[General] Boost Your Confidence with Desktop Practice Test for Microsoft AZ-500 Exam
95
【General】 Boost Your Confidence with Desktop Practice Test for Microsoft AZ-500 Exam
Posted at 1/30/2026 20:51:02      View:124 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Getcertkey AZ-500 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1bPOUOruoD2a2uIrz8PhHtef7yaAThSgu
To be the best global supplier of electronic AZ-500 study materials for our customers through innovation and enhancement of our customers' satisfaction has always been our common pursuit. The advantages of our AZ-500 guide dumps are too many to count. And the most important point is that the pass rate of our AZ-500 learning quiz is preety high as 98% to 99%. I guess this is also the candidates care most as well. You can totally trust in our AZ-500 exam questions!
There are various topics included in Microsoft AZ-500 that you should master during your preparation time. They are as follows:
  • Manage Identity and Access;
  • Secure Data and Applications;
  • Implement Platform Protection.
  • Manage Security Operations;
All of these domains are separated into different sections and each has its own percentage rate of occurring during your test. Therefore, we recommend that you check the official certification page to know the additional details that will help you during your preparation.
What Is Your Career Path after AZ-500?After receiving the aforementioned associate-level certificate, you can also decide to enhance your skills further and bag another certification. There are certifications at the expert-level which are best for anyone seeking to have more say in their career. They include:
  • The Microsoft Certified: DevOps Engineer Expert;
  • The Microsoft Certified: Azure Solutions Architect Expert.
The first certificate for developers requires passing one test while the latter for solutions architect demands acing two tests. Earning any of them makes you an expert who can command a more advanced role and even a better salary.
2026 Unparalleled Valid Exam AZ-500 Preparation & Microsoft Azure Security Technologies Latest Exam ExperienceIn this age of anxiety, everyone seems to have great pressure. If you are better, you will have a more relaxed life. AZ-500 guide materials allow you to increase the efficiency of your work. You can spend more time doing other things. Our study materials allow you to pass the AZ-500 exam in the shortest possible time. You will stand at a higher starting point than others. Why are AZ-500 Practice Questions worth your choice? I hope you can spend a little time free downloading our demo of our AZ-500 exam questions, then you will know the advantages of our AZ-500 study materials!
Microsoft Azure Security Technologies Sample Questions (Q289-Q294):NEW QUESTION # 289
You are troubleshooting a security issue for an Azure Storage account.
You enable the diagnostic logs for the storage account.
What should you use to retrieve the diagnostics logs?
  • A. SQL query editor in Azure
  • B. Azure Storage Explorer
  • C. File Explorer in Windows
  • D. Azure Security Center
If you want to download the metrics for long-term storage or to analyze them locally, you must use a tool or write some code to read the tables. You must download the minute metrics for analysis. The tables do not appear if you list all the tables in your storage account, but you can access them directly by name. Many storage-browsing tools are aware of these tables and enable you to view them directly (see Azure Storage Client Tools for a list of available tools).
Microsoft provides several graphical user interface (GUI) tools for working with the data in your Azure Storage account. All of the tools outlined in the following table are free.
https://docs.microsoft.com/en-us ... %2fazure%2fstorage%
2fblobs%2ftoc.json
https://docs.microsoft.com/en-us ... n/storage-explorers
NEW QUESTION # 290
You create resources in an Azure subscription as shown in the following table.
VNET1 contains two subnets named Subnet1 and Subnet2. Subnet1 has a network ID of 10.0.0.0/24. Subnet2 has a network ID of 10.1.1.0/24.
Contoso1901 is configured as shown in the exhibit. (Click the Exhibit tab.)
NEW QUESTION # 291
You suspect that users are attempting to sign in to resources to which they have no access.
You need to create an Azure Log Analytics query to identify failed user sign-in attempts from the last three days. The results must only show users who had more than five failed sign-in attempts.
How should you configure the query? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... /log-query/examples
NEW QUESTION # 292
You need to create Role1 to meet the platform protection requirements.
How should you complete the role definition of Role1? To answer, select the appropriate options in the answer area.
A new custom RBAC role named Role1 must be used to delegate the administration of the managed disks in Resource Group1. Role1 must be available only for Resource Group1.
NEW QUESTION # 293
You have an Azure subscription that contains the following resources:
A network virtual appliance (NVA) that runs non-Microsoft firewall software and routes all outbound traffic from the virtual machines to the internet An Azure function that contains a script to manage the firewall rules of the NVA Azure Security Center standard tier enabled for all virtual machines An Azure Sentinel workspace
30 virtual machines
You need to ensure that when a high-priority alert is generated in Security Center for a virtual machine, an incident is created in Azure Sentinel and then a script is initiated to configure a firewall rule for the NVA.
How should you configure Azure Sentinel to meet the requirements? To answer, drag the appropriate components to the correct requirements. Each component may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
https://docs.microsoft.com/en-us ... cidents-from-alerts
https://docs.microsoft.com/en-us ... ure-security-center
NEW QUESTION # 294
Are you on the way to pass the AZ-500 exam? Our AZ-500 exam questions will be the best choice for you. And if you still feel uncertain about the content, wondering whether it is the exact AZ-500 exam material that you want, you can free download the demo to check it out. You will be quite surprised by the convenience to have an overview just by clicking into the link, and you can experience all kinds of AZ-500 versions.
AZ-500 Latest Exam Experience: https://www.getcertkey.com/AZ-500_braindumps.html
What's more, part of that Getcertkey AZ-500 dumps now are free: https://drive.google.com/open?id=1bPOUOruoD2a2uIrz8PhHtef7yaAThSgu
