[General] 最高のSD-WAN-Engineer試験過去問と信頼できるSD-WAN-Engineer試験準備
99
【General】 最高のSD-WAN-Engineer試験過去問と信頼できるSD-WAN-Engineer試験準備
Posted at 1/30/2026 00:02:27      View:165 | Replies:1        Print      Only Author   [Copy Link] 1#
合格できるPalo Alto Networks Palo Alto Networks SD-WAN Engineer試験はいくつありますか? それらをすべて試してみてください! Jpexamは、Palo Alto Networks SD-WAN Engineer コーススペシャリストが開発した実際のPalo Alto Networks SD-WAN-Engineerの回答を含むPalo Alto Networks SD-WAN Engineer SD-WAN-Engineer試験問題への完全なアクセス権をUnlimited Access Planに提示します。 Palo Alto Networks Palo Alto Networks SD-WAN Engineerテストに合格できるだけでなく、さらに良くなります! また、すべての試験の質問と回答にアクセスして、合計1800以上の試験に合格することもできます。
Palo Alto Networks SD-WAN-Engineer 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
トピック 2
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
トピック 3
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
トピック 4
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
トピック 5
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
素敵なSD-WAN-Engineer試験過去問 & 合格スムーズSD-WAN-Engineer試験準備 | 実際的なSD-WAN-Engineerテスト難易度JpexamのSD-WAN-Engineer参考書は間違いなくあなたが一番信頼できるSD-WAN-Engineer試験に関連する資料です。まだそれを信じていないなら、すぐに自分で体験してください。そうすると、きっと私の言葉を信じるようになります。Jpexamのサイトをクリックして問題集のデモをダウンロードすることができますから、ご利用ください。PDF版でもソフト版でも提供されていますから、先ず体験して下さい。問題集の品質を自分自身で確かめましょう。
Palo Alto Networks SD-WAN Engineer 認定 SD-WAN-Engineer 試験問題 (Q81-Q86):質問 # 81
A network engineer is troubleshooting a "Voice Quality" issue. They suspect that the DSCP markings are being stripped or altered by the ISP.
Which tool in the Prisma SD-WAN portal allows the engineer to capture live packets on the WAN interface and inspect the IP header ToS/DSCP field?
  • A. Flow Browser
  • B. Path Quality Monitor
  • C. Packet Capture (PCAP)
  • D. Event Logs
Comprehensive and Detailed Explanation
To validate specific packet-level details like DSCP (Differentiated Services Code Point) values, header checksums, or exact payload sizes, a Packet Capture (PCAP) is required.
* PCAP Tool: Prisma SD-WAN provides a built-in PCAP utility accessible directly from the portal. The engineer can select the specific Interface (e.g., Internet 1), apply a Filter (e.g., port 5060 or host
1.2.3.4), and capture the traffic.
* Analysis: The resulting .pcap file can be downloaded and opened in Wireshark. This allows the engineer to definitively see if the packets leaving the ION have DSCP EF (46) and if the packets arriving (if capturing on the other side) still retain that marking, or if the ISP has bleached it to CS0 (0).
* Flow Browser (A): While it shows "Application" and metrics, the Flow Browser typically displays the assigned priority class, not necessarily the raw bit-level DSCP value present in the packet header on the wire.
質問 # 82
When allocating Aggregate Bandwidth for a Prisma Access "Remote Network" deployment (connecting 50 branch sites), how is the bandwidth license enforced?
  • A. The bandwidth is allocated per device serial number and cannot be shared.
  • B. Each branch site is hard-capped at the specific bandwidth limit defined in its individual IPSec tunnel configuration.
  • C. The bandwidth is shared as a pool across all sites in a specific Compute Location (Region); individual sites can burst up to the available pool capacity.
  • D. The bandwidth license is only checked once during the initial onboarding; there is no ongoing enforcement.
Prisma Access manages Remote Network bandwidth using an Aggregate Bandwidth licensing model.
Compute Locations: When you purchase bandwidth (e.g., 1 Gbps), you allocate it to specific Prisma Access Compute Locations (e.g., US West, Europe Central).
Shared Pool: All branch sites (Remote Networks) that connect to that specific Compute Location share the allocated bandwidth pool. For example, if you allocate 500 Mbps to "US West" and connect 10 branches to it, they compete for that 500 Mbps aggregate.
Bursting: An individual branch is not strictly rate-limited to a "slice" (e.g., 50 Mbps) unless you explicitly configure QoS guarantees. By default, a single branch can burst and consume a large portion of the aggregate pool if other branches are idle. The enforcement happens at the Region/Compute Node level, ensuring the total throughput does not exceed the licensed capacity for that region.
質問 # 83
A network design mandates segmentation at the routing level and traffic isolation across various services, such as teller cash registers, ATM traffic, guest Wi-Fi, and corporate applications. Which command can be used to validate and display the Virtual Routing and Forwarding (VRF) route leak rules?
  • A. inspect vrf route_leak_rule all
  • B. dump vrf route_leak_rule
  • C. show interface vrf route_leak_rule all
  • D. inspect flow_browser vrf all
In complex retail or banking environments, maintaining strict network segmentation is a regulatory and security requirement. Prisma SD-WAN utilizes Virtual Routing and Forwarding (VRF) to provide this isolation, ensuring that high-security traffic, such as ATM transactions or teller cash registers, remains logically separated from Guest Wi-Fi or general corporate applications. While isolation is the default state, route leaking is used to allow specific communication between these VRFs-for instance, allowing multiple isolated segments to reach a common shared service like a DNS server or a centralized security gateway.
