Valid SD-WAN-Engineer Practice Materials | Mock SD-WAN-Engineer Exam
94
Posted at 1/30/2026 13:14:09      View:196 | Replies:4        Print      Only Author   [Copy Link] 1#
Maybe there are so many candidates think the SD-WAN-Engineer exam is difficult to pass that they be beaten by it. But now, you don’t worry about that anymore, because we will provide you an excellent exam material. Our SD-WAN-Engineer exam materials are very useful for you and can help you score a high mark in the test. It also boosts the function of timing and the function to simulate the SD-WAN-Engineer Exam so you can improve your speed to answer and get full preparation for the test. Trust us that our SD-WAN-Engineer exam torrent can help you pass the exam and find an ideal job.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
Topic 5
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
Fantastic Valid SD-WAN-Engineer Practice Materials & Leader in Qualification Exams & Pass-Sure SD-WAN-Engineer: Palo Alto Networks SD-WAN EngineerOur desktop-based Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) practice exam software needs no internet connection. The web-based Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) practice exam is similar to the desktop-based software. You can take the web-based Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) practice exam on any browser without needing to install separate software. In addition, all operating systems also support this web-based Palo Alto Networks SD-WAN-Engineer Practice Exam. Both Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) practice exams track your performance and help to overcome mistakes. Furthermore, you can customize your Building Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) practice exams according to your needs.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q75-Q80):NEW QUESTION # 75
An administrator is configuring an ION 2000 device for a deployment where high availability is required, but the site has only a single internet circuit. The administrator configures a Bypass Pair (Fail-to-Wire) on ports 1 and 2 connecting the ISP modem to the legacy firewall.
If the ION device loses power, what is the resulting behavior of the traffic flowing through this Bypass Pair?
  • A. The device reboots into "Safe Mode" and acts as a Layer 2 switch.
  • B. Traffic is rerouted to the LTE modem automatically.
  • C. The internal relay closes, physically bridging Port 1 and Port 2, allowing traffic to flow transparently between the modem and firewall.
  • D. Traffic is blocked to prevent uninspected packets from entering the network (Fail-to-Block).
Comprehensive and Detailed Explanation
The Bypass Pair feature on Prisma SD-WAN ION devices (specifically supported models like ION 2000, 3000, 7000, 9000) is a hardware-based resiliency mechanism known as Fail-to-Wire.
Operation: A "Bypass Pair" logically groups two physical interfaces (e.g., WAN 1 and LAN 1). Under normal operation, the ION processes traffic between them.
Power Loss: In the event of a total power loss (or critical software failure), a mechanical relay inside the device physically closes the circuit between the two ports.
Result: This creates a direct electrical connection (like a patch cable) between the upstream device (ISP Modem) and the downstream device (Legacy Firewall or Router). This ensures that internet connectivity is preserved for the site, even if the SD-WAN appliance is completely dead. This is critical for single-point-of-failure deployments where maintaining basic dial-tone is more important than SD-WAN optimization during a hardware outage.
NEW QUESTION # 76
When identifying devices for IoT classification purposes, which two methods does Prisma SD-WAN use to discover devices that are not directly connected to the branch ION? (Choose two.)
  • A. CDP
  • B. Syslog
  • C. SNMP
  • D. LLDP
Prisma SD-WAN (formerly CloudGenix) integrates with Palo Alto Networks IoT Security to provide comprehensive visibility into all devices at a branch, including those that are not directly connected to the ION device. While the ION automatically detects and classifies devices connected directly to its interfaces via traffic inspection (DPI), DHCP, and ARP analysis, gaining visibility into off-branch devices (devices connected to downstream switches or access points) requires additional discovery mechanisms that can query the network infrastructure or ingest its logs.
1. SNMP (Simple Network Management Protocol): This is the primary active discovery method for off-branch devices. The Prisma SD-WAN ION device acts as a sensor that actively polls local network switches and wireless controllers using SNMP. By querying the ARP tables and MAC address tables (Bridge MIBs) of these intermediate network devices, the ION can identify endpoints that are connected to the switch ports, even if those endpoints are not currently sending traffic through the ION. This allows the system to map the topology and discover silent or lateral-traffic-only devices.
2. Syslog: In conjunction with SNMP, the IoT Security solution can utilize Syslog messages to discover and profile devices. Network infrastructure devices (like switches and WLAN controllers) can be configured to send Syslog messages to the collection point (which enables the IoT Security service) whenever a device connects or disconnects (e.g., port up/down events, DHCP snooping logs, or 802.1x authentication logs). These logs provide real-time data about device presence and identity (MAC/IP mappings) for devices that are not directly adjacent to the ION, ensuring 100% visibility across the branch network segments. LLDP (A) and CDP (B) are typically Link Layer discovery protocols used for discovering directly connected neighbors and do not propagate beyond the immediate link, making them unsuitable for discovering devices multiple hops away or behind a switch.
NEW QUESTION # 77
Which configuration requirement must be met to allow two branch ION devices to automatically establish a direct Dynamic VPN (branch-to-branch) connection for traffic flow, bypassing the Data Center?
  • A. Both ION devices must be members of the same VPN Cluster.
  • B. A static "Gre Tunnel" must be manually configured between the two sites.
  • C. The Data Center ION must be offline to trigger the dynamic failover.
  • D. The "Standard VPN" path policy must be selected.
