[General] Nutanix NCA-6.10 Sample Questions & NCA-6.10 Visual Cert Test
97
General Nutanix NCA-6.10 Sample Questions & NCA-6.10 Visual Cert Test
Posted at 1/30/2026 02:06:01      View125 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Pass4SureQuiz NCA-6.10 dumps for free: https://drive.google.com/open?id=17NcDXzMLt28sFGxNsgg3LA46-5OFAL7H
Our NCA-6.10 preparation exam have assembled a team of professional experts incorporating domestic and overseas experts and scholars to research and design related exam bank, committing great efforts to help the candidates to pass the NCA-6.10 exam. Most of the experts have been studying in the professional field for many years and have accumulated much experience in our NCA-6.10 Practice Questions. Our company is considerably cautious in the selection of talent and always hires employees with store of specialized knowledge and skills to help you get the dreaming NCA-6.10 certification.
Comparing to the training institution, our website can ensure you pass the Nutanix actual test with less time and money. You just need to use spare time to practice the NCA-6.10 exam questions and remember key points of test answers. If you get a bad result in the NCA-6.10 Practice Test, we will full refund you to reduce the loss of your money.
NCA-6.10 Visual Cert Test & Valid NCA-6.10 Test VoucherOur NCA-6.10 test materials boost three versions and they include the PDF version, PC version and the APP online version. The clients can use any electronic equipment on it. If only the users equipment can link with the internet they can use their equipment to learn our NCA-6.10 qualification test guide. They can use their cellphones, laptops and tablet computers to learn our NCA-6.10 Study Materials. The language is also refined to simplify the large amount of information. So the learners have no obstacles to learn our NCA-6.10 certification guide.
Nutanix Certified Associate v6.10 Sample Questions (Q54-Q59):NEW QUESTION # 54
An administrator receives the alert:
What is the most likely cause?
  • A. This node in the cluster is already in maintenance mode.
  • B. Another node in this cluster is already in maintenance mode.
  • C. Other nodes in the cluster may not have enough resource available.
  • D. This node in the cluster may not have enough resources available.
NEW QUESTION # 55
What is the minimum cluster size for Redundancy Factor 3?
  • A. 4 nodes
  • B. 3 nodes
  • C. 6 nodes
  • D. 5 nodes
https://portal.nutanix.com/page/ ... ancy-factor3-c.html
NEW QUESTION # 56
Which Nutanix Disaster Recovery component or feature provides the best Recovery Time Objective (RTO)?
  • A. Async
  • B. NearSync
  • C. Metro Availability
  • D. Availability Zone
Nutanix Metro Availability provides the best Recovery Time Objective (RTO) because it enables synchronous replication between two sites. In the event of a failure at one site, VMs can be instantly restarted on the other site with minimal disruption. This setup ensures zero data loss and near-instantaneous recovery.
* A. Asyncrovides high RPO (Recovery Point Objective) but has a longer RTO compared to synchronous replication methods.
* B. Availability Zone:This term refers to a general site setup, not specific to recovery objectives.
* C. Metro Availability:Correct, as it uses synchronous replication for near-zero RTO.
* D. NearSyncrovides better RPO than Async but does not match the RTO of Metro Availability.
Nutanix Data Protection and Disaster Recovery Guide.
Nutanix University Certification Content.
NEW QUESTION # 57
When multiple Alert policies are applied to an entity, which will take precedence?
  • A. Policy are applied to all entities of an entity type.
  • B. Policy are applied to an entity type in a cluster.
  • C. Policy are applied to an entity type in a category.
  • D. Policy are applied to a specific entity type.
When multiple alert policies are applied to an entity, Nutanix uses a hierarchical approach. Policies applied to an entity type within a categorytake precedence. For example:
* If a category (e.g., "roduction") has policies applied to entities like VMs, and the entity matches that category, the category-specific policy will override general policies.
* This prioritization allows administrators to fine-tune alert policies for specific workloads or environments.
Nutanix Alerts Management Guide - Policy Precedence Overview.
Nutanix University Certification Training Material.
NEW QUESTION # 58
After starting LCM updates, an administrator would like to see a detailed view of each update as it progresses.
Which Prism Element dashboard should the administrator use to monitor the LCM updates?
  • A. Analysis
  • B. Hardware
  • C. Alerts
  • D. Tasks
TheTasksdashboard in Prism Element provides detailed visibility into the progress of all ongoing and completed tasks, including Life Cycle Manager (LCM) updates. Administrators can monitor the step-by-step status of LCM operations, track failures, and identify bottlenecks.
* A. Analysis:Incorrect, as this is used for performance monitoring, not task progress.
* B. Tasks:Correct, as it displays detailed progress for updates and other operations.
* C. Hardware:Incorrect, as this focuses on the state and configuration of hardware components.
* D. Alerts:Incorrect, as this shows system alerts and issues, not detailed task progress.
Nutanix Life Cycle Manager Guide: Monitoring Updates.
Prism Element Administration Guide: Tasks Dashboard.
NEW QUESTION # 59
Our NCA-6.10 study materials just need you to memorize all keypoints of the knowledge of the real exam. It is unnecessary to review all irrelevant knowledges. At present, our NCA-6.10 exam questions have helped thousands of people pass the exam and obtain the certificate. Also, the passing rate of our NCA-6.10 Training Materials is the highest according to our investigation. None of the other exam braindumps in the market has the pass rate high as 98% to 100% as our NCA-6.10 learning quiz.
NCA-6.10 Visual Cert Test: https://www.pass4surequiz.com/NCA-6.10-exam-quiz.html
We will send the latest version of our NCA-6.10 training materials to our customers for free during the whole year after purchasing, Nutanix NCA-6.10 Sample Questions Please type the following into Google for more information: printing to PDF, So it is not surprise that NCA-6.10 Visual Cert Test - Nutanix Certified Associate v6.10 exam dumps are with high-quality and good comments, Besides, the explanations of NCA-6.10 valid questions & answers are very specific and easy to understand.
Then the windows software can simulate the real test environment, which makes you feel you are doing the real test, We have researched an intelligent system to help testing errors of the NCA-6.10 Exam Materials.
Nutanix Certified Associate v6.10 actual test pdf, NCA-6.10 actual test latest versionWe will send the latest version of our NCA-6.10 training materials to our customers for free during the whole year after purchasing, Please type the following into Google for more information: printing to PDF.
So it is not surprise that Nutanix Certified Associate v6.10 exam dumps are with high-quality and good comments, Besides, the explanations of NCA-6.10 valid questions & answers are very specific and easy to understand.
Now, you may need some useful and valid study material to help you.
2026 Latest Pass4SureQuiz NCA-6.10 PDF Dumps and NCA-6.10 Exam Engine Free Share: https://drive.google.com/open?id=17NcDXzMLt28sFGxNsgg3LA46-5OFAL7H
