[General] Data-Architect權威考題,Data-Architect考古題介紹
92
【General】 Data-Architect權威考題,Data-Architect考古題介紹
Posted at 1/30/2026 07:20:16      View:196 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! 免費下載Fast2test Data-Architect考試題庫的完整版:https://drive.google.com/open?id=1NtfJTLr_TDM5KlNbXm0VcJjfCIRPSiSV
Fast2test的Data-Architect考古題是經過眾多考生檢驗過的資料,可以保證有很高的成功率。如果你用過考古題以後仍然沒有通過考試,Fast2test會全額退款。或者你也可以選擇為你免費更新考試考古題。有了這樣的保障,實在沒有必要擔心了。
Salesforce 資料架構師 (CDA) 認證是業界高度尊重的認證,它展示了候選人在 Salesforce 數據架構和管理方面的熟練程度。該認證獲得全球雇主的認可,對於任何想在 Salesforce 生態系統中推進職業生涯的人來說都是非常有價值的資產。CDA 認證也是高級認證,如應用架構師和系統架構師的先決條件。
值得信賴的Data-Architect權威考題擁有模擬真實考試環境與場境的軟件VCE版本&最新的Data-Architect考古題介紹Fast2test Salesforce的Data-Architect考試培訓資料你可以得到最新的Salesforce的Data-Architect考試的試題及答案,它可以使你順利通過Salesforce的Data-Architect考試認證,Salesforce的Data-Architect考試認證有助於你的職業生涯,在以後不同的環境,給出一個可能,Salesforce的Data-Architect考試合格的使用,我們Fast2test Salesforce的Data-Architect考試培訓資料確保你完全理解問題及問題背後的概念,它可以幫助你很輕鬆的完成考試,並且一次通過。
最新的 Salesforce Application Architect Data-Architect 免費考試真題 (Q217-Q222):問題 #217
A company has 12 million records, and a nightly integration queries these records.
Which two areas should a Data Architect investigate during troubleshooting if queries are timing out? (Choose two.)
  • A. Create custom indexes on the fields used in the filter criteria.
  • B. Modify the integration users' profile to have View All Data.
  • C. Create a formula field instead of having multiple filter criteria.
  • D. Make sure the query doesn't contain NULL in any filter criteria.
答案:A,D
解題說明:
Making sure the query does not contain NULL in any filter criteria can avoid full table scans and leverage indexes more efficiently. Queries with NULL filters are not selective and can cause performance issues. Creating custom indexes on the fields used in the filter criteria can also enhance the query performance by reducing the number of records to scan.
問題 #218
UC recently migrated 1 Billion customer related records from a legacy data store to Heroku Postgres. A subset of the data need to be synchronized with salesforce so that service agents are able to support customers directly within the service console. The remaining non- synchronized set of data will need to be accessed by salesforce at any point in time, but UC management is concerned about storage limitations.
What should a data architect recommend to meet these requirements with minimal effort?
  • A. As needed, make call outs into Heroku postgres and persist the data in salesforce.
  • B. Migrate the data to big objects and leverage async SOQL with custom objects.
  • C. Use Heroku connect to bi-directional, sync all data between systems.
  • D. Virtualize the remaining set of data with salesforce connect and external objects.
答案:D
問題 #219
A Salesforce customer has plenty of data storage. Sales Reps are complaining that searches are bringing back old records that aren't relevant any longer. Sales Managers need the data for their historical reporting. What strategy should a data architect use to ensure a better user experience for the Sales Reps?
  • A. Archive and purge old data from Salesforce on a monthly basis.
  • B. Set data access to Private to hide old data from Sales Reps.
  • C. Use Batch Apex to archive old data on a rolling nightly basis.
  • D. Create a Permission Set to hide old data from Sales Reps.
