[General] 最優質的Cisco 300-445題庫資訊是行業領先材料&授權的300-445:Designing and Implementing Enterprise Ne
83
【General】 最優質的Cisco 300-445題庫資訊是行業領先材料&授權的300-445:Designing and Implementing Enterprise Ne
Posted at 1/30/2026 13:15:15      View:233 | Replies:3        Print      Only Author   [Copy Link] 1#
BONUS!!! 免費下載VCESoft 300-445考試題庫的完整版:https://drive.google.com/open?id=1FGjjoftLWQtAReGPlF5c8Yo9GbZVJX86
如果你發現我們300-445有任何品質問題或者沒有考過,我們將無條件全額退款,VCESoft是專業提供Cisco的300-445最新考題和答案的網站,幾乎全部覆蓋了300-445全部的知識點.。
不同的方式是可以達到相同的目的的,就看你選擇什麼樣的方式,走什麼樣的路。很多人都想通過Cisco 300-445 認證考試來使自己的工作和生活有所提升,但是參加過Cisco 300-445 認證考試的人都知道通過Cisco 300-445 認證考試不是很簡單。有的人為了能通過Cisco 300-445 認證考試花費了很多寶貴的時間和精力卻沒有成功。
300-445考試指南 & 300-445證照信息Cisco的300-445考試認證,VCESoft是當前最新Cisco的300-445考試認證和考題準備問題提供認證的候選人中的佼佼者,我們資源不斷被修訂和更新,具有緊密的相關性和緊密性,今天你準備Cisco的300-445認證,你將要選擇你要開始的訓練,而且要通過你下一次的考題,由於我們大部分考題是每月更新一次,你將得到最好的資源與市場的新鮮品質和可靠性的保證。
最新的 CCNP Enterprise 300-445 免費考試真題 (Q36-Q41):問題 #36
What type of alert rule configuration is used to monitor VPN connectivity issues affecting the end-user experience?
  • A. State-based rules
  • B. Throughput-based rules
  • C. Performance-based rules
  • D. Connectivity-based rules
答案:D
解題說明:
Connectivity-based rules are used to monitor VPN connectivity issues affecting the end-user experience by setting thresholds for VPN connection establishment times, packet loss rates, and latency to detect connectivity failures, disruptions, or degradation and trigger alerts for immediate investigation and resolution.
問題 #37
SNMP data indicates that a wireless access point is experiencing high channel utilization and increased retransmissions. What optimization would you recommend to improve voice call quality for users on this access point?
  • A. Change the access point to a different, less congested channel
  • B. Disable all non-voice traffic on the wireless network
  • C. Implement strict admission control for all wireless clients
  • D. Increase the transmit power of the access point
答案:A
解題說明:
In wireless network assurance, high channel utilization and increased retransmissions are clear indicators of RF interference or over-subscription. Retransmissions are particularly damaging to voice call quality because they introduce significant jitter and late-arrival packet loss that the jitter buffer cannot overcome.
The recommended optimization is tochange the access point to a different, less congested channel(Option B). This directly reduces the competition for airtime (Channel Utilization) and the likelihood of collisions from neighboring access points (Co-Channel Interference), which in turn lowers the retransmission rate.
Modern wireless controllers usingRadio Resource Management (RRM)often automate this, but a manual adjustment based on SNMP telemetry is a valid operational fix.
Other options are technically flawed:
* Option A:Increasing transmit power oftenincreasesinterference and channel utilization for surrounding cells, making the problem worse for everyone.
* Option Cisabling all non-voice traffic is an extreme measure that is rarely feasible in a real business environment.
* Option D:Admission control limits thenumberof users but doesn't solve the underlying issue of poor channel health for those already connected.
問題 #38
How does an endpoint agent contribute to network data collection?
  • A. Monitoring end-user devices
  • B. Configuring network protocols
  • C. Analyzing network traffic
  • D. Managing network infrastructure
答案:A
解題說明:
An endpoint agent contributes to network data collection by monitoring end-user devices and capturing relevant performance metrics for analysis.
問題 #39
An engineer is trying to configure a Page Load test and is trying to assign the east1-agent-1 to run it, but cannot see that agent listed. What is the reason that the designated agent does not appear?
  • A. The agent is disabled
  • B. The agent is not running
  • C. The agent is still registering
  • D. The agent does not support Page load tests
答案:D
解題說明:
In the framework ofDesigning and Implementing Enterprise Network Assurance (300-445 ENNA), selecting the appropriate agent for specific test types is a critical configuration step. The ThousandEyes platform utilizes different agent binaries and capabilities depending on the underlying hardware and software environment. Specifically,Page Load testsandTransaction testsrequire the agent to have a browser engine (Chromium) installed and functional to render web content and measure DOM-related metrics.
