[General] PDII-JPN Exam Practice - Study PDII-JPN Center
97
【General】 PDII-JPN Exam Practice - Study PDII-JPN Center
Posted at 1/30/2026 02:01:41      View:125 | Replies:1        Print      Only Author   [Copy Link] 1#
Though there always exists fierce competition among companies in the same field. Our PDII-JPN study materials are always the top sellers in the market and our website is regarded as the leader in this career. Because we never stop improve our PDII-JPN practice guide, and the most important reason is that we want to be responsible for our customers. So we creat the most effective and accurate PDII-JPN Exam Braindumps for our customers and always consider carefully for our worthy customer.
If you feel that you always suffer from procrastination and cannot make full use of your spare time, maybe our PDII-JPN study materials can help you solve your problem. We are willing to recommend you to try the PDII-JPN study materials from our company. Our PDII-JPN training guide are high quality and efficiency test tools for all people. If you buy our PDII-JPN Preparation questions, we can promise that you can use our PDII-JPN study materials for study in anytime and anywhere. Because we have three version of PDII-JPN exam questions that can satisfy all needs of our customers.
Study Salesforce PDII-JPN Center - PDII-JPN Interactive QuestionsThe striking function of our  prepare torrent has attracted tens of thousands of exam candidates around the world with regular buyers who trust us by instinct when they have to deal with exams in this area. They are PDII-JPN exam torrent of versatility for providing not only the essential parts the exam test frequently but the new trendy question points. So our PDII-JPN Test Braindumps has attracted tens of thousands of regular buyers around the world. The successful endeavor of any kind of exam not only hinges on the effort the exam candidates paid, but the quality of practice materials’ usefulness. We trust you willpower, and we provide the high quality and high-effective PDII-JPN exam torrent here.
Salesforce  Sample Questions (Q147-Q152):NEW QUESTION # 147
開発者が連絡先のテスト データを作成するには、どのような方法がありますか? (2つ選んでください。)
  • A. Test.loadData (Contact.sObjectType, 'staticResource')
  • B. myDataFactory.createContacts(10)
  • C. Test.createTestData ()
  • D. Test.loadTestRecords(Contact.sObjectType, 'staticResource')
NEW QUESTION # 148
ポイント ツー ポイント統合の一環として、開発者は外部の Web サービスを呼び出す必要があります。これは、需要が高いため、応答を提供するのに長い時間がかかります。要求の一部として、開発者はコールアウトを行う前にエンド ユーザーからキー入力を収集する必要があります。
これらのビジネス要件を実装するために開発者が使用する必要がある 2 つの要素はどれですか?
2つの答えを選択してください
  • A. Lightning Web コンポーネント
  • B. プロセスビルダー
  • C. Continuation オブジェクトを返す Apex メソッド
  • D. 今すぐスクリーン
NEW QUESTION # 149
現在のユーザーのロケールで日付を文字列に変換するにはどのメソッドを使用する必要がありますか?
  • A. 日付.paras
  • B. 文字列の値
  • C. 文字列.形式
  • D. 日付。フォーマット
NEW QUESTION # 150
以下のコード スニペットを参照してください。
Credit_Memo__c というカスタム オブジェクトが Salesforce 環境に存在します。このタイプのレコードを取得して操作する新機能開発の一環として、開発者は、Apex トランザクション内でレコードのセットが変更されるときに競合状態が確実に防止されるようにする必要があります。
前述の Apex コードで、開発者はクエリステートメントを変更して SOQL 機能を使用し、トランザクション内の競合状態を防ぐにはどうすればよいでしょうか?
  • A.
  • B.
  • C.
  • D.
To prevent race conditions during an Apex transaction, the SOQL query can be modified to include the "FOR UPDATE" keyword. This keyword locks the records that are returned by the query, preventing other transactions from modifying them until the current transaction is complete. This ensures that the retrieved records cannot be changed by another process before the current transaction is completed, thus preventing race conditions. The correct option to use in the code snippet provided is:
[SELECT Id, Name, Amount__c FROM Credit_Memo__c WHERE Customer_Id__c = :customerId LIMIT 50 FOR UPDATE] This will lock up to 50 records of Credit_Memo__c with the specified Customer_Id__c for the duration of the transaction.
