[General] ActualVCE Commitment to Your Palo Alto Networks SD-WAN-Engineer Exam Success
90
【General】 ActualVCE Commitment to Your Palo Alto Networks SD-WAN-Engineer Exam Success
Posted at 1/30/2026 04:47:28      View:144 | Replies:1        Print      Only Author   [Copy Link] 1#
For most people who have no much time to prepare the Palo Alto Networks real exam, latest SD-WAN-Engineer exam questions will be your excellent partner to help you get high passing score in the valid test. Once you receive our SD-WAN-Engineer Dumps Torrent, it will just need one or two days to practice test questions and answers. If you finished it well, clearing exam will be easy.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
Topic 5
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
Pass Guaranteed Quiz 2026 Palo Alto Networks SD-WAN-Engineer: Palo Alto Networks SD-WAN Engineer – Efficient Actual Test AnswersGenerally speaking, preparing for the SD-WAN-Engineer exam is a very hard and even some suffering process. Because time is limited, sometimes we have to spare time to do other things to review the exam content, which makes the preparation process full of pressure and anxiety. But from the point of view of customers, our SD-WAN-Engineer Actual Exam will not let you suffer from this. We have a high pass rate of our SD-WAN-Engineer study materials as 98% to 100%. Our SD-WAN-Engineer learning quiz will be your best choice.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q10-Q15):NEW QUESTION # 10
An administrator has configured a Path Policy for "ERP_Traffic". The policy allows two public internet links, "ISP-A" and "ISP-B", both marked as "Active". The Path Quality Profile (SLA) requires a latency of less than 150ms. Currently, both ISP-A and ISP-B have a latency of 40ms, well within the SLA.
How does the Prisma SD-WAN ION determine which link to use for a new flow of "ERP_Traffic" when both active paths meet the SLA requirements?
  • A. It selects the path with the lowest numerical latency (e.g., if ISP-A drops to 39ms).
  • B. It duplicates the packets across both paths (Packet Duplication) to ensure delivery.
  • C. It selects the path with the highest available bandwidth capacity.
  • D. It selects the path that appears first in the interface configuration list.
Comprehensive and Detailed Explanation
Prisma SD-WAN utilizes a sophisticated decision engine for Application-Based Path Selection that goes beyond simple failover. When configuring a Path Policy, the administrator defines "Active" paths and a "Path Quality Profile" (SLA).
SLA Compliance (The Filter): First, the system filters the available paths based on the Path Quality Profile. In this scenario, both ISP-A and ISP-B have 40ms latency against a 150ms threshold. Both are "green" or compliant paths.
Selection Criteria (The Tie-Breaker): When multiple paths are configured as "Active" and all meet the performance SLA, the ION device aims to optimize the overall user experience and network utilization. The default behavior for load balancing across healthy, compliant active paths is to select the path with the highest available bandwidth capacity.
By steering new flows to the link with the most "headroom" (available Mbps), the system prevents the saturation of a smaller link (e.g., a 20Mbps DSL line) while a larger link (e.g., 1Gbps Fiber) sits underutilized. This maximizes the aggregate throughput for the site. While latency is the qualifier, bandwidth availability is often the selector for compliant paths. Note that if the application was defined as "Real-Time" and configured for packet duplication, behavior would differ, but for standard traffic, capacity-based distribution is the standard active/active logic.
NEW QUESTION # 11
A network installer is attempting to claim a new ION device using the "Claim Code" method. The device is connected to the internet, but the status in the portal remains stuck at "Claimed" and does not transition to
"Online". The installer connects a laptop to the LAN port of the ION and can successfully browse the internet, confirming the uplink is active.
What is the most likely cause of the device failing to reach the "Online" state?
  • A. The device is missing the "Site" assignment in the portal.
  • B. The upstream firewall is blocking outbound TCP port 443 or UDP port 123 (NTP).
  • C. The "Circuit Label" has not been applied to the WAN interface.
  • D. The device has not yet downloaded the latest software image.
NEW QUESTION # 12
NEW QUESTION # 13
In a Data Center deployment, what is the key functional difference between configuring a BGP neighbor as a "Core Peer" versus an "Edge Peer"?
