PDII Free Test Questions - Certification PDII Book Torrent
Posted at 1/30/2026 17:00:55
View133
Replies1
DOWNLOAD the newest ITPassLeader PDII PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=105sTyxZPJ3g_xelgbifRq9ikEOBlj8AX
PDII certification exam is a very import component Salesforce certification exam. But passing Salesforce certification PDII exam is not so simple. In order to give to relieve pressure and save time and effort for candidates who take a preparation for the PDII Certification Exam, ITPassLeader specially produce a variety of training tools. So you can choose an appropriate quick training from ITPassLeader to pass the exam.
Nowadays, a certificate is not only an affirmation of your ablity but also help you enter a better company. PDII learning materials will offer you an opportunity to get the certificate successfully. We have a professional team to search for the information about the exam, therefore PDII Exam Dumps of us are high-quality. We also pass guarantee and money back guarantee. Just think that, you just need to spend some money, and you can get a certificate, therefore you can have more competitive force in the job market as well as improve your salary.
Salesforce - The Best PDII Free Test QuestionsOur PDII prep torrent boosts the highest standards of technical accuracy and only use certificated subject matter and experts. We provide the latest and accurate PDII exam torrent to the client and the questions and the answers we provide are based on the real exam. We can promise to you the passing rate is high and about 98%-100%. Our PDII Test Braindumps also boosts high hit rate and can stimulate the exam to let you have a good preparation for the PDII exam. Your success is bound with our PDII exam questions.
Salesforce Certified Platform Developer II (PDII) exam is a challenging certification that measures your ability to design and develop custom solutions using Apex and Visualforce. Platform Developer II certification is intended for experienced developers who have a deep understanding of Salesforce's architecture and API capabilities. Passing the PDII Exam demonstrates your proficiency in developing complex business solutions on the Salesforce platform and can help you advance your career as a Salesforce developer.
Salesforce Platform Developer II Sample Questions (Q157-Q162):NEW QUESTION # 157
A Visualforce page loads slowly due to the large amount of data it displays. Which strategy can a developer use to improve the performance?
- A. Use lazy loading to load the data on demand, instead of in the controller's constructor.
- B. Use the transient keyword for the List variables used in the custom controller.
- C. Use JavaScript to move data processing to the browser instead of the controller.
- D. Use an <apex:actionPoller> in the page to load all of the data asynchronously.
When a Visualforce page is slow because it attempts to load a massive dataset all at once, the bottleneck is often the time taken by the controller constructor to query and process those records before the page can even begin to render. Lazy Loading (Option B) is a strategy where the developer avoids loading all data during the initial page initialization.
Instead of querying 10,000 records in the constructor, the developer can load only the structural elements of the page first. Then, using an action method (triggered by <apex:actionFunction> or a window.onload script), the data is fetched in the background. This allows the user to see the page layout immediately while the data
"populates" shortly after. This significantly improves the Time to First Byte (TTFB) and the perceived performance of the page.
Option A (transient) is excellent for reducing the View State size and speeding up postbacks (button clicks), but it does not inherently speed up the initial load time of a large dataset. Option C (JavaScript processing) can help but doesn't solve the data retrieval bottleneck. Option D (actionPoller) is used for periodic updates and is not an efficient way to load an initial large dataset. Lazy loading ensures that the "heavy lifting" is decoupled from the initial page load, providing a more responsive experience.
NEW QUESTION # 158
The Account edit button must be overridden in an org where a subset of users still use Salesforce Classic. The org already has a Lightning Component that will do the work necessary for the override, and the client wants to be able to reuse it.
How should a developer implement this?
- A. Override the edit button for Lightning with a Lightning Component, and Classic with a Visualforce page that contains the Lightning Component
- B. Override the edit button for both Lightning and Classic with a Lightning Component
- C. Override the edit button for Lightning with a Lightning Page, and Classic with a Visualforce page that contains the Lightning Component
- D. Override the edit button for both Lightning and Classic with a new Visualforce page
NEW QUESTION # 159
Given the following containment hierarchy:
What is the correct way to communicate the new value of a property named ''passthrough'' to my-parent-component if the property is defined within my-child-component?
To communicate a property change up a containment hierarchy in Lightning Web Components (LWC), the child component should dispatch a custom event with the detail of the change. The parent component listens for this event and handles it accordingly.
Option A is the correct method because it creates a new custom event with the detail property containing the new value of passthrough. This event is then dispatched, and the parent component can listen for this event to handle the updated value.
Options B, C, and D are incorrect because they either don't pass any data with the event or they don't use the detail object which is the standard way to pass data with custom events in LWC.
Lightning Web Components Developer Guide - Communicating with Events
NEW QUESTION # 160
Which two best practices should the developer implement to optimize this code? Choose 2 answers
- A. Query the Driving-Structure_C records outside of the loop
- B. Use a collection for the DML statement.
- C. Change the trigger context to after update, after insert
- D. Remove the DML statement.
