Mule-Dev-301 Exam Questions and Salesforce Certified MuleSoft Developer II Torre
Posted at 1/29/2026 19:59:41
Our company has always been following the trend of the Mule-Dev-301 certification. Our research and development team not only study what questions will come up in the exam, but also design powerful study tools like Mule-Dev-301 exam simulation software. This Software version of our Mule-Dev-301 learning quesions are famous for its simulating function of the real exam, which can give the candidates a chance to experience the real exam before they really come to it.
The pass rate is 98.65% for Mule-Dev-301 study guide, and you can pass the exam just one time. In order to build up your confidence for the exam, we are pass guarantee and money back guarantee. If you fail to pass the exam by using Mule-Dev-301 exam braindumps of us, we will give you full refund. Besides, Mule-Dev-301 learning materials are edited and verified by professional specialists, and therefore the quality can be guaranteed, and you can use them at ease. We have online and offline service. If you have any questions for Mule-Dev-301 Exam Materials, you can consult us, and we will give you reply as quick as possible.
Reliable Mule-Dev-301 Test Testking & Valid Dumps Mule-Dev-301 FilesConsidered many of our customers are too busy to study, the Mule-Dev-301 real study dumps designed by our company were according to the real exam content, which would help you cope with the Mule-Dev-301 exam with great ease. The masses have sharp eyes, with so many rave reviews and hot sale our customers can clearly see that how excellent our Mule-Dev-301 Exam Questions are. After carefully calculating about the costs and benefits, our Mule-Dev-301 prep guide would be the reliable choice for you, for an ascending life. And you can free download the demo of our Mule-Dev-301 exam questions before your payment.
Salesforce Certified MuleSoft Developer II Sample Questions (Q19-Q24):NEW QUESTION # 19
A Mule implementation uses a HTTP Request within an Unit Successful scope to connect to an API.
How should a permanent error response like HTTP:UNAUTHORIZED be handle inside Until Successful to reduce latency?
- A. In Until Successful configuration, set the retry count to 1 for error type HTTP: UNAUTHORIZED.
- B. Put the HTTP Request inside a try scope in Unit Successful.
In the error handler, use On Error Propagate to catch permanent errors like HTTP UNAUTHORIZED. - C. Configure retrying until a MULERETRY_EXHAUSTED error is raised or the API responds back with a successful response.
- D. Put the HTTP Request inside a try scope in Unit Successful.
In the error handler, use On Error Continue to catch permanent errors like HTTP UNAUTHORIZED.
To handle a permanent error response like HTTP:UNAUTHORIZED inside Until Successful, the developer should put the HTTP Request inside a try scope in Unit Successful, and use On Error Continue to catch permanent errors like HTTP UNAUTHORIZED in the error handler. This way, the developer can avoid retrying requests that will always fail due to a permanent error, and reduce latency. On Error Continue allows the flow to continue processing after handling the error. Reference: https://docs.mulesoft.com/mule-runtime/4.3/until-successful-scope https://docs.mulesoft.com/mule-r ... or-continue-concept
NEW QUESTION # 20
An API has been developed and deployed to CloudHub Among the policies applied to this API is an allowlist of IP addresses. A developer wants to run a test in Anypoint Studio and does not want any policies applied because their workstation is not included in the allowlist.
What must the developer do in order to run this test locally without the policies applied?
- A. Pass in the runtime parameter ''-Danpow.platform.gatekeeper=disabled''
- B. Create a properties file specifically for local development and set the API instance ID to a value that is not used in API Manager
- C. Run the test as-s, with no changes because the Studio runtime will not attempt to connect to API Manager
- D. Deactivate the API in API Manager so the Autodiscovery element will not find the application when it runs in Studio
To run a test locally without the policies applied, the developer should create a properties file specifically for local development and set the API instance ID to a value that is not used in API Manager. This way, the developer can use different configuration properties for different environments and avoid triggering API autodiscovery when running tests locally. API autodiscovery is a mechanism that associates an API implementation with its corresponding API specification and policies in API Manager based on its API instance ID. By setting this ID to a value that does not exist in API Manager, the developer can prevent API autodiscovery from finding and applying any policies to the local test. Reference: https://docs.mulesoft.com/api-ma ... g-api-autodiscovery https://docs.mulesoft.com/mule-runtime/4.3/configuring-properties
NEW QUESTION # 21
A Mule application includes a subflow containing a Scatter.Gather scope. Within each log of the Scatter.Gatter. an HTTP connector calls a PUT endpoint to modify records in different upstream system. The subflow is called inside an Unit successful scope to retry if a transitory exception is raised.
