[General] DVA-C02 Braindumps Torrent | Free DVA-C02 Pdf Guide
107
General DVA-C02 Braindumps Torrent | Free DVA-C02 Pdf Guide
Posted at 1/30/2026 16:49:46      View162 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Amazon DVA-C02 dumps are available on Google Drive shared by PassTestking: https://drive.google.com/open?id=1bcV81U-epzDGOFVHBp3PjdevWwG70Rhu
Passing a exam for most candidates may be not very easy, our DVA-C02 Exam Materials are trying to make the make the difficult things become easier. With the experienced experts to revise the DVA-C02 exam dump, and the professionals to check timely, the versions update is quietly fast. Thinking that if you got the certificate, you can get a higher salary, and youre your position in the company will also in a higher level.
The AWS Certified Developer - Associate certification exam covers a wide range of topics, including AWS core services, security, databases, and deployment and management. Candidates are required to have a strong understanding of programming languages such as Python, Java, and Ruby, as well as experience with AWS services such as EC2, S3, and Lambda.
The AWS Certified Developer - Associate certification is a great way for developers to advance their careers and stay up-to-date with the latest cloud computing technologies. It is highly valued by employers and can lead to better job opportunities and higher salaries. Preparing for the exam requires a strong understanding of AWS services and their use cases, as well as hands-on experience with building and deploying applications on the AWS platform.
The DVA-C02 Exam measures the candidate's knowledge in various aspects of AWS development, including AWS core services, AWS security, serverless applications, and deploying and managing AWS services. DVA-C02 exam consists of 65 multiple-choice and multiple-response questions, and the candidate has 130 minutes to complete the exam.
DVA-C02 Test Questions & DVA-C02 Test Dumps & DVA-C02 Study GuidePassTestking provides 24/7 customer support to answer any of your queries or concerns regarding the AWS Certified Developer - Associate (DVA-C02) certification exam. They have a team of highly skilled and experienced professionals who have a thorough knowledge of the AWS Certified Developer - Associate (DVA-C02) exam questions and format. With the aim of helping aspirants to achieve the AWS Certified Developer - Associate (DVA-C02) certification, PassTestking is committed to providing the best quality and updated Amazon DVA-C02 exam dumps.
Amazon AWS Certified Developer - Associate Sample Questions (Q412-Q417):NEW QUESTION # 412
A developer is automating a new application deployment with AWS Serverless Application Model (AWS SAM). The new application has one AWS Lambda function and one Amazon S3 bucket.
The Lambda function must access the S3 bucket to only read objects.
How should the developer configure AWS SAM to grant the necessary read privilege to the S3 bucket?
  • A. Reference a second Lambda authorizer function.
  • B. Add the S3ReadPolicy template to the Lambda function's execution role.
  • C. Add a custom S3 bucket policy to the Lambda function.
  • D. Create an Amazon Simple Queue Service (SQS) topic for only S3 object reads. Reference the topic in the template.
NEW QUESTION # 413
A developer needs to migrate an online retail application to AWS to handle an anticipated increase in traffic. The application currently runs on two servers: one server for the web application and another server for the database. The web server renders webpages and manages session state in memory. The database server hosts a MySQL database that contains order details. When traffic to the application is heavy, the memory usage for the web server approaches 100% and the application slows down considerably.
The developer has found that most of the memory increase and performance decrease is related to the load of managing additional user sessions. For the web server migration, the developer will use Amazon EC2 instances with an Auto Scaling group behind an Application Load Balancer.
Which additional set of changes should the developer make to the application to improve the application's performance?
  • A. Use Amazon ElastiCache for Memcached to store and manage the session data. Use an Amazon RDS for MySQL DB instance to store the application data.
  • B. Use Amazon ElastiCache for Memcached to store and manage the session data and the application data.
  • C. Use the EC2 instance store to manage the session data. Use an Amazon RDS for MySQL DB instance to store the application data.
  • D. Use an EC2 instance to host the MySQL database. Store the session data and the application data in the MySQL database.
Session stores are easy to create with Amazon ElastiCache for Memcached.
https://aws.amazon.com/elasticache/memcached/
With Amazon RDS, you can deploy scalable MySQL servers in minutes with cost-efficient and resizable hardware capacity.
https://aws.amazon.com/rds/mysql/
NEW QUESTION # 414
A developer is using AWS Amplify Hosting to build and deploy an application. The developer is receiving an increased number of bug reports from users. The developer wants to add end-to-end testing to the application to eliminate as many bugs as possible before the bugs reach production.
Which solution should the developer implement to meet these requirements?
  • A. Run the amplify add test command in the Amplify CLI.
