[General] JN0-481 Exam Test | JN0-481 Latest Dump
66
General JN0-481 Exam Test | JN0-481 Latest Dump
Posted at 1/30/2026 02:21:36      View187 | Replies2        Print      Only Author   [Copy Link] 1#
Our company committed all versions of JN0-481 practice materials attached with free update service. When JN0-481 exam preparation has new updates, the customer services staff will send you the latest version. So we never stop the pace of offering the best services and JN0-481 practice materials for you. And we offer you the free demo of our JN0-481 Learning Materials to check the quality before payment. Tens of thousands of candidates have fostered learning abilities by using our JN0-481 Learning materials you can be one of them definitely.
The JN0-481 exam questions by experts based on the calendar year of all kinds of exam after analysis, it is concluded that conforms to the exam thesis focus in the development trend, and summarize all kind of difficulties you will face, highlight the user review must master the knowledge content. And unlike other teaching platform, the Data Center, Specialist (JNCIS-DC) study question is outlined the main content of the calendar year examination questions didn't show in front of the user in the form of a long time, but as far as possible with extremely concise prominent text of JN0-481 Test Guide is accurate incisive expression of the proposition of this year's forecast trend, and through the simulation of topic design meticulously.
JN0-481 Latest Dump & JN0-481 Valid Exam DurationWhen you are studying for the JN0-481 exam, maybe you are busy to go to work, for your family and so on. How to cost the less time to reach the goal? Its a critical question for you. Time is precious for everyone to do the efficient job. If you want to get good JN0-481 prep guide, it must be spending less time to pass it. Exactly, our product is elaborately composed with major questions and answers. If your privacy let out from us, we believe you wont believe us at all. Thats uneconomical for us. In the website security, we are doing well not only in the purchase environment but also the JN0-481 Exam Torrent customers privacy protection. We are seeking the long development for JN0-481 prep guide.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q44-Q49):NEW QUESTION # 44
In the Juniper Apstra Ul. You are creating a VNI pool for virtual networks.
In this scenario, which VNI range is acceptable?
  • A. The valid VNI range is 1 through 10000.
  • B. The valid VNI range is 2 through 4096.
  • C. The valid VNI range is 4096 through 16777214.
  • D. Any range is acceptable for the VNI pool.
In the Juniper Apstra UI, you can create VNI pools for virtual networks that use VXLAN encapsulation in the overlay network. A VNI pool is a resource pool that contains a range of VNIs that can be assigned to the virtual networks. The valid VNI range for a VNI pool is 4096 through
16777214, according to the VXLAN standard. Therefore, the statement B is correct in this scenario. The following three statements are incorrect in this scenario:
Any range is acceptable for the VNI pool. This is not true, because the VNI range has a lower and upper limit defined by the VXLAN standard. The lower limit is 4096, and the upper limit is
16777214. Any VNI outside this range is invalid and cannot be used for VXLAN encapsulation.
The valid VNI range is 2 through 4096. This is not true, because the VNI range does not start from 2, but from 4096. The VNIs from 2 to 4095 are reserved and cannot be used for VXLAN encapsulation. The valid VNI range is 1 through 10000. This is not true, because the VNI range does not include 1, which is also reserved and cannot be used for VXLAN encapsulation. The VNI range also does not end at 10000, but at 16777214, which is the maximum possible value for a 24-bit VNI field.
NEW QUESTION # 45
You are working with a three-stage IP fabric using EBGP for peering. In this scenario, which two actions are required to implement ECMP? (Choose two.)
  • A. Use a load balancing policy applied lo BGP as an import policy.
  • B. Use a load balancing policy applied to BGP as an export policy.
  • C. Use the multipath multiple-as BGP parameter.
  • D. Use a load balancing policy applied to the forwarding table as an export policy.
To implement ECMP in IP fabric using EBGP, you need to enable BGP to install multiple equal- cost paths in the routing table and to advertise them to the peers.
NEW QUESTION # 46
Referring to the exhibit, which role does Device A serve in an IP fabric?
  • A. server
  • B. leaf
  • C. spine
  • D. super spine
Device A serves as a spine in an IP fabric. An IP fabric is a network architecture that uses a spine-leaf topology to provide high performance, scalability, and reliability for data center networks. A spine- leaf topology consists of two layers of devices: spine devices and leaf devices.
Spine devices are the core devices that interconnect all the leaf devices using equal-cost multipath (ECMP) routing. Leaf devices are the edge devices that connect to the servers, storage, or other network devices. In the exhibit, Device A is connected to four leaf devices using multiple links, which indicates that it is a spine device.