Dynamic VPNs (also known as ION-to-ION or Branch-to-Branch VPNs) allow Prisma SD-WAN devices to establish direct, on-demand secure tunnels between branch sites to optimize latency for peer-to-peer traffic (e.g., VoIP calls between offices).
To enable this capability, the primary architectural requirement is the configuration of VPN Clusters.
A VPN Cluster defines a logical group of devices that are authorized to communicate with one another.
By default, or if devices are in different clusters without peering, the topology typically defaults to Hub-and-Spoke, where branches only talk to the Data Center.
When two branch ION devices are placed into the same VPN Cluster (or peered clusters), the controller shares the necessary reachability and cryptographic information between them.
Once in the same cluster, the ION devices monitor traffic. If a user at Branch A tries to contact a server at Branch B, the ION devices detect this interest. If a direct path is available (e.g., via public internet), they will dynamically negotiate a direct VPN tunnel, bypassing the Data Center hub. This offloads the hub and reduces latency. Option B is incorrect because SD-WAN eliminates manual GRE config. Option C is incorrect because dynamic VPNs are a performance feature, not just a disaster recovery feature.
NEW QUESTION # 78
A network installer is at a remote branch site to deploy a new ION 3000 device. The device has been racked, cabled to the internet, and powered on. The installer has the "Claim Code" displayed on the email sent by the administrator.
When the administrator enters this Claim Code into the Prisma SD-WAN portal, what is the immediate status of the device before the configuration is fully pushed?
  • A. Active
  • B. Online
  • C. Provisioned
  • D. Claimed
In the Prisma SD-WAN (CloudGenix) Zero Touch Provisioning (ZTP) lifecycle, the device status transitions through specific stages that indicate its readiness and connectivity.
When an administrator enters the Claim Code (or Serial Number/Claim Code pair) into the portal, the device status immediately updates to "Claimed".
This status confirms that the portal has registered the device's unique identity and associated it with the customer's tenant. However, "Claimed" does not necessarily mean the device is fully operational or passing traffic yet. It simply signifies that the ownership is verified.
Once the physical device at the site successfully connects to the internet and reaches the Prisma SD-WAN Controller (using the call-home function), it will authenticate using its installed certificate. Upon successful authentication and the establishment of the secure control channel, the status will transition from "Claimed" to
"Online".
Only after the device is "Online" can the controller push the specific site configuration (Device Shell), policies, and IP addressing required for the device to become "Provisioned" and eventually "Active" in the data path. If the device remains in the "Claimed" state for an extended period, it indicates that the hardware has not yet successfully contacted the controller, which prompts troubleshooting of the physical internet circuit or firewall rules upstream.
NEW QUESTION # 79
In the Prisma SD-WAN portal, the Application Health dashboard assigns a color-coded "Health Score" (Green, Yellow, Red) to applications.
Which three metrics are combined to calculate this composite AppX (Application Experience) score? (Choose three.)
  • A. Bandwidth Utilization
  • B. Network Transfer Time (NTT)
  • C. Transaction Failure Rate
  • D. Server Response Time (SRT)
  • E. Jitter
Answer: B,C,D
The AppX (Application Experience) score is a proprietary metric used by Prisma SD-WAN to provide a holistic view of user experience, rather than just network statistics. It is calculated based on three key components:
* Transaction Failure Rate (A): The percentage of application transactions that failed (e.g., TCP resets, HTTP 500 errors). This indicates availability.
* Network Transfer Time (B): The time taken for packets to traverse the network (WAN/LAN latency).
This indicates network health.
* Server Response Time (C): The time taken by the application server to respond to a request. This indicates backend performance.
Why not D or E?
* Bandwidth Utilization (D) is a capacity metric, not a direct measure of quality. A link can be 90% full but still deliver packets quickly (good AppX), or 10% full but dropping packets (bad AppX).
* Jitter (E) is a network-layer metric primarily relevant for UDP Real-Time media. While important, the high-level "AppX" score for general TCP apps focuses on the "Time-to-Glass" metrics (NTT/SRT) and success rates.
NEW QUESTION # 80
We offer you SD-WAN-Engineer study guide with questions and answers, and you can practice it by concealing the answers, and when you have finished practicing, you can cancel the concealment, through the way like this, you can know the deficient knowledge for SD-WAN-Engineer exam dumps, so that you can put your attention to the disadvantages. In addition, we also have the free demo for SD-WAN-Engineer Study Guide for you to have a try in our website. These free demos will give you a reference of showing the mode of the complete version. If you want SD-WAN-Engineer exam dumps, just add them into your card.
Mock SD-WAN-Engineer Exam: https://www.testsimulate.com/SD-WAN-Engineer-study-materials.html
Posted at 2/1/2026 01:46:41        Only Author  2#
Truly an exceptional piece of writing, thank you for sharing. We are offering Latest braindumps HPE6-A87 ppt, full of valuable content, for free, hoping it proves helpful.
Posted at 2/7/2026 09:52:15        Only Author  3#
I’m stunned by how wonderful your article is, thank you for sharing it! Free CSSBB reliable exam pass4sure exam papers for you to download. Best of luck in your exams!
Posted at 2/17/2026 10:55:00        Only Author  4#
Thank you for the article, it was an absolute revelation. The New test camp ARA-C01 free content is great, and you can enjoy it at no expense.
Posted at 3/8/2026 08:13:46        Only Author  5#
Your article is exceptional, thank you for sharing it with us! I got a promotion and raise with the CPC-CDE-RECERT valid test vce. Now it’s available for everyone. Wishing you all success in your promotions!
