1Z0-106WPӛ ÌI֪Rͽ򞲻؞ʂ䅢ITPJCԇṩӖϣ҂VCESoft 1Z0-106ԇ}DZƾWվܽo㱣ϵһWվxVCESoft 1Z0-106ԇ}͵x˳ɹڱվԵõµOracle 1Z0-106}Ć}𰸣ʹͨ^1Z0-106JCԇ
ҼꖼæM˕Ժˎ_ʼtˎǾ́oʲеMVCESoftWվ㿴ÿMVCESoftWվN࣬е⣬ͨ^мgOracle 1Z0-106JCYʹԼһ¹˾@òeĹCITܣһõšIlչ·
ڙ1Z0-106WPӛģM挍ԇhcܛVCE汾Ĝʂ1Z0-106Oracle Linux 8 Advanced System AdministrationÌI֪Rͽ򞲻؞ʂ䅢ITPJCԇṩӖϣ҂VCESoftDZƾWվܽo㱣ϵһWվxVCESoft͵x˳ɹڱվԵõµOracle 1Z0-106}Ć}𰸣ʹͨ^1Z0-106JCԇ
혱һ£ԏ녴惦dVCESoft 1Z0-106ԇ}棺https://drive.google.com/open?id=14WppshozvmroWWeqNTC1pc4qCU1Mzc5l
Posted at 2/3/2026 14:46:31        Only Author  2#
Truly an impressive article, Im grateful for your share. The Valid practice questions GAFRB files test questions are now available for freeyour career success is just a step away!