答案:A
解題說明:
Archiving and purging old data from Salesforce on a monthly basis is a good strategy to improve the user experience for the Sales Reps, as it will reduce the clutter and improve the search performance. Creating a permission set or setting data access to private are not effective ways to hide old data from Sales Reps, as they will still consume data storage and affect search results. Using Batch Apex to archive old data on a rolling nightly basis is also not a good option, as it will consume API requests and processing time, and may not comply with the data retention policy.
問題 #220
A Salesforce customer has plenty of data storage. Sales Reps are complaining that searches are bringing back old records that aren't relevant any longer. Sales Managers need the data for their historical reporting.What strategy should a data architect use to ensure a better user experience for the Sales Reps?
答案:A
問題 #221
Universal Containers (UC) is going thought major reorganization of their sales team. This would require changes to a large a number of group members and sharing rules. UCs administrator is concerned about long processing time and failure during the process.
What should a Data architect implement to make changes efficiently?
  • A. Enable Defer Sharing Calculation prior to making sharing rule changes.
  • B. Log a case with salesforce to make sharing rule changes.
  • C. Log out all users and make changes to sharing rules.
  • D. Delete old sharing rules and build new sharing rules
答案:A
問題 #222
Fast2test題供了不同培訓工具和資源來準備Salesforce的Data-Architect考試,編制指南包括課程,實踐的檢驗,測試引擎和部分免費PDF下載,我們的考題及答案反應的問題問Salesforce的Data-Architect考試
Data-Architect考古題介紹: https://tw.fast2test.com/Data-Architect-premium-file.html
Salesforce Data-Architect權威考題 到時,您可以直接通過我們的網站進行購買,或者與我們的客服人員聯系,當你選擇Data-Architect考試時有沒有選擇相關的考試課程,Salesforce Data-Architect權威考題 在IT行業中工作的專業人士也希望自己有個很好的提升機會和很大的提升空間,可以保證你第一次參加Salesforce Data-Architect的認證考試就以高分順利通過,90%左右的覆蓋率,在這裏,我們推薦一個很好的學習資料網站,而且網站上的部分測試資料是免費的,重要的是真實的模擬練習可以幫助你通過 Salesforce的Data-Architect的考試認證,Fast2test Salesforce的Data-Architect的考試資料不僅可以節約你的時間成本,還可以讓你順利通過認證,你沒有理由不選擇,覆蓋94%左右。
傳感器在創建智能製造技術所依賴的信息流中發揮著重要作用,該怎麽選都是有數的,到時,您可以直接通過我們的網站進行購買,或者與我們的客服人員聯系,當你選擇Data-Architect考試時有沒有選擇相關的考試課程,在IT行業中工作的專業人士也希望自己有個很好的提升機會和很大的提升空間。
Data-Architect權威考題 - 提供有效材料以通過Salesforce Certified Data Architect考試可以保證你第一次參加Salesforce Data-Architect的認證考試就以高分順利通過,90%左右的覆蓋率。
順便提一下,可以從雲存儲中下載Fast2test Data-Architect考試題庫的完整版:https://drive.google.com/open?id=1NtfJTLr_TDM5KlNbXm0VcJjfCIRPSiSV
Posted at 2/5/2026 15:32:52        Only Author  2#
Wenn Sie unsere Prüfungsmaterialien zur Salesforce AP-212 Zertifizierungsprüfung kaufen, wird DeutschPrüfung Ihnen den besten Service und die beste Qualität bieten. Unsere Salesforce AP-212 Zertifizierungssoftware wird schon von dem Anbieter und dem Dritten autorisiert. Außerdem haben wir auch viele IT-Experten, die nach den Bedürfnissen der Kunden eine Serie von Produkten laut dem Kompendium bearbeitet. Die Materialien zur Salesforce AP-212 Zertifizierungsprüfung haben einen hohen Goldgehalt. Sie können von den Experten und Gelehrte für Forschung benutzt werden. Sie können alle unseren Produkte teilweise als Probe vorm Kauf umsonst benutzen, so dass Sie die Qualität sowie die Anwendbarkeit testen können.
