[General] Nokia 4A0-D01 Exam | Real 4A0-D01 Dumps - Download Demo Free of 4A0-D01 Exam Boo
66
General Nokia 4A0-D01 Exam | Real 4A0-D01 Dumps - Download Demo Free of 4A0-D01 Exam Boo
Posted at 1/30/2026 02:45:28      View197 | Replies2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ValidBraindumps 4A0-D01 dumps for free: https://drive.google.com/open?id=123dzR7tbHgsilzGhIHLsQoqEyhGh3IHS
Our 4A0-D01 study question is compiled and verified by the first-rate experts in the industry domestically and they are linked closely with the real exam. Our test bank provides all the questions which may appear in the real exam and all the important information about the exam. You can use the practice test software to test whether you have mastered the 4A0-D01 Test Practice materials and the function of stimulating the exam to be familiar with the real exam's pace. So our 4A0-D01 exam questions are real-exam-based and convenient for the clients to prepare for the 4A0-D01 exam.
Nokia 4A0-D01 Exam Syllabus Topics:
  • SR Linux User and System Management: This section of the exam measures skills of a Network Automation Specialist and includes managing user roles, TLS configurations for secure communication, and automation features like Zero-Touch Provisioning (ZTP). It covers ZTP setup, configuration processes, and common issues that may arise during deployment.
  • Module 5 C EDA (Event Driven Automation) Introduction
  • SR Linux Configuration and Routing: This section of the exam measures skills of a Network Automation Specialist and focuses on configuring and managing SR Linux systems. It examines the YANG-driven CLI, JSON output, environment variables, and static and dynamic routing. Learners also explore BGP, ECMP, IP-VRF, MAC-VRF, and the use of VXLAN with EVPN to implement both Layer 2 and Layer 3 overlays, including symmetric and asymmetric models.
  • This section of the exam measures skills of a Network Automation Specialist and introduces the principles of Event Driven Automation in SR Linux environments. It covers integration with Kubernetes and explores core use cases such as intent-based automation for fabrics and services, as well as enhanced network observability.
Topic 5
  • SR Linux Logging, Monitoring, and Filtering: This section of the exam measures skills of a Data Center Network Engineer and addresses how to implement logging, monitoring, and traffic filtering in SR Linux. It explains log file usage, ACL types, CPM filtering, and packet capture filters. Configuration tasks involve applying ACLs and monitoring network activity using capture tools.
4A0-D01 Exam Bootcamp | Authorized 4A0-D01 Exam DumpsBeing respected and gaining a high social status maybe what you always long for. But if you want to achieve that you must own good abilities and profound knowledge in some certain area. Passing the 4A0-D01 certification can prove that and help you realize your goal and if you buy our 4A0-D01 Quiz prep you will pass the exam successfully. Our product is compiled by experts and approved by professionals with years of experiences. You can download and try out our latest 4A0-D01 quiz torrent freely before your purchase.
Nokia Data Center Fabric Fundamentals Exam Sample Questions (Q22-Q27):NEW QUESTION # 22
Which of the following statements about resilient ECMP load balancing is TRUE?
  • A. Hash buckets are used to ensure that flows egressing the same interface on one router use different egress interfaces on downstream routers.
  • B. A different hash seed is used on downstream routers to ensure that flows are randomly distributed across all eligible router interfaces.
  • C. The hash value used to distribute traffic is calculated as a modulo function on specific fields of the packet header.
  • D. When one of the next-hops fail, only flows currently egressing to that next-hop are impacted.
In resilient ECMP load balancing, when a next-hop fails, only the flows that were using that specific next-hop are affected and need to be redistributed, minimizing disruption to other flows.
NEW QUESTION # 23
Which of the following statements about IP-VRFs in Nokia's SR Linux is FALSE?
  • A. Packets in an IP-VRF are forwarded based on the destination IP address.
  • B. The router maintains a distinct route table for each IP-VRF instance.
  • C. An IP-VRF is a Layer 3 network instance.
  • D. Multiple servers can be connected to the same subnet in an IP-VRF.
Multiple servers connected to the same subnet typically reside within the same Layer 2 domain or MAC-VRF. IP-VRFs operate at Layer 3 and segment routing and forwarding by separate routing tables, so multiple servers on the same subnet are not a function of IP-VRF.
NEW QUESTION # 24
Which of the following statements about the data center's leaf-spine topology (clos network) is FALSE?
  • A. Each leaf router is connected to all the spine routers in the cluster.
  • B. It uses ECMP to distribute traffic across duplicate links.
  • C. It provides a consistent path for east-west traffic.
  • D. It uses the spanning tree protocol to avoid forwarding loops.
The leaf-spine (Clos) topology does not use the spanning tree protocol because it relies on equal-cost multipath (ECMP) routing to prevent loops and efficiently utilize all available paths. Spanning tree is typically avoided in modern data center fabrics to enable full bandwidth utilization.
NEW QUESTION # 25
Which of the following is NOT one of the reasons why BGP is used as the routing protocol in the data center?
  • A. BGP neighbors automatically discover each other.
  • B. It is more efficient than link-state protocols like IS-IS and OSPF.
  • C. It is a well understood and mature routing protocol.
  • D. It supports both IPv4 and IPv6.
BGP is not chosen because it is more efficient than link-state protocols; in fact, link-state protocols like IS-IS and OSPF generally provide faster convergence and more efficient route calculation. BGP is used in data centers mainly because it is mature, well understood, supports both IPv4 and IPv6, and offers flexible policy control.
NEW QUESTION # 26
Examine the exhibit. What type of information is NOT included in the IMET route advertised by VTEP1?
  • A. Flooding list
  • B. IP address of VTEP1
  • C. VXLAN network identifier (VNI)
  • D. Route distinguisher of VTEP1's MAC-VRF
The IMET route includes the VNI, flooding list, and IP address of the originating VTEP, but it does not include the route distinguisher of the VTEP's MAC-VRF.
NEW QUESTION # 27
4A0-D01 learning materials are high-quality, because we have a professional team to collect the latest information for the exam. We can ensure you that 4A0-D01 exam braindumps you receive is the latest information we have. Our company is strict with the quality and answers, therefore you just need to use them at ease. We offer you free demo to have a try before buying 4A0-D01 Exam Dumps, so that you can have a better understanding of what you are going to buy. In addition, you can receive the download link and password within ten minutes, and if you dont, you can contact us, and we will solve that for you.
4A0-D01 Exam Bootcamp: https://www.validbraindumps.com/4A0-D01-exam-prep.html
What's more, part of that ValidBraindumps 4A0-D01 dumps now are free: https://drive.google.com/open?id=123dzR7tbHgsilzGhIHLsQoqEyhGh3IHS
Posted at 2/14/2026 23:48:15        Only Author  2#
Thank you for sharing this breathtaking article, its truly amazing! The FCP_FMG_AD-7.6 vce files material is very useful, and its available at no charge.
Posted at 2/24/2026 11:31:37        Only Author  3#
ɤΤ褦CompTIAPK0-005JԇY˜ʂ䤹ȐǤޤҡPK0-005J}οᡢۤäȤޤPK0-005JեȰ憖}ϤͤƤयIT˜I򤷤Ƥˡ{CompTIAPK0-005JYJȡäޤԇY˥ѩ`ԭҡ}ȫĤ°Ǥ