  • B. Create unit tests in the application. Deploy the unit tests by using the amplify push command in the Amplify CLI.
  • C. Add a test phase to the aws-exports.js file for the application.
  • D. Add a test phase to the amplify.yml build settings for the application.
The solution that will meet the requirements is to add a test phase to the amplify.yml build settings for the application. This way, the developer can run end-to-end tests on every code commit and catch any bugs before deploying to production. The other options either do not support end-to-end testing, or do not run tests automatically.
NEW QUESTION # 415
A company has installed smart motes in all Its customer locations. The smart meter's measure power usage at
1minute intervals and send the usage readings to a remote endpoint tot collection. The company needs to create an endpoint that will receive the smart meter readings and store the readings in a database. The company wants to store the location ID and timestamp information.
The company wants to give Is customers low-latency access to their current usage and historical usage on demand The company expects demand to increase significantly. The solution must not impact performance or include downtime write seeing.
When solution will meet these requirements MOST cost-effectively?
  • A. Store the smart meter readings in Amazon EastCache for Reds Create a Sorted set key y using the location ID and timestamp columns. Use the columns to filter on the customers' data.
  • B. Store the smart meter readings in an Amazon RDS database. Create an index on the location ID and timestamp columns Use the columns to filter on the customers 'data.
  • C. Store the smart motor readings m an Amazon DynamoDB table Croato a composite Key oy using the location ID and timestamp columns. Use the columns to filter on the customers' data.
  • D. Store the smart meter readings m Amazon S3 Parton the data by using the location ID and timestamp columns. Use Amazon Athena lo tiler on me customers' data.
The solution that will meet the requirements most cost-effectively is to store the smart meter readings in an Amazon DynamoDB table. Create a composite key by using the location ID and timestamp columns. Use the columns to filter on the customers' data. This way, the company can leverage the scalability, performance, and low latency of DynamoDB to store and retrieve the smart meter readings. The company can also use the composite key to query the data by location ID and timestamp efficiently. The other options either involve more expensive or less scalable services, or do not provide low-latency access to the current usage.
NEW QUESTION # 416
A developer has observed an increase in bugs in the AWS Lambda functions that a development team has deployed in its Node.js application.
To minimize these bugs, the developer wants to implement automated testing of Lambda functions in an environment that closely simulates the Lambda environment.
The developer needs to give other developers the ability to run the tests locally. The developer also needs to integrate the tests into the team's continuous integration and continuous delivery (CI/CD) pipeline before the AWS Cloud Development Kit (AWS CDK) deployment.
Which solution will meet these requirements?
  • A. Install the AWS Serverless Application Model (AWS SAM) CLI tool. Use the sam local generate-event command to generate sample events for the automated tests. Create automated test scripts that use the sam local invoke command to invoke the Lambda functions. Check the response. Document the test scripts for the other developers on the team. Update the CI/CD pipeline to run the test scripts.
  • B. Create sample events based on the Lambda documentation. Create a Docker container from the Node.js base image to invoke the Lambda functions. Check the response. Document how to run the Docker container for the other developers on the team. Update the CllCD pipeline to run the Docker container.
  • C. Install a unit testing framework that reproduces the Lambda execution environment. Create sample events based on the Lambda documentation. Invoke the handler function by using a unit testing framework. Check the response. Document how to run the unit testing framework for the other developers on the team. Update the CI/CD pipeline to run the unit testing framework.
  • D. Create sample events based on the Lambda documentation. Create automated test scripts that use the cdk local invoke command to invoke the Lambda functions. Check the response. Document the test scripts for the other developers on the team. Update the CI/CD pipeline to run the test scripts.
The AWS Serverless Application Model Command Line Interface (AWS SAM CLI) is a command-line tool for local development and testing of Serverless applications3. The sam local generate-event command of AWS SAM CLI generates sample events for automated tests3. The sam local invoke command is used to invoke Lambda functions3. Therefore, option C is correct.
NEW QUESTION # 417
When you select to use PassTestking's products, you have set the first foot on the peak of the IT industry and the way to your dream is one step closer. The practice questions of PassTestking can not only help you pass Amazon Certification DVA-C02 Exam and consolidate your professional knowledge, but also provide you one year free update service.
Free DVA-C02 Pdf Guide: https://www.passtestking.com/Amazon/DVA-C02-practice-exam-dumps.html
P.S. Free & New DVA-C02 dumps are available on Google Drive shared by PassTestking: https://drive.google.com/open?id=1bcV81U-epzDGOFVHBp3PjdevWwG70Rhu
Posted at 5/16/2026 22:28:59        Only Author  2#
What a phenomenal read, I truly appreciate you sharing it! NCP-CI-Azure new test guide files offers great value, and the content is completely free.