To optimize the code in question, it's important to follow best practices that reduce the number of SOQL queries and DML statements within loops, as these can quickly consume governor limits and lead to inefficiencies. Option C is correct because using a collection to hold records and performing a single DML operation outside of loops reduces the number of DML operations, which is a best practice for bulkifying code in Salesforce. Option D is also correct because querying records outside of a loop prevents hitting SOQL governor limits and makes the code more efficient. Options A and B are not correct in the context provided, as there isn't enough information to determine if changing the trigger context is necessary, and removing the DML statement altogether may not be feasible if the logic requires data to be persisted.
References
Apex Best Practices: Apex Developer Guide Best Practices
NEW QUESTION # 161
A developer is writing a Visualforce page that queries accounts in the system and presents a data table with the results. The users want to be able to filter the results based on up to five fields. However, the users want to pick the five fields to use as filter fields when they run the page. Which Apex code feature is required to facilitate this solution?
- A. Dynamic SOQL
- B. Metadata API
- C. Variable binding
- D. Streaming API
The requirement is to allow users to select which fields they want to filter by at runtime. In standard (static) SOQL, the fields in the WHERE clause must be defined at compile time (e.g., WHERE Name = :val).
Because the fields themselves are not known until the user interacts with the page, the developer cannot write a static query.
Dynamic SOQL is the required feature. It allows the developer to construct the SOQL query string as a text string at runtime, incorporating the specific field names selected by the user, and then execute that string using Database.query(queryString). This provides the flexibility to build queries on the fly based on user input. Metadata API is for configuration changes, Streaming API is for push notifications, and Variable binding (:var) is used in both static and dynamic SOQL but does not solve the issue of changing the field names themselves.
NEW QUESTION # 162
Regular practice can give you the skills and confidence needed to perform well on your PDII exam. By practicing your Platform Developer II (PDII) exam regularly, you can increase your chances of success and make sure that all of your hard work pays off when it comes time to take the test. We understand that every Platform Developer II (PDII) exam taker has different preferences. To make sure that our Platform Developer II (PDII) preparation material is accessible to everyone, we made it available in three different formats. You can choose the most suitable and convenient one for you.
Certification PDII Book Torrent: https://www.itpassleader.com/Salesforce/PDII-dumps-pass-exam.html
- PDII Exam Blueprint I Exam PDII Assessment 💠 Valid PDII Test Discount 🏍 Download PDII for free by simply entering [url]www.testkingpass.com website 🙁
DII Reliable Exam Pass4sure[/url] - 2026 PDII Free Test Questions | Accurate 100% Free Certification PDII Book Torrent 🔒 Search on [url]www.pdfvce.com for { PDII } to obtain exam materials for free download 🐈Trustworthy PDII Exam Torrent[/url]
- Pass Guaranteed 2026 PDII: Platform Developer II CHigh Pass-Rate Free Test Questions ⚔ Easily obtain ⮆ PDII ⮄ for free download through ⏩ [url]www.troytecdumps.com ⏪ 🍽
DII Valid Dumps Ppt[/url] - 2026 Salesforce PDII CThe Best Free Test Questions 📎 Immediately open ⇛ [url]www.pdfvce.com ⇚ and search for PDII to obtain a free download ⛰
DII Valid Dumps Ppt[/url] - 2026 Salesforce PDII CThe Best Free Test Questions ⚾ Search for ▷ PDII ◁ and download it for free immediately on ▶ [url]www.practicevce.com ◀ 🟡
DII Valid Test Online[/url] - Authentic Salesforce PDII PDF Dumps - Get Outstanding Results In Exam 👎 Easily obtain ⇛ PDII ⇚ for free download through [ [url]www.pdfvce.com ] 📋Valid Real PDII Exam[/url]
- PDII Free Pdf Guide 🍳 Test PDII Answers 👶 Exam PDII Assessment 🔬 Easily obtain ⇛ PDII ⇚ for free download through { [url]www.prepawayexam.com } 🎠
DII Free Pdf Guide[/url] - PDII Reliable Exam Pass4sure 💿 PDII Reliable Exam Pass4sure 🐉 PDII Exams Torrent ⭕ Easily obtain ➡ PDII ️⬅️ for free download through ☀ [url]www.pdfvce.com ️☀️ 🎉
DII Mock Exams[/url] - Web-based Salesforce PDII Practice Exam Software - Solution for Online Self-Assessment 💿 ➤ [url]www.validtorrent.com ⮘ is best website to obtain [ PDII ] for free download 📖Trustworthy PDII Exam Torrent[/url]
- 2026 PDII Free Test Questions | Accurate 100% Free Certification PDII Book Torrent 🤠 Open website ▷ [url]www.pdfvce.com ◁ and search for ➤ PDII ⮘ for free download 🕣
DII Valid Test Online[/url] - PDII Pass Guide 💮 PDII Exam Questions 🩳 PDII Valid Dumps Ppt 🐊 Download ➥ PDII 🡄 for free by simply searching on [url]www.prepawayete.com 🌻
DII Free Pdf Guide[/url] - bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dl.instructure.com, www.flirtic.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest ITPassLeader PDII PDF Dumps and PDII Exam Engine Free Share: https://drive.google.com/open?id=105sTyxZPJ3g_xelgbifRq9ikEOBlj8AX
