[Hardware] How Can You Pass the Nutanix NCP-DB-6.10 Exam Quickly and Easily?
81
Hardware How Can You Pass the Nutanix NCP-DB-6.10 Exam Quickly and Easily?
Posted at 1/30/2026 16:44:24      View152 | Replies1        Print      Only Author   [Copy Link] 1#
We know that tenet from the bottom of our heart, so all parts of service are made due to your interests. You are entitled to have full money back if you fail the exam even after getting our NCP-DB-6.10 test prep. Our staff will help you with genial attitude. We esteem your variant choices so all these versions of NCP-DB-6.10 Study Materials are made for your individual preference and inclination.
In order to help you enjoy the best learning experience, our PDF NCP-DB-6.10 study guide supports you download on your computers and print on papers. In this way, you can make the best use of your spare time. Whatever you are occupied with your work, as long as you really want to learn our NCP-DB-6.10 test engine, you must be inspired by your interests and motivation. Once you print all the contents of our NCP-DB-6.10 Practice Test on the paper, you will find what you need to study is not as difficult as you imagined before. Also, you can make notes on your papers to help you memorize and understand the difficult parts. Maybe you are just scared by yourself. Getting the NCP-DB-6.10 certificate is easy with the help of our test engine. You should seize the opportunities of passing the exam.
Valid Study NCP-DB-6.10 Questions & NCP-DB-6.10 Reliable Test DumpsYou will be able to apply for high-paying jobs in top companies worldwide after passing the Nutanix NCP-DB-6.10 test. The Nutanix NCP-DB-6.10 Exam provides many benefits such as higher pay, promotions, resume enhancement, and skill development.
Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Sample Questions (Q29-Q34):NEW QUESTION # 29
As administrator has been asked to add a database to a PostgreSQL instance already managed by NDB.
Which task should be performed?
  • A. Provision a new DB server VM and add the new DB.
  • B. Update a database clone to add a new DB.
  • C. Add a new database to a source DB.
  • D. Register a new DB VM to add the DB.
When an administrator is asked to add a database to a PostgreSQL instance already managed by NDB, the most appropriate task is to add a new database to the existing source database. In NDB, a PostgreSQL instance refers to a managed database server or cluster, and adding a new database involves creating it within the existing instance using NDB's database management capabilities. This can be done through the NDB GUI or CLI by selecting the source database and adding the new database, leveraging the current configuration and resources without requiring new VM provisioning.
NEW QUESTION # 30
What are the three severity levels displayed under the Alert dashboard?
  • A. Critical. Waiting, Failed
  • B. Failed, Warning, Stopped
  • C. Critical, Warning Info
  • D. Failed, Warning, Error
The Alerts dashboard in Nutanix displays alert messages with three severity levels: Critical, Warning, and Info. These severity levels help users understand the importance and urgency of each alert, allowing them to prioritize their responses accordingly.
NEW QUESTION # 31
How can HA drivers for a Database VM be upgraded?
  • A. One-click software upgrade
  • B. LCM driver upgrade
  • C. Database software patching
  • D. Database VM OS patching
HA drivers are software components that enable high availability features for database VMs, such as failover, fencing, and heartbeat. HA drivers can be upgraded using the Life Cycle Management (LCM) feature of Nutanix Prism. LCM can detect the available updates for HA drivers and apply them to the database VMs in a non-disruptive manner. LCM can also perform health checks and pre-upgrade validations to ensure the successful completion of the upgrade process. One-click software upgrade is a feature of Nutanix Era that allows you to upgrade the Era software itself, not the HA drivers. Database VM OS patching is a feature of Nutanix Era that allows you to patch the operating system of the database VMs, not the HA drivers. Database software patching is a feature of Nutanix Era that allows you to patch the database software of the database VMs, not the HA drivers.
NEW QUESTION # 32
An administrator needs to maintain five days of time-travel capability to any second, plus an additional seven days of discrete recovery at a daily interval. How should the administrator define the Frequency and retention on the SLA?