FOR UPDATE
Preventing Record Update Conflicts
NEW QUESTION # 151
Visualforce 検索ページで使用される RemoteAction を定義する以下の Apex クラスを検討してください。
Java
global with sharing class MyRemoter {
public String accountName { get; set; }
public static Account account { get; set; }
public MyRemoter() {}
@RemoteAction
global static Account getAccount(String accountName) {
account = [SELECT Id, Name, NumberOfEmployees FROM Account WHERE Name = :accountName]; return account;
リモート アクションが正しいアカウントを返したことをアサートするコード スニペットはどれですか。
  • A. Java
    MyRemoter remote = new MyRemoter('TestAccount');
    Account a = remote.getAccount();
    System.assertEquals( 'TestAccount' , a.Name );
  • B. Java
    Account a = MyRemoter.getAccount('TestAccount');
    System.assertEquals( 'TestAccount', a.Name );
  • C. Java
    MyRemoter remote = new MyRemoter();
    Account a = remote.getAccount('TestAccount');
  • D. Java
    Account a = controller.getAccount('TestAccount');
In Salesforce Apex, a @RemoteAction method must be defined as static. Static methods belong to the class itself rather than to a specific instance of the class. Therefore, when writing a unit test to verify the behavior of a RemoteAction, the method should be called using the class name notation (ClassName.methodName) rather than by instantiating the class first.
Option D correctly demonstrates the standard way to invoke a static method in Apex: Account a = MyRemoter.getAccount('TestAccount');. Because the method is static, it does not require the new keyword or a constructor to be called. Option A is incorrect because it attempts to call a static method on an instance variable (remote.getAccount), which is considered an illegal or improper reference in Apex. Option B is incorrect because it treats the RemoteAction like an instance method and assumes a non-existent constructor that takes a String. Option C is incorrect because it uses an undefined variable controller.
By calling the method statically in the test, the developer correctly simulates how the Visualforce Remoting engine calls the method from JavaScript at runtime. The assertion System.assertEquals then verifies that the record retrieved from the database matches the expected name, ensuring the search logic is functioning correctly.
NEW QUESTION # 152
Our PDII-JPN cram materials take the clients' needs to pass the test smoothly into full consideration. The questions and answers boost high hit rate and the odds that they may appear in the real exam are high. Our PDII-JPN exam questions have included all the information. Our PDII-JPN cram materials analysis the popular trend among the industry and the possible answers and questions which may appear in the real exam fully. Our PDII-JPN Latest Exam file stimulate the real exam's environment and pace to help the learners to get a well preparation for the real exam in advance.
Study PDII-JPN Center: https://www.braindumpspass.com/Salesforce/PDII-JPN-practice-exam-dumps.html
Salesforce PDII-JPN Exam Practice Method to Claim Guarantee, Salesforce PDII-JPN Exam Practice So what you need most is to know the whole examination process, If you choose to purchase our PDII-JPN exam simulator you can practice like attending the real test, Salesforce PDII-JPN Exam Practice This is a fair principle, We have engaged in this career for more than ten years and with our PDII-JPN exam questions, you will not only get aid to gain your dreaming certification, but also you can enjoy the first-class service online.
The terms client and server are used here in their generic PDII-JPN senses, not in the specialized sense of distributed client/server architectures, I studied a lot to fix them.
Method to Claim Guarantee, So what you need most is to know the whole examination process, If you choose to purchase our PDII-JPN exam simulator you can practice like attending the real test.
Free PDF Quiz 2026 Salesforce Marvelous PDII-JPN:  Exam PracticeThis is a fair principle, We have engaged in this career for more than ten years and with our PDII-JPN exam questions, you will not only get aid to gain your dreaming certification, but also you can enjoy the first-class service online.
Posted at 2/14/2026 17:22:55        Only Author  2#
I found the article to be incredibly beneficial to my understanding. Wishing for a smooth C_TS4FI_2023 Pass4sure pass guide exam ahead. Wish me luck!