A technical spike is being performed to increase reliability of the Mule application.
Which steps should be performed within the Mule flow above the ensure idempontent behavior?
- A. Remove the Put requests from the Scatter-Getter and perform them sequentially
- B. None, the flow already exhibits idempotent behavior
- C. Ensure an error-handling flow performs corrective actions to roll back all changes if any leg of the Scatter-Gather fails
- D. Change the PUT requests inside the Scatter-Gather to POST requests
To ensure idempotent behavior within a Mule flow that contains a subflow with a Scatter-Gather scope, the developer should ensure an error-handling flow performs corrective actions to roll back all changes if any leg of the Scatter-Gather fails. Idempotency means that multiple identical requests have the same effect as a single request. Therefore, if one of the HTTP requests inside the Scatter-Gather fails, the error-handling flow should undo any changes made by other successful requests to ensure consistency and avoid partial updates. Reference: https://docs.mulesoft.com/mule-runtime/4.3/scatter-gather-concept https://docs.mulesoft.com/mule-runtime/4.3/error-handling
NEW QUESTION # 22
A Mule API receives a JSON payload and updates the target system with the payload. The developer uses JSON schemas to ensure the data is valid.
How can the data be validation before posting to the target system?
- A. Using the DataWeave if Else condition test the values of the payload against the examples included in the schema
- B. Use a DataWeave 2.09 transform operation, and at the log of the DataWeave script, add:
%dw 2.0
Import.json-moduls - C. Apply the JSON Schema policy in API Manager and reference the correct schema in the policy configuration
- D. Add the JSON module dependency and add the validate-schema operation in the flow, configured to reference the schema
To validate the data before posting to the target system, the developer should add the JSON module dependency and add the validate-schema operation in the flow, configured to reference the schema. The JSON module provides a validate-schema operation that validates a JSON payload against a JSON schema and throws an error if the payload is invalid. Reference: https://docs.mulesoft.com/json-module/1.1/json-validate-schema
NEW QUESTION # 23
A healthcare portal needs to validate the token that it sends to a Mule API. The developer plans to implement a custom policy using the HTTP Policy Transform Extension to match the token received in the header from the heathcare portal.
Which files does the developer need to create in order to package the custom policy?
- A. Deployable ZIP file, YAML configuration file
- B. XML template file, YAML configuration file
- C. JSON properties file, YAML configuration file
- D. JSON properties file, XML template file
To package a custom policy using the HTTP Policy Transform Extension, the developer needs to create an XML template file and a YAML configuration file. The XML template file defines the policy logic using Mule components and placeholders for user-defined properties. The YAML configuration file defines the metadata of the policy, such as its name, description, category, parameters, and dependencies. Reference: https://docs.mulesoft.com/api-ma ... ackaging-the-policy
NEW QUESTION # 24
It is believe that employers nowadays are more open to learn new knowledge, as they realize that Salesforce certification may be conducive to them in refreshing their life, especially in their career arena. A professional Salesforce certification serves as the most powerful way for you to show your professional knowledge and skills. For those who are struggling for promotion or better job, they should figure out what kind of Mule-Dev-301 Test Guide is most suitable for them. However, some employers are hesitating to choose. With our high-accuracy Mule-Dev-301 test guide, our candidates can grasp the key points, and become sophisticated with the exam content. You only need to spend 20-30 hours practicing with our Salesforce Certified MuleSoft Developer II learn tool, passing the exam would be a piece of cake.
Reliable Mule-Dev-301 Test Testking: https://www.examboosts.com/Salesforce/Mule-Dev-301-practice-exam-dumps.html
Salesforce Mule-Dev-301 Valid Exam Discount By doing this they can gain several personal and professional benefits, Salesforce Mule-Dev-301 Valid Exam Discount This is an outstanding merit of the APP online version, You may think 100% guarantee pass rate is hard to achieve; however, we can assure you that our Mule-Dev-301 exam study material is definitely a reliable choice and we will take responsibility for your passing the Mule-Dev-301 exam, Money spent on the Mule-Dev-301 exam test is an investment, so does time and energy.
Apple Software Update will compare your Mac's current installed software with the Mule-Dev-301 latest versions available from Apple, Green belt certification provides hands on and knowledge and implementation driven competencies to the professionals.
