[General] Three Formats Of Latest SOA-C02 Exam Questions
90
General Three Formats Of Latest SOA-C02 Exam Questions
Posted at 1/30/2026 12:44:03      View204 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New SOA-C02 dumps are available on Google Drive shared by Prep4King: https://drive.google.com/open?id=1Nv66LALPN5MkfJfUL6ytT-oKqCBilD-s
Quitters never win and winners never quit. If you are determined to clear SOA-C02 exam and obtain a certification you shouldn't give up because of one failure. If you are willing, our Amazon SOA-C02 valid exam simulations file can help you clear exam and regain confidence. Every year there are thousands of candidates choosing our products and obtain certifications so that our SOA-C02 valid exam simulations file is famous for its high passing-rate in this field. If you want to pass exam one-shot, you shouldn't miss our files.
Candidates must have a good understanding of AWS architecture and best practices, as well as experience in deploying and managing AWS services. They should also be familiar with automation tools such as AWS Lambda and AWS Elastic Beanstalk, and have experience in working with AWS security and compliance services such as AWS Identity and Access Management (IAM) and AWS Key Management Service (KMS).
Quiz 2026 SOA-C02: AWS Certified SysOps Administrator - Associate (SOA-C02) C The Best Updated DemoIn todays global market, tens of thousands of companies and business people are involved in this line of SOA-C02 exam. It is of utmost importance to inquire into the status of exam candidates wills to figure out what are the SOA-C02 practice materials you really needed. According to your requirements we made our SOA-C02 Study Materials for your information, and for our pass rate of the SOA-C02 exam questions is high as 98% to 100%, we can claim that you will pass the exam for sure.
Amazon AWS Certified SysOps Administrator - Associate (SOA-C02) Sample Questions (Q559-Q564):NEW QUESTION # 559
A software company runs a workload on Amazon EC2 instances behind an Application Load Balancer (ALB) A SysOcs administrator needs to define a custom health check for the EC2 instances. What is the MOST operationally efficient solution?
  • A. Set up each EC2 Instance so that it writes its healthy/unhealthy status into a shared Amazon S3 bucket for the ALB to read
  • B. Set up Amazon ElasticCache to track the EC2 instances as they scale in and out
  • C. Configure the health check on the ALB and ensure that the HeathCheckPath setting is correct
  • D. Configure an Amazon API Gateway health check to ensure custom checks on aw of the EC2 instances
NEW QUESTION # 560
A software development company has multiple developers who work on the same product. Each developer must have their own development environment, and these development environments must be identical. Each development environment consists of Amazon EC2 instances and an Amazon RDS DB instance. The development environments should be created only when necessary, and they must be terminated each night to minimize costs.
What is the MOST operationally efficient solution that meets these requirements?
  • A. Provide developers with access to the same AWS CloudFormation template so that they can provision their development environment when necessary. Schedule a nightly cron job on each development instance to stop all running processes to reduce CPU utilization to nearly zero.
  • B. Provide developers with CLI commands so that they can provision their own development environment when necessary. Schedule a nightly Amazon EventBridge (Amazon CloudWatch Events) rule to invoke an AWS Lambda function to terminate all EC2 instances and the DB instance.
  • C. Provide developers with CLI commands so that they can provision their own development environment when necessary. Schedule a nightly Amazon EventBridge (Amazon CloudWatch Events) rule to cause AWS CloudFormation to delete all of the development environment resources.
  • D. Provide developers with access to the same AWS CloudFormation template so that they can provision their development environment when necessary. Schedule a nightly Amazon EventBridge (Amazon CloudWatch Events) rule to invoke an AWS Lambda function to delete the AWS CloudFormation stacks.
NEW QUESTION # 561
An environment consists of 100 Amazon EC2 Windows instances The Amazon CloudWatch agent Is deployed and running on at EC2 instances with a baseline configuration file to capture log files There is a new requirement to capture the DHCP tog tiles that exist on 50 of the instances What is the MOST operational efficient way to meet this new requirement?
