B2C-Commerce-Architect Latest Real Test - B2C-Commerce-Architect Best Vce
87
Posted at 1/29/2026 18:36:53      View:105 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that Prep4King B2C-Commerce-Architect dumps now are free: https://drive.google.com/open?id=1JmVWtqi-zs4ONYKfkzfpJom2D592M9do
Holding a Salesforce Certified B2C Commerce Architect B2C-Commerce-Architect Certification in a certain field definitely shows that one have a good command of the B2C-Commerce-Architect knowledge and professional skills in the related field. However, it is universally accepted that the majority of the candidates for the Salesforce Certified B2C Commerce Architect exam are those who do not have enough spare time and are not able to study in the most efficient way.
Salesforce B2C-Commerce-Architect exam is a certification exam that is designed to test your knowledge and skills in B2C commerce architecture. As a Salesforce Certified B2C Commerce Architect, you will be responsible for designing and implementing complex B2C commerce solutions that meet the needs of your clients. B2C-Commerce-Architect Exam is a great way to showcase your expertise in B2C commerce architecture and demonstrate your ability to design scalable and effective solutions.
Avail Unparalleled B2C-Commerce-Architect Latest Real Test to Pass B2C-Commerce-Architect on the First AttemptWe committed to providing you with the best possible Salesforce Certified B2C Commerce Architect (B2C-Commerce-Architect) practice test material to succeed in the Salesforce B2C-Commerce-Architect exam. With real B2C-Commerce-Architect exam questions in PDF, customizable Salesforce B2C-Commerce-Architect practice exams, free demos, and 24/7 support, you can be confident that you are getting the best possible B2C-Commerce-Architect Exam Material for the test. Buy today and start your journey to Salesforce Certified B2C Commerce Architect (B2C-Commerce-Architect) exam success with Prep4King!
Salesforce B2C-Commerce-Architect Certification Exam is a valuable certification for professionals who want to enhance their career in B2C Commerce architecture. Salesforce Certified B2C Commerce Architect certification demonstrates that the candidate has the skills and knowledge required to design and implement B2C Commerce solutions using Salesforce Commerce Cloud. Salesforce Certified B2C Commerce Architect certification also enhances the candidate's credibility in the industry and increases their chances of getting better job opportunities and higher salaries.
Salesforce Certified B2C Commerce Architect Sample Questions (Q24-Q29):NEW QUESTION # 24
Your project has 4 storefronts for different branches. Everyday at 4.00 am runs a job to import inventories, master catalog and storefronts for each of those sites. You're in charge of job configuration, given this information what should be the best approach to achieve it?
  • A. First flow with organization scope to import master catalog, another flow with 4 steps to import each storefront catalog with site scope and in parallel inventory import with organization scope.
  • B. 2 flows needed. First one to import master catalog with organization scope and in parallel import storefronts with site scope and second flow to import the inventory with organization scope.
  • C. 3 flows are needed. First master catalog with organization scope. Second flow is to import storefront catalogs with site scope and last to import inventory with organization scope.
  • D. None of these answers are correct
NEW QUESTION # 25
An existing B2C Commerce site has the following aliases configuration:
Which statement related to this configuration is incorrect?
NEW QUESTION # 26
The client provided these business requirements:
* The B2C Commerce platform will integratewith the Client s Order Management System (OMS).
* The OMS supports Integration using REST services.
* The OMS is hosted on the Clients infrastructure.
Whet configurations are needed for this integration with the OMS?
  • A. A service profile configuration, a WAF configuration, and a service credential configuration.
  • B. A service configuration, a service profile configuration, and a user credential configuration.
  • C. A service configuration, a hostname alias configuration, and a user credential configuration.
  • D. A service configuration, a service profile configuration, and a service credential configuration.
For integrating the B2C Commerce platform with the client's OMS using REST services, the required configurations include:
Service Configuration: This specifies the service endpoints, HTTP methods, and any other service-specific settings necessary for the integration.
Service Profile Configuration: This defines the behavior of the service such as timeout settings, retry logic, and cache settings.
Service Credential Configuration: This involves setting up the credentials that will be used to authenticate the requests to the client's OMS. These credentials are often managed securely through encrypted storage and retrieval mechanisms.
These configurations ensure secure, efficient, and reliable communication between the B2C Commerce platform and the client's OMS, adhering to best practices in web service integration.
NEW QUESTION # 27
A client has just pushed a new site live to Production. However during smoke testing. It's found that some customers are not seeing the correct pricing on the Product Detail Page.
What three places would the Architect begin to look for the cause of this Issue?
Choose 3 answers
  • A. Check that there was not an error during replication.
  • B. Check the Global Preferences to be sure the settings are correct.
  • C. Check the Quota Status page.
  • D. Check Log Center
  • E. Check that the cache is set correctly
Answer: A,C,E
NEW QUESTION # 28
The Home-Show route uses this middleware chain:
The developer added Home.;s in another cartridge, which is before the original cartridge in the cartridge path, to extend that route but it does not have the middleware chain:
Assuming the code is correct on both functions, what is the expected result?
  • A. A RunTime error is thrown, "Error: Params do not match route".
  • B. The base code executes and then the custom code executes.
  • C. The custom code executes and then the base code executes.
  • D. The base code executes, but the custom code is ignored because the signature lines do not match.
NEW QUESTION # 29
B2C-Commerce-Architect Best Vce: https://www.prep4king.com/B2C-Commerce-Architect-exam-prep-material.html
BONUS!!! Download part of Prep4King B2C-Commerce-Architect dumps for free: https://drive.google.com/open?id=1JmVWtqi-zs4ONYKfkzfpJom2D592M9do
Posted at 2/3/2026 13:36:20        Only Author  2#
What an incredible read, thank you for sharing this wonderful article. I’m offering the CPC authorized pdf resources for free! Good luck to all.