  • A. - Continuous log retention (days): 5
    - Weekly snapshot retention (weeks): 1
  • B. - Weekly snapshot retention (weeks): 1
    - Continuous log retention (days): 7
  • C. - Daily snapshot retention (days): 7
  • D. - Continuous log retention (days): 7
    - Daily snapshot retention (days): 5
The correct answer is D because it meets the requirements of maintaining five days of time-travel capability to any second and an additional seven days of discrete recovery at a daily interval.
Continuous log retention allows the administrator to restore the database to any point in time within the specified number of days, while snapshot retention allows the administrator to restore the database to a specific point in time at a fixed interval. Therefore, by setting the daily snapshot retention to 7 days, the administrator can ensure that there is a discrete recovery point for each day of the week. By setting the continuous log retention to 5 days, the administrator can ensure that there is a time-travel capability to any second within the last five days. The other options do not meet the requirements because they either have less than five days of continuous log retention or less than seven days of snapshot retention.
NEW QUESTION # 33
An administrator needs to create and refresh clones to a point in time. NDB allows which two methods for satisfying this requirement? (Choose two.)
  • A. Full backups
  • B. Transaction logs
  • C. Snapshots
  • D. VM snapshots
NDB allows creating and refreshing clones to a point in time using two primary methods:
Snapshots: NDB uses storage snapshots (e.g., via Nutanix Volumes or AHV) to capture the database state at a specific point. These snapshots can be used to create or refresh clones, providing a consistent recovery point.
Transaction logs: Transaction logs (e.g., PostgreSQL WAL, SQL Server logs) enable point-in- time recovery (PITR) by applying logs to a snapshot, allowing clones to be refreshed to a precise moment.
NEW QUESTION # 34
It's known that there are numerious materials for the NCP-DB-6.10 Exam, choose a good materials can help you pass the exam quickly. Our product for the NCP-DB-6.10 exam also have materials, besides we have three versions of the practice materials. The PDF version can be printed into the paper version, and you can take some notes on it, and you can study it at anywhere and anytime, the PDF version also provide the free demo and you can practice it before buying. The online version uses the onlin tool, it support all web browers, and it's convenient and easy to learn it also provide the text history and performance review, this version is online and you can practice it in your free time. The desktop version stimulate the real exam environment, it will make the exam more easier.
Valid Study NCP-DB-6.10 Questions: https://www.validtorrent.com/NCP-DB-6.10-valid-exam-torrent.html
Searching for high-quality and comprehensive NCP-DB-6.10 exam valid torrents for your NCP-DB-6.10 exam certification, Nutanix NCP-DB-6.10 New Dumps Ebook We pay more attention on customer's demand, Now we ValidTorrent provide you the best NCP-DB-6.10 exam pdf practice material, Just to try on our NCP-DB-6.10 training guide, and you will love it, You should take account of our PDF version of our NCP-DB-6.10 learning materials which can be easily printed and convenient to bring with wherever you go.On one hand, the content of our NCP-DB-6.10 exam dumps in PDF version is also the latest just as the other version.
Understanding QuickTime and QuickTime Pro, In cases where I had forgotten NCP-DB-6.10 the reason for a turn in the work, I was able to find a previous version of my test specification and see why I had changed it.
100% Pass Quiz 2026 Nutanix Accurate NCP-DB-6.10: Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 New Dumps EbookSearching for high-quality and comprehensive NCP-DB-6.10 Exam valid torrents for your NCP-DB-6.10 exam certification, We pay more attention on customer's demand, Now we ValidTorrent provide you the best NCP-DB-6.10 exam pdf practice material.
Posted at 2/15/2026 07:29:03        Only Author  2#
Your article has truly left me speechless, thank you for sharing! I used the PA-Life-Accident-and-Health reliable test guide files to get promoted and raise my salary. Its free for everyone now. Wishing you quick career growth!
