[General] Quiz Salesforce Identity-and-Access-Management-Architect Marvelous Vce Files
96
【General】 Quiz Salesforce Identity-and-Access-Management-Architect Marvelous Vce Files
Posted at 1/29/2026 17:37:06      View:158 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest Fast2test Identity-and-Access-Management-Architect PDF Dumps and Identity-and-Access-Management-Architect Exam Engine Free Share: https://drive.google.com/open?id=1j9mSgAntVaTX96wFs8mp3pNsEWNdPX50
We are here to help you pass the certification exam on your first attempt. Our Salesforce Identity-and-Access-Management-Architect Questions are genuine and ensure your success on the first try. Therefore, you can save yourself from Salesforce Certified Identity and Access Management Architect exam failure and anxiety. Our expert team tries hard to improve Salesforce certification preparation products for its valued customers.
Salesforce Identity-and-Access-Management-Architect Exam Syllabus Topics:
  • Identity Management Concepts: This topic covers common authentication patterns, building blocks of identity solutions (authentication, authorization, accountability), and establishing trust between systems. It also includes methods for provisioning users in Salesforce and troubleshooting common points of failure in SSO solutions.
  • Salesforce as an Identity Provider: In this topic, you'll find information on OAuth flows, configuring Connected Apps for authorization, and implementation concepts of OAuth. It also recommends Salesforce technologies to provide identity to third-party systems.
  • Salesforce Identity: This topic explains the role of Identity Connect in Salesforce Identity implementations, the fit of Salesforce Customer 360 Identity in a comprehensive Customer 360 solution, and recommendations for Salesforce license types based on specific requirements.
Salesforce Certified Identity and Access Management Architect (IAM) Exam is a certification program designed for professionals who specialize in identity and access management solutions. Identity-and-Access-Management-Architect Exam is an advanced-level certification that validates an individual's expertise in designing and implementing security solutions using Salesforce's Identity and Access Management platform. Salesforce Certified Identity and Access Management Architect certification is ideal for professionals who have extensive experience in security architecture, identity management, and access control.
Identity-and-Access-Management-Architect Pass4sure Questions & Identity-and-Access-Management-Architect Guide Torrent & Identity-and-Access-Management-Architect Exam TorrentIn order to gain more competitive advantage in the interview, more and more people have been eager to obtain the Identity-and-Access-Management-Architect certification. They believe that passing certification is a manifestation of their ability, and they have been convinced that obtaining a Identity-and-Access-Management-Architect certification can help them find a better job. However, many people in real life are daunted, because it is not easy to obtain. Our Identity-and-Access-Management-Architect Study Tool can help you obtain the Identity-and-Access-Management-Architect certification and own a powerful weapon for your interview. Our Identity-and-Access-Management-Architect qualification test will help you gain recognition with true talents and better adapted to society. Now, I would like to give you a brief introduction in order to make you deepen your impression of our Identity-and-Access-Management-Architect test guides.
Salesforce Certified Identity and Access Management Architect Sample Questions (Q54-Q59):NEW QUESTION # 54
Northern Trail Outfitters (NTO) employees use a custom on-premise helpdesk application to request, approve, notify, and track access granted to various on-premises and cloud applications, including Salesforce.
Salesforce is currently used to authenticate users.
How should NTO provision Salesforce users as soon as they are approved in the helpdesk application with the approved profiles and permission sets?
  • A. Use Salesforce Connect to integrate with the helpdesk application.
  • B. Have the helpdesk initiate an IdP-initiated Just-m-Time provisioning Security Assertion Markup Language flow.
  • C. Build an integration that performs a remote call-in to the Salesforce SOAP or REST API.
  • D. Use a login flow to query the helpdesk to validate user status.
NEW QUESTION # 55
Universal Containers (UC) plans to use a SAML-based third-party IdP serving both of the Salesforce Partner Community and the corporate portal. UC partners will log in 65* to the corporate portal to access protected resources, including links to Salesforce resources. What would be the recommended way to configure the IdP so that seamless access can be achieved in this scenario?
  • A. Set up the corporate portal as a Connected App in Salesforce and use the User Agent OAuth flow.
  • B. Set up the corporate portal as a ConnectedApp in Salesforce and use the Web server OAuth flow.
  • C. Configure SP-initiated SSO that passes the SAML token upon Salesforce resource access request.
  • D. Configure IdP-initiated SSO that passes the SAML token upon Salesforce resource access request.