  • A. A Core Peer automatically redistributes learned routes into the SD-WAN fabric, whereas an Edge Peer does not.
  • B. A Core Peer is used for connecting to the internet, while an Edge Peer connects to the MPLS provider.
  • C. A Core Peer is used for LAN-side routing to learn DC prefixes, while an Edge Peer is used for WAN-side routing to the Service Provider.
  • D. A Core Peer supports eBGP only, while an Edge Peer supports iBGP only.
In the Prisma SD-WAN Data Center (DC) model, the terminology for BGP peers defines their role in the topology and how the system generates route maps.
Core Peer: This peer type is designated for the LAN-side connection (facing the DC Core Switch or internal Routers). Its primary purpose is to learn the subnets/prefixes hosted in the data center so the ION can advertise them to the remote branches. The system automatically creates route maps to facilitate this redistribution into the fabric.
Edge Peer: This peer type is designated for the WAN-side connection (facing the Edge Router or MPLS PE). Its primary purpose is to provide reachability to the underlay network.
Distinction: Selecting the correct type affects the default Route Maps and Prefix Lists generated by the controller. Configuring a Core Peer correctly ensures that the DC's internal subnets are properly learned and propagated to the overlay, whereas an Edge Peer configuration focuses on WAN next-hop reachability.
NEW QUESTION # 14
In a data center (DC) with two ION devices, all of the remote branch Prisma SD-WAN VPNs are active only on DC ION-1.
Why are no VPNs active on DC ION-2?
  • A. The BGP core peer is down.
  • B. The DC and branches are in a different domain.
  • C. The static route to core as a next hop is missing.
  • D. The ION device is behind a NAT.
In a Prisma SD-WAN Data Center deployment, the operational state of the Secure Fabric VPNs (overlay tunnels) is directly tied to the health of the BGP Core Peer configuration.4 Core Peer Dependency: DC ION devices typically peer with the data center core switch (Core Router) via BGP to learn the subnets (prefixes) for the applications hosted in the DC. The Prisma SD-WAN controller monitors this BGP peering status.5 Controller Logic: If the BGP Core Peer on a DC ION goes down (or is not established), the controller automatically marks the VPN tunnels terminating at that specific ION as "Inactive".6 This is a fail-safe mechanism designed to prevent remote branches from sending traffic to a DC ION that has lost conne7ctivity to the internal data center network (and thus the applications).
Scenario Analysis: In this scenario, DC ION-1 has active VPNs, meaning its BGP Core Peer is UP and it is successfully advertising reachability. DC ION-2 has no active VPNs, which strongly indicates that its BGP Core Peer is down.8 Because the controller sees the peer is down, it suppresses the tunnel establishment or marks existing tunnels as inactive to ensure traffic is only directed to the healthy node (ION-1).
NEW QUESTION # 15
Our goal is to increase customer's satisfaction and always put customers in the first place. As for us, the customer is God. We provide you with 24-hour online service for our SD-WAN-Engineer study tool. If you have any questions, please send us an e-mail. We will promptly provide feedback to you and we sincerely help you to solve the problem. Our specialists check daily to find whether there is an update on the SD-WAN-Engineer study tool. If there is an update system, we will automatically send it to you. Therefore, we can guarantee that our SD-WAN-Engineer Test Torrent has the latest knowledge and keep up with the pace of change. Many people are worried about electronic viruses of online shopping. But you don't have to worry about our products. Our SD-WAN-Engineer exam materials are absolutely safe and virus-free. If you encounter installation problems, we have professional staff to provide you with remote online guidance. We always put your needs in the first place.
Latest SD-WAN-Engineer Exam Fee: https://www.actualvce.com/Palo-Alto-Networks/SD-WAN-Engineer-valid-vce-dumps.html
Posted at 2/6/2026 12:01:41        Only Author  2#
Thank you for sharing such a powerful article, it really left an impression. I received a promotion and raise thanks to the Reliable Professional-Cloud-Security-Engineer test sims. Now it’s free for everyone. Wishing you success in your career!
