[General] Latest AZ-104 Practice Questions, AZ-104 Cheap Dumps
89
【General】 Latest AZ-104 Practice Questions, AZ-104 Cheap Dumps
Posted at 1/30/2026 09:26:34      View:180 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of NewPassLeader AZ-104 dumps for free: https://drive.google.com/open?id=1wOtsHSWly4p2QF3Mt9P-ZAb0et66nidq
To meet the needs of users, and to keep up with the trend of the examination outline, our products will provide customers with larest version of our products. Our company's experts are daily testing our AZ-104 study guide for timely updates. So we solemnly promise the users, our products make every effort to provide our users with the latest learning materials. As long as the users choose to purchase our AZ-104 Exam Dumps, there is no doubt that he will enjoy the advantages of the most powerful update. Most importantly, these continuously updated systems are completely free to users. As long as our AZ-104 learning material updated, users will receive the most recent information from our AZ-104 learning materials. So, buy our products immediately!
Microsoft AZ-104 certification exam is designed for individuals who want to prove their proficiency in managing and monitoring Azure resources. Microsoft Azure Administrator certification is ideal for professionals who have a deep understanding of cloud computing and Microsoft Azure, as well as experience in implementing, managing, and monitoring Azure solutions. AZ-104 Exam is intended to validate skills in areas such as Azure administration, Azure virtual machines, Azure storage, Azure networking, and Azure identity.
AZ-104 Cheap Dumps - AZ-104 Reliable Braindumps BookThere is no another great way to pass the Microsoft AZ-104 exam in the first attempt only by doing a selective study with valid AZ-104 braindumps. If you already have a job and you are searching for the best way to improve your current AZ-104 test situation, then you should consider the AZ-104 Exam Dumps. By using our updated AZ-104 products, you will be able to get reliable and relative AZ-104 exam prep questions, so you can pass the exam easily. You can get one-year free AZ-104 exam updates from the date of purchase.
Microsoft Azure is a cloud computing platform that offers a wide variety of services to businesses to help them streamline their operations and reduce costs. The platform is known for its scalability, flexibility, and security. As more businesses move to cloud-based services, the demand for certified Azure professionals is on the rise. The industry-recognized certification for Azure administrators is the Microsoft AZ-104 Exam.
Microsoft Azure Administrator Sample Questions (Q11-Q16):NEW QUESTION # 11
HOTSPOT
You have an Azure subscription.
You need to use an Azure Resource Manager (ARM) template to create a virtual machine that will have multiple data disks.
How should you complete the template? To answer, select the appropriate options in the answer area.
Hot Area:
Section: [none]
NEW QUESTION # 12
You have an Active Directory forest named contoso.com.
You install and configure Azure AD Connect to use password hash synchronization as the single sign-on (SSO) method. Staging mode is enabled.
You review the synchronization results and discover that the Synchronization Service Manager does not display any sync jobs.
You need to ensure that the synchronization completes successfully.
What should you do?
  • A. Run Azure AD Connect and disable staging mode.
  • B. Run Azure AD Connect and set the SSO method to Pass-through Authentication.
  • C. From Azure PowerShell, run Start-AdSyncSyncCycle -PolicyType Initial.
  • D. From Synchronization Service Manager, run a full import.
Staging mode must be disabled. If the Azure AD Connect server is in staging mode, password hash synchronization is temporarily disabled.
References: https://docs.microsoft.com/en-us ... t/active-directory- aadconnectsync-troubleshoot-password-hash-synchronization#no-passwords-are-synchronized- troubleshoot-by-using-the-troubleshooting-task
NEW QUESTION # 13
You have an Azure subscription that contains eight virtual machines and the resources shown in the following table.
You need to configure access for VNET1. The solution must meet the following requirements:
- The virtual machines connected to VNET1 must be able to communicate
with the virtual machines connected to VNET2 by using the Microsoft
backbone.
- The virtual machines connected to VNET1 must be able to access
storage1, storage2 and Azure AD by using the Microsoft backbone.
What is the minimum number of service endpoints you should add to VNET1?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
First service endpoint: One service endpoint for Microsoft.Storage added to VNET1.
The question asks how many to add to VNET1. When adding service endpoints on the VNET1 side you only get to choose the service ( Microsoft.Storage ) not the actual storage accounts.
Once you add this service endpoint it can be then linked to on the storage side for both accounts.
Second Service Endpoint: Microsoft.AzureActiveDirectory.
NEW QUESTION # 14
You have an Azure subscription that contains the resources in the following table.
To which subnets can you apply NSG1?
  • A. the subnets on VNet2 only
  • B. the subnets on VNet2 and VNet3 only
  • C. the subnets on VNet3 only
  • D. the subnets on VNet1, VNet2, and VNet3
  • E. the subnets on VNet1 only
Section: [none]
All Azure resources are created in an Azure region and subscription. A resource can only be created in a virtual network that exists in the same region and subscription as the resource.
https://docs.microsoft.com/en-us ... net-plan-design-arm
NEW QUESTION # 15
You have an Azure subscription that contains a storage account.
You have an on-premises server named Server1 that runs Window Server 2016. Server1 has 2 TB of data.
You need to transfer the data to the storage account by using the Azure Import/Export service.
In which order should you perform the actions? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
NOTE: More than one order of answer choices is correct. You will receive credit for any of the correct orders you select.
1 - Attach an external disk to Server1 and then run waimportexport.exe
2 - From the Azure portal, create an import job.
3 - Detach the external disks from Server1 and ship the disks to an Azure data center.
4 - From the Azure portal, update the import job
https://docs.microsoft.com/en-us ... port-export-service
NEW QUESTION # 16
AZ-104 Cheap Dumps: https://www.newpassleader.com/Microsoft/AZ-104-exam-preparation-materials.html
What's more, part of that NewPassLeader AZ-104 dumps now are free: https://drive.google.com/open?id=1wOtsHSWly4p2QF3Mt9P-ZAb0et66nidq