NEW QUESTION # 47
You have a virtual network that needs controlled access to other virtual networks in the same routing zone. Using the Juniper Apstra Ul. which feature would be used to accomplish this task?
  • A. routing policy
  • B. anti-affinity policy
  • C. interface policy
  • D. security policy
A security policy is the feature that would be used to accomplish the task of controlling access to other virtual networks in the same routing zone using the Juniper Apstra UI. A security policy allows you to define rules that specify which traffic is allowed or denied between different virtual networks, IP endpoints, or routing zones. A security policy can be applied to one or more virtual networks in the same routing zone, and it can use various criteria to match the traffic, such as source and destination IP addresses, protocols, ports, or tags. A security policy can also support DHCP relay, which enables the forwarding of DHCP requests from one virtual network to another.
NEW QUESTION # 48
In the Juniper Apstra Ul, which three resources are assigned under the Resources menu?
(Choose three.)
  • A. ASN pools
  • B. VTEP pools
  • C. IP address pools
  • D. logical device pools
  • E. VNI pools
Answer: A,C,E
In the Juniper Apstra UI, the Resources menu allows you to create and manage global and local resources that are used for various elements of the network design and configuration. The Resources menu includes the following three types of resources that can be assigned to the network devices and virtual networks:
ASN pools: These are pools of autonomous system numbers (ASNs) that are used for the underlay routing protocol (EBGP) between the leaf and spine devices. You can create ASN pools with either 2-byte or 4-byte ASNs, and assign them to the logical devices in the blueprint. VNI pools: These are pools of virtual network identifiers (VNIs) that are used for the overlay network (VXLAN) between the end hosts. You can create VNI pools with a range of VNIs, and assign them to the virtual networks in the blueprint.
IP address pools: These are pools of IPv4 or IPv6 addresses that are used for various purposes in the network, such as the loopback addresses for the devices, the IP prefixes for the virtual networks, the host IP addresses for the end hosts, and the gateway IP addresses for the IRB interfaces. You can create IP address pools with a range of IP addresses, and assign them to the logical devices and virtual networks in the blueprint.
The following two types of resources are not assigned under the Resources menu:
VTEP pools: These are not resources that can be created or assigned by the user. VTEPs are VXLAN tunnel endpoints that are automatically generated by the Apstra server based on the loopback IP addresses of the devices. VTEPs are used as the source and destination IP addresses for the VXLAN tunnels in the overlay network.
Logical device pools: These are not resources that can be created or assigned by the user.
Logical device pools are groups of logical devices that share the same role, interface map, and resource assignments in the blueprint. Logical device pools are used to simplify the network design and configuration by applying the same settings to multiple devices.
NEW QUESTION # 49
Do you want to pass the Juniper JN0-481 exam better and faster? Then please select the ActualTestsIT. It can help you achieve your dreams. ActualTestsIT is a website that provide accurate exam materials for people who want to participate in the IT certification. ActualTestsIT can help a lot of IT professionals to enhance their career blueprint. Our strength will make you incredible. You can try a part of the questions and answers about Juniper JN0-481 Exam to test our reliability.
JN0-481 Latest Dump: https://www.actualtestsit.com/Juniper/JN0-481-exam-prep-dumps.html
Successful companies are those which identify customers' requirements and provide the solution to JN0-481 exam candidate needs and to make those dreams come true, we are in continuous touch with the exam candidates to get more useful ways, These professionals have years of experience and they constantly work with us to ensure the top standard of JN0-481 exam questions time, Juniper JN0-481 Exam Test Do you want to be the kind of person?
Specifying Flash Options, Defining `Audio` display and JN0-481 Valid Exam Duration play parameters, Successful companies are those which identify customers' requirements and provide the solution to JN0-481 Exam candidate needs and to make those dreams come true, we are in continuous touch with the exam candidates to get more useful ways.
Accurate JN0-481 Practice Engine gives you high-effective Exam Quiz - ActualTestsITThese professionals have years of experience and they constantly work with us to ensure the top standard of JN0-481 exam questions time, Do you want to be the kind of person?
There are many advantages of the PDF version, Passing my Juniper JN0-481 exam during my second attempt was easy and passing during the first attempt can easily be made a possibility!
Posted at 2/5/2026 21:59:05        Only Author  2#
Thank you for bringing this shocking article! Thanks to the Associate-Cloud-Engineer reliable practice questions ppt, I achieved a promotion and salary raise. Now, Im sharing it for free with everyone. Best of luck with your career advancements!
Posted at 3/6/2026 11:09:59        Only Author  3#
The article is easy to understand, and I have benefited a lot from it. I owe my promotion and raise to the FlashArray-Implementation-Specialist reliable test dumps.zip questions, and today Im sharing them for free with all of you!