To verify that these configurations have been correctly pushed from the Controller to the local ION device, administrators utilize the ION CLI (Command Line Interface) for deep-dive diagnostics. The command inspect vrf route_leak_rule all is the definitive tool for this purpose. Unlike "show" commands which typically provide interface status, "inspect" commands in the Prisma SD-WAN ecosystem are designed to pull real-time operational state data from the control plane's internal databases.
When executed, this command displays the specific prefix-level rules that allow routes to "leak" from one VRF table into another. It provides visibility into the source VRF, the destination VRF, and the exact network prefixes or default routes being shared. This is critical for troubleshooting "Day 2" operations; if a teller register cannot reach a shared database, the administrator can use this command to confirm if the necessary route leak rule is active and accurately reflecting the intent of the VRF Profile configured in the portal.
Without this command, verifying inter-VRF reachability would be limited to trial-and-error connectivity tests, making it an essential part of the Prisma SD-WAN engineer's toolkit.
質問 # 84
Which troubleshooting step should be taken when users at a branch site are experiencing a maximum throughput of 200 Mbps for Direct Internet Access (DIA) traffic on a 1 Gbps internet connection?
  • A. Ensure the WAN interface is set to 1 Gbps or auto mode.
  • B. Ensure QoS policy is applies to the site.
  • C. Ensure the circuit configuration at the site level is properly set.
  • D. Ensure performance policy is applied to the site.
In Prisma SD-WAN, the effective throughput for any given circuit is fundamentally dictated by the Circuit Configuration defined at the site level. When a branch experiences a "throughput ceiling" (e.g., traffic capped at 200 Mbps on a 1 Gbps physical link), the most likely cause is that the software-defined bandwidth limit for that circuit has been set incorrectly in the Prisma SD-WAN Controller.
Prisma SD-WAN ION devices do not simply forward traffic at the maximum physical line rate by default; they rely on the administrator-defined Upstream and Downstream bandwidth values to perform traffic shaping, policing, and path selection. If a circuit is physically capable of 1 Gbps but is configured in the portal as having only 200 Mbps, the ION device will enforce this 200 Mbps limit to prevent oversubscribing the link and to ensure that Quality of Service (QoS) and path selection calculations remain accurate based on the assumed capacity.
To resolve this, an engineer must navigate to the Site Configuration, locate the specific WAN circuit, and verify that the bandwidth settings match the actual service provider's handoff. If these values are set lower than the actual link speed, the device will artificially throttle the traffic. While ensuring the WAN interface is set to the correct speed/duplex (Option B) is a valid physical layer check, and QoS/Performance policies (Options A and C) manage how that bandwidth is used, it is the Circuit Configuration that defines the total available bandwidth for the SD-WAN fabric to utilize. Correcting this configuration allows the ION device to scale its throughput to match the full 1 Gbps capability of the broadband connection.
質問 # 85
In a Data Center deployment, what is the key functional difference between configuring a BGP neighbor as a "Core Peer" versus an "Edge Peer"?
  • A. A Core Peer is used for LAN-side routing to learn DC prefixes, while an Edge Peer is used for WAN-side routing to the Service Provider.
  • B. A Core Peer supports eBGP only, while an Edge Peer supports iBGP only.
  • C. A Core Peer is used for connecting to the internet, while an Edge Peer connects to the MPLS provider.
  • D. A Core Peer automatically redistributes learned routes into the SD-WAN fabric, whereas an Edge Peer does not.
In the Prisma SD-WAN Data Center (DC) model, the terminology for BGP peers defines their role in the topology and how the system generates route maps.
Core Peer: This peer type is designated for the LAN-side connection (facing the DC Core Switch or internal Routers). Its primary purpose is to learn the subnets/prefixes hosted in the data center so the ION can advertise them to the remote branches. The system automatically creates route maps to facilitate this redistribution into the fabric.
Edge Peer: This peer type is designated for the WAN-side connection (facing the Edge Router or MPLS PE). Its primary purpose is to provide reachability to the underlay network.
Distinction: Selecting the correct type affects the default Route Maps and Prefix Lists generated by the controller. Configuring a Core Peer correctly ensures that the DC's internal subnets are properly learned and propagated to the overlay, whereas an Edge Peer configuration focuses on WAN next-hop reachability.
質問 # 86
別の人の言い回しより自分の体験感じは大切なことです。我々の希望は誠意と専業化を感じられることですなので、お客様に無料のPalo Alto Networks SD-WAN-Engineer問題集デモを提供します。購買の後、行き届いたアフタサービスを続けて提供します。Palo Alto Networks SD-WAN-Engineer問題集を更新しるなり、あなたのメールボックスに送付します。あなたは一年間での更新サービスを楽しみにします。
SD-WAN-Engineer試験準備: https://www.jpexam.com/SD-WAN-Engineer_exam.html
Posted at 2/16/2026 07:48:50        Only Author  2#
I really appreciate your article, it opened my eyes to new possibilities. The Latest C_BCBAI_2509 dumps free download resources are available for free—good luck, everyone!
