Cyber AB CMMC-CCA Regualer Update Exam Pass at Your First Attempt | Valid CMMC-C
98
Posted at 1/30/2026 01:25:40      View:149 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Cyber AB CMMC-CCA dumps are available on Google Drive shared by TestBraindump: https://drive.google.com/open?id=1TlckvayreMY5ElSkeAL-EWQzXvvbtfhT
TestBraindump also offers Cyber AB CMMC-CCA desktop practice exam software which is accessible without any internet connection after the verification of the required license. This software is very beneficial for all those applicants who want to prepare in a scenario which is similar to the Certified CMMC Assessor (CCA) Exam real examination.
Cyber AB CMMC-CCA Exam Syllabus Topics:
  • Assessing CMMC Level 2 Practices: This section of the exam measures skills of cybersecurity assessors in evaluating whether organizations meet the required practices of CMMC Level 2. It emphasizes applying CMMC model constructs, understanding model levels, domains, and implementation, and using evidence to determine compliance with established cybersecurity practices.
  • CMMC Level 2 Assessment Scoping: This section of the exam measures skills of cybersecurity assessors and revolves around determining the proper scope of a CMMC assessment. It involves analyzing and categorizing Controlled Unclassified Information (CUI) assets, interpreting the Level 2 scoping guidelines, and making accurate judgments in scenario-based exercises to define what assets and systems fall within assessment boundaries.
  • CMMC Assessment Process (CAP): This section of the exam measures skills of compliance professionals and tests knowledge of the full assessment lifecycle. It covers the steps needed to plan, prepare, conduct, and report on a CMMC Level 2 assessment, including the phases of execution and how to document and follow up on findings in alignment with DoD and CMMC-AB expectations.
  • Evaluating Organizations Seeking Certification (OSC) against CMMC Level 2 Requirements: This section of the exam measures skills of cybersecurity assessors and focuses on evaluating the environments of organizations seeking certification at CMMC Level 2. It covers understanding differences between logical and physical settings, recognizing constraints in cloud, hybrid, on-premises, single, and multi-site environments, and knowing what environmental exclusions apply for Level 2 assessments.
Valid CMMC-CCA Exam Notes, CMMC-CCA Exams DumpsTestBraindump Cyber AB CMMC-CCA dumps contain required materials for the candidates. Once you purchase our products, all problems will be readily solved. You can try to use our free demo and download pdf real questions and answers before you make a decision. These exam simulations will help you to understand our products. Widespread scope and regularly update are the outstanding characteristic of TestBraindump Cyber AB CMMC-CCA braindump. By choosing it, all IT certifications are ok.
Cyber AB Certified CMMC Assessor (CCA) Exam Sample Questions (Q66-Q71):NEW QUESTION # 66
A contractor has retained you to assess compliance with CMMC practices as part of their triennial review.
During your assessment of the AU domain, you discovered that the contractor has recently installed new nodes and servers on their network infrastructure. To assess their implementation of AU.L2-3.3.7 - Authoritative Time Source, you trigger some events documented to meet AU.L2-3.3.1 - System Auditing across both the new and existing systems, generating audit logs. Upon examining these logs, you notice inconsistencies in the timestamps between newly installed and previously existing nodes. Further investigation reveals that while the contractor has implemented a central Network Time Protocol (NTP) server as the authoritative time source, the new systems are configured to automatically adjust and synchronize their clocks only when the time difference with the NTP server exceeds 30 seconds. Based on this scenario, why is time synchronization with the NTP server necessary, and what is the recommended synchronization time?
  • A. To increase the accuracy of digital clocks on devices, with a recommended synchronization time of 1 week
  • B. To reduce the network bandwidth used by system clocks, with a recommended synchronization time of once a month
  • C. To allow users to set their preferred time zones on individual systems, with a recommended synchronization time of 24 hours
  • D. To ensure that all systems record the audit logs using the same time source, with a recommended synchronization time of 1 second
Comprehensive and Detailed In-Depth Explanation:
AU.L2-3.3.7 requires synchronization with an authoritative time source to "generate consistent timestamps for audit records," critical for correlating events across systems. The 30-second threshold causes inconsistencies, failing this requirement. The CMMC guide doesn't specify an exact time, but best practices (e.g., NIST) recommend 1 second for audit log accuracy, ensuring precise event sequencing. Options B, C, and D undermine audit integrity or practicality-user time zones aren't relevant, monthly syncs are too infrequent, and weekly syncs lack precision.
Extract from Official CMMC Documentation:
* CMMC Assessment Guide Level 2 (v2.0), AU.L2-3.3.7: "Synchronization provides uniformity of timestamps for systems with multiple clocks."
* NIST SP 800-171A, 3.3.7: "Best practice recommends synchronization within 1 second for audit accuracy." Resources:
* https://dodcio.defense.gov/Porta ... AG_Level2_MasterV2.
0_FINAL_202112016_508.pdf
NEW QUESTION # 67
Your C3PAO has selected you as the Lead Assessor for the Assessment Team assessing an OSC's implementation of CMMC practices. Part of this assessment includes validating the OSC's CMMC assessment scope. Which of the following is NOT a factor to consider when determining which assets are in scope?
  • A. Organizational assets that process CUI or FCI.
  • B. Assets that secure the CUI or FCI storage location.
  • C. Government assets transmitting CUI into the OSC's systems.
  • D. Third-party assets that store CUI or FCI.