Mule-Dev-301 exam preparation, real Salesforce test dumps for Salesforce Certified MuleSoft Developer IIBy doing this they can gain several personal and professional Mule-Dev-301 Valid Exam Discount benefits, This is an outstanding merit of the APP online version, You may think 100% guarantee pass rate is hard to achieve; however, we can assure you that our Mule-Dev-301 Exam study material is definitely a reliable choice and we will take responsibility for your passing the Mule-Dev-301 exam.
Money spent on the Mule-Dev-301 exam test is an investment, so does time and energy, How to pass Salesforce Mule-Dev-301 exams?
- Practice Mule-Dev-301 Test 💸 Exam Mule-Dev-301 Material 🧔 Mule-Dev-301 Latest Exam Cram 🏝 Search for ⇛ Mule-Dev-301 ⇚ and obtain a free download on “ [url]www.examcollectionpass.com ” 👏Exam Sample Mule-Dev-301 Online[/url]
- Exam Sample Mule-Dev-301 Online 🕰 Mule-Dev-301 Sample Exam 🤭 Test Mule-Dev-301 Cram Review ⚒ Simply search for ▶ Mule-Dev-301 ◀ for free download on “ [url]www.pdfvce.com ” 🥺
df Mule-Dev-301 Format[/url] - 2026 Latest 100% Free Mule-Dev-301 – 100% Free Valid Exam Discount | Reliable Mule-Dev-301 Test Testking 🍉 Search for ➠ Mule-Dev-301 🠰 and download it for free on ⇛ [url]www.examdiscuss.com ⇚ website 🌳Exam Sample Mule-Dev-301 Online[/url]
- Simulated Mule-Dev-301 Test 💍 Exam Mule-Dev-301 Material 🐰 Mule-Dev-301 Valid Dumps Free 🛒 Easily obtain free download of ✔ Mule-Dev-301 ️✔️ by searching on ✔ [url]www.pdfvce.com ️✔️ 🛃Mule-Dev-301 Sample Exam[/url]
- Pdf Mule-Dev-301 Format 🥟 Valid Mule-Dev-301 Vce 🎼 Practice Mule-Dev-301 Test ⏮ Search for 「 Mule-Dev-301 」 and download exam materials for free through ▶ [url]www.prepawayexam.com ◀ 🌶Valid Mule-Dev-301 Vce[/url]
- Mule-Dev-301 Cert Torrent - Mule-Dev-301 Actual Answers - Mule-Dev-301 Practice Pdf 🎦 The page for free download of ⇛ Mule-Dev-301 ⇚ on ➡ [url]www.pdfvce.com ️⬅️ will open immediately 💟Valid Mule-Dev-301 Test Camp[/url]
- Exam Sample Mule-Dev-301 Online 🛷 Simulated Mule-Dev-301 Test 🟪 Mule-Dev-301 Valid Dumps Free ⛄ Go to website { [url]www.practicevce.com } open and search for ➠ Mule-Dev-301 🠰 to download for free 🐯Test Mule-Dev-301 Collection Pdf[/url]
- Mule-Dev-301 Reliable Exam Testking 🐦 Test Mule-Dev-301 Cram Review 👭 Mule-Dev-301 Pass4sure Exam Prep 🧯 Open website ➡ [url]www.pdfvce.com ️⬅️ and search for 「 Mule-Dev-301 」 for free download 🖐Mule-Dev-301 Sample Exam[/url]
- High-efficient Mule-Dev-301 Training materials are helpful Exam Questions - [url]www.easy4engine.com 🌀 Search for ➥ Mule-Dev-301 🡄 and download it for free on ➥ www.easy4engine.com 🡄 website 🐉Simulated Mule-Dev-301 Test[/url]
- Pass Your Salesforce Mule-Dev-301 Exam on the First Try with Pdfvce 🐴 Download ▷ Mule-Dev-301 ◁ for free by simply searching on ⮆ [url]www.pdfvce.com ⮄ 🏗Mule-Dev-301 Sample Exam[/url]
- Mule-Dev-301 Valid Dumps Free 🔏 Exam Sample Mule-Dev-301 Online 👈 Exam Sample Mule-Dev-301 Online 💞 Download “ Mule-Dev-301 ” for free by simply entering ➡ [url]www.prep4sures.top ️⬅️ website 🏙Mule-Dev-301 Valid Dumps Free[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, letterboxd.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