  • A. Run the CloudWatch agent configuration file wizard on each EC2 instance Verify that the base the log files are included and add the DHCP tog files during the wizard creation process
  • B. Create an additional CloudWatch agent configuration file to capture the DHCP logs Use the AWS Systems Manager Run Command to restart the CloudWatch agent on each EC2 instance with the append-config option to apply the additional configuration file
  • C. Log in to each EC2 instance with administrator rights Create a PowerShell script to push the needed baseline log files and DHCP log files to CloudWatch
  • D. Run the CloudWatch agent configuration file wizard on each EC2 instance and select the advanced detail level. This wifi capture the operating system log files.
The most operationally efficient way to capture DHCP log files on 50 of the 100 EC2 instances is to create an additional CloudWatch agent configuration file and use AWS Systems Manager Run Command to update the CloudWatch agent configuration.
* Create an Additional CloudWatch Agent Configuration File:
* Create a new CloudWatch agent configuration file that includes the settings to capture DHCP log files.
* Use AWS Systems Manager Run Command:
* AWS Systems Manager Run Command allows you to remotely and securely manage the configuration of your managed instances.
* Use the Run Command to restart the CloudWatch agent on each EC2 instance with the append- config option to apply the additional configuration file.
* Steps:
* Open the Systems Manager console.
* Choose "Run Command."
* Create a new command document or use an existing one that restarts the CloudWatch agent with the append-config option.
* Target the 50 specific EC2 instances.
Amazon CloudWatch Agent Configuration
NEW QUESTION # 562
A company uses an Amazon Elastic File System (Amazon EFS) file system to share files across many Linux Amazon EC2 instances. A SysOps administrator notices that the file system's PercentIOLimit metric is consistently at 100% for 15 minutes or longer. The SysOps administrator also notices that the application that reads and writes to that file system is performing poorly. They application requires high throughput and IOPS while accessing the file system.
What should the SysOps administrator do to remediate the consistently high PercentIOLimit metric?
  • A. Create an EFS lifecycle policy to transition future files to the Infrequent Access (IA) storage class to improve performance. Use AWS DataSync to migrate existing data to IA storage.
  • B. Modify the existing EFS file system and activate Max I/O performance mode.
  • C. Modify the existing EFS file system and activate Provisioned Throughput mode.
  • D. Create a new EFS file system that uses Max I/O performance mode. Use AWS DataSync to migrate data to the new EFS file system.
NEW QUESTION # 563
A company using AWS Organizations requires that no Amazon S3 buckets in its production accounts should ever be deleted.
What is the SIMPLEST approach the SysOps administrator can take to ensure S3 buckets in those accounts can never be deleted?
  • A. Use AWS Shield to deny the s3eleteBucket action on the AWS account instead of all S3 buckets.
  • B. Create an IAM group that has an IAM policy to deny the s3eleteBucket action on all buckets in production accounts.
  • C. Set up MFA Delete on all the S3 buckets to prevent the buckets from being deleted.
  • D. Use service control policies to deny the s3eleteBucket action on all buckets in production accounts.
https://docs.aws.amazon.com/orga ... _policies_scps.html If you're using AWS Organizations, check the service control policies for any statements that explicitly deny Amazon S3 access. In particular, check the service control policies for statements denying the s3utBucketPolicy action. https://aws.amazon.com/tw/premiu ... nied-bucket-policy/
NEW QUESTION # 564
The Amazon SOA-C02 certification provides is beneficial to accelerate your career in the tech sector. Today, the Amazon SOA-C02 certification is a fantastic choice to get high-paying jobs and promotions, and to achieve it, you must crack the challenging SOA-C02 Exam. It is critical to prepare with actual AWS Certified SysOps Administrator - Associate (SOA-C02) (SOA-C02) exam questions if you have less time and want to clear the test in a short time. You will fail and waste time and money if you do not prepare with real and updated SOA-C02 Questions.
SOA-C02 Frenquent Update: https://www.prep4king.com/SOA-C02-exam-prep-material.html
DOWNLOAD the newest Prep4King SOA-C02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Nv66LALPN5MkfJfUL6ytT-oKqCBilD-s
Posted at 2/17/2026 18:24:51        Only Author  2#
What an awe-inspiring article, Im so grateful for your sharing. I used the H35-211_V2.5 new exam bootcamp materials to get promoted and raise my salary. Its now free for everyone. Best of luck with your career goals!
Posted at 2/23/2026 10:28:22        Only Author  3#
Your article is brilliant beyond words, Im thankful for your share! Wishing for a smooth NPPE valid vce exam ahead. Wish me luck!
