[General] 100% Pass Salesforce - PDI - Platform Developer I (PDI)¨CReliable Best Study Mate
90
¡¾General¡¿ 100% Pass Salesforce - PDI - Platform Developer I (PDI)¨CReliable Best Study Mate
Posted at 1/30/2026 04:31:12      View£º205 | Replies£º1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce PDI dumps are available on Google Drive shared by 2Pass4sure: https://drive.google.com/open?id=1bIFEubLmO5no6skT_vywN8noHsRg5Msn
It is not hard to know that PDI torrent prep is compiled by hundreds of industry experts based on the syllabus and development trends of industries that contain all the key points that may be involved in the examination. Therefore, with PDI exam questions, you no longer need to purchase any other review materials, and you also don¡¯t need to spend a lot of money on tutoring classes. At the same time, PDI Test Guide will provide you with very flexible learning time in order to help you pass the exam.
So many candidates have encountered difficulties in preparing to pass the PDI exam. But our study materials will help candidates to pass the exam easily. Our PDI guide questions can provide statistics report function to help the learners to find weak links and deal with them. The PDI test torrent boost the function of timing and simulating the exam. They set the timer to simulate the exam and help the learners adjust the speed and keep alert. So the PDI Guide questions are very convenient for the learners to master and pass the exam. So believe us and take action immediately to buy our PDI exam torrent.
Best PDI Study Material & High-quality Reliable PDI Practice Questions Help you Clear Platform Developer I (PDI) EfficientlyExams like the Salesforce PDI exam provided by Salesforce are crucial for the advancement of your career. Candidates want to succeed on their Platform Developer I (PDI) exam. For candidates to study for and successfully pass their chosen certification exam the first time, 2Pass4sure provides Platform Developer I (PDI) PDI Exam Questions. You may use the top PDI study resources from 2Pass4sure to prepare for the Platform Developer I (PDI) exam. Salesforce PDI exam questions are a dependable and trustworthy source of training.
Salesforce Platform Developer I (PDI) Sample Questions (Q194-Q199):NEW QUESTION # 194
Universal Containers has an order system that uses an Order Number to identify an order for customers and service agents. Order records will be imported into Salesforce.
How should the Order Number field be defined in Salesforce?
  • A. Lookup
  • B. External ID and Unique
  • C. Direct Lookup
  • D. Indirect Lockup
NEW QUESTION # 195
Flow Builder uses an Apex action to provide additional information about multiple Contacts, stored in a custom class, ContactInfo. Which is the correct definition of the Apex method that gets the additional information?
A)
B)
C)
D)
  • A. Option D
  • B. Option B
  • C. Option C
  • D. Option A
NEW QUESTION # 196
A Lightning component has a wired property, searchResults, that stores a list of Opportunities. Which definition of the Apex method, to which the searchResults property is wired, should be used?
  • A. @AuraEnabled(cacheable=true)
    public static List<Opportunity> search(String term) { /* implementation*/ }
  • B. @AuraEnabled(cacheable=false)
    public static List<Opportunity> search(String term) { /*implementation*/ }
  • C. @AuraEnabled(cacheable=true)
    public List<Opportunity> search(String term) { /*implementation*/ }
  • D. @AuraEnabled(cacheable=false)
NEW QUESTION # 197
A developer creates a batch Apex job to update a large number of records, and receives reports of the job timing out and not completing.
What is the first step towards troubleshooting the issue?
  • A. Check the debug logs for the batch job.
  • B. Disable the batch job and recreate it with a smaller number of records.
  • C. Check the asynchronous job monitoring page to view the job status and logs.
  • D. Decrease the batch size to reduce the load on the system.
When troubleshooting batch Apex jobs:
* Asynchronous Job Monitoring:
* Navigate to Setup > Apex Jobs to view the status of the batch job.
* Provides information such as success, errors, and total execution time.
* This step is crucial to diagnose whether the issue is with system limits, batch size, or specific records.
* Debug Logs:
* After identifying the issue in the job monitoring page, use debug logs to pinpoint specific errors or bottlenecks.
* B. Check the debug logs for the batch job: Debug logs are a secondary step after checking the job status.
* C. Disable and recreate with fewer records: Premature without investigating the root cause.
* D. Decrease the batch size: Adjusting batch size is a solution but only after identifying the cause of the timeout.
* Asynchronous Job Monitoring: https://help.salesforce.com/s/articleView?id=000331217&type=1
* Debugging Apex: https://developer.salesforce.com ... xcode.meta/apexcode
/apex_debugging.htm
Why Not the Other Options?References:
NEW QUESTION # 198
What should a developer do to check the code coverage of a class after running all tests?
  • A. View Use cede coverage percentage for the class using the Overall Code Coverage panel in the Developer Console Tests tab.
  • B. View the Class Test Percentage tab on the Apex Class fist view m Salesforce Setup.
  • C. View the Code Coverage column in the list view on the Apex Classes page.
  • D. Select and run the class on the Apex Test Execution page in the Developer Console.
NEW QUESTION # 199
One of the biggest highlights of the Platform Developer I (PDI) prep torrent is the availability of three versions: PDF, app/online, and software/pc, each with its own advantages: The PDF version of PDI Exam Torrent has a free demo available for download. You can print exam materials out and read it just like you read a paper. The online version of PDI test guide is based on web browser usage design and can be used by any browser device. At the same time, the first time it is opened on the Internet, it can be used offline next time. You can practice anytime, anywhere. The Platform Developer I (PDI) software supports the MS operating system and can simulate the real test environment. The contents of the three versions are the same. Each of them neither limits the number of devices used or the number of users at the same time. You can choose according to your needs.
Reliable PDI Practice Questions: https://www.2pass4sure.com/Salesforce-PDI/PDI-actual-exam-braindumps.html
The Platform Developer I (PDI) PDI certification exam assists you to climb the corporate ladder easily and helps you to achieve your professional career objectives, Privacy By visiting this website, you acknowledge that you have read and understood 2Pass4sure Reliable PDI Practice Questions Privacy Policy, Here, I will descript our Reliable PDI Practice Questions - Platform Developer I (PDI) exam dumps, our Salesforce Reliable PDI Practice Questions dumps contains the questions & answers together with detail analysis, Salesforce Best PDI Study Material They expand business for their companies and own the promotion successfully.
The need for oxygen therapy, Null Values in Indexes, The Platform Developer I (PDI) PDI certification exam assists you to climb the corporate ladder easily and helps you to achieve your professional career objectives.
100% Pass Quiz Best PDI Study Material - Unparalleled Reliable Platform Developer I (PDI) Practice QuestionsPrivacy By visiting this website, you acknowledge PDI that you have read and understood 2Pass4sure Privacy Policy, Here, I will descript our Platform Developer I (PDI) exam dumps, our Reliable PDI Practice Questions Salesforce dumps contains the questions & answers together with detail analysis.
They expand business for their companies and own the promotion successfully, The complex portions of the PDI certification syllabus have been explained with the help of simulations and real-life based instances.
DOWNLOAD the newest 2Pass4sure PDI PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1bIFEubLmO5no6skT_vywN8noHsRg5Msn
Posted at 3/9/2026 10:15:03        Only Author  2#
I¡¯m sincerely grateful for your article, it really stood out to me. The Valid test COH-285 questions explanations test played a big part in my career growth, and I¡¯m offering it to you for free today!