According to the ENNA implementation guidelines, not all Enterprise Agents support these browser-based tests. The exhibit displays a "New Test" configuration screen where the engineer is searching for "east1-agent-
1". While other agents like "west-2-ag-1" are visible, the designated agent is missing because itdoes not support Page load tests(Option D). This common occurrence happens when an Enterprise Agent is deployed on resource-constrained hardware-such as certainCisco Catalyst 9000 switchesorCisco ISR 4000 series routers-where the Chromium browser package is either not supported or has not been enabled due to memory and CPU limitations.
When an agent lacks the required capabilities for a specific test layer (e.g., Web layer tests), it is automatically filtered out from the selection list in the ThousandEyes portal to prevent invalid test configurations. To identify compatible agents, an engineer can look for the "Browser" or "Dual Chromium" labels in the agent settings. If the "east1-agent-1" were merely offline (Option A), disabled (Option B), or still registering (Option C), it would typically still appear in the list but with a status indicator showing its unavailability, rather than being entirely hidden from the test assignment menu. Therefore, the absence of the agent in a web- layer test configuration explicitly indicates a lack of functional support for the required browser-based metrics.
問題 #40
What is the primary objective of diagnosing end-device network issues using collected data?
  • A. Identifying network vulnerabilities
  • B. Ensuring device compliance
  • C. Resolving connectivity issues
  • D. Optimizing server performance
答案:C
解題說明:
The primary objective of diagnosing end-device network issues using collected data is to identify and resolve connectivity issues affecting device performance and user experience.
問題 #41
你在煩惱什麼呢?是因為Cisco的300-445認證考試而煩惱嗎?確實,300-445考試是一門很難通過的考試。但是你也不用過分擔心。只要你利用了適當的方法,輕鬆地通過考試也不是不可能的。那麼你知道什麼是適當的方法嗎?使用VCESoft的300-445資料就是一種最好不過的方法。VCESoft一直以來幫助了很多參加IT認定考試的考生,並且得到了大家的一致好評。這個資料可以保證你一次通過考試,請放心使用。
300-445考試指南: https://www.vcesoft.com/300-445-pdf.html
VCESoft 300-445考試指南提供的考試學習資料是根據最新的考試知識點和輔導材料整編而來,知識點覆蓋很全面,是您備考的最佳助手,選擇VCESoft你可以安心的準備你的Cisco 300-445考試,選擇VCESoft 300-445考試指南的產品卻可以讓你花少量的錢,一次性安全通過考試,Cisco 300-445 考古题的命中率很高,可以幫助大家一次通過 300-445 考試,想要順利通過300-445考試,最直接,最有效的方式就是練習和實際考試有相關性的2019最新的300-445題庫,VCESoft 300-445考試指南網站的考試資料可以幫助你達到自己的目標。
身體暫時好轉之後,陳元開始修煉起來的,秦雲帶著李如濟、薛沖進入府內,VCESoft提供的考試學習資料是根據最新的考試知識點和輔導材料整編而來,知識點覆蓋很全面,是您備考的最佳助手,選擇VCESoft你可以安心的準備你的Cisco 300-445考試
最實用的300-445認證考試的實用考古題匯總選擇VCESoft的產品卻可以讓你花少量的錢,一次性安全通過考試,Cisco 300-445 考古题的命中率很高,可以幫助大家一次通過 300-445 考試,想要順利通過300-445考試,最直接,最有效的方式就是練習和實際考試有相關性的2019最新的300-445題庫。
此外,這些VCESoft 300-445考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1FGjjoftLWQtAReGPlF5c8Yo9GbZVJX86
Posted at 2/3/2026 21:38:13        Only Author  2#
Thank you for sharing such a motivational and uplifting article! Improve your IT skills and access free Reliable SOA-C02 exam dumps questions. Wishing you the best of luck!
Posted at 2/10/2026 03:13:48        Only Author  3#
Your article is an absolute masterpiece, thank you for sharing! The Latest test EAEP2201 questions answers resource is full of valuable information and is free for everyone. We hope it’s useful to you.
Posted at yesterday 10:27        Only Author  4#
I was deeply moved by the article. The extensive content in Reliable Databricks-Machine-Learning-Professional exam cost is offered free of charge to support you.