The CMMC Assessment Scope - Level 2 includes assets under the OSC's control that process, store, or transmit CUI/FCI (Option B), secure these assets (Option C), or are managed by third parties (e.g., ESPs) handling CUI/FCI (Option D). Government assets transmitting CUI into the OSC's systems (Option A) are out of scope, as they fall under a separate government authorization boundary and are not managed by the OSC. The scoping guide explicitly excludes such assets, making A the correct answer.
CMMC Assessment Scope - Level 2, Section 2.3.5 (Out-of-Scope Assets), p. 7: "Government assets transmitting CUI into OSC systems are out of scope."
NEW QUESTION # 68
An assessor is reviewing whether an organization appropriately analyzed the security impact of a new release of an application. Which of the following documents is MOST useful for the assessor to review?
  • A. Change Control Board (CCB) meeting minutes and supporting documents
  • B. A description of the change from the software vendor
  • C. A log of security incidents/issues after the change was implemented
  • D. System audit logs showing that the change occurred, when, and by whom
* Applicable Requirement: CM.L2-3.4.3 - "Track, review, approve/disapprove, and audit changes to organizational systems."
* Why CCB Minutes Are Correct (supports B):
* Change Control Board (CCB) documentation includes impact analyses, approvals, disapprovals, and justification for system changes.
* The CMMC Assessment Guide explicitly identifies CCB minutes and supporting records as primary evidence of compliance with change management practices.
Why Other Options Are Insufficient:
* A (Vendor description): Provides information on the update, but does not show organizational review or approval.
* C (Audit logs): Show when a change occurred, but not whether it was analyzed and approved beforehand.
* D (Incident logs): Reflects results after implementation, but not the review/approval process.
Assessment Guidance Extract (NIST SP 800-171A, CM.L2-3.4.3):
* Objectives include verifying that system changes are:
* Documented,
* Reviewed,
* Approved/disapproved, and
* Audited.
* Evidence such as CCB minutes and approval records directly satisfies these objectives.
References (CCA Official Sources):
* NIST SP 800-171 Rev. 2 - CM.L2-3.4.3 (Change Management)
* NIST SP 800-171A - Assessment Objectives for CM.L2-3.4.3
* CMMC Assessment Guide - Level 2, Version 2.13 - Change Management evidence expectations
NEW QUESTION # 69
What is NOT required for the Lead Assessor to confirm when verifying readiness to conduct an assessment?
  • A. Whether the OSC can better meet the targeted CMMC Level
  • B. That necessary logistics have been arranged
  • C. That risks have been identified
  • D. That evidence is available and accessible for the targeted CMMC Level
The Lead Assessor's readiness checks focus on logistics, scope, evidence availability, and risk awareness to ensure the assessment can proceed. It is not the assessor's role to advise or determine if the OSC could achieve a higher certification level - the OSC selects its target level.
Exact extracts:
* "Lead Assessors must confirm readiness by verifying logistics, scope boundaries, risks, and evidence availability."
* "Assessors do not advise OSCs on selecting certification levels or alternative approaches; this is outside the assessment scope." Why the other options are required:
* A: OSC risks must be identified and discussed as part of scoping.
* B: Logistics (scheduling, facilities, communications) must be confirmed.
* D: Evidence must be available and accessible to avoid delays.
CMMC Assessment Process (CAP), Pre-Assessment Readiness Activities.
CCA Study Guide - Lead Assessor Responsibilities.
NEW QUESTION # 70
Jane is a CCA for a leading C3PAO. She is selected to be part of a team of four, headed by James, to assess how Micron Inc., an OSC, has implemented the requirements for a CMMC Level 2 certification. However, she witnesses James striking a deal with Micron's CISO to manipulate some findings to ensure the OSC is certified. What should Jane do?
  • A. Assume nothing happened and continue with the assessment.
  • B. Ask for a bribe from James to keep quiet.
  • C. Privately request clarification from James.
  • D. Contact the DoD CIO and report James.
Comprehensive and Detailed in Depth Explanation:
The CoPC requires internal resolution first (Option B). Option A ignores duty, Option C is unethical, and Option D skips internal steps.
Extract from Official Document (CoPC):
* Paragraph 4.1(1)(a) - Violation Reporting (pg. 10):"Attempt to rectify the violation with the individual in question prior to reporting." References:
CMMC Code of Professional Conduct, Paragraph 4.1(1)(a).
NEW QUESTION # 71
Sometimes many people find they always have one begin that if I have money……If so I advise you apply for an IT certification steadfastly. Cyber AB CMMC-CCA valid exam questions and answers give an excellent beginning for your dream. If you pass exams and get a certification, you can obtain a high-salary job and realize your goal. CMMC-CCA Valid Exam Questions and answers help you pass exam certainly. We have a series of products for IT certification exams.
Valid CMMC-CCA Exam Notes: https://www.testbraindump.com/CMMC-CCA-exam-prep.html
BTW, DOWNLOAD part of TestBraindump CMMC-CCA dumps from Cloud Storage: https://drive.google.com/open?id=1TlckvayreMY5ElSkeAL-EWQzXvvbtfhT
Posted at 2/9/2026 17:33:19        Only Author  2#
The article was a real source of knowledge for me. Upgrade your IT knowledge with free NCP-CN Book Free. Best wishes for success!
Posted at 2/23/2026 17:53:37        Only Author  3#
This article is excellent, I truly appreciate you sharing it with us. Thanks to the Latest SSM braindumps pdf, I got promoted and received a salary boost. It’s free now. Wishing you all a successful career advancement!