The recommended way to configure the IdP for seamless access is to use IdP-initiated SSO that passes the SAML token upon Salesforce resource accessrequest. This means that the user logs in to the corporate portal first, and then clicks a link to access a Salesforce resource. The IdP sends a SAML response to Salesforce with the user's identity and other attributes. Salesforce verifies the SAML response and logs in the user to the appropriate Salesforce org and community12. This way, the user does not have to log in again to Salesforce or enter any credentials3. References: 1: SAML SSO with Salesforce as the Service Provider 2: Set Up Single Sign-On for Your Internal Users Unit | Salesforce - Trailhead 3: What is IdP-Initiated Single Sign-On? - OneLogin
NEW QUESTION # 56
Which two things should be done to ensure end users can only use single sign-on (SSO) to login in to Salesforce?
Choose 2 answers
  • A. Assign user "is Single Sign-on Enabled" permission via profile or permission set.
  • B. Request Salesforce Support to enable delegated authentication.
  • C. Once SSO is enabled, users are only able to login using Salesforce credentials.
  • D. Enable My Domain and select "revent login from https://login.salesforce.com".
NEW QUESTION # 57
Which three are capabilities of SAML-based Federated authentication? Choose 3 answers
  • A. SAML tokens can be in XML or JSON format and can be used interchangeably.
  • B. Trust relationships between Identity Provider and Service Provider are required.
  • C. Centralized federation provides single point of access, control and auditing.
  • D. Access tokens areused to access resources on the server once the user is authenticated.
  • E. Web applications with no passwords are more secure and stronger against attacks.
Answer: B,C,E
A is correct because SAML-based Federated authentication requires trust relationships between the IdP and the SP. The IdP issues a SAML assertion that contains information about the user's identity and attributes.
The SP validates the assertion and grants access to the user.
C is correct because web applications that use SAML-based Federatedauthentication do not require passwords for users to log in. Instead, they rely on the IdP to authenticate the users and provide a secure token. This eliminates the risk of password breaches and phishing attacks.
E is correct because centralized federationprovides a single point of access, control, and auditing for web applications that use SAML-based Federated authentication. Users can access multiple applications with one login, administrators can manage user access from one place, and auditors can monitor user activity across applications.
B is incorrect because SAML tokens are always in XML format. They cannot be used interchangeably with JSON tokens, which are used by OAuth or OpenID Connect protocols.
D is incorrect because access tokens are not usedby SAML-based Federated authentication. Access tokens are used by OAuth or OpenID Connect protocols to access resources on the server once the user is authenticated.
References: : [Single Sign-On Implementation Guide Developer Documentation] : [Identity 101: Design Patterns for Access Management Salesforce Developers YouTube] : Certification - Identity and Access Management Architect - Trailhead : OAuth Authorization Flows Trailblazer Community Documentation :
User Authentication Module - Trailhead
NEW QUESTION # 58
Universal Containers (UC) has an existing web application that itwould like to access from Salesforce without requiring users to re-authenticate. The web application is owned UC and the UC team that is responsible for it is willing to add new javascript code and/or libraries to the application. What implementation should an Architect recommend to UC?
  • A. Rewrite the web application as a set of Visualforce pages and Apex code.
  • B. Add the web application as a ConnectedApp using OAuth User-Agent flow.
  • C. Create a Canvas app and use Signed Requests to authenticate the users.
  • D. Configure the web application as an item in the Salesforce App Launcher.
A Canvas app is a web application that can be embedded within Salesforce and access Salesforce data using the signed request authentication method. This method allows the Canvas app to receive a signed request that contains the context and OAuth token when it is loaded. The Canvas app can use the SDK to request a new or refreshed signed request on demand2. This way, the users do not need to re-authenticate when accessing the web application from Salesforce. References: Requesting a Signed Request, SAML SingleSign-On for Canvas Apps, Mastering Salesforce Canvas Apps
NEW QUESTION # 59
The pass rate of the Identity-and-Access-Management-Architect exam braindumps is 98.75%, and pass guarantee and money back guarantee, if you indeed fail in the exam by using Identity-and-Access-Management-Architect exam dumps of us , we will refund your money or if you need to attend other exam, we will replace other 2 valid exam dumps for free. Besides, the Identity-and-Access-Management-Architect Exam Dumps contain both quality and certain quantity, it is good for you to practice and pass the exam successfully.
Identity-and-Access-Management-Architect Test Practice: https://www.fast2test.com/Identity-and-Access-Management-Architect-premium-file.html
BONUS!!! Download part of Fast2test Identity-and-Access-Management-Architect dumps for free: https://drive.google.com/open?id=1j9mSgAntVaTX96wFs8mp3pNsEWNdPX50
Posted at 2/15/2026 04:55:46        Only Author  2#
The article is very empowering, thanks for sharing! Upgrade your IT skills with free L4M3 test questions vce. Best wishes for your success!
